//將收到的數(shù)據(jù)返回,經(jīng)測試可以,利用查詢方式
#include"stm32f10x_it.h"
#include "stm32f10x_conf.h"
void delayms(unsigned intcount);//延時(shí)程序
void RCC_Configuration(void); //時(shí)鐘配置
void USART_Configuration(void);//定義串口初始化函數(shù)
void NVIC_Configuration( void);
void Uart1_PutChar(u8 ch);
void Uart1_PutString(u8* buf , u8len);
voidGPIO1_Configuration(void);
voidGPIO_Configuration(void);
ErrorStatusHSEStartUpStatus;
//使能外部晶振
RCC_HSEConfig(RCC_HSE_ON);
//等待外部晶振穩(wěn)定
HSEStartUpStatus =RCC_WaitForHSEStartUp();
//如果外部晶振啟動成功,則進(jìn)行下一步操作
if(HSEStartUpStatus==SUCCESS)
//設(shè)置HCLK(AHB時(shí)鐘)=SYSCLK
RCC_HCLKConfig(RCC_SYSCLK_Div1);
//PCLK1(APB1) = HCLK/2
RCC_PCLK1Config(RCC_HCLK_Div2);
//PCLK2(APB2) = HCLK
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_4);
//啟動PLL
RCC_PLLCmd(ENABLE);
//等待PLL穩(wěn)定
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) ==RESET);
//系統(tǒng)時(shí)鐘SYSCLK來自PLL輸出
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
//切換時(shí)鐘后等待系統(tǒng)時(shí)鐘穩(wěn)定
while(RCC_GetSYSCLKSource()!=0x08);
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
//RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2 ,ENABLE);
int main(void)
int i;
unsigned char str[]="A";
u8 uart2_get_data;
RCC_Configuration();
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA |
RCC_APB2Periph_AFIO, ENABLE);//使能各部分時(shí)鐘
//NVIC_Configuration(); //串口中斷配置
//RCC中打開相應(yīng)串口
GPIO_Configuration();
//串口1的管腳初始化
GPIO1_Configuration();
USART_Configuration();
while (1)
GPIO_SetBits(GPIOA,GPIO_Pin_8) ;
GPIO_SetBits(GPIOA,GPIO_Pin_11) ;
GPIO_SetBits(GPIOA,GPIO_Pin_15) ;
if(USART_GetFlagStatus(USART2, USART_FLAG_RXNE)==SET)
uart2_get_data = USART_ReceiveData(USART2);
for(i=0;i<1000000;i++);
USART_SendData(USART2,uart2_get_data);
while(USART_GetFlagStatus(USART2, USART_FLAG_TC) ==RESET);
GPIO_ResetBits(GPIOA,GPIO_Pin_11);
GPIO_ResetBits(GPIOA,GPIO_Pin_15);
void GPIO_Configuration(void)
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_11|GPIO_Pin_15;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
GPIO_Init(GPIOA,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //管腳2
GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP; //復(fù)用推挽輸出
GPIO_Init(GPIOA, &GPIO_InitStructure); //TX初始化
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; //管腳3
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IN_FLOATING; //浮空輸入
GPIO_Init(GPIOA, &GPIO_InitStructure); //RX初始化
void delayms(unsigned int count)
unsigned int i,j;
for(i=0;i
for(j=0;j<5000;j++);
void USART_Configuration(void)//串口初始化函數(shù)
USART_ClockInitTypeDefUSART_ClockInitStructure;
//串口參數(shù)初始化
USART_InitTypeDef USART_InitStructure;//串口設(shè)置恢復(fù)默認(rèn)參數(shù)
//初始化參數(shù)設(shè)置
USART_InitStructure.USART_BaudRate = 9600;//波特率9600
USART_InitStructure.USART_WordLength =USART_WordLength_8b; //字長8位
USART_InitStructure.USART_StopBits =USART_StopBits_1; //1位停止字節(jié)
USART_InitStructure.USART_Parity =USART_Parity_No; //無奇偶校驗(yàn)
USART_InitStructure.USART_HardwareFlowControl =USART_HardwareFlowControl_None;//無流控制
USART_InitStructure.USART_Mode =USART_Mode_Rx | USART_Mode_Tx;//打開Rx接收和Tx發(fā)送功能
USART_Init(USART2,&USART_InitStructure); //初始化
//USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//使能接受中斷,在接受移位 寄存器中有數(shù)據(jù)是產(chǎn)生
USART_ClockInitStructure.USART_Clock =USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL =USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA =USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit =USART_LastBit_Disable;
USART_ClockInit(USART2,&USART_ClockInitStructure);
USART_Cmd(USART2, ENABLE); //啟動串口
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);//選擇分組方式0
NVIC_InitStructure.NVIC_IRQChannel =USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd =ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_SendData(USART2,(u8) ch);
while(USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET);
void Uart1_PutString(u8* buf , u8 len)
u8 i;
for( i=0;i
Uart1_PutChar(*buf++);
