查看: 4885|回復: 0
SPI通信之DS1302和DS18B20電路圖程序
ID:100029 發表于 2015-12-22 21:37 | 顯示全部樓層 |閱讀模式
#include"reg52.h"
#include"intrins.h"
sbit DIO=P3^0;
sbit B7=B^7;
sbit A0=ACC^0;
uchar tL,tH;
void delay(uchar us)
  while(us--);
bit init18b20()
bit w;
DIO=0;        //pull low
delay(145);   //pull low 880us
DIO=1;        //pull High
delay(15);    //pull High 90us
w=DIO;        //after read state
delay(90);    //Not less than 480 us
return w;     //w=0,success,w=1,fail
uchar r18b20(void)
   uchar i;
B=0;
for(i=0;i<8;i++)
B=B>>1;
DIO=0;
_nop_();  //pull low 2us
_nop_();  //12M nop 2 times,6M 1 time.
DIO=1;    //pull high  read
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
B7=DIO;    //after 15us ,read bit to B
delay(10); // 60us
return B;
void w18b20(uchar dat)
   uchar i;
   for(i=0;i<8;i++)
             DIO=0;
             _nop_();
             _nop_();
            DIO=dat & 0x01;
            delay(5);
            DIO=1;
             _nop_();
             dat=dat>>1;
bit converT(void)
    if(init18b20()==0)  //0 sucess
       w18b20(0xcc);
w18b20(0x44);
return 1;
else               //1 fail
return 0;
void readdata(void)
  uchar Lsb,Msb;
if(init18b20()==0)   //sucess
    w18b20(0xcc);
w18b20(0xbe);
Lsb=r18b20();
Msb=r18b20();
tL=Lsb;
tH=Msb;
                 tL=0;
tH=0;
uchar temp;
                      if(convert()==1)
                              readdata();
temp=(temp1<<4) | (temp0>>4);
if(temp1 & 0x08 )  //-
                                      P3=0x01;
P2=0x3F & (~temp)+1;
else                      //+
                                       P3=0xff;
                       P2=temp;
下面程序為分屏顯示
#include"reg52.h"
#include"intrins.h"
sbit rs=P2^0;
sbit rw=P2^1;
sbit en=P2^2;
sbit rst =P2^3;
sbit sclk=P2^4;
sbit DI  =P2^5;
sbit ds18b20=P2^6;
sbit A7=ACC^7;
sbit A0=ACC^0;
sbit B0=B^0;
uchar tt0[]="Time:";
uchar tt1[]="Data:";
uchar tt2[]="week:";
uchar tt3[]="temp:";
static char ch[7][3]={"Sun","Mon","Tue","Wed","Thu","Tri","Sat"};
unsigned char TT,temp1;
unsigned char temp2;
  while(us--);
bit Reset(void)
   bit k;
   ds18b20=0;
   delay(145);
   ds18b20=1;
   delay(10);
   k=ds18b20;
   delay(90);
   return k;
unsigned char ReadByte(void)
   unsigned char j,buf=0;
   for(j=0;j<8;j++)
        buf=buf>>1;
        ds18b20=0;
        _nop_();
        _nop_();
        ds18b20=1;
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        if(ds18b20==1)
            buf|=0x80;
           delay(8);
   return buf;
void WriteByte(unsigned char dat)
    unsigned char j;
    for(j=0;j<8;j++)
       if(dat&0x01)
            ds18b20=0;
            _nop_();
            _nop_();
            ds18b20=1;
            delay(10);
            ds18b20=0;
           delay(10);
            ds18b20=1;
            _nop_();
            _nop_();
   dat=dat>>1;
bit Convert(void)
 if(Reset()==0)
        WriteByte(0xcc);
        WriteByte(0x44);
        return 1;
    return 0;
void ReadFlash(void)
 unsigned char Lsb,Msb;
    if(Reset()==0)
        WriteByte(0xcc);
        WriteByte(0xbe);
        Lsb=ReadByte();
        Msb=ReadByte();
        temp1=Lsb;
        temp2=Msb;
        temp1=0;
        temp2=0;
void w1602(uchar dat,bit r)
rs=r;
rw=0;
P3=dat;
en=0;
delay(2);
en=1;
delay(4);
en=0;
void init1602()
         w1602(0x38,0);
w1602(0x06,0);
w1602(0x0c,0);
w1602(0x01,0);
uchar r1302(uchar addr)
        uchar n;
rst=0;
sclk=0;
_nop_();
rst=1;
B=addr;
for(n=0;n<8;n++)
sclk=0;
DI=B0;
sclk=1;
B=B>>1;
for(n=0;n<8;n++)
A7=DI;
sclk=1;
ACC=ACC>>1;
sclk=0;
rst=0;
return(ACC);
   uchar i,n;
unsigned int m;
   init1602();
          m=1500;
          while(m--)
w1602(0x80,0);
for(i=0;i<5;i++)
w1602(tt0[i],1);
w1602(0x30+(r1302(0x85)>>4 & 0x0f),1);
w1602(0x30+(r1302(0x85) & 0x0f),1);
w1602(0x2d,1);
w1602(0x30+(r1302(0x83)>>4 & 0x0f),1);
w1602(0x30+(r1302(0x83) & 0x0f),1);
w1602(0x2d,1);
w1602(0x30+(r1302(0x81)>>4 & 0x0f),1);
w1602(0x30+(r1302(0x81) & 0x0f),1);
w1602(0xc0,0);
for(i=0;i<5;i++)
w1602(tt1[i],1);
w1602(0x30+(r1302(0x87)>>4 & 0x0f),1);
w1602(0x30+(r1302(0x87) & 0x0f),1);
w1602(0x2d,1);
w1602(0x30+(r1302(0x89)>>4 & 0x0f),1);
w1602(0x30+(r1302(0x89) & 0x0f),1);
w1602(0x2d,1);
w1602(0x30+(r1302(0x8d)>>4 & 0x0f),1);
w1602(0x30+(r1302(0x8d) & 0x0f),1);
w1602(0x01,0);
m=500;
          while(m--)
if(Convert()==1)
                ReadFlash();
                TT=(temp2<<4)|(temp1>>4);
 w1602(0x80,0);
for(i=0;i<5;i++)
w1602(tt2[i],1);
            for(n=0;n<3;n++)
w1602(ch[(r1302(0x8B) & 0x07)-1][n],1);
w1602(0xc0,0);
for(i=0;i<5;i++)
w1602(tt3[i],1);
if(temp2 & 0x80)
w1602(0x2d,1);
               w1602(0x30+((~TT & 0x3f) +1)/10,1);
w1602(0x30+((~TT & 0x3f) +1)%10,1);
if(TT & 0x7F)
w1602(0x2b,1);
w1602(0x20,1);
w1602(0x30+TT/10,1);
w1602(0x30+TT%10,1);
w1602(0x01,0);
