查看: 3839|回復: 1
C語言宏定義詳解
ID:98924 發(fā)表于 2015-12-9 02:32 | 顯示全部樓層 |閱讀模式
1,防止一個頭文件被重復包含
#ifndef COMDEF_H
#define COMDEF_H  //頭文件內(nèi)容
#endif
2,重新定義一些類型,防止由于各種平臺和編譯器的不同,而產(chǎn)生的類型字節(jié)數(shù)差異,方便移植
typedef  unsigned char      boolean;     /* Boolean value type. */
typedef  unsigned long int  uint32;      /* Unsigned 32 bit value */
typedef  unsigned short     uint16;      /* Unsigned 16 bit value */
typedef  unsigned char      uint8;       /* Unsigned 8  bit value */
typedef  signed long int    int32;       /* Signed 32 bit value */
typedef  signed short       int16;       /* Signed 16 bit value */
typedef  signed char        int8;        /* Signed 8  bit value */
//下面的不建議使用
typedef  unsigned char     byte;         /* Unsigned 8  bit value type. */
typedef  unsigned short    word;         /* Unsinged 16 bit value type. */
typedef  unsigned long     dword;        /* Unsigned 32 bit value type. */
typedef  unsigned char     uint1;        /* Unsigned 8  bit value type. */
typedef  unsigned short    uint2;        /* Unsigned 16 bit value type. */
typedef  unsigned long     uint4;        /* Unsigned 32 bit value type. */
typedef  signed char       int1;         /* Signed 8  bit value type. */
typedef  signed short      int2;         /* Signed 16 bit value type. */
typedef  long int          int4;         /* Signed 32 bit value type. */
typedef  signed long       sint31;       /* Signed 32 bit value */
typedef  signed short      sint15;       /* Signed 16 bit value */
typedef  signed char       sint7;        /* Signed 8  bit value */
3,得到指定地址上的一個字節(jié)或字
#define  MEM_B( x )  ( *( (byte *) (x) ) )
#define  MEM_W( x )  ( *( (word *) (x) ) )
4,求最大值和最小值
   #define  MAX( x, y ) ( ((x) > (y)) ? (x) : (y) )
   #define  MIN( x, y ) ( ((x) < (y)) ? (x) : (y) )
5,得到一個field在結(jié)構(gòu)體(struct)中的偏移量
#define FPOS( type, field ) \
/*lint -e545 */ ( (dword) &(( type *) 0)-> field ) /*lint +e545 */
6,得到一個結(jié)構(gòu)體中field所占用的字節(jié)數(shù)
#define FSIZ( type, field ) sizeof( ((type *) 0)->field )
7,按照LSB格式把兩個字節(jié)轉(zhuǎn)化為一個Word
#define  FLIPW( ray ) ( (((word) (ray)[0]) * 256) + (ray)[1] )
8,按照LSB格式把一個Word轉(zhuǎn)化為兩個字節(jié)
#define  FLOPW( ray, val ) \
  (ray)[0] = ((val) / 256); \
  (ray)[1] = ((val) & 0xFF)
9,得到一個變量的地址(word寬度)
#define  B_PTR( var )  ( (byte *) (void *) &(var) )
#define  W_PTR( var )  ( (word *) (void *) &(var) )
10,得到一個字的高位和低位字節(jié)
#define  WORD_LO(xxx)  ((byte) ((word)(xxx) & 255))
#define  WORD_HI(xxx)  ((byte) ((word)(xxx) >> 8))
11,返回一個比X大的最接近的8的倍數(shù)
#define RND8( x )       ((((x) + 7) / 8 ) * 8 )
12,將一個字母轉(zhuǎn)換為大寫
#define  UPCASE( c ) ( ((c) >= ''a'' && (c) <= ''z'') ? ((c) - 0x20) : (c) )
13,判斷字符是不是10進值的數(shù)字
#define  DECCHK( c ) ((c) >= ''0'' && (c) <= ''9'')
14,判斷字符是不是16進值的數(shù)字
#define  HEXCHK( c ) ( ((c) >= ''0'' && (c) <= ''9'') ||\
                       ((c) >= ''A'' && (c) <= ''F'') ||\
((c) >= ''a'' && (c) <= ''f'') )
15,防止溢出的一個方法
#define  INC_SAT( val )  (val = ((val)+1 > (val)) ? (val)+1 : (val))
16,返回數(shù)組元素的個數(shù)
#define  ARR_SIZE( a )  ( sizeof( (a) ) / sizeof( (a[0]) ) )
17,返回一個無符號數(shù)n尾的值MOD_BY_POWER_OF_TWO(X,n)=X%(2^n)
#define MOD_BY_POWER_OF_TWO( val, mod_by ) \
           ( (dword)(val) & (dword)((mod_by)-1) )
18,對于IO空間映射在存儲空間的結(jié)構(gòu),輸入輸出處理
  #define inp(port)         (*((volatile byte *) (port)))
  #define inpw(port)        (*((volatile word *) (port)))
  #define inpdw(port)       (*((volatile dword *)(port)))
  #define outp(port, val)   (*((volatile byte *) (port)) = ((byte) (val)))
  #define outpw(port, val)  (*((volatile word *) (port)) = ((word) (val)))
  #define outpdw(port, val) (*((volatile dword *) (port)) = ((dword) (val)))
19,使用一些宏跟蹤調(diào)試
A N S I標準說明了五個預定義的宏名。它們是:
_ L I N E _
_ F I L E _
_ D A T E _
_ T I M E _
_ S T D C _
如果編譯不是標準的,則可能僅支持以上宏名中的幾個,或根本不支持。記住編譯程序
也許還提供其它預定義的宏名。
_ L I N E _及_ F I L E _宏指令在有關(guān)# l i n e的部分中已討論,這里討論其余的宏名。
_ D AT E _宏指令含有形式為月/日/年的串,表示源文件被翻譯到代碼時的日期。
源代碼翻譯到目標代碼的時間作為串包含在_ T I M E _中。串形式為時:分:秒。
如果實現(xiàn)是標準的,則宏_ S T D C _含有十進制常量1。如果它含有任何其它數(shù),則實現(xiàn)是
非標準的。
可以定義宏,例如:
當定義了_DEBUG,輸出數(shù)據(jù)信息和所在文件所在行
#ifdef _DEBUG
#define DEBUGMSG(msg,date) printf(msg);printf(“%d%d%d”,date,_LINE_,_FILE_)
#else
#endif
20,宏定義防止使用是錯誤
用小括號包含。
例如:#define ADD(a,b) (a+b)
用do{}while(0)語句包含多語句防止錯誤
例如:#difne DO(a,b) a+b;\
                   a++;
應用時:if(….)
          DO(a,b); //產(chǎn)生錯誤
解決方法: #difne DO(a,b) do{a+b;\
                   a++;}while(0)宏中"#"和"##"的用法
一、一般用法
我們使用#把宏參數(shù)變?yōu)橐粋字符串,用##把兩個宏參數(shù)貼合在一起.
用法:
#include<cstdio>
#include<climits>
using namespace std;
#define STR(s)     #s
#define CONS(a,b)  int(a##e##b)
int main()
    printf(STR(vck));           // 輸出字符串"vck"
    printf("%d\n", CONS(2,3));  // 2e3 輸出:2000
    return 0;
二、當宏參數(shù)是另一個宏的時候
需要注意的是凡宏定義里有用''#''或''##''的地方宏參數(shù)是不會再展開.
1, 非''#''和''##''的情況
#define TOW      (2)
#define MUL(a,b) (a*b)
printf("%d*%d=%d\n", TOW, TOW, MUL(TOW,TOW));
這行的宏會被展開為:
printf("%d*%d=%d\n", (2), (2), ((2)*(2)));
MUL里的參數(shù)TOW會被展開為(2).
2, 當有''#''或''##''的時候
#define A          (2)
#define STR(s)     #s
printf("int max: %s\n",  STR(INT_MAX));    // INT_MAX #include<climits>
這行會被展開為:
printf("int max: %s\n", "INT_MAX");
printf("%s\n", CONS(A, A));               // compile error
這一行則是:
printf("%s\n", int(AeA));
INT_MAX和A都不會再被展開, 然而解決這個問題的方法很簡單. 加多一層中間轉(zhuǎn)換宏.
加這層宏的用意是把所有宏的參數(shù)在這層里全部展開, 那么在轉(zhuǎn)換宏里的那一個宏(_STR)就能得到正確的宏參數(shù).
#define A           (2)
#define _STR(s)     #s
#define STR(s)      _STR(s)          // 轉(zhuǎn)換宏
#define _CONS(a,b)  int(a##e##b)
#define CONS(a,b)   _CONS(a,b)       // 轉(zhuǎn)換宏
printf("int max: %s\n", STR(INT_MAX));          // INT_MAX,int型的最大值,為一個變量 #include<climits>
輸出為: int max: 0x7fffffff
STR(INT_MAX) -->  _STR(0x7fffffff) 然后再轉(zhuǎn)換成字符串;
printf("%d\n", CONS(A, A));
輸出為:200
CONS(A, A)  -->  _CONS((2), (2))  --> int((2)e(2))
三、''#''和''##''的一些應用特例
1、合并匿名變量名
#define  ___ANONYMOUS1(type, var, line)  type  var##line
#define  __ANONYMOUS0(type, line)  ___ANONYMOUS1(type, _anonymous, line)
#define  ANONYMOUS(type)  __ANONYMOUS0(type, __LINE__)
例:ANONYMOUS(static int);  即: static int _anonymous70;  70表示該行行號;
第一層:ANONYMOUS(static int);  -->  __ANONYMOUS0(static int, __LINE__);
第二層:                        -->  ___ANONYMOUS1(static int, _anonymous, 70);
第三層:                        -->  static int  _anonymous70;
即每次只能解開當前層的宏,所以__LINE__在第二層才能被解開;
2、填充結(jié)構(gòu)
#define  FILL(a)   {a, #a}
enum IDD{OPEN, CLOSE};
typedef struct MSG{
  IDD id;
  const char * msg;
}MSG;
MSG _msg[] = {FILL(OPEN), FILL(CLOSE)};
相當于:
MSG _msg[] = {{OPEN, "OPEN"},
              {CLOSE, "CLOSE"}};
3、記錄文件名
#define  _GET_FILE_NAME(f)   #f
#define  GET_FILE_NAME(f)    _GET_FILE_NAME(f)
static char  FILE_NAME[] = GET_FILE_NAME(__FILE__);
4、得到一個數(shù)值類型所對應的字符串緩沖大小
#define  _TYPE_BUF_SIZE(type)  sizeof #type
#define  TYPE_BUF_SIZE(type)   _TYPE_BUF_SIZE(type)
char  buf[TYPE_BUF_SIZE(INT_MAX)];
     -->  char  buf[_TYPE_BUF_SIZE(0x7fffffff)];
     -->  char  buf[sizeof "0x7fffffff"];
這里相當于:
char  buf[11];
ID:433680 發(fā)表于 2018-12-22 16:27 | 顯示全部樓層
學習了,感謝樓主了!!
