查看: 4362|回復(fù): 0
51單片機控制PCF8591輸出4種波形周期可調(diào)
ID:95068 發(fā)表于 2015-11-15 13:01 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
sbit  SCL=P2^6;
sbit  SDA=P2^7;
sbit  key1=P3^6;
sbit  key2=P3^7;
uint n=0;
uchar code  Sinwave[]={    //正弦波波表
127, 152, 176, 198, 217, 233, 245, 252,
255, 252, 245, 233, 217, 198,176, 152,
127, 102, 78,  56,  37,  21,  9,   2,
0,   2,   9,  21,  37,  56,  78, 102
uchar code Triwave[] = {   //三角波波表
0,  16,  32,  48,  64,  80,  96, 112,
128, 144, 160, 176, 192, 208,224, 240,
255, 240, 224, 208, 192, 176, 160, 144,
128, 112,  96,  80,  64,  48,  32,  16
uchar code Sawwave[] = {   //鋸齒波表
0, 8, 16, 24, 32, 40,  48,  56,
64,72,80,  88,  96, 104, 112,120,
128, 136, 144, 152, 160, 168, 176,184,
192, 200, 208, 216, 224,232, 240, 248,
uchar code Squwave[]={   //方波波表
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
255,255,255,255,255,255,255,255,
uint f=30;
void delay()
void  delay10()
{ uint i,j;
  for(i=0;i<10;i++)
    for(j=0;j<250;j++);
  void  delay11()
{ uint i,j;
  for(i=0;i<f;i++)
    for(j=0;j<250;j++);
void init()
{  SCL=1;
   delay();
   SDA=1;
   delay();
void start()
{   init();
        SDA=0;
        delay();
void write(uchar date)
{         uchar i,temp;
     temp=date;
         for(i=0;i<8;i++)
          { temp=temp<<1;
            SCL=0;
            delay();
            SDA=CY;
            delay();
            SCL=1;
            delay();
         SCL=0;
         delay();
         SDA=1;
         delay();
void respons()
{         uchar i;
     SCL=1;
         delay();
         while((SDA==1)&&(i<250))
           i++;
         SCL=0;
         delay();
void stop()
        SDA=0;
        delay();
        SCL=1;
        delay();
        SDA=1;
        delay();
  void writewave(uchar xc)
      init();
      start();
             write(0x90);
          respons();
          write(0x40);
          respons();
          write(xc);
          respons();
          stop();
void keyscan()
{ if(key1==0)
            delay10();
         if(key1==0)
         { f+=10;
           while(!key1);
   if(key2==0)
            delay10();
         if(key2==0)
         { f-=10;
         if(f<=20) f=20;
           while(!key2);
void  main()
   {  keyscan();
   for(n=0;n<32;n++)
        { writewave(Sinwave[n]);
     delay11();        }
    for(n=0;n<32;n++)
     { writewave(Triwave[n]);
       delay11();  }
        for(n=0;n<32;n++)
     { writewave(Sawwave[n]);
        delay11();}
         for(n=0;n<32;n++)
   { writewave(Squwave[n]);
      delay11(); }
參與人數(shù) 1黑幣 +50 收起 理由
admin + 50 共享資料的積分獎勵!
相關(guān)帖子
