查看: 14746|回復: 20
1.8寸四位共陽數碼管時鐘 電路圖及51單片機程序分享
程序是網上轉載的,分享出來大家一起學習
1.8寸四位數碼管時鐘.rar (186.64 KB, 下載次數: 135)
//四位數碼管電子鐘
//應用程序 C
//neo
//V1.1 2011-7-16
//MCS-51 12MHZ C語言
//接口說明:  DS1302、DS18B20
#include <reg52.h>
#include <intrins.h>
#define uint8 unsigned char
#define uint  unsigned int
uchar Disp_Buff[4];
char SB=4;  // clock set time bit
//bit Set_Flag;  // set time flag
bit T=0;  // display Temperature and Time flag
bit TT=0; // 10S Auto change display Temperature and Time flag
//#define T0_H  0xf0    // 4ms
//#define T0_L  0x60
#define T0_H  0xf5    // 2666us
#define T0_L  0x96
#define ST    20
#define T1_H  0xb1    //20ms
#define T1_L  0xe0
#define NumLed_Bit P2
#define Disp       P1
#define Key        P3
#define Key1 1
#define Key2 2
#define Key3 3
#define Key4 4
#define Key_NULL 0
sbit Beep=P0^7;
void Play(uchar t);
sbit Red_Led=P3^7;
// Driver DS1302
sbit RST=P0^0;
sbit IO=P0^1;
sbit SCLK=P0^2;
#define second_write 0x80
#define minute_write 0x82
#define hour_write   0x84
#define week_write   0x8a
#define day_write    0x86
#define month_write  0x88
#define year_write   0x8c
#define second_read 0x81
#define minute_read 0x83
#define hour_read   0x85
#define week_read   0x8b
#define day_read    0x87
#define month_read  0x89
#define year_read   0x8d
#define sclk_high    SCLK=1;
#define sclk_low     SCLK=0;
#define io_high      IO=1;
#define io_low       IO=0;
#define io_read      IO
#define rst_high     RST=1;
#define rst_low      RST=0;
struct {uint8 second;
        uint8 minute;
     uint8 hour;
     uint8 day;
     uint8 week;
  uint8 month;
  uint8 year; } current_time;
static void ds1302write(uint8 content)
uint8 i;
for(i=8;i>0;i--) { if(content&0x01) io_high
                       else io_low
                    content>>=1; sclk_high  sclk_low
static uint8 ds1302read(void)
uint8 i,readvalue;
io_high
for(i=8;i>0;i--) { readvalue>>=1; if(io_read) readvalue|=0x80;
                                      else     readvalue&=0x7f;
     sclk_high  sclk_low  }
return readvalue;
void ds1302write_byte (uint8 address,uint8 content)
rst_low  sclk_low  rst_high  ds1302write(address);
ds1302write(content); rst_low  sclk_high
uint8 ds1302read_byte(uint8 address)
uint8 readvalue;
readvalue=ds1302read();
rst_low  sclk_high
return readvalue;
void Clock_Init(void)
uchar R;
if(ds1302read_byte(0xc1)!=0xf0) {
                                  ds1302write_byte(0x8e,0x00);
             ds1302write_byte(year_write,0x11);
             ds1302write_byte(week_write,0x06);
             ds1302write_byte(month_write,0x04);
             ds1302write_byte(day_write,0x09);
             ds1302write_byte(hour_write,0x23);
             ds1302write_byte(minute_write,0x59);
             ds1302write_byte(second_write,0x30);
                                  ds1302write_byte(0x90,0xa5);
                                  ds1302write_byte(0xc0,0xf0);
                                  for (R=0;R<10;R+=2)
             ds1302write_byte(0xc2+R,0);
          ds1302write_byte(0x8e,0x80);
void Clock_Updata(void)
current_time.second=ds1302read_byte(second_read);
current_time.minute=ds1302read_byte(minute_read);
current_time.hour=  ds1302read_byte(hour_read);
current_time.day=   ds1302read_byte(day_read);
current_time.month= ds1302read_byte(month_read);
current_time.week=  ds1302read_byte(week_read);
current_time.year=  ds1302read_byte(year_read);
void Write_Time(void)
  ds1302write_byte(0x82,((Disp_Buff[2]<<4)|Disp_Buff[3]));
  ds1302write_byte(0x84,((Disp_Buff[0]<<4)|Disp_Buff[1]));
void Write_Alarm(void)
  ds1302write_byte(0xca,((Disp_Buff[2]<<4)|Disp_Buff[3])); // alarm minute
  ds1302write_byte(0xc8,((Disp_Buff[0]<<4)|Disp_Buff[1])); // alarm hour
  ds1302write_byte(0xc6,1);
void Alarm(void)
if(ds1302read_byte(0xc7)==1&&
    current_time.minute==ds1302read_byte(0xcb)&&
current_time.hour==ds1302read_byte(0xc9)  )
        ds1302write_byte(0xc6,0);
        Play(3);
// DS18B20 driver
sbit io_DQ=P0^6;
#define DQ_HIGH io_DQ=1;
#define DQ_LOW  io_DQ=0;
#define DQ_READ io_DQ
unsigned char Temperature[4];
void Delay_10Us (unsigned int Count)
  while(--Count)
        _nop_();
unsigned char Ds18b20_Init(void)
    unsigned char Flag;
DQ_HIGH Delay_10Us(3);
    DQ_LOW  Delay_10Us(80);
    DQ_HIGH Delay_10Us(15);
Flag=DQ_READ;
    return Flag;
void Write_f(unsigned char cmd)
    unsigned char i;
for(i=8;i>0;i--) {
                    EA=0;
        DQ_LOW
                       DQ_READ=cmd&0x01;
                       Delay_10Us(5);
                       DQ_HIGH
                       EA=1;
        cmd>>=1;
unsigned char Read_f(void)
  unsigned char Read_Value,i;
  for (i=8;i>0;i--) {
                      EA=0;
       DQ_LOW
                         Read_Value>>=1;
                         DQ_HIGH
                         if (DQ_READ==1) Read_Value|=0x80;
                         EA=1;
       Delay_10Us(3);
  return Read_Value;
unsigned int Read_Temp(void)
      unsigned char Temp_H, Temp_L;
         unsigned int  Return_Temp;
         EA=0;      // close interrupt;
   Ds18b20_Init();
         Write_f(0xcc);
         Write_f(0x44);
         Ds18b20_Init();
         Write_f(0xcc);
         Write_f(0xbe);
         Temp_L=Read_f();
         Temp_H=Read_f();
         EA=1;
   Return_Temp=Temp_H;
         Return_Temp<<=8;
         Return_Temp|=Temp_L;
         return Return_Temp;
void Temperature_Update(void)
     unsigned char T_flag=0;
     unsigned int  Temp_Dat;
     float         Temp;
     Temp_Dat=Read_Temp();
     if(Temp_Dat&0xf000) {T_flag=1; Temp_Dat=~Temp_Dat+1; }
     Temp=Temp_Dat*0.0625;
     Temp_Dat=Temp*10;
     Temperature[0]=T_flag;
     Temperature[1]=Temp_Dat/100;
     Temperature[2]=Temp_Dat%100/10;
     Temperature[3]=Temp_Dat%10;
void Timer0_Init(void)
    TMOD|=0x01;
    TH0=T0_H;
    TL0=T0_L;
    EA=1;
    ET0=1;
    TR0=1;
bit T_10S,T_1S;
bit S;   // shining flag
bit pp=1;      // open or close :
unsigned int ms1,ms2,ms3;
uchar Bit;// Number Led select
uchar code Disp_NumCode[]={0x3F,0x06,0x5B,0x4F,
                           0x66,0x6D,0x7D,0x07,
         0x7F,0x6F,  // dp-a  P07-P00  0-9,
         0x39,   //c 10
         0x37,0x79,0x3F, //NEO  11-13
         0x6D,0x39,0x77, // S,C,A 14-16
         0x5E,0x73,0x71, // d,p,F   17-19
         0x00,     //  " "  20
         0x38,0x08    //   L  21  _ 22
uchar code Open_Logo[]={11,12,13,20};
uchar code S_C[]={14,22,15,20};
uchar code S_A[]={14,22,16,20};
uchar code d_p[]={17,22,18,20};
uchar code BELL[]={17,12,21,21};
uchar code ON[]= {20,13,11,20};
uchar code OFF[]={20,13,19,19};
void Put_In(uchar *P)
uchar a;
for (a=0;a<4;a++)
     Disp_Buff[a]=P[a];
void Timer0_Isr(void) interrupt 1
TH0=T0_H;     //4ms
TL0=T0_L;
Disp=0x00;
    switch(Bit) {
                       case 0 : NumLed_Bit=0xfe; break;
              case 1 : NumLed_Bit=0xfd; break;
              case 2 : NumLed_Bit=0xfb; break;
              case 3 : NumLed_Bit=0xf7; break;
              case 4 :  NumLed_Bit=0xf3; break; // display :
              default : break;
    switch(Bit) {
                    case 0 :  {
                 if(SB==0)
                            if (S)     NumLed_Bit=0xfe;
             if(S==0)   NumLed_Bit=0x00;
            else NumLed_Bit=0xfe;
         }break;
        case 1 :  {
                    if(SB==1)
                            if (S)     NumLed_Bit=0xfd;
              else NumLed_Bit=0xfd;
         }break;
        case 2 :  {
                 if(SB==2)
                            if (S)     NumLed_Bit=0xfb;
             else NumLed_Bit=0xfb;
         } break;
      case 3 : {
                  if(SB==3)
                            if (S)     NumLed_Bit=0xf7;
              else NumLed_Bit=0xf7;
       } break;
              case 4 : {
                  if(T==0||TT==0)  NumLed_Bit=0xf3;  // display :
         if( T || TT )   NumLed_Bit=0xfb;  // display  .
         } break;
              default : break;
if(Bit<4) {
             Disp=Disp_NumCode[Disp_Buff[Bit]];
     if(pp==1)
           if (T==0||TT==0)
         if(current_time.second%2) Disp=0x80;
                       else                    Disp=0x00;
     if( T || TT )  Disp=0x80;
     else Disp=0x00;    // close :
if(++Bit>4) Bit=0;
void Timer1_Init(void)
    TMOD|=0x10;
    TH1=T1_H;  //20ms
    TL1=T1_L;
    EA=1;
    ET1=1;
    TR1=1;
uchar Key_Time;
void Timer1_Isr(void) interrupt 3
TH1=T1_H;
TL1=T1_L;
if(Key!=0xff) Key_Time++;
if(++ms1>ST)  { ms1=0;  S=~S;   }   //when set time Shining bit
if(++ms2>=50) { ms2=0;  T_1S=1; }
if(++ms3>500) { ms3=0;  T_10S=1;}
void DelayM(unsigned int a){//-延時函數 1MS/次
unsigned char i;
while(a--)
  for(i = 0; i < 125; i++)
  }          //i 從0加到125,CPU大概就耗時1毫秒
void Play(uchar t)
  uchar i;
  switch(t) {
             case 1:
                    Beep=0;
     DelayM(100);
                  } break;
     case 2:
        Beep=0;
     DelayM(400);
        Beep=1;
        DelayM(500);
     Beep=0;
     DelayM(100);
       } break;
    case 3:
        for(i=0;i<20;i++)
     Beep=0;
     DelayM(100);
        Beep=1;
     DelayM(100);
     Beep=0;
     DelayM(100);
     Beep=1;
        DelayM(500);
       } break;
    default : break;
Beep=1;
uchar Key_Scan(void)
static bit Key_Down;
static uchar K;
uchar K_Value=0;
if(Key_Time>250) Key_Time=3;
if(Key_Time>=3&&Key_Down==0)
                  Key_Time=0;
      Key_Down=1;
      switch(Key)
      case  0xfe : K=1; break;
         case  0xfd : K=2; break;
      case  0xfb : K=3; break;
      case  0xf7 : K=4; break;
      default :    K=0; break;
if(Key==0xFF&&Key_Down==1)
     Key_Down=0;
     K_Value=K;
       Play(1);
return K_Value;
void Disp_Time(void)
Disp_Buff[3]=current_time.minute%16;
Disp_Buff[2]=current_time.minute/16;
Disp_Buff[1]=current_time.hour%16;
Disp_Buff[0]=current_time.hour/16;
void Disp_Temperature_3bit(void)
Disp_Buff[3]=20;
Disp_Buff[2]=10; // display 'c'
Disp_Buff[1]=Temperature[2];
Disp_Buff[0]=Temperature[1];
void Disp_Temperature_4bit(void)
Disp_Buff[3]=Temperature[3];
Disp_Buff[2]=10; // display c
uchar Select_M=4;
void MENU (void)
   uchar K;
   char Menu=0;
   pp=0; // close ':'
   while(Menu!=4)
      K=Key_Scan();
      switch (Menu)
        case 0 : { Put_In(S_C); } break;
           case 1 : { Put_In(S_A); } break;
        case 2 : { Put_In(d_p); } break;
        case 3 : { Put_In(BELL);}
        default : break;
       if(K==Key3) Menu=4;
       if(K==Key2) Menu=(Menu+1)%4;
       if(K==Key1) {
                    Select_M=Menu; Menu=4;
  pp=1;
void Set_Time(void)
bit Set_Flag=1;  // set time flag
uchar K;
SB=0;
Disp_Time();
T=0;
TT=0;
while(Set_Flag)
       K=Key_Scan();
    if(K==Key1)
          switch(SB)
                                 case 0 : {
                                              if(Disp_Buff[1]>3)
                   Disp_Buff[0]=(Disp_Buff[0]+1)%2;
                   Disp_Buff[0]=(Disp_Buff[0]+1)%3;
                } break;
                                 case 1 : {
                                        if(Disp_Buff[0]==2)
                   Disp_Buff[1]=(Disp_Buff[1]+1)%4;
                 Disp_Buff[1]=(Disp_Buff[1]+1)%10;
                }  break;
                                 case 2 : {
                                        Disp_Buff[2]=(Disp_Buff[2]+1)%6;
                                              }  break;
                                 case 3 :    {
                                        Disp_Buff[3]=(Disp_Buff[3]+1)%10;
                                             }  break;
                              default : break;
    if(K==Key2) { SB=  (SB+1)%4; }
       if(K==Key3) { Set_Flag=0; SB=4; }
    if(K==Key4) {
                  Set_Flag=0; SB=4; Write_Time(); T_10S=0;
void Write_Ds1302Ram(uchar address,uchar dat)
  ds1302write_byte(address,dat);
uchar dp; // display modle select bit
void Set_Dp(void)
bit dp_Set=1;
uchar K;
pp=0;    // close ':'
//dp=ds1302read_byte(0xc3);
while(dp_Set)
  K=Key_Scan();
  switch(dp)
   case 1 : Put_In(ON);  break;
   case 0 : Put_In(OFF); break;
   default : break;
  if(K==Key3)   dp_Set=0;
  if(K==Key2)   dp=(dp+1)%2;
  if(K==Key1) { dp_Set=0;  Write_Ds1302Ram(0xc2,dp);  T=0;  TT=0; T_10S=0; }
pp=1;
uchar Bell_State;
void Set_Bell(void)
bit Bell_Set=1;
uchar K;
pp=0;
//Bell_State=ds1302read_byte(0xc5);
while(Bell_Set)
  K=Key_Scan();
  switch(Bell_State)
   default : break;
  if(K==Key3)   Bell_Set=0;
  if(K==Key2)   Bell_State=(Bell_State+1)%2;
  if(K==Key1) {
               Write_Ds1302Ram(0xc4,Bell_State); Bell_Set=0; T=0; TT=0; T_10S=0;
pp=1;
void Set_Alarm(void)
static bit First_Alarm_Set=0;
uchar K;
SB=0;
T=0;
TT=0;
if(First_Alarm_Set)
  Disp_Buff[0]=ds1302read_byte(0xc9)/16;    //alarm hour
  Disp_Buff[1]=ds1302read_byte(0xc9)%16;
  Disp_Buff[2]=ds1302read_byte(0xcb)/16;    //alarm minute
  Disp_Buff[3]=ds1302read_byte(0xcb)%16;
  else  Disp_Time();
while(Set_Flag)
       K=Key_Scan();
    if(K==Key1)
          switch(SB)
                                 case 0 : {
                                              if(Disp_Buff[1]>3)
                } break;
                                 case 1 : {
                                        if(Disp_Buff[0]==2)
                }  break;
                                 case 2 : {
                                              }  break;
                                 case 3 :    {
                                             }  break;
                              default : break;
    if(K==Key4) {
        Set_Flag=0; SB=4;
        First_Alarm_Set=1;
        Write_Alarm(); T_10S=0;
void Ds1302Ram_Init(void)
uchar i;
//for(i=0xc3;i<0xc7;i+=2)
i=ds1302read_byte(0xc3);
     if(i!=0||i!=1)
         Write_Ds1302Ram(0xc2,0);
i=ds1302read_byte(0xc5);
     if(i!=0||i!=1)
         Write_Ds1302Ram(0xc4,0);
uchar K;
Key=0xff;
Timer0_Init();
Timer1_Init();
Clock_Init();
//Ds1302Ram_Init();
Put_In(Open_Logo);
Play(1);
DelayM(3000);
Clock_Updata();
   //if(T_1S) {  T_1S=0;  Clock_Updata(); Temperature_Update(); }
   Clock_Updata();
   if(current_time.minute==0&&
      current_time.second==0&&
Bell_State==1)
  { DelayM(1000); Play(2);  }
   K=Key_Scan();
   if(K==4) MENU();
   if(K==1&&dp==0) T=~T;
switch (Select_M)
      case 0 : { Set_Time();  Select_M=4; } break;
      case 1 : { Set_Alarm(); Select_M=4; } break;
      case 2 : { Set_Dp();    Select_M=4; } break;
      case 3 : { Set_Bell();  Select_M=4; };break;
      default : break;
   if(T_10S==1&&dp) { TT=~TT;  T_10S=0; }
   if(TT==0&&dp)
     Disp_Time();
   if(TT&&dp)
    Disp_Temperature_3bit();
   if(T==0&&dp==0)
     Disp_Time();
   if(T&&dp==0)
   Alarm();
admin + 50 共享資料的積分獎勵!
收藏收藏8 分享淘帖 頂 踩
ID:92510 發表于 2015-10-15 13:28 | 只看該作者
好東西,學習學習
ID:97771 發表于 2015-12-1 21:30 | 只看該作者
不錯不錯
ID:74784 發表于 2015-12-1 22:20 | 只看該作者
我的2.3寸的老年數字鐘
ID:97588 發表于 2015-12-12 09:16 來自觸屏版 | 只看該作者
學習。要是模塊化就更方便些
ID:95809 發表于 2015-12-24 13:49 | 只看該作者
最近在做時鐘,下載學習了,
ID:127457 發表于 2016-6-24 19:49 來自觸屏版 | 只看該作者
想自己做一個   剛好找到這么一個最全的教程。
ID:140489 發表于 2016-9-26 13:51 | 只看該作者
新手想下載,沒黑幣,只有頂一下
ID:142660 發表于 2016-10-13 22:35 | 只看該作者
學習學習
ID:146910 發表于 2016-11-30 13:50 | 只看該作者
ID:152187 發表于 2016-12-4 23:51 | 只看該作者
新手學習吧
ID:152442 發表于 2016-12-5 22:58 | 只看該作者
感謝分享
ID:156593 發表于 2017-1-7 22:50 | 只看該作者
剛到的新手 支持你
ID:65980 發表于 2017-1-8 11:45 | 只看該作者
微信公眾號:單片機共享平臺,加入有更多資料
ID:198298 發表于 2017-5-8 22:41 | 只看該作者
單片機用處很大
ID:89286 發表于 2017-8-27 13:06 | 只看該作者
thanks for sharing
ID:232619 發表于 2017-9-17 10:57 | 只看該作者
謝謝樓主~
ID:243884 發表于 2017-12-2 23:43 來自觸屏版 | 只看該作者
謝謝,學習學習
ID:47634 發表于 2018-4-18 08:45 | 只看該作者
lxa0 發表于 2015-12-1 22:20
我的2.3寸的老年數字鐘
好漂亮,用啥畫的電路圖?
ID:342302 發表于 2018-6-1 23:42 | 只看該作者
新手上路,學習學習
ID:681573 發表于 2020-3-25 08:42 | 只看該作者
好好學習,天天向上
