- #include "main.h"
- xdata uchar year,month,date,day,hour,min,sec,DTemp=0;
- xdata uchar al1_min,al1_hour,al1_day,al2_min,al2_hour,al2_day;
- bit ack;
- uchar BCD2HEX(uchar val) //BCD轉(zhuǎn)換為Byte
- uchar i;
- i= val&0x0f;
- val >>= 4;
- val &= 0x0f;
- val *= 10;
- i += val;
- return i;
- uchar B_BCD(uchar val)//B碼轉(zhuǎn)換為BCD碼
- uchar i,j,k;
- i=val/10;
- j=val%10;
- k=j+(i<<4);
- return k;
- void delayus(uchar i)
- while(--i) ;
- /************************START***************************/
- void Start()
- SDA=1; //發(fā)送起始條件的數(shù)據(jù)信號(hào)
- delayus(1);
- SCL=1;
- delayus(5); //起始條件建立時(shí)間大于4.7us,延時(shí)
- SDA=0; //發(fā)送起始信號(hào)
- delayus(5); // 起始條件鎖定時(shí)間大于4μs
- SCL=0; //鉗住I2C總線,準(zhǔn)備發(fā)送或接收數(shù)據(jù)
- delayus(2);
- /************************STOP****************************/
- void Stop()
- SDA=0; //發(fā)送結(jié)束條件的數(shù)據(jù)信號(hào)
- delayus(1); //發(fā)送結(jié)束條件的時(shí)鐘信號(hào)
- SCL=1; //結(jié)束條件建立時(shí)間大于4us
- delayus(5);
- SDA=1; //發(fā)送I2C總線結(jié)束信號(hào)
- delayus(4);
- 字節(jié)數(shù)據(jù)發(fā)送函數(shù)
- 函數(shù)原型: void SendByte(uchar Dat);
- 功能: 將數(shù)據(jù)c發(fā)送出去,可以是地址,也可以是數(shù)據(jù),發(fā)完后等待應(yīng)答,并對(duì)
- 此狀態(tài)位進(jìn)行操作.(不應(yīng)答或非應(yīng)答都使ack=0)
- ack=1 發(fā)送數(shù)據(jù)正常,
- ack=0 被控器無(wú)應(yīng)答或損壞。
- void SendByte(uchar Dat)
- uchar BitCnt;
- for(BitCnt=0;BitCnt<8;BitCnt++) //要傳送的數(shù)據(jù)長(zhǎng)度為8位
- if((Dat<<BitCnt)&0x80)
- SDA=1; //判斷發(fā)送位
- else
- SDA=0;
- delayus(1);
- SCL=1; //置時(shí)鐘線為高,通知被控器開(kāi)始接收數(shù)據(jù)位
- delayus(5); //保證時(shí)鐘高電平周期大于4μs
- SCL=0;
- delayus(2);
- SDA=1; //8位發(fā)送完后釋放數(shù)據(jù)線,準(zhǔn)備接收應(yīng)答位
- delayus(2);
- SCL=1;
- delayus(3);
- if(SDA==1)
- ack=0;
- else
- ack=1; //判斷是否接收到應(yīng)答信號(hào)
- SCL=0;
- delayus(2);
- 字節(jié)數(shù)據(jù)接收函數(shù)
- 函數(shù)原型: uchar RcvByte();
- 功能: 用來(lái)接收從器件傳來(lái)的數(shù)據(jù),并判斷總線錯(cuò)誤(不發(fā)應(yīng)答信號(hào)),
- 發(fā)完后請(qǐng)用應(yīng)答函數(shù)應(yīng)答從機(jī)。
- uchar RcvByte()
- uchar retc;
- uchar BitCnt;
- retc=0;
- SDA=1; //置數(shù)據(jù)線為輸入方式
- delayus(1);
- SCL=0; //置時(shí)鐘線為低,準(zhǔn)備接收數(shù)據(jù)位
- delayus(5); //時(shí)鐘低電平周期大于4.7μs
- SCL=1; //置時(shí)鐘線為高使數(shù)據(jù)線上數(shù)據(jù)有效
- delayus(3);
- retc=retc<<1;
- if(SDA==1)
- retc=retc+1; //讀數(shù)據(jù)位,接收的數(shù)據(jù)位放入retc中
- delayus(2);
- SCL=0;
- delayus(2);
- return(retc);
- 應(yīng)答子函數(shù)
- 函數(shù)原型: void I2CACK(bit a);
- 功能: 主控器進(jìn)行應(yīng)答信號(hào)(可以是應(yīng)答或非應(yīng)答信號(hào),由位參數(shù)a決定)
- void I2CACK(bit a)
- if(a==0)
- SDA=0; //在此發(fā)出應(yīng)答或非應(yīng)答信號(hào)
- else
- SDA=1;
- delayus(3);
- SCL=1;
- delayus(5); //時(shí)鐘低電平周期大于4μs
- SCL=0; //清時(shí)鐘線,鉗住I2C總線以便繼續(xù)接收
- delayus(2);
- /***********將一個(gè)字節(jié)寫(xiě)入DS3231指定的地址***********/
- uchar I2CWrite(uchar addr,uchar bytedata)
- Start();
- SendByte(ADDRTC);
- if (ack == 0)
- return 0;
- SendByte(addr);
- if (ack == 0)
- return 0;
- SendByte(bytedata);
- if (ack == 0)
- return 0;
- Stop();
- delayus(10);
- return 1;
- /************從DS3231當(dāng)前地址讀一個(gè)字節(jié)************/
- uchar I2CRead()
- uchar read_data;
- Start();
- SendByte(ADDRTC+1);
- if(ack==0)
- DisplayChar(11,1,'t');
- return(0);
- read_data = RcvByte();
- I2CACK(1);
- Stop();
- return read_data;
- /************從DS3231指定地址讀一個(gè)字節(jié)************/
- uchar I2CReadAdd(uchar addr)
- Start();
- SendByte(ADDRTC);
- if(ack==0)
- DisplayChar(12,1,'x');
- return(0);
- SendByte(addr);
- if(ack==0)
- DisplayChar(13,1,'y');
- return(0);
- return(I2CRead());
- /*********************讀取時(shí)間**********************/
- void Readtime()
- uchar temp;
- temp=I2CReadAdd(DS3231_SEC);//秒
- sec=BCD2HEX(temp);
- temp=I2CReadAdd(DS3231_MIN);//分
- min=BCD2HEX(temp);
- temp=I2CReadAdd(DS3231_HOUR); //時(shí)
- //temp&=0x3F;
- hour=BCD2HEX(temp);
- day=I2CReadAdd(DS3231_DAY);//星期
- temp=I2CReadAdd(DS3231_DATE); //日
- date=BCD2HEX(temp);
- temp=I2CReadAdd(DS3231_MONTH); //月
- month=BCD2HEX(temp);
- temp=I2CReadAdd(DS3231_YEAR); //年
- year=BCD2HEX(temp);
- Dtemp=I2CReadAdd(DS3231_TEMP_H);//溫度
- /*******************讀取鬧鈴時(shí)間********************/
- void ReadAlarm()
- uchar temp;
- temp=I2CReadAdd(DS3231_AL1MIN);//分
- al1_min=BCD2HEX(temp);
- temp=I2CReadAdd(DS3231_AL1HOUR); //時(shí)
- al1_hour=BCD2HEX(temp);
- temp=I2CReadAdd(DS3231_AL1DAY); //星期or日
- al1_day=BCD2HEX(temp);
- temp=I2CReadAdd(DS3231_AL2MIN);//分
- al2_min=BCD2HEX(temp);
- temp=I2CReadAdd(DS3231_AL2HOUR); //時(shí)
- al2_hour=BCD2HEX(temp);
- temp=I2CReadAdd(DS3231_AL2DAY); //星期or日
- al2_day=BCD2HEX(temp);
- /****************修改時(shí)間***************************/
- /*void SetTime(uchar yea,uchar mon,uchar da,uchar hou,uchar min,uchar sec)
- uchar temp=0;
- temp=B_BCD(sec);
- I2CWrite(0x00,temp);//修改秒
- temp=B_BCD(min);
- I2CWrite(0x01,temp);//修改分
- temp=B_BCD(hou);
- I2CWrite(0x02,temp);//修改時(shí)
- temp=B_BCD(da);
- I2CWrite(0x04,temp);//修改日
- temp=B_BCD(mon);
- I2CWrite(0x05,temp);//修改月
- temp=B_BCD(yea);
- I2CWrite(0x06,temp);//修改年
- bit runnian()//閏年判斷
- if((year%4==0&&year%100!=0)||(year%100==0&&year%400==0))
- return 1;
- else
- return 0;
- void autoweek()
- Readtime();
- if( month == 1 || month == 2 )
- month += 12;
- if( year> 0 )
- year--;
- else
- year = 4;
- day = (1+(( date + 2*month + 3*(month+1)/5 + year + year/4 ) %7));
- I2CWrite(DS3231_DAY,day);
- void InitDS3231()
- SCL=1;
- delayus(5);
- SDA=1;
- delayus(5);
- I2CWrite(DS3231_AL1DAY,0x81); //A1M4置位,時(shí)分秒匹配時(shí)鬧鐘響應(yīng)
- I2CWrite(DS3231_AL2DAY,0x81); //A2M4置位,時(shí)分匹配時(shí)鬧鐘響應(yīng)
- I2CWrite(DS3231_CONTROL,0x04); //中斷允許,鬧鐘1和2關(guān)閉
- I2CWrite(DS3231_STATUS,0x00); //32KHZ輸出禁止,鬧鐘標(biāo)志位清零
- //SetTime(11,1,14,8,10,0);
- /* -------- read temperature -------- */
- /*void read_temp()
- int itemp;
- float ftemp;
- do
- itemp=I2CReadAdd(0x0e);
- } while(itemp & 0x20); // wait until CNVT bit goes inactive
- Start();
- SendByte(ADDRTC);
- SendByte(0x11); //address of temperature MSB
- Start();
- SendByte(ADDRTC + 1); //send the device address for read
- itemp = ( (int) RcvByte() << 5 );
- I2CACK(0);
- itemp += ( RcvByte() >> 3);
- I2CACK(1);
- Stop();
- if(itemp & 0x1000) {itemp += 0xe000;} //if sign bit set, make 16 bit 2's comp
- ftemp = 0.03125 * (float) itemp; // convert to degrees C
- // ftemp = ftemp * 9 / 5 + 32; // skip this if you don't want degrees F
- Dtemp = (uchar) ftemp;
復(fù)制代碼 |
