查看: 4300|回復: 1
ILI9341_initialize初始化程序
ID:90084 發表于 2015-9-15 01:26 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. void initial_ILI9341()
  2. {
  3. // VCI=2.8V
  4.     //************* Reset LCD Driver ****************//
  5.         RES = 1;
  6.         delayms(1);   // Delay 1ms
  7.         RES = 0;
  8.         delayms(10); // Delay 10ms                      // This delay time is necessary
  9.         RES = 1;
  10.         delayms(120); // Delay 1200 ms
  11.     //************* Start Initial Sequence **********//
  12.
  13. WriteCOM(0xCF);
  14. WriteCOM_DATA(0x00);
  15. WriteCOM_DATA(0xC1);
  16. WriteCOM_DATA(0X30);
  17. WriteCOM(0xED);
  18. WriteCOM_DATA(0x64);
  19. WriteCOM_DATA(0x03);
  20. WriteCOM_DATA(0X12);
  21. WriteCOM_DATA(0X81);
  22. WriteCOM(0xE8);
  23. WriteCOM_DATA(0x85);
  24. WriteCOM_DATA(0x00);
  25. WriteCOM_DATA(0x78);
  26. WriteCOM(0xCB);
  27. WriteCOM_DATA(0x39);
  28. WriteCOM_DATA(0x2C);
  29. WriteCOM_DATA(0x00);
  30. WriteCOM_DATA(0x34);
  31. WriteCOM_DATA(0x02);
  32. WriteCOM(0xF7);
  33. WriteCOM_DATA(0x20);
  34. WriteCOM(0xEA);
  35. WriteCOM_DATA(0x00);
  36. WriteCOM_DATA(0x00);
  37. WriteCOM(0xC0);    //Power control
  38. WriteCOM_DATA(0x18);   //VRH[5:0]
  39. WriteCOM(0xC1);    //Power control
  40. WriteCOM_DATA(0x12);   //SAP[2:0];BT[3:0]
  41. WriteCOM(0xC5);    //VCM control
  42. WriteCOM_DATA(0x31);
  43. WriteCOM_DATA(0x3C);
  44. WriteCOM(0xC7);    //VCM control2
  45. WriteCOM_DATA(0X99);
  46. WriteCOM(0x36);    // Memory Access Control
  47. WriteCOM_DATA(0x08);
  48. WriteCOM(0x3A);
  49. WriteCOM_DATA(0x55);
  50. WriteCOM(0xB1);
  51. WriteCOM_DATA(0x00);
  52. WriteCOM_DATA(0x16);
  53. WriteCOM(0xB6);    // Display Function Control
  54. WriteCOM_DATA(0x0A);
  55. WriteCOM_DATA(0xA2);
  56. WriteCOM(0xF6);
  57. WriteCOM_DATA(0x01);
  58. WriteCOM_DATA(0x30);
  59. WriteCOM(0xF2);    // 3Gamma Function Disable
  60. WriteCOM_DATA(0x00);
  61. WriteCOM(0x26);    //Gamma curve selected
  62. WriteCOM_DATA(0x02);
  63. WriteCOM(0xE0);    //Set Gamma
  64. WriteCOM_DATA(0x0F);
  65. WriteCOM_DATA(0x1D);
  66. WriteCOM_DATA(0x1A);
  67. WriteCOM_DATA(0x0A);
  68. WriteCOM_DATA(0x0D);
  69. WriteCOM_DATA(0x07);
  70. WriteCOM_DATA(0x49);
  71. WriteCOM_DATA(0X66);
  72. WriteCOM_DATA(0x3B);
  73. WriteCOM_DATA(0x07);
  74. WriteCOM_DATA(0x11);
  75. WriteCOM_DATA(0x01);
  76. WriteCOM_DATA(0x09);
  77. WriteCOM_DATA(0x05);
  78. WriteCOM_DATA(0x04);
  79. WriteCOM(0XE1);    //Set Gamma
  80. WriteCOM_DATA(0x00);
  81. WriteCOM_DATA(0x18);
  82. WriteCOM_DATA(0x1D);
  83. WriteCOM_DATA(0x02);
  84. WriteCOM_DATA(0x0F);
  85. WriteCOM_DATA(0x04);
  86. WriteCOM_DATA(0x36);
  87. WriteCOM_DATA(0x13);
  88. WriteCOM_DATA(0x4C);
  89. WriteCOM_DATA(0x07);
  90. WriteCOM_DATA(0x13);
  91. WriteCOM_DATA(0x0F);
  92. WriteCOM_DATA(0x2E);
  93. WriteCOM_DATA(0x2F);
  94. WriteCOM_DATA(0x05);
  95. WriteCOM(0x11);    //Exit Sleep
  96. delayms(120);
  97. WriteCOM(0x29);    //Display on
  98. }
  99. /************************************初始化結束**********************************/
ID:112693 發表于 2017-5-4 09:20 | 只看該作者
學習一下
