查看: 2805|回復(fù): 1
430下的SI4432模塊初始化
ID:88321 發(fā)表于 2015-9-1 10:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
// 無線模塊初始化
void RF_init(void)
    SpiWriteRegister(0x07, 0x80);//SW reset  //向0X07地址  寫入0X80  軟件復(fù)位
    while ( RF4432_IRQ == 1); //讀取中斷狀態(tài)          清除中斷  釋放         SI4432_NIRQ
    ItStatus1 = SpiReadRegister(0x03);        //讀取中斷狀態(tài)          清除中斷  釋放         SI4432_NIRQ        //read the Interrupt Status1 register
    ItStatus2 = SpiReadRegister(0x04);        //read the Interrupt Status2 register
    SpiWriteRegister(0x06, 0x80);
    SpiWriteRegister(0x07, 0x01);        //write 0x80 to the Operating & Function Control1 register
    SpiWriteRegister(0x09, 0x64);                //云寶
    //SpiWriteRegister(0x09, 0x7f);     //思為
    SpiWriteRegister(0x0A, 0x05);  //關(guān)閉低頻輸出
    SpiWriteRegister(0x0B, 0xEA);  //GPIO 0 當(dāng)做普通輸出口
    SpiWriteRegister(0x0C, 0xEA);  //GPIO 1 當(dāng)做普通輸出口
    SpiWriteRegister(0x0D, 0xF4);  //GPIO 2 輸出收到的數(shù)據(jù)
    SpiWriteRegister(0x70, 0x24);  //0x2c);  // 下面的設(shè)置根據(jù)Silabs 的Excel
    SpiWriteRegister(0x1D, 0x40);  // 使能 afc
    ///*/ 1.2K bps setting
    SpiWriteRegister(0x1C, 0x16);
    SpiWriteRegister(0x20, 0x83);
        SpiWriteRegister(0x21, 0xc0);  //
        SpiWriteRegister(0x22, 0x13);  //
        SpiWriteRegister(0x23, 0xa9);  //
        SpiWriteRegister(0x24, 0x00);  //
        SpiWriteRegister(0x25, 0x04);  //
        SpiWriteRegister(0x2A, 0x14);// 1.2K bps 發(fā)射速率
        SpiWriteRegister(0x6E, 0x09);
        SpiWriteRegister(0x6F, 0xd5);
        //SI4432_WriteReg(0x70, 0x2c);//
        SpiWriteRegister(0x6D, 0x07);  //07 設(shè)置為最大功率發(fā)射
        SpiWriteRegister(0x0D, 0xFC);  //GPIO 2 信道空閑指示(常態(tài)為低,忙為高)
        SpiWriteRegister(0x79, 0x00);   // 不需要跳頻
        SpiWriteRegister(0x7A, 0x00);   // 不需要跳頻
        SpiWriteRegister(0x71, 0x22);  // 發(fā)射不需要 CLK,F(xiàn)iFo , FSK模式
        SpiWriteRegister(0x72, 0x30);  // 頻偏為 30KHz
        SpiWriteRegister(0x73, 0x00);   // 沒有頻率偏差
        SpiWriteRegister(0x74, 0x00);   // 沒有頻率偏差
        //SpiWriteRegister(0x75, 0x53);  // 頻率設(shè)置 433.5
        //SpiWriteRegister(0x76, 0x57);  //
        //SpiWriteRegister(0x77, 0x80);
        SpiWriteRegister(0x75, 0x60);  // 頻率設(shè)置 490
        SpiWriteRegister(0x76, 0x7d);  //
        SpiWriteRegister(0x77, 0x00);
        /*set the packet structure and the modulation type*/
        //set the preamble length to 10bytes
        SpiWriteRegister(0x34, 0x0C);        //write 0x0A to the Preamble Length register
        //set preamble detection threshold to 20bits
        SpiWriteRegister(0x35, 0x2A);        //write 0x2A to the Preamble Detection Control  register
        //Disable header bytes; set variable packet length (the length of the payload is defined by the
        //received packet length field of the packet); set the synch word to two bytes long
        SpiWriteRegister(0x33, 0x02);        //write 0x02 to the Header Control2 register
        //Set the sync word pattern to 0x2DD4
        SpiWriteRegister(0x36, 0x2D);        //write 0x2D to the Sync Word 3 register
        SpiWriteRegister(0x37, 0xD4);        //write 0xD4 to the Sync Word 2 register
        //enable the TX & RX packet handler and CRC-16 (IBM) check
        SpiWriteRegister(0x30, 0x8D);        //write 0x8D to the Data Access Control register
        //Disable the receive header filters
        SpiWriteRegister(0x32, 0x00);
        /*enable receiver chain*/
        SpiWriteRegister(0x07, 0x05);        //打開接收        //write 0x05 to the Operating Function Control 1 register
        //Enable two interrupts:
        // a) one which shows that a valid packet received: 'ipkval'
        // b) second shows if the packet received with incorrect CRC: 'icrcerror'
        SpiWriteRegister(0x05, 0x03);         //打開 接收中斷        //write 0x03 to the Interrupt Enable 1 register
        SpiWriteRegister(0x06, 0x00);        //write 0x00 to the Interrupt Enable 2 register
        //read interrupt status registers to release all pending interrupts
        ItStatus1 = SpiReadRegister(0x03);        //read the Interrupt Status1 register
ID:136504 發(fā)表于 2016-9-7 16:09 | 只看該作者
HW3000國產(chǎn)第一家433無線模塊,完美替換si4432,4463.cc1101。一不小心就省了一輛寶馬的錢。咨詢電話:13570852936;
