查看: 5522|回復: 6
光立方程序
ID:88367 發表于 2015-8-16 11:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <REG52.H>
#include <intrins.h>
uchar display[8][8];
/*rank:A,1,2,3,4,I,心,U*/
uchar code table_cha[8][8]={0x51,0x51,0x51,0x4a,0x4a,0x4a,0x44,0x44,0x18,0x1c,0x18,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0x66,0x30,0x18,0xc,0x6,0xf6,0x3c,0x66,0x60,0x38,0x60,0x60,0x66,0x3c,0x30,0x38,0x3c,0x3e,0x36,0x7e,0x30,0x30,0x3c,0x3c,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0xff,0xff,0xff,0x7e,0x3c,0x18,0x18,0x66,0x66,0x66,0x66,0x66,0x66,0x7e,0x3c};
/*the "ideasoft"*/
uchar code table_id[40]={0x81,0xff,0x81,0x00,0xff,0x81,0x81,0x7e,0x00,0xff,0x89,0x89,0x00,0xf8,0x27,0x27,0xf8,0x00,0x8f,0x89,0x89,0xf9,0x00,0xff,0x81,0x81,0xff,0x00,0xff,0x09,0x09,0x09,0x01,0x0,0x01,0x01,0xff,0x01,0x01,0x00};
/*railway*/
uchar code dat[128]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x6f,0x8f,0x93,0x73,0x6f,0x8f,0x93,0x73,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
/*railway 2*/
uchar code dat2[28]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
/*railway 3*/
uchar code dat3[24]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x16,0x26,0x36,0x46,0x56,0x66,0x65,0x64,0x63,0x62,0x61,0x60,0x50,0x40,0x30,0x20,0x10};
/*3p char*/
uchar code table_3p[3][8]={0xff,0x89,0xf5,0x93,0x93,0xf5,0x89,0xff,0x0e,0x1f,0x3f,0x7e,0x7e,0x3f,0x1f,0x0e,0x18,0x3c,0x7e,0xff,0x18,0x18,0x18,0x18};
/*initializtion
That is to initialize the program .
It is write to set the timer in c52 mcu.
So the program can renovate the led_3d_cube in fixed time use the interrupt function.*/
void sinter()
         IE=0x82;
         TCON=0x01;
         TH0=0xc0;
         TL0=0;
         TR0=1;
void delay5us(void)   //誤差 -0.026765046296us STC 1T 22.1184Mhz
    unsigned char a,b;
    for(b=7;b>0;b--)
        for(a=2;a>0;a--);
void delay(uint i)
         while (i--){
                 delay5us();}//12t的mcu 注釋這個延時即可
/*To judge the num bit*/
uchar judgebit(uchar num,uchar b)
         char n;
         num=num&(1<<b);
         if (num)
         n=1;
         n=0;
         return n;
/*To figure out the round number*/
uchar abs(uchar a)
         uchar b;
         b=a/10;
         a=a-b*10;
         if (a>=5)
         b++;
         return b;
/*To figure out the absolute value*/
uchar abss(char a)
         if (a<0)
         a=-a;
         return a;
/*The function can comparat the character.
And remove the big one to the back.*/
void max(uchar *a,uchar *b)
   uchar t;
   if ((*a)>(*b))
                   t=(*a);
                   (*a)=(*b);
                   (*b)=t;
/*The function is to figure out the max number and return it.*/
uchar maxt(uchar a,uchar b,uchar c)
         if (a<b)
         a=b;
         if (a<c)
         a=c;
         return a;
void clear(char le)
         uchar i,j;
         for (j=0;j<8;j++)
                   for (i=0;i<8;i++)
                   display[j][i]=le;
void trailler(uint speed)
         char i,j;
         for (i=6;i>=-3;i--)
                   if (i>=0)
                            for (j=0;j<8;j++)
                            display[j][i]=display[j][i+1];
                   if (i<4)
                            for (j=0;j<8;j++)
                            display[j][i+4]=0;
                   delay(speed);
void point(uchar x,uchar y,uchar z,uchar le)
         uchar ch1,ch0;
         ch1=1<<x;
         ch0=~ch1;
         if (le)
         display[z][y]=display[z][y]|ch1;
         display[z][y]=display[z][y]&ch0;
void type(uchar cha,uchar y)
         uchar xx;
         for (xx=0;xx<8;xx++)
         display[xx][y]=table_cha[cha][xx];
/*The first variable is the distance from the midpoint.
The second is the layer.
the third is the flash speed of the time between each two point.
The forth is the enable io,it controls weather draw or claen.*/
void cirp(char cpp,uchar dir,uchar le)
         uchar a,b,c,cp;
         if ((cpp<128)&(cpp>=0))
                   if (dir)
                   cp=127-cpp;
                   cp=cpp;
                   a=(dat[cp]>>5)&0x07;
                   b=(dat[cp]>>2)&0x07;
                   c=dat[cp]&0x03;
                   if (cpp>63)
                   c=7-c;
                   point (a,b,c,le);
void line(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar le)
         char t,a,b,c,a1,b1,c1,i;
         a1=x2-x1;
         b1=y2-y1;
         c1=z2-z1;
         t=maxt(abss(a1),abss(b1),abss(c1));
         a=x1*10;
         b=y1*10;
         c=z1*10;
         a1=a1*10/t;
         b1=b1*10/t;
         c1=c1*10/t;
         for (i=0;i<t;i++)
                   point(abs(a),abs(b),abs(c),le);
                   a+=a1;
                   b+=b1;
                   c+=c1;
         point(x2,y2,z2,le);
void box(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
         uchar i,j,t=0;
         max(&x1,&x2);
         max(&y1,&y2);
         max(&z1,&z2);
         for (i=x1;i<=x2;i++)
                   t|=1<<i;
         if (!le)
                   t=~t;
         if (fill)
                   if (le)
                            for (i=z1;i<=z2;i++)
                                     for (j=y1;j<=y2;j++)
                                               display[j][i]|=t;
                                               display[j][i]&=t;
                   if (le)
                            display[y1][z1]|=t;
                            display[y2][z1]|=t;
                            display[y1][z2]|=t;
                            display[y2][z2]|=t;
                           display[y1][z1]&=t;
                            display[y2][z1]&=t;
                            display[y1][z2]&=t;
                            display[y2][z2]&=t;
                   t=(0x01<<x1)|(0x01<<x2);
                   if (!le)
                            t=~t;
                   if (le)
                            for (j=z1;j<=z2;j+=(z2-z1))
                                     for (i=y1;i<=y2;i++)
                                               display[i][j]|=t;
                            for (j=y1;j<=y2;j+=(y2-y1))
                                               display[j][i]|=t;
                                     display[i][j]&=t;
                                     display[j][i]&=t;
void box_apeak_xy(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
         uchar i;
         max(&z1,&z2);
         if (fill)
                            line (x1,y1,i,x2,y2,i,le);
                   line (x1,y1,z1,x2,y2,z1,le);
                   line (x1,y1,z2,x2,y2,z2,le);
                   line (x2,y2,z1,x2,y2,z2,le);
                   line (x1,y1,z1,x1,y1,z2,le);
void poke(uchar n,uchar x,uchar y)
         uchar i;
         for (i=0;i<8;i++)
          point(x,y,i,judgebit(n,i));
void boxtola(char i,uchar n)
         if ((i>=0)&(i<8))
                   poke(n,0,7-i);
         if ((i>=8)&(i<16))
                   poke(n,i-8,0);
         if ((i>=16)&(i<24))
                   poke(n,7,i-16);
void rolldisplay(uint speed)
         uchar j;
         char i,a;
         for (i=23;i>-40;i--)
                   for (j=0;j<40;j++)
                            a=i+j;
                            if ((a>=0)&(a<24))
                            boxtola(a,table_id[j]);
                   delay(speed);
void roll_apeak_yz(uchar n,uint speed)
         uchar i;
         switch(n)
                   case 1:
                            for (i=0;i<7;i++)
                                     display[i][7]=0;
                                     display[7][6-i]=255;
                                     delay(speed);
                            break;
                   case 2:
                            for (i=0;i<7;i++)
                                     display[7][7-i]=0;
                                     display[6-i][0]=255;
                                     delay(speed);
                            break;
                   case 3:
                            for (i=0;i<7;i++)
                                     display[7-i][0]=0;
                                     display[0][i+1]=255;
                                     delay(speed);
                            break;
                   case 0:
                            for (i=0;i<7;i++)
                                     display[0][i]=0;
                                     display[i+1][7]=255;
                                     delay(speed);
void roll_apeak_xy(uchar n,uint speed)
         uchar i;
         switch(n)
                   case 1:
                            for (i=0;i<7;i++)
                                     line(0,i,0,0,i,7,0);
                                     line(i+1,7,0,i+1,7,7,1);
                                     delay(speed);
                            break;
                   case 2:
                            for (i=0;i<7;i++)
                                     line(i,7,0,i,7,7,0);
                                     line(7,6-i,0,7,6-i,7,1);
                                     delay(speed);
                            break;
                   case 3:
                            for (i=0;i<7;i++)
                                     line(7,7-i,0,7,7-i,7,0);
                                     line(6-i,0,0,6-i,0,7,1);
                                     delay(speed);
                            break;
                   case 0:
                            for (i=0;i<7;i++)
                                     line(7-i,0,0,7-i,0,7,0);
                                     line(0,i+1,0,0,i+1,7,1);
                                     delay(speed);
void roll_3_xy(uchar n,uint speed)
         uchar i;
         switch(n)
                   case 1:
                            for (i=0;i<8;i++)
                                     box_apeak_xy (0,i,0,7,7-i,7,1,1);
                                     delay(speed);
                                     if (i<7)
                                     box_apeak_xy (3,3,0,0,i,7,1,0);
                            break;
                   case 2:
                            for (i=0;i<8;i++)
                                      box_apeak_xy (7-i,0,0,i,7,7,1,1);
                                     delay(speed);
                                     if (i<7)
                                     box_apeak_xy (3,4,0,i,7,7,1,0);
                            break;
                   case 3:
                            for (i=0;i<8;i++)
                                     delay(speed);
                                     if (i<7)
                                     box_apeak_xy (4,4,0,7,7-i,7,1,0);
                            break;
                   case 0:
                            for (i=0;i<8;i++)
                                     delay(speed);
                                     if (i<7)
                                     box_apeak_xy (4,3,0,7-i,0,7,1,0);
void trans(uchar z,uint speed)
         uchar i,j;
         for (j=0;j<8;j++)
                   for (i=0;i<8;i++)
                            display[z][i]>>=1;
                   delay(speed);
void tranoutchar(uchar c,uint speed)
         uchar i,j,k,a,i2=0;
         for (i=0;i<8;i++)
                   if (i<7)
                   box_apeak_xy (i+1,0,0,i+1,7,7,1,1);
                   box_apeak_xy (i2,0,0,i2,7,7,1,0);
                   a=0;
                   i2=i+1;
                   for (j=0;j<=i;j++)
                            a=a|(1<<j);
                   for (k=0;k<8;k++)
                            display[k][3]|=table_cha[c][k]&a;
                            display[k][4]|=table_cha[c][k]&a;
                   delay(speed);
void transss()
         uchar i,j;
         for (i=0;i<8;i++)
                   for (j=0;j<8;j++)
                   display[i][j]<<=1;
/*From now on,the function below is to display the flash.*/
void flash_1()
         clear(0);
         type(1,0);
         delay(60000);
         type(2,0);
         delay(60000);
         type(3,0);
         delay(60000);
         type(4,0);
         delay(60000);
         delay(60000);
         clear(0);
         rolldisplay(30000);
         type(0,7);
         delay(60000);
         trailler(6000);
         delay(60000);
void flash_2()
         uchar i;
         for (i=129;i>0;i--)
                   cirp(i-2,0,1);
                   delay(8000);
                   cirp(i-1,0,0);
         delay(8000);
         for (i=0;i<136;i++)
                   cirp(i,1,1);
                   delay(8000);
                   cirp(i-8,1,0);
         delay(8000);
                  for (i=129;i>0;i--)
                   cirp(i-2,0,1);
                   delay(8000);
         delay(8000);
                   for (i=0;i<128;i++)
                   cirp(i-8,1,0);
                   delay(8000);
         delay(60000);
void flash_3()
         char i;
         for (i=0;i<8;i++)
                   box_apeak_xy(0,i,0,7,i,7,1,1);
                   delay(20000);
                   if (i<7)
                   box_apeak_xy(0,i,0,7,i,7,1,0);
         for (i=7;i>=0;i--)
                   delay(20000);
                   if (i>0)
         for (i=0;i<8;i++)
                   delay(20000);
                   if (i<7)
void flash_4()
         char i,j,an[8];
         for (j=7;j<15;j++)
                   an[j-7]=j;
         for (i=0;i<=16;i++)
                   for (j=0;j<8;j++)
                            if ((an[j]<8)&(an[j]>=0))
                            line(0,an[j],j,7,an[j],j,1);
                   for (j=0;j<8;j++)
                            if (((an[j]+1)<8)&(an[j]>=0))
                            line(0,an[j]+1,j,7,an[j]+1,j,0);
                   for (j=0;j<8;j++)
                            if (an[j]>0)
                            an[j]--;
                   delay(15000);
         for (j=0;j<8;j++)
                   an[j]=1-j;
         for (i=0;i<=16;i++)
                   for (j=0;j<8;j++)
                   for (j=0;j<8;j++)
                            if (((an[j]-1)<7)&(an[j]>0))
                            line(0,an[j]-1,j,7,an[j]-1,j,0);
                   for (j=0;j<8;j++)
                            if (an[j]<7)
                            an[j]++;
                   delay(15000);
void flash_5()
         uint a=15000;//a=delay
         char i=8,j,an[4];
         //1
         for (j=7;j<11;j++)
                   an[j-7]=j;
         while(i--)
                   for (j=0;j<4;j++)
                            if (an[j]<8)
                            box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1);
                            if (an[j]<7)
                            box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0);
                   for (j=0;j<4;j++)
                            if (an[j]>3)
                            an[j]--;
                   delay(a);
         //2
         i=3;
         for (j=0;j<4;j++)
         an[j]=5-j;
         while(i--)
                   for (j=1;j<4;j++)
                            if (an[j]<4)
                            if (an[j]<3)
                   for (j=0;j<4;j++)
                            if (an[j]>0)
                            an[j]--;
                   delay(a);
         //3
         i=3;
         for (j=1;j<4;j++)
         an[j]=4-j;
         while(i--)
                   for (j=1;j<4;j++)
                            if (an[j]>=0)
                            if (an[j]>0)
                            box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0);
                   for (j=1;j<4;j++)
                            if (an[j]<3)
                            an[j]++;
                   delay(a);
         //4
         i=3;
         for (j=0;j<4;j++)
         an[j]=j+1;
         while(i--)
                   for (j=1;j<4;j++)
                            if (an[j]>3)
                            if (an[j]>3)
                   for (j=0;j<4;j++)
                            an[j]++;
                   delay(a);
         //5
         i=3;
         for (j=3;j<6;j++)
                   an[j-2]=j;
         while(i--)
                   for (j=1;j<4;j++)
                   for (j=0;j<4;j++)
                            if (an[j]>3)
                            an[j]--;
                   delay(a);
         //6
         i=3;
         for (j=0;j<4;j++)
         an[j]=5-j;
         while(i--)
                   for (j=1;j<4;j++)
                            if (an[j]<4)
                            if (an[j]<3)
                   for (j=0;j<4;j++)
                            if (an[j]>0)
                            an[j]--;
                   delay(a);
         //7
         i=3;
         for (j=0;j<4;j++)
         an[j]=3-j;
         an[0]=2;
         while(i--)
                   for (j=0;j<3;j++)
                            if (an[j]>=0)
                            if (an[j]>=0)
                   for (j=0;j<4;j++)
                            if (j<5-i)
                            an[j]--;
                   delay(a);
         //8
         i=10;
         for (j=0;j<4;j++)
                   an[j]=j-2;
         while(i--)
                   for (j=0;j<4;j++)
                            if (an[j]>=0)
                            if (an[j]>=0)
                   for (j=0;j<4;j++)
                            if (an[j]<7)
                            an[j]++;
                   delay(a);
void flash_6()
      uchar i,j,k,z;
      roll_apeak_yz(1,10000);
      roll_apeak_yz(2,10000);
      roll_apeak_yz(3,10000);
      roll_apeak_yz(0,10000);
      for (i=0;i<3;i++)
                         for (j=0;j<8;j++)
                                  for (k=0;k<8;k++)
                                           if ((table_3p[i][j]>>k)&1)
                                                     for (z=1;z<8;z++)
        point (j,7-k,z,1);
        if (z-1)
        point (j,7-k,z-1,0);
        delay(5000);
                         trans(7,15000);
void flash_7()
      uchar i;
      uint a=3000;
      roll_apeak_xy(0,10000);
      roll_apeak_xy(1,10000);
      roll_apeak_xy(2,10000);
      roll_apeak_xy(3,10000);
      for (i=0;i<8;i++)
               box_apeak_xy (0,i,0,7-i,i,7,1,1);
               delay(a);
      delay(30000);
      roll_3_xy(0,a);
      delay(30000);
      roll_3_xy(1,a);
      delay(30000);
      roll_3_xy(2,a);
      delay(30000);
      roll_3_xy(3,a);
      delay(30000);
      roll_3_xy(0,a);
      delay(30000);
      roll_3_xy(1,a);
      delay(30000);
      roll_3_xy(2,a);
      delay(30000);
      roll_3_xy(3,a);
      for (i=7;i>0;i--)
               box_apeak_xy(i,0,0,i,7,7,1,0);
               delay(a);
void flash_8()
      uchar i;
      for (i=5;i<8;i++)
               tranoutchar(i,10000);
               delay(60000);
               delay(60000);
void flash_9()
      char i;
      uchar j,an[8],x,y,t,x1,y1;
      for (i=0;i<8;i++)
               box_apeak_xy (i,0,0,i,7,7,1,1);
               if (i)
               box_apeak_xy (i-1,0,0,i-1,7,7,1,0);
               delay(10000);
      for (i=0;i<7;i++)
               line(6-i,6-i,0,6-i,6-i,7,1);
               delay(10000);
      for (i=0;i<8;i++)
               an[i]=14;
      for (i=0;i<85;i++)
               clear(0);
               for (j=0;j<8;j++)
                         t=an[j]%28;
                         x=dat2[t]>>5;
                         y=(dat2[t]>>2)&0x07;
                         t=(an[j]-14)%28;
                         x1=dat2[t]>>5;
                         y1=(dat2[t]>>2)&0x07;
                         line(x,y,j,x1,y1,j,1);
               for (j=0;j<8;j++)
               if ((i>j)&(j>i-71))
               an[j]++;
               delay(5000);
      for (i=0;i<85;i++)
               clear(0);
               for (j=0;j<8;j++)
                         t=an[j]%28;
                         x=dat2[t]>>5;
                         t=(an[j]-14)%28;
                         x1=dat2[t]>>5;
               for (j=0;j<8;j++)
               if ((i>j)&(j>i-71))
               an[j]--;
               delay(5000);
      for (i=0;i<29;i++)
               clear(0);
               t=an[0]%28;
               x=dat2[t]>>5;
               t=(an[0]-14)%28;
               x1=dat2[t]>>5;
               box_apeak_xy(x,y,0,x1,y1,7,0,1);
               box_apeak_xy(x,y,1,x1,y1,6,0,1);
               an[0]++;
               delay(5000);
      for (i=0;i<16;i++)
               clear(0);
               t=an[0]%28;
               x=dat2[t]>>5;
               t=(an[0]-14)%28;
               x1=dat2[t]>>5;
               box_apeak_xy(x,y,0,x1,y1,7,1,1);
               an[0]--;
               delay(5000);
      for (i=0;i<8;i++)
               line(i,i,0,0,0,i,0);
               delay(5000);
      for (i=1;i<7;i++)
               line(i,i,7,7,7,i,0);
               delay(5000);
      for (i=1;i<8;i++)
               clear(0);
               box(7,7,7,7-i,7-i,7-i,0,1);
               delay(10000);
      for (i=1;i<7;i++)
               clear(0);
               box(0,0,0,7-i,7-i,7-i,0,1);
               delay(10000);
      for (i=1;i<8;i++)
               clear(0);
               box(0,0,0,i,i,i,0,1);
               delay(10000);
      for (i=1;i<7;i++)
               clear(0);
               box(7,0,0,i,7-i,7-i,0,1);
               delay(10000);
      for (i=1;i<8;i++)
               box(7,0,0,7-i,i,i,1,1);
               delay(10000);
      for (i=1;i<7;i++)
               clear(0);
               box(0,7,7,7-i,i,i,1,1);
               delay(10000);
void flash_10()
      uchar i,j,an[4],x,y,t;
      for (i=1;i<7;i++)
               clear(0);
               box(0,6,6,1,7,7,1,1);
               box(i,6,6-i,i+1,7,7-i,1,1);
               box(i,6,6,i+1,7,7,1,1);
               box(0,6,6-i,1,7,7-i,1,1);
               box(0,6-i,6,1,7-i,7,1,1);
               box(i,6-i,6-i,i+1,7-i,7-i,1,1);
               box(i,6-i,6,i+1,7-i,7,1,1);
               box(0,6-i,6-i,1,7-i,7-i,1,1);
               delay(30000);
      for (i=0;i<4;i++)
               an[i]=6*i;
      for (i=0;i<35;i++)
               clear(0);
               for(j=0;j<4;j++)
                         t=an[j]%24;
                         x=dat3[t]>>4;
                         y=dat3[t]&0x0f;
                         box(x,y,0,x+1,y+1,1,1,1);
                         box(x,y,6,x+1,y+1,7,1,1);
               for (j=0;j<4;j++)
               an[j]++;
               delay(10000);
      for (i=0;i<35;i++)
               clear(0);
               for(j=0;j<4;j++)
                         t=an[j]%24;
                         x=dat3[t]>>4;
                         y=dat3[t]&0x0f;
               for (j=0;j<4;j++)
               an[j]--;
               delay(10000);
      for (i=0;i<35;i++)
               clear(0);
               for(j=0;j<4;j++)
                         t=an[j]%24;
                         x=dat3[t]>>4;
                         y=dat3[t]&0x0f;
                         box(x,0,y,x+1,1,y+1,1,1);
                         box(x,6,y,x+1,7,y+1,1,1);
               for (j=0;j<4;j++)
               an[j]++;
               delay(10000);
      for (i=0;i<36;i++)
               clear(0);
               for(j=0;j<4;j++)
                         t=an[j]%24;
                         x=dat3[t]>>4;
                         y=dat3[t]&0x0f;
               for (j=0;j<4;j++)
               an[j]--;
               delay(10000);
      for (i=6;i>0;i--)
               clear(0);
               delay(30000);
void flash_11()
      uchar i,j,t,x,y;
      uchar code daa[13]={0,1,2,0x23,5,6,7,6,5,0x23,2,1,0};
      for (j=0;j<5;j++)
               for (i=0;i<13;i++)
                         if (daa[i]>>4)
                                  t=daa[i]&0x0f;
                                  line (0,0,t+1,0,7,t+1,1);
                                  t=daa[i];
                         line (0,0,t,0,7,t,1);
                         transss();
                         delay(10000);
      for (j=1;j<8;j++)
               if (j>3)
                         t=4;
                         t=j;
               for (i=0;i<24;i+=j)
                         x=dat3[i]>>4;
                         y=dat3[i]&0x0f;
                         box_apeak_xy(0,x,y,0,x+1,y+1,1,1);
                         transss();
                         delay(10000);
      for (j=1;j<8;j++)
               if (j>3)
                         t=4;
                         t=j;
               for (i=0;i<24;i+=j)
                         x=dat3[i]>>4;
                         y=dat3[i]&0x0f;
                         point (0,x,y,1);
                         transss();
                         delay(10000);
         sinter();
                 while(1){
        // clear(0);
         /*play list*/
         //flash_1();
         clear(0);
         flash_2();
         flash_3();
         flash_4();
         flash_4();
         flash_5();
      flash_5();
      flash_6();
      flash_7();
      flash_8();
      flash_9();
      flash_10();
      clear (0);
      flash_11();
      flash_9();
      flash_5();
      flash_7();
      flash_5();
      flash_6();
      flash_8();
      flash_9();
      flash_10();
//P0;   //573 in
//P1;  //uln2803
//P2;  //573 LE
void print() interrupt 1
         uchar i;
         static uchar layer=0;
         P1=0;
         for (i=0;i<8;i++)
                   P2=1<<i;
                   delay(3);
                   P0=display[layer][i];
                   delay(3);
         P1=1<<layer;
         if (layer<7)
                   layer++;
                   layer=0;
         TH0=0xc0;
         TL0=0;
參與人數 1黑幣 +5 收起 理由
渡客維2 + 5 很給力!
ID:88367 發表于 2015-8-16 11:51 | 只看該作者
希望對各位學習光立方的有用!
ID:79544 發表于 2015-9-27 23:23 | 只看該作者
謝謝分享,分享是快樂的!
ID:167196 發表于 2017-2-28 17:57 | 只看該作者
謝謝樓主
ID:167196 發表于 2017-2-28 17:58 | 只看該作者
謝謝樓主
ID:167286 發表于 2017-2-28 23:36 來自觸屏版 | 只看該作者
有實物連接圖嗎,驅動ic型號什么
ID:223039 發表于 2017-7-28 17:26 | 只看該作者
謝謝啦,真棒
