查看: 8534|回復: 0
stm32外部按鍵中斷程序源碼
ID:86860 發表于 2015-7-26 02:18 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "stm32f10x.h"
unsigned intTimingDelay;
void Delay(unsigned intx)
TimingDelay=x;
while(TimingDelay--);
void EXTI9_5_IRQHandler(void)//中斷處理函數
  unsigned inttt;
tt=6553500;
if(EXTI_GetITStatus(EXTI_Line5)!=RESET)
GPIO_SetBits(GPIOC,GPIO_Pin_7);
while(tt--);
GPIO_ResetBits(GPIOC,GPIO_Pin_7);
while(tt--);
EXTI_ClearFlag(EXTI_Line5);//清除中斷標志
EXTI_ClearITPendingBit(EXTI_Line5);//清除EXTI線路掛起位
int main(void)
//配置IO口
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD| RCC_APB2Periph_GPIOE,ENABLE);//IO口使能設置
  GPIO_InitTypeDefGPIO_InitStructure;   //定義結構體
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOC,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;  //設置為上拉輸入
  GPIO_Init(GPIOE,&GPIO_InitStructure);
//配置外部中斷控制器
  EXTI_InitTypeDef EXTI_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//使能時鐘
EXTI_InitStructure.EXTI_Line = EXTI_Line5; //使用IO口5作為中斷口
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; //設置EXTI線路為中斷請求
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;//下降沿觸發
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
GPIO_EXTILineConfig(GPIO_PortSourceGPIOE,GPIO_PinSource5);//將PE5掛接到EXTI9_5_IRQn中斷源上
//配置中斷控制器
  NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);//選擇中斷組0
NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;//指定中斷源,0-4管腳屬于EXTI0_IRQn~EXTI4_IRQn,5-9管腳屬于EXTI9_5_IRQn,10-15管腳屬于EXTI15_10_IRQn
//NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =3;
NVIC_InitStructure.NVIC_IRQChannelSubPriority =1;//無先占優先級,從優先級為1
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
while(1);
//以下是報錯函數
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file,uint32_t line)
#endif
