查看: 3295|回復: 0
帶字庫的lcd12864液晶驅動c51程序
ID:83710 發表于 2015-6-23 23:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include<stdlib.h>
#include<intrins.h>
uchar xian,flag;
uint time=0;
#define Lcd_data P0
sbit RS  =  P2^6;             //(數據命令)寄存器選擇輸入
sbit RW  =  P2^5;             //液晶讀/寫控制
sbit EN  =  P2^7;             //液晶使能控制
sbit PSB =  P3^2;             //串/并方式控制
uchar code dis1[]={"    長恨歌    "};
uchar code dis2[]={"在天愿作比翼鳥"};
uchar code        dis3[]={"在地愿為連理枝"};
uchar code dis4[]={"自古多情空余恨"};
uchar code dis5[]={"此恨綿綿無絕期"};
void delay(uint x)
    uint i,j;
        for(i=x;i>0;i--)
           for(j=110;j>0;j--);
//寫指令到LCD
void write_com(uchar com)
        RS=0;
        RW=0;
        EN=0;
        P0=com;
        delay(1);
        EN=1;
        delay(1);
        EN=0;
//寫指令到LCD
void write_data(uchar dat)
         RS=1;
         RW=0;
         EN=0;
         P0=dat;
         delay(1);
         EN=1;
         delay(1);
         EN=0;
void lcd_pos(uchar X,uchar Y)
     uchar pos;
         if(X==0)X=0x80;
         else if(X==1)X=0x90;
         else if(X==2)X=0x88;
         else if(X==3)X=0x98;
         pos=X+Y;
         write_com(pos);
void display(uchar p[],uchar a)
     uchar*display1;
     display1=p;
         lcd_pos(a,0);
     while((*display1)!='\0')
                 write_data(*display1);
                 display1++;
void init()
      TMOD=0x02;
          EA=1;
          ET0=1;
          TH0=6;
          TL0=6;
      TR0=1;
          time=0;
          xian=0;
void lcd_init()
    PSB=1;//并口方式
        write_com(0x30); //設置8位數據
        delay(5);
        write_com(0x0c);//顯示開,光標關
        delay(5);
        write_com(0x01); //清除顯示內容
        delay(5);
main()
         init();
         delay(10);
         lcd_init();
                 switch(xian)
                            case 0:display(dis1,0); break;
                                case 1:display(dis2,1); break;
                                case 2:display(dis3,2); break;
                                case 3:display(dis4,3); break;
                                case 4:display(dis5,0); break;goto a;
                                default:break;
        a:
        while(1);
void timer0() interrupt 1
      time++;
          if(time==4000)
              time=0;
                  xian++;
              if(xian==5)xian=0;
