- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar xdata tab[512];
- sbit p1_7=P1^7;
- sbit CS=P2^0; //片選信號(低電平有效)
- sbit DATEIN =P2^1;//主-從數據輸入
- sbit SCLK=P2^2;//時鐘信號
- sbit DATEOUT=P2^3;//從-主數據輸出
- unsigned char bdata dat;
- sbit dat_0=dat^0;
- sbit dat_1=dat^1;
- sbit dat_2=dat^2;
- sbit dat_3=dat^3;
- sbit dat_4=dat^4;
- sbit dat_5=dat^5;
- sbit dat_6=dat^6;
- sbit dat_7=dat^7;
- bit is_init;//決定是否延時;
- uchar lpp;
- unsigned char fhz;//返回值
- uchar fhz_buff; //讀返回值中間量
- //unsigned char xdata tab[512];
- ///*******************以上是SD卡
- VS1003mp3模塊的接口定義
- sbit XRST=P1^0;//復位
- sbit DREQ=P1^1; //數據請求
- sbit XDCS=P1^2; //數據片選
- sbit XCS=P1^3; //命令片選
- /* VS1003mp3SPI通信接口定義
- sbit SCK=P1^4; //時鐘
- sbit SI=P1^5; //串行輸入
- sbit SO=P1^6; //串行輸出
- void delay(uint time)
- { while(time)
- time--;
- unsigned char bdata datmp3;
- sbit datmp3_0=datmp3^0;
- sbit datmp3_1=datmp3^1;
- sbit datmp3_2=datmp3^2;
- sbit datmp3_3=datmp3^3;
- sbit datmp3_4=datmp3^4;
- sbit datmp3_5=datmp3^5;
- sbit datmp3_6=datmp3^6;
- sbit datmp3_7=datmp3^7;
- ///*************************************以下是MP3模塊的程序
- void delay1ms(uint j)//延時100us
- {unsigned char i;
- for(i=j;i;i--)
- void spi_write_mp3_1(uchar h)//SPI寫入一個字節,這里是最底層的數據發送!
- datmp3=h;
- SI=datmp3_7;
- //為了進一步提高速度我這里采用了順序結構!全是斷橋殘雪惹的禍!第一次愛的人播放正常!而斷橋殘雪不行了!一定盡全力
- SCK=0; //從SD讀取和MP3寫數據流下手
- SCK=1;
- SI=datmp3_6;
- SCK=0;
- SCK=1;
- SI=datmp3_5;
- SCK=0;
- SCK=1;
- SI=datmp3_4;
- SCK=0;
- SCK=1;
- SI=datmp3_3;
- SCK=0;
- SCK=1;
- SI=datmp3_2;
- SCK=0;
- SCK=1;
- SI=datmp3_1;
- SCK=0;
- SCK=1;
- SI=datmp3_0;
- SCK=0;
- SCK=1;
- /*uchar spi_read_mp3()// SPI讀取一個字節
- uchar i,read;
- for(i=8;i;i--)
- SCLK=1;
- delay();
- SCLK=0;
- delay();
- read=SO&0x80;
- read=(read<<1);
- SCLK=1;
- return (read);
- void write_comd_mp3(uchar add,uint date)//寫入控制命令add地址date是數據注意這里是16位的數據,內部做分開了處理
- uchar h,l;
- l=date;
- h=(date>>8);
- DREQ=1;
- while(!DREQ); //檢測MP3模塊的忙狀態
- XCS=0;
- spi_write_mp3_1(2); //表示寫操作
- spi_write_mp3_1(add);
- spi_write_mp3_1(h); //先寫高8位
- spi_write_mp3_1(l);
- XCS=1;
- void write_date_mp3(uchar dat)//寫入音頻數據信息這里還有一點是XDCS在此函數外拉低
- DREQ=1;
- while(!DREQ);
- datmp3=dat;
- SI=datmp3_7;
- SCK=1;
- SI=datmp3_6;
- SCK=0;
- SCK=1;
- SI=datmp3_5;
- SCK=0;
- SCK=1;
- SI=datmp3_4;
- SCK=0;
- SCK=1;
- SI=datmp3_3;
- SCK=0;
- SCK=1;
- SI=datmp3_2;
- SCK=0;
- SCK=1;
- SI=datmp3_1;
- SCK=0;
- SCK=1;
- SI=datmp3_0;
- SCK=0;
- SCK=1;
- void init_mp3() //初始化vs1003
- XRST=1;
- delay1ms(100);
- XRST=0;
- delay1ms(100);
- XRST=1;
- delay1ms(100);
- write_comd_mp3(0x00,0x0804);//模式設置
- write_comd_mp3(0x03,0x9800);//時鐘控制
- write_comd_mp3(0x0b,15000);//聲音音量控制 00是最大的!!!!!這里也是十六位的!
- XDCS=0;//數據片選
- spi_write_mp3_1(0);
- XDCS=1;
- void sing(uchar fhz)//正選測試
- write_comd_mp3(0x00,0x0820);
- DREQ=1;
- while(!DREQ);
- XDCS=0;
- write_date_mp3(0x53);
- write_date_mp3(0xef);
- write_date_mp3(0x6e);//正選測試開啟
- write_date_mp3(fhz); //頻率選擇
- write_date_mp3(0);
- delay1ms(60000);
- write_date_mp3(0x45); //正選關段
- write_date_mp3(0x78);
- write_date_mp3(0x69);
- write_date_mp3(0x74);
- XDCS=1;
- //以上是MP3程序
- /*讀sd卡子程序,無返回值,有參函數,參數為要寫入DATEIN數據線的字節*/
- void write(unsigned char wr_)// 寫入一個字節SD卡
- dat=wr_;
- DATEIN=dat_7;
- SCLK=0;
- if(is_init)delay(200);
- //if(!is_init)delay(1);
- SCLK=1;
- if(is_init) delay(200);
- // if(!is_init)delay(1);
- DATEIN=dat_6;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_5;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_4;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_3;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_2;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_1;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_0;
- SCLK=0;
- SCLK=1;
- unsigned char read()// 讀取一個字節SD卡
- DATEOUT=1;
- SCLK=1;
- SCLK=0;
- dat_7=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_6=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_5=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_4=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_3=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_2=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_1=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_0=DATEOUT;
- return (dat);
- void write1(unsigned char wr_)// 寫入一個字節SD卡
- dat=wr_;
- DATEIN=dat_7;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_6;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_5;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_4;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_3;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_2;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_1;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_0;
- SCLK=0;
- SCLK=1;
- unsigned char read1()// 讀取一個字節SD卡
- DATEOUT=1;
- SCLK=1;
- SCLK=0;
- dat_7=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_6=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_5=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_4=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_3=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_2=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_1=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_0=DATEOUT;
- return (dat);
- //******************************8
- void restsd()//復位SD卡
- { uchar i;
- uchar pcmd[6]={0x40,0x00,0x00,0x00,0x00,0x95};
- is_init=1;
- CS=1;
- for(i=0;i<15;i++)
- //120時鐘
- write(0xff);
- CS=1;
- write(0xff);//據說是提高兼容性
- CS=0;//片選開
- write( pcmd[0]);
- write( pcmd[1]);
- write( pcmd[2]);
- write( pcmd[3]);
- write( pcmd[4]);
- write( pcmd[5]);
- fhz=read();
- for(;;)
- fhz=read();
- if(fhz==0x01)break;
- CS=1;
- write(0xff);
- void initsd()//初始化SD
- uchar pcmd[6]={0x41,0x00,0x00,0x00,0x00,0xff};//
- CS=1;
- CS=0;//片選開
- write( pcmd[0]);
- write( pcmd[1]);
- write( pcmd[2]);
- write( pcmd[3]);
- write( pcmd[4]);
- write( pcmd[5]);
- fhz=read();
- for(;;)
- fhz=read();
- if(fhz==0x00)break;
- CS=1;
- write(0xff);
- void readsd(unsigned long addstart)//讀SD卡物理一扇區的值送TAB表中
- uint k,n;
- uchar zh2,zh3,zh4;
- uchar *p;
- p=&addstart; //取出存放Numb的地址的最高位!詳細請看匯編!!
- p++; //由于最高位不用所以這里舍去小于2G
- zh2=*p;//從高到底的地第二字節 、、
- p++;
- zh3=*p; //從高到底的地第三字節
- p++;
- zh4=*p; //從高到底的地第四字節
- //readsd(numb);//讀物理扇區
- CS=0;//片選開
- write1( 0x51);
- write1( 0x00);//這里是2G以下可以為00
- write1( zh2);
- write1( zh3);
- write1( zh4);
- write1( 0xff);
- DATEOUT=1;
- for(;;)
- fhz=read1();
- DATEOUT=1;
- for(;;)
- fhz=read1();
- if(fhz==0xfe)break;
- DATEOUT=1;
- n=0;
- for(k=512;k;k--)
- tab[n]=read1();
- n++;
- fhz=read1();
- fhz=read1();
- CS=1;
- write1(0xff);
- void readsd_mp3(unsigned long numbs) //讀一扇區的數據送MP3解碼!!!
- uchar *p;
- uint j;
- p=&numbs; //取出存放Numb的地址的最高位!詳細請看匯編!!
- p++;
- p++;
- XDCS=0;
- CS=0;//片選開
- dat=0x51;
- DATEIN=dat_7;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_6;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_5;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_4;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_3;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_2;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_1;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_0;
- SCLK=0;
- SCLK=1; //fhz=read1(); 以上是寫SD卡
- //write1( 0x00);//這里是2G以下可以為00 //fhz=read1(); 以下是寫SD卡
- dat=0x00;
- DATEIN=dat_7;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_6;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_5;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_4;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_3;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_2;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_1;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_0;
- SCLK=0;
- //write1( zh2); //fhz=read1(); 以下是寫SD卡
- dat=zh2;
- DATEIN=dat_7;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_6;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_5;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_4;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_3;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_2;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_1;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_0;
- SCLK=0;
- // write1( zh3); //fhz=read1(); 以下是寫SD卡
- dat=zh3;
- DATEIN=dat_7;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_6;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_5;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_4;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_3;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_2;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_1;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_0;
- SCLK=0;
- //write1( zh4); //fhz=read1(); 以下是寫SD卡
- dat=zh4;
- DATEIN=dat_7;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_6;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_5;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_4;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_3;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_2;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_1;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_0;
- SCLK=0;
- // write1( 0xff); //fhz=read1(); 以下是寫SD卡
- dat=0xff;
- DATEIN=dat_7;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_6;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_5;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_4;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_3;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_2;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_1;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_0;
- SCLK=0;
- SCLK=1;
- DATEOUT=1; // 以上是寫SD卡
- for(;;)
- //fhz=read1(); 以下是讀SD卡
- DATEOUT=1;
- SCLK=1;
- SCLK=0;
- dat_7=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_6=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_5=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_4=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_3=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_2=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_1=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_0=DATEOUT;
- fhz=dat; // 以上是讀SD卡
- DATEOUT=1;
- for(;;)
- // fhz=read1(); 以下是讀SD卡
- DATEOUT=1;
- SCLK=1;
- SCLK=0;
- dat_7=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_6=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_5=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_4=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_3=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_2=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_1=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_0=DATEOUT;
- fhz=dat; //fhz=read1(); 以上是讀SD卡
- DATEOUT=1;
- // n=0;
- for(j=512;j;j--)
- DATEOUT=1; //fhz=read1(); 以下是讀SD卡
- SCLK=1;
- SCLK=0;
- dat_7=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_6=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_5=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_4=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_3=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_2=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_1=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_0=DATEOUT; //fhz=read1(); 以上是讀SD卡
- datmp3=dat; //fhz=read1(); 以下是寫mp3bit流
- DREQ=1;
- while(!DREQ);
- SI=datmp3_7;
- SCK=1;
- SI=datmp3_6;
- SCK=0;
- SCK=1;
- SI=datmp3_5;
- SCK=0;
- SCK=1;
- SI=datmp3_4;
- SCK=0;
- SCK=1;
- SI=datmp3_3;
- SCK=0;
- SCK=1;
- SI=datmp3_2;
- SCK=0;
- SCK=1;
- SI=datmp3_1;
- SCK=0;
- SCK=1;
- SI=datmp3_0;
- SCK=0;
- SCK=1;
- //以上是寫mp3bit流
- //**********************以下是讀CRC*****
- DATEOUT=1;
- SCLK=1;
- SCLK=0;
- dat_7=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_6=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_5=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_4=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_3=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_2=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_1=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_0=DATEOUT;
- DATEOUT=1;
- SCLK=1;
- SCLK=0;
- dat_7=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_6=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_5=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_4=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_3=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_2=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_1=DATEOUT;
- SCLK=1;
- SCLK=0;
- dat_0=DATEOUT;
- CS=1;
- dat=0xff;
- DATEIN=dat_7;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_6;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_5;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_4;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_3;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_2;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_1;
- SCLK=0;
- SCLK=1;
- DATEIN=dat_0;
- SCLK=0;
- SCLK=1;
- XDCS=1;
- //**********************以上是讀CRC***** //**************
- ////***************************************以上是SD主程序
- FAT32文件系統是用來尋找歌曲文件的手段!必須的 ////////////////////////////////////////////////////////////////////////////////////////////////////
- 下面是了
- 名稱:FAT32 文件系統
- 說明:不要認為FAT32多神秘,其實他就是"查字典" 只是每一個環節都不能錯!!!一環扣一環
- 編制:王均偉
- 地點:天津市開發區泰達地下交通空間第四項目部宿舍
- 時間:2010年12月29日19:00完成!調試完畢!!所有歌曲完整無缺的再現!
- 記:本文件系統是以簇為單位,也就是說要讀就是一簇!不存在精確到扇區的算法!因此在切換
- 歌曲時容易出現幾毫秒的等待或噪音!只讀 了根目錄的第一個扇區,所以不能播放超過第一扇區
- 存放的P3文件!也是經一步改進的地方!但是相對此系統而言,就簡單了!我總結了!只要你有思路
- 你有想法!那么不管是否可行根據這個想法畫出流程圖,一步一步改進細化流程圖,然后把流程分成幾個
- 功能塊!分別編寫子函數,最后連起來!調試!關鍵是調試,一編編,一個問題要問:為什么會這樣?是什么原因
- 導致的?一步步排查!實驗,排查!一定能找到阻礙你的那塊石頭!!!
- /* 函數名:unsigned long find_sd_type(); *
- /* 作用:FAT32系統中用來尋找根目錄中的MP3文件 *
- /* 輸入:無 *
- /* 輸出:返回一個長整形作為找到的MP3文件的簇號 *
- unsigned long find_sd_type()
- uchar i,n,a,m,clr;
- static uchar some,next ; //定義靜態變量用來記錄當前的歌曲是第幾首!給查根目錄程序一個基準
- unsigned long h1,h2,h3,h4,startadd;
- switch (some)
- case 3:{some=0;i=next;break;}//第四首
- case 2:{some=3;i=next;break;}//第三首
- case 1:{some=2;i=next;break;}//第二首
- case 0:{some=1;next=0;break;}//第一首
- readsd(4323840);//把根目錄中的第一扇區數據讀入tab中!!!
- for(;;)
- n=tab[8+(16*i)];//
- a=tab[9+(16*i)];//
- m=tab[10+(16*i)];//
- clr=tab[16*i];
- if((n==0x4d)&(a==0x50)&(m==0x33)&(clr!=0xe5)){break;} //如果有mp3文件擴展名且第一個不是E5的話,E5代表已經刪除了的文件的就退出,沒有就一直找!
- i++;
- next=i;//這里表示i的值送next暫存,應為你不能用i,他的值是隨時變化的;
- next++; //這個表示這一首個唱完了,下一首!!呵呵2010年12月29日!!!19:16在開始的SWITCH里要判斷的!!!!就是這樣的
- //注意這里的i--;是必要的!應為我在比較后
- h1=tab[20+(16*i)]; //i多加了一次,所以要減去,因為下面我要用的!!就是這個原因!
- h2=tab[21+(16*i)];//查文件開始簇的地址
- h3=tab[26+(16*i)];
- h4=tab[27+(16*i)];//這里得到h1-h4表示
- h2=(h2<<24);//注意這里!h2是在32為中的32-24位 開始我在這里搞錯了
- h1=(h1<<16);//注意這里!h1是在32為中的17-24位 ///格式轉換!把它有逆序排列的十六進制轉換成正常的高位在前的十六進制!!!
- h4=(h4<<8);//注意這里!h2是在32為中的8-16位 / /上面不用轉換,文件名的排列是正確的!
- startadd=h1+h2+h3+h4;
- return(startadd);//返回文件的開始簇開始
- /* 函數名:unsigned long find_sd_fat(unsigned long startadd1); *
- /* 作用:FAT32系統中用來查找FAT是否有下一簇的開始地址 *
- /* 如有則返回,沒有則退出 *
- /* 輸入:已經執行完的的或前一個簇號 *
- /* 輸出:返回一個長整形作為找到的MP3文件的下一簇開始地址*
- unsigned long find_sd_fat(unsigned long startadd1)
- unsigned long a,b,c,d,startadd;
- uchar snumb;
- snumb=((startadd1*4)/512);//占得扇區數
- readsd(2363904+(snumb*512));//讀fat表放入tab中
- a=tab[(startadd1*4)-(snumb*512)];//最低字節
- b=tab[(startadd1*4)-(snumb*512)+1];
- c=tab[(startadd1*4)-(snumb*512)+2];
- d=tab[(startadd1*4)-(snumb*512)+3];//最高字節
- d=(d<<24);
- c=(c<<16);
- b=(b<<8);
- startadd=a+b+c+d;
- return (startadd);
- void main() //主程序
- unsigned long numb,f,st;//numb是簇號,f是物理地址,st 中間變量
- init_mp3();//初始化MP3
- is_init=1;
- restsd(); //復位SD卡
- initsd(); //初始化SD卡
- is_init=0;//提高始終頻率
- sing(100);//正選測試
- while(1)//主循環
- // numb=4327936; //從4327936物理地址開始讀歌曲!
- loop: numb=find_sd_type();//計算mp3文件的開始簇,返回計算出的文件開始簇號!
- while(1)
- f=(4323840+(numb-2)*4096);// 將計算歌曲的開始簇地址轉化成SD卡的物理地址
- st=f;//中間量ST保證一個個基準量,F則不行!因為F要加0X200時刻變化的!!而ST則是不變的!!
- for(;;) //讀出一簇數據送往MP3;
- readsd_mp3(f);//給他地址他就播放!!!當然是物理SD地址
- f=(f+0x200);//因為是一簇所以要讀扇區后腰加一扇區的地址更新
- if(f==(st+4096))break; //如果是一簇播放完畢!那么要退出!尋找下一簇!怎么找?FAT表
- numb=find_sd_fat(numb); //查FAT表!找到下一簇!
- if(numb==0x0fffffff)//文件播放完畢?完畢就轉到下一首,沒完繼續查fat表
- {goto loop;
- }// 是否播放完畢?檢測到0X0FFFFFFF表示播放完畢!如果完畢則轉到loop執行
