查看: 6493|回復: 1
MPLAB IDE老是彈出一個窗口,怎么解決?the extended cpu mode configuration bit is...
ID:82438 發表于 2015-6-15 22:45 | 顯示全部樓層 |閱讀模式
使用pic18F66J60單片機編譯時,總是提示the extended cpu mode configuration bit is enabled, but the program that was loaded was not built using extended cpu instructions.therefore,your code may not work properly.  加了這條指令#pragma config XINST = OFF也不管用。哪位大神幫忙解答一下?
ID:109298 發表于 2016-3-17 10:56 | 顯示全部樓層
請問您的問題解決了么,我也遇到這樣的問題了。我的QQ1399791321,謝謝
