此外部中斷的設置我完全是采用了寄存器的操作,沒有用一個庫函數來實現的,這樣做設置是很慢的,一位一位的校準,但是我喜歡這樣做。效果如同我想的一樣!。。。。。。。。,與天津第四項目部宿舍
- #include "stm32f10x.h"
- GPIO_InitTypeDef GPIO_InitStructure;
- void mysysint();
- void my_EXTI_int();
- int main(void)
- mysysint();//RCC初始化,時鐘設置72MHZ
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);//使能APB2時鐘
- /* Configure PD0 and PD2 in output pushpull mode */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9| GPIO_Pin_10| GPIO_Pin_11;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- my_EXTI_int();
- while(1);
- void my_EXTI_int()//呼呼!
- /* PA8被我設置成輸入,上啦、下拉 */
- GPIOA->CRH=0x44444448;
- /*配置PA的8-11腳為中斷輸入線*/
- AFIO->EXTICR[2]=0x0;
- /*設置外部中斷線8中斷請求開啟其他的都關閉*/
- EXTI->IMR=0x00000100;
- /*下降沿觸發*/
- EXTI->FTSR=0x00000100;
- /*EXTI9_5的優先級設為10*/
- NVIC->IP[23]=10;
- /*開啟23號中斷即EXTI9_5,關閉其他所有外部的中斷*/
- NVIC->ISER[0]=0x00800000;
- void mysysint()//系統初始化程序
- ErrorStatus HSEStartUpStatus;//說明標志位
- RCC_DeInit();//所有外設全部缺省設置
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- /* Wait till HSE is ready and if Time out is reached exit */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)//啟動成功
- /*這兩條FLASH指令必須加上,不知為啥?不加上就運行幾秒后出錯,參照系統初始化*/
- /* Enable The Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//FLASH緩存開啟
- /* Configure the Latency cycle: Set 2 Latency cycles */
- FLASH_SetLatency(FLASH_Latency_2); //設置FLASH這些位表示SYSCLK(系統時鐘)周期與閃存訪問時間的比例,為010:兩個等待狀態,當 48MHz < SYSCLK ≤ 72MHz
- /* Set PLL clock output to 72MHz using HSE (8MHz) as entry clock */
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//外部時鐘為8M,PLL的輸入時鐘=8MHZ,倍頻系數9,
- /* Configure HCLK such as HCLK = SYSCLK */
- RCC_HCLKConfig(RCC_SYSCLK_Div1);//設置了啦AHB分頻器的分頻系數=1,即HCLK=SYSCLK=72MHZ
- /* Configure PCLK1 such as PCLK1 = HCLK/2 */
- RCC_PCLK1Config(RCC_HCLK_Div2);//設置了APB1外設的時鐘頻率最大是36M這里是APB1的分頻器設為2,PCLK1=HCLK/2=72/2=36MHZ正好是最大值
- /* Configure PCLK2 such as PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);//設置PLCK2=HCLK=72MHZ,的APB2分頻器=1
- /* Select the PLL as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//設置了SYSCLK的提供者為PLL,頻率由上面算出=72MHZ
- /* disable PLL Ready interrupt */
- RCC_ITConfig(RCC_IT_PLLRDY, DISABLE);//PLL中斷關閉
- RCC_ITConfig(RCC_IT_HSERDY,DISABLE);//HSE中斷關閉
- RCC_ITConfig(RCC_IT_HSIRDY, DISABLE); //HSI中斷關閉
- RCC_ITConfig(RCC_IT_LSERDY, DISABLE); //LSE中斷關閉
- RCC_ITConfig(RCC_IT_LSIRDY, DISABLE); //LSI中斷關閉
- /* PLL clock divided by 1.5 used as USB clock source */
- RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);//設置USB的時鐘為=72、1.5=48mhz
- /* Configure ADCCLK such as ADCCLK = PCLK2/2 */
- RCC_ADCCLKConfig(RCC_PCLK2_Div2);//設置ADC時鐘=PCLK2/2= 36MHZ
- /* disable the LSE */
- RCC_LSEConfig(RCC_LSE_OFF);//外部低速晶振關閉
- /*DISable the RTC clock */
- RCC_RTCCLKCmd(DISABLE);
- /* DISable the Clock Security System */
- RCC_ClockSecuritySystemCmd(DISABLE);
- /* Enable the PLL */
- RCC_PLLCmd(ENABLE);//使能PLL
- /* PLL ans system clock config */
- else
- /* Add here some code to deal with this error */
