查看: 7287|回復: 0
stm32 NAND閃存成功讀取ID程序
ID:82781 發表于 2015-6-14 01:32 | 顯示全部樓層 |閱讀模式
今天對我意義很重大,終于把NAND閃存的ID號給讀出來了,這就意味著我的時序是沒有問題的,操作也是沒有問題的,就這么干以后,當我讀出數據:AD F1 80 1D,沸騰了。也許這就是我想要的,這樣的快樂,知足了。
這是我用IO驅動外部器件的第一步,也是很值得紀念的日子,
下面是程序:(這里我采用的是庫代碼與裸寄存器操作)
  1. #include "stm32f10x.h"
  2. #include "stm32f10x_flash.h"
  3. #define SET_CLE GPIO_SetBits(GPIOD, GPIO_Pin_6)
  4. #define CLR_CLE GPIO_ResetBits(GPIOD, GPIO_Pin_6)
  5. #define SET_ALE GPIO_SetBits(GPIOD, GPIO_Pin_5)
  6. #define CLR_ALE GPIO_ResetBits(GPIOD, GPIO_Pin_5)
  7. #define SET_CE GPIO_SetBits(GPIOD, GPIO_Pin_7)
  8. #define CLR_CE GPIO_ResetBits(GPIOD, GPIO_Pin_7)
  9. #define SET_WE GPIO_SetBits(GPIOD, GPIO_Pin_14)
  10. #define CLR_WE GPIO_ResetBits(GPIOD, GPIO_Pin_14)
  11. #define SET_RE GPIO_SetBits(GPIOD, GPIO_Pin_15)
  12. #define CLR_RE GPIO_ResetBits(GPIOD, GPIO_Pin_15)
  13. void mysysinit(void);//系統時鐘初始
  14. void my_USART_init(void);//初始化
  15. void my_send_byte(unsigned char send_date); //發送一個字節
  16. GPIO_InitTypeDef GPIO_InitStructure;
  17. void READ_NAND_ID(void);
  18. void delay_1us(uint32_t);
  19. void my_NAND_INIT(void ); //nand flash 初始化
  20. void wait_NAND_readay(void);
  21. int main()
  22. {
  23.
  24. mysysinit();//RCC初始化,系統時鐘設置72MHZ
  25.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//使能APB2的GPIO_D時鐘
  26.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);//使能APB2的GPIO_D時鐘
  27.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//使能APB2的GPIO_B時鐘
  28. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE);//使能APB2的GPIO_E時鐘
  29. RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);//使能APB2的GPIO_E時鐘
  30.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);//使能APB1的USART2時鐘
  31.   /* led*/
  32.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9| GPIO_Pin_10| GPIO_Pin_11;
  33.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  34.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  35.   GPIO_Init(GPIOD, &GPIO_InitStructure);
  36.   /* 設置PB.5用于控制NAND的為上拉輸入 */
  37.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  38.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  39.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  40.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  41.    my_USART_init();
  42.
  43.
  44.
  45.
  46.         wait_NAND_readay();
  47.     GPIO_SetBits(GPIOD, GPIO_Pin_8);
  48.                 my_send_byte(0);
  49.           my_send_byte(1);
  50.        my_send_byte(2);
  51.     my_send_byte(3);
  52.
  53. READ_NAND_ID();
  54.   while(1);
  55. }
  56. /*等待芯片不忙*/
  57. void wait_NAND_readay()
  58. {
  59. uint8_t wait=0;//忙閑信號
  60. //等待芯片不忙
  61.    do
  62.    { wait=GPIO_ReadOutputDataBit(GPIOB, GPIO_Pin_5);//讀取忙閑引腳
  63.    }
  64.     while(0x00==wait);
  65. }
  66. /*讀取NAND閃存的ID序列號串口發送*/
  67. void READ_NAND_ID()
  68. {
  69. uint8_t a=0,b=0,c=0,d=0;
  70.
  71.    /* 設置PD口用于控制NAND的為輸出 */
  72.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6| GPIO_Pin_7| GPIO_Pin_14| GPIO_Pin_15;
  73.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  74.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  75.   GPIO_Init(GPIOD, &GPIO_InitStructure);
  76. /*設置PE口得低八位為輸出*/
  77.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1| GPIO_Pin_2| GPIO_Pin_3| GPIO_Pin_4|GPIO_Pin_7 | GPIO_Pin_6| GPIO_Pin_7;
  78.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  79.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  80.   GPIO_Init(GPIOE, &GPIO_InitStructure);
  81. //delay_1us(1000000);
  82.   CLR_CE;//開啟片選
  83.   SET_CLE;//命令鎖存開啟
  84.   CLR_WE;//寫使能
  85.   CLR_ALE;//地址鎖存關閉
  86.   SET_RE;//讀關閉
  87.   GPIO_Write(GPIOE, 0x90); //讀ID命令
  88.   SET_WE;//關閉寫
  89.   CLR_CLE;
  90.   SET_ALE;
  91.   CLR_WE;
  92.   GPIO_Write(GPIOE, 0x00); //地址00
  93.   SET_WE;
  94.   /*設置PE口得低八位為輸入*/
  95.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1| GPIO_Pin_2| GPIO_Pin_3| GPIO_Pin_4|GPIO_Pin_7 | GPIO_Pin_6| GPIO_Pin_7;
  96.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  97.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  98.   GPIO_Init(GPIOE, &GPIO_InitStructure);
  99.   CLR_ALE; //注意啊,這里一定把他放在下面應為是有時間要求的;時序圖TAR=15納秒之后才是RE的操作;
  100.        //讀出的結果是AD F1 80 1D ,2011年8月26日,與天津第四項目部宿舍
  101.   CLR_RE;
  102.    a=(GPIOE->IDR);
  103.   SET_RE;
  104.     CLR_RE;
  105.   b=(GPIOE->IDR);
  106.   SET_RE;
  107.     CLR_RE;
  108.    c=(GPIOE->IDR);
  109. SET_RE;
  110.   CLR_RE;
  111.     d=(GPIOE->IDR);//delay_1us(1);
  112. SET_RE;
  113.   SET_CE;//關閉片選
  114.                 my_send_byte(a);
  115.           my_send_byte(b);
  116.        my_send_byte(c);
  117.     my_send_byte(d);
  118. }
  119. /********************
  120.   延時函數
  121.   形參:uint8_t time
  122.   功能:延時數值為time值
  123. *********************/
  124. void delay_1us(uint32_t time)
  125. {   uint32_t b,c;
  126.         for(c=time;c;c--) //定時=time*3*333.6=time*1000.8ns
  127.          {
  128.    for(b=8;b;b--); //8*13.9*3= 333.6
  129.          }
  130. }
  131. /***********************************
  132. 發送一個字節函數通過串口
  133. ************************************/
  134. void my_send_byte(unsigned char send_date )
  135. {
  136.   while( (USART1->SR&0x00000080)!=0x80);//發送寄存器為空
  137.    USART1->DR=send_date;
  138. }
  139. /**********************************
  140.           初始化串口
  141. **********************************/
  142. void my_USART_init()
  143. {
  144. /*USART2的優先級設為5*/
  145. NVIC->IP[37]=5;
  146. /*開啟38號中斷即USART2,關閉其他所有外部的中斷*/
  147. NVIC->ISER[1]=0x00000020;
  148. /*設置復用模式下的引腳模式為全雙工:TX輸出推挽復用,RX為輸入上拉模式,速度50MHZ*/
  149.             GPIOA->CRH=0x000008b0;
  150.   /* 1.開啟USART,
  151. *
  152. */
  153. USART1->CR1=0x2000;
  154. /* 1.關閉局域網模式
  155. * 2.1個停止位
  156. * 3.CK引腳禁能
  157. */
  158. USART1->CR2=0;
  159. /* 1.關閉調制解調模式
  160. * 2.關閉DMA模式
  161. * 3.關閉智能卡、紅外模式
  162. *   4.關閉錯誤中斷
  163. */
  164. USART1->CR3=0;
  165. /*     波特率設置
  166.      2011年8月11日
  167.         王均偉
  168.          天津第四項目部宿舍
  169.     BRR中的第四位(DIV_Fraction)作為小數,高12位(DIV_MANtissa)作為整數部分,
  170.
  171.     1,根據公式:波特率=fck/16*usardiv,其中usardivBRR寄存器的值,所以變形得:USARDIV=fck/16*波特率
  172.     2.算出來BRR寄存器的值后就要把這個值變成16進制數據寫入BRR寄存器中,
  173.       遵循以下規則:
  174.       小數部分*16=DIV_Fraction或者取近似的值
  175.       整數部分直接=DIV_MANtissa
  176.     3.把這個16進制值寫入BRR寄存器
  177.     例如我要算波特率設成9600bps的BRR寄存器值,
  178.     1.先求USARDIV=36000000/16*9600=234.375
  179.     2.換成十六進制:DIV_Fraction=16*0.375=0x6
  180.                     DIV_MANtissa=234=0xea
  181.     3.組合并寫入寄存器
  182.                      USART2->BRR=0x0ea6;值得注意的是這里是16位半字操作,所以不要以為是32位。
  183. */
  184. USART1->BRR=0x0ea6;
  185. /* 1.開啟USART
  186. * 2.開啟接收完畢中斷
  187. * 3.開啟發送功能
  188. *   4.開啟接收功能
  189. */
  190. USART1->CR1=0x202c;
  191. }
  192. void mysysinit()//系統初始化程序
  193. {
  194. ErrorStatus HSEStartUpStatus;//說明標志位
  195. RCC_DeInit();//所有外設全部缺省設置
  196. /* Enable HSE */
  197. RCC_HSEConfig(RCC_HSE_ON);
  198. /* Wait till HSE is ready and if Time out is reached exit */
  199. HSEStartUpStatus = RCC_WaitForHSEStartUp();
  200. if(HSEStartUpStatus == SUCCESS)//啟動成功
  201. {
  202. /*這兩條FLASH指令必須加上,不知為啥?不加上就運行幾秒后出錯,參照系統初始化*/
  203. /* Enable The Prefetch Buffer */
  204. FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//FLASH緩存開啟
  205. /* Configure the Latency cycle: Set 2 Latency cycles */
  206.   FLASH_SetLatency(FLASH_Latency_2);  //設置FLASH這些位表示SYSCLK(系統時鐘)周期與閃存訪問時間的比例,為010:兩個等待狀態,當 48MHz < SYSCLK ≤ 72MHz
  207. /* Set PLL clock output to 72MHz using HSE (8MHz) as entry clock */
  208. RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//外部時鐘為8M,PLL的輸入時鐘=8MHZ,倍頻系數9,
  209. /* Configure HCLK such as HCLK = SYSCLK */
  210. RCC_HCLKConfig(RCC_SYSCLK_Div1);//設置了啦AHB分頻器的分頻系數=1,即HCLK=SYSCLK=72MHZ
  211. /* Configure PCLK1 such as PCLK1 = HCLK/2 */
  212. RCC_PCLK1Config(RCC_HCLK_Div2);//設置了APB1外設的時鐘頻率最大是36M這里是APB1的分頻器設為2,PCLK1=HCLK/2=72/2=36MHZ正好是最大值
  213. /* Configure PCLK2 such as PCLK2 = HCLK */
  214. RCC_PCLK2Config(RCC_HCLK_Div1);//設置PLCK2=HCLK=72MHZ,的APB2分頻器=1
  215. /* Select the PLL as system clock source */
  216. RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//設置了SYSCLK的提供者為PLL,頻率由上面算出=72MHZ
  217. /* disable PLL Ready interrupt */
  218. RCC_ITConfig(RCC_IT_PLLRDY, DISABLE);//PLL中斷關閉
  219. /* disable PLL Ready interrupt */
  220. RCC_ITConfig(RCC_IT_HSERDY,DISABLE);//HSE中斷關閉
  221. /* disable PLL Ready interrupt */
  222. RCC_ITConfig(RCC_IT_HSIRDY, DISABLE); //HSI中斷關閉
  223. /* disable PLL Ready interrupt */
  224. RCC_ITConfig(RCC_IT_LSERDY, DISABLE); //LSE中斷關閉
  225. /* disable PLL Ready interrupt */
  226. RCC_ITConfig(RCC_IT_LSIRDY, DISABLE); //LSI中斷關閉
  227. /* PLL clock divided by 1.5 used as USB clock source */
  228. RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);//設置USB的時鐘為=72、1.5=48mhz
  229. /* Configure ADCCLK such as ADCCLK = PCLK2/2 */
  230. RCC_ADCCLKConfig(RCC_PCLK2_Div2);//設置ADC時鐘=PCLK2/2= 36MHZ
  231. /* disable the LSE */
  232. RCC_LSEConfig(RCC_LSE_OFF);//外部低速晶振關閉
  233. /*DISable the RTC clock */
  234. RCC_RTCCLKCmd(DISABLE);
  235. /* DISable the Clock Security System */
  236. RCC_ClockSecuritySystemCmd(DISABLE);
  237. /* Enable the PLL */
  238. RCC_PLLCmd(ENABLE);//使能PLL
  239. /* PLL ans system clock config */
  240. }
  241. else
  242. {
  243. /* Add here some code to deal with this error */
  244. }
  245. }
