#include <REG51.H>
//--重定義函數變量--//
#define ulong unsigned long
//--定義SPI要使用的 IO--//
sbit MOSIO = P3^4;
sbit R_CLK = P3^5;
sbit S_CLK = P3^6;
unsigned char code tab17[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
unsigned char code tab0[] = {0x00, 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80, /*行掃描*/
0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80, 0x00};
unsigned char code tab1[] = {96,2,28,10,16,18,16,2,254,63,16,2,16,18,112,18,24,10,22,10,16,36,16,42,16,49,156,32,0,0,0,0}; /*我*/
unsigned char code tab2[] = {0,14,252,1,72,8,144,4,254,63,2,16,33,8,252,31,32,0,224,7,80,2,136,1,68,2,58,28,0,0,0,0}; /*愛*/
unsigned char code tab3[] = {144,0,144,0,208,63,72,32,40,16,12,2,10,2,136,10,136,18,72,18,72,34,40,34,8,2,136,3,0,0,0,0}; /*你*/
unsigned char code tab15[] = {0,0,0,0,60,240,102,156,67,130,0,0,0,0,0,0,0,0,0,0,48,24,96,8,192,7,0,0,0,0,0,0}; /*笑臉*/
unsigned char code tab16[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
//--全局函數聲明--//
void HC595SendData( uchar BT3, uchar BT2,uchar BT1,uchar BT0);
* 函 數 名 : main
* 函數功能 : 主函數
* 輸 入 : 無
* 輸 出 : 無
void main(void)
int k, ms,j;
//--定義一個指針數據指向漢字--//
uchar *p[] = { tab1, tab2, tab3, tab15 ,tab16};
for(ms = 20; ms > 0; ms--) //顯示50次,即肉眼可識別的停留時間
for(k = 0; k < 16; k++) //顯示一個字
//--因為字模軟件取的數組是高電平有效,所以列要取反--//
HC595SendData(~(*(p[0] + 2*(k+j) + 1)),~(*(p[0] + 2*(k+j) )),
tab0[2*k],tab0[2*k + 1]);
HC595SendData(0xff,0xff,0,0); //清屏
j++;
if(j==(17*15))
j=0;
* 函 數 名 : HC595SendData
* 函數功能 : 通過595發(fā)送四個字節(jié)的數據
* 輸 入 : BT3:第四個595輸出數值
* * BT2: 第三個595輸出數值
* * BT1:第二個595輸出數值
* * BT0:第一個595輸出數值
* 輸 出 : 無
uchar i;
//--發(fā)送第一個字節(jié)--//
for(i=0;i<8;i++)
MOSIO = BT3 >> 7 ; //從高位到低位
BT3 <<= 1;
S_CLK = 0;
S_CLK = 1;
for(i=0;i<8;i++)
MOSIO = BT2 >>7; //從高位到低位
BT2 <<= 1;
S_CLK = 0;
S_CLK = 1;
for(i=0;i<8;i++)
MOSIO = BT1 >> 7; //從高位到低位
BT1 <<= 1;
S_CLK = 0;
S_CLK = 1;
for(i=0;i<8;i++)
MOSIO = BT0 >> 7; //從高位到低位
BT0 <<= 1;
S_CLK = 0;
S_CLK = 1;
//--輸出--//
R_CLK = 0; //set dataline low
R_CLK = 1; //片選
請問if(j==(17*15))是什么意思?為什么我的只能循環(huán)一次,下一次就是亂碼了?
