查看: 3354|回復: 0
STM32的PWM輸出例程
ID:82083 發表于 2015-6-9 02:03 | 顯示全部樓層 |閱讀模式
                        閱讀了ALIENTEK MINI板的PWM實驗例程,感覺可以簡化一下,簡化后如下:
(其中工程里面的delay.c和delay.h可以在配套光盤里找也可以網上下載)
初始化文件,可以隨意命名,在此命名為Timer3PWM.c
#include "stm32f10x.h"
//arr:自動重裝值   psc:時鐘預分頻數
void TIM3_PWM_Init(u16 arr,u16 psc)
  TIM_TimeBaseInitTypeDefTIM_TimeBaseStructure;
  TIM_OCInitTypeDef TIM_OCInitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);//使能定時器3時鐘
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|
                        RCC_APB2Periph_AFIO,ENABLE);//使能GPIO和服用功能時鐘
  GPIO_InitStructure.GPIO_Pin =GPIO_Pin_7;  //PWM輸出在PA7
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//復用推挽輸出
  GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure);//初始化GPIO
   GPIO_InitStructure.GPIO_Pin =GPIO_Pin_8; //PA8連DS0
  //為防止PA8的輸出干擾DS0的顯示,應配置PA8為浮空輸入
   GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IN_FLOATING;
  TIM_TimeBaseStructure.TIM_Period = arr;//設置自動重裝載周期值
  TIM_TimeBaseStructure.TIM_Prescaler = psc;//設置預分頻值
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;//設置時鐘分割
  TIM_TimeBaseStructure.TIM_CounterMode =TIM_CounterMode_Up; //向上計數模式
TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);//初始化TIM3
  TIM_OCInitStructure.TIM_OCMode =TIM_OCMode_PWM2; //選擇PWM模式2
  TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable; //比較輸出使能
  TIM_OCInitStructure.TIM_OCPolarity =TIM_OCPolarity_High; //輸出極性高
TIM_OC2Init(TIM3,&TIM_OCInitStructure);//初始化外設TIM3OC2
  TIM_OC2PreloadConfig(TIM3,TIM_OCPreload_Enable);//使能預裝載寄存器
  TIM_Cmd(TIM3,ENABLE); //使能TIM3
void NVIC_Config(void)
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設置NVIC中斷分組2:
                                                  // 2位搶占優先級,2位響應優先級
主函數,命名為main.c
#include"stm32f10x.h"
#include "delay.h"
#include "timer3PWM.h"
void main(void)
  u16 ledpwmval = 0;
  u8 dir = 1;
   delay_init(72);//時鐘延時初始化
   TIM3_PWM_Init(899,0);//PWM頻率72000/900 = 8KHz
   NVIC_Config();//設置NVIC中斷分組
    delay_ms(10);
    if(dir)
      ledpwmval++;
      ledpwmval--;
    if(ledpwmval > 300)
      dir = 0;
    if(ledpwmval == 0)
      dir = 1;
    TIM_SetCompare2(TIM3,ledpwmval);
(記得把PA7和PA8短接)
