查看: 3224|回復(fù): 0
STM32分類定義
ID:82083 發(fā)表于 2015-6-9 00:23 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#define STM32F10X_LD     STM32F10X_LD: STM32 Lowdensity devices */
  #defineSTM32F10X_LD_VL     STM32F10X_LD_VL: STM32 Low density Value Linedevices */
   #defineSTM32F10X_MD      STM32F10X_MD: STM32 Medium density devices */
  #define STM32F10X_MD_VL  VLSTM32F10X_MD_VL: STM32 Medium density Value Linedevices
   #defineSTM32F10X_HD      STM32F10X_HD: STM32 High density devices */
  #define STM32F10X_HD_VL STM32F10X_HD_VL: STM32 High density value line devices*/
  #define STM32F10X_XL      STM32F10X_XL: STM32 XL-density devices */
   #defineSTM32F10X_CL     STM32F10X_CL: STM32 Connectivity line devices*/
- Low-density devices are STM32F101xx, STM32F102xx andSTM32F103xx microcontrollers
   where the Flash memory densityranges between 16 and 32 Kbytes.
- Low-density value line devices are STM32F100xxmicrocontrollers where the Flash
   memory density ranges between16 and 32 Kbytes.
- Medium-density devices are STM32F101xx,STM32F102xx and STM32F103xx microcontrollers
   where the Flash memory densityranges between 64 and 128 Kbytes.
- Medium-density value line devices areSTM32F100xx microcontrollers where the
   Flash memory density rangesbetween 64 and 128Kbytes.
- High-density devices are STM32F101xx andSTM32F103xx microcontrollers where
   the Flash memory densityranges between 256 and 512 Kbytes.
- High-density value line devices are STM32F100xxmicrocontrollers where the
   Flash memory density rangesbetween 256 and 512Kbytes.
- XL-density devices are STM32F101xx andSTM32F103xx microcontrollers where
   the Flash memory densityranges between 512 and 1024 Kbytes.
- Connectivity line devices are STM32F105xx andSTM32F107xx microcontrollers.
cl:互聯(lián)型產(chǎn)品,stm32f105/107系列
vl:超值型產(chǎn)品,stm32f100系列
xl:超高密度產(chǎn)品,stm32f101/103系列
ld:低密度產(chǎn)品,F(xiàn)LASH小于64K
md:中等密度產(chǎn)品,F(xiàn)LASH=64 or 128
hd:高密度產(chǎn)品,F(xiàn)LASH大于128
- startup_stm32f10x_ld_vl.s: for STM32 Low density Value linedevices
- startup_stm32f10x_ld.s: for STM32 Low density devices
- startup_stm32f10x_md_vl.s: for STM32 Medium density Value linedevices
- startup_stm32f10x_md.s: for STM32 Medium density devices
- startup_stm32f10x_hd.s: for STM32 High density devices
- startup_stm32f10x_xl.s: for STM32 XL density devices
- startup_stm32f10x_cl.s: for STM32 Connectivity linedevices
