大家好,下面這個程序可以用串口助手發送十六進制數并在數碼管上顯示.因為串口通訊軟件只能發2位數,所以顯示也只能是2位,請教大家:如和實現三位數字的發送與顯示,舉例說明:比如我想發送123并在單片機的數碼管上顯示123,該如何發送與分離數字.程序如下:
#include<reg52.h>
#define uchar unsigned char #define uint unsigned int uchar ss,sg;
uchar code table[]={ 0xc0,0xf9,0xa4,0xb0, 0x99,0x92,0x82,0xf8, 0x80,0x90,0x88,0x83, 0xc6,0xa1,0x86,0x8e};
void Init_Uart(void);
void delay(uint z) { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); }
void display(uint i) { uchar ss,sg;
ss=i/16; sg=i%16;
P0=table[ss]; P2=0x7f; delay(2); P0=table[sg]; P2=0xbf; delay(2);
void main(void) { uint i = 0; Init_Uart(); while(1) { if(RI==1) { RI = 0; i = SBUF; } else display(i);
void Init_Uart(void) { TMOD = 0x20; TH1 = 0xFD; TL1 = 0xFD; TR1 = 1; SCON = 0x50; PCON = 0; EA = 1; }
2010-2-17 18:28 上傳
