- #include "radio.h"
- #include"spi.h"
- #include"uart.h"
- #define TxGPIOSetting() SpiWriteRegister(0x0E, 0x02)
- #define RxGPIOSetting() SpiWriteRegister(0x0E, 0x01)
- #define IdleGPIOSetting() SpiWriteRegister(0x0E, 0x01)
- void RF_init(void)
- //Set the physical parameters
- //Frequency: 433MHz
- //Modulation type: GFSK
- //CrytalTolerance: Rx,10ppm; Tx, 10ppm
- //Data rate: 9.6Kbps/1.2Kbps
- //AFC: Enable
- //Frequency deviation: 20KHz
- //set the center frequency to 433 MHz
- SpiWriteRegister(0x75, 0x53); //write data to the Frequency Band Select register
- SpiWriteRegister(0x76, 0x4B); //write data to the Nominal Carrier Frequency1 register
- SpiWriteRegister(0x77, 0x00); //write data to the Nominal Carrier Frequency0 register
- //set the desired TX data rate (1.2kbps)
- SpiWriteRegister(0x6E, 0x09); //write data to the TXDataRate 1 register
- SpiWriteRegister(0x6F, 0xD5); //write data to the TXDataRate 0 register
- SpiWriteRegister(0x70, 0x2C); //write data to the Modulation Mode Control 1 register
- SpiWriteRegister(0x58, 0x80);
- //set the TX power to MAX. dBm
- SpiWriteRegister(0x6D, 0x1F); //write data to the TX Power register
- //set the Tx deviation register (+-20kHz)
- SpiWriteRegister(0x72, 0x20); //write data to the Frequency Deviation register
- /*set the modem parameters according to the exel calculator(parameters: 1.2 kbps, deviation: 20 kHz*/
- SpiWriteRegister(0x1C, 0x2C); //write data to the IF Filter Bandwidth register
- SpiWriteRegister(0x20, 0x41); //write data to the Clock Recovery Oversampling Ratio register
- SpiWriteRegister(0x21, 0x60); //write data to the Clock Recovery Offset 2 register
- SpiWriteRegister(0x22, 0x27); //write data to the Clock Recovery Offset 1 register
- SpiWriteRegister(0x23, 0x52); //write data to the Clock Recovery Offset 0 register
- SpiWriteRegister(0x24, 0x00); //write data to the Clock Recovery Timing Loop Gain 1 register
- SpiWriteRegister(0x25, 0x04); //write data to the Clock Recovery Timing Loop Gain 0 register
- SpiWriteRegister(0x1D, 0x40); //write data to the AFC Loop Gearshift Override register
- SpiWriteRegister(0x1E, 0x0A);
- SpiWriteRegister(0x2A, 0x0F); //write data to the AFC Limiter register
- SpiWriteRegister(0x1F, 0x03);
- SpiWriteRegister(0x69, 0x60);
- /*set the packet structure and the modulation type*/
- //set the preamble length to 10bytes if the antenna diversity is used and set to 5bytes if not
- SpiWriteRegister(0x34, 0x0C); //write data to the Preamble Length register
- //set preamble detection threshold to 20bits
- SpiWriteRegister(0x35, 0x2A); //write data to the Preamble Detection Control register
- //Disable header bytes; set variable packet length (the length of the payload is defined by the
- //received packet length field of the packet); set the synch word to two bytes long
- SpiWriteRegister(0x33, 0x02); //write data to the Header Control2 register
- //Set the sync word pattern to 0x2DD4
- SpiWriteRegister(0x36, 0x2D); //write data to the Sync Word 3 register
- SpiWriteRegister(0x37, 0xD4); //write data to the Sync Word 2 register
- //enable the TX & RX packet handler and CRC-16 (IBM) check
- SpiWriteRegister(0x30, 0x8D); //write data to the Data Access Control register
- //Disable the receive header filters
- SpiWriteRegister(0x32, 0x00 ); //write data to the Header Control1 register
- //enable FIFO mode and GFSK modulation
- SpiWriteRegister(0x71, 0x63); //write data to the Modulation Mode Control 2 register
- /*set the GPIO's according the testcard type*/
- SpiWriteRegister(0x0B, 0xCA); //Set GPIO0 output
- SpiWriteRegister(0x0C, 0xCA); //Set GPIO1 output
- SpiWriteRegister(0x0D, 0xCA); //Set GPIO2 output Rx Data
- //set Crystal Oscillator Load Capacitance register
- SpiWriteRegister(0x09, CRYSTAL_CAPACITANCE); //write data to the Crystal Oscillator Load Capacitance register
- idata U8 ItStatus1,ItStatus2;
- // Function Name :RFSetRxMode
- // Return Value : None
- // Parameters : None
- // Notes : 設(shè)置模塊工作在接收狀態(tài)下,當(dāng)一切準(zhǔn)備好的時(shí)候,調(diào)用該函數(shù)可以讓模塊工作于接收模式下
- void RFSetRxMode(void)
- //read interrupt status registers to release all pending interrupts
- ItStatus1 = SpiReadRegister(0x03); //read the Interrupt Status1 register
- ItStatus2 = SpiReadRegister(0x04); //read the Interrupt Status2 register
- //Set the Rx switcher,利用GPIO口控制模塊內(nèi)部的天線開關(guān)。
- RxGPIOSetting();
- /*enable receiver chain*/
- SpiWriteRegister(0x07, 0x05);
- // Function Name :RFSetTxMode
- // Notes : 設(shè)置模塊工作在接收狀態(tài)下,當(dāng)一切準(zhǔn)備好的時(shí)候,調(diào)用該函數(shù)可以讓模塊工作于發(fā)射狀態(tài)模式下
- void RFSetTxMode(void)
- //Read interrupt status regsiters. It clear all pending interrupts and the nIRQ pin goes back to high.
- TxGPIOSetting();
- /*enable transmitter*/
- //The radio forms the packet and send it automatically.
- SpiWriteRegister(0x07, 0x09);
- // Function Name :RFSetIdleMode
- // Notes : 設(shè)置模塊工作在空閑狀態(tài)下。當(dāng)模塊不需要接收數(shù)據(jù)也不需要發(fā)射數(shù)據(jù)的時(shí)候可以調(diào)用該函數(shù)以便省電;
- void RFSetIdleMode(void)
- //The radio will work in idle mode
- SpiWriteRegister(0x07, 0x01); //write 0x09 to the Operating Function Control 1 register
- IdleGPIOSetting();
- // Function Name :RFFIFOSendData
- // Parameters : uint8 length: the length of the content which will be sent out. This value should
- // not more than 64bytes because the FIFO is 64bytes. If it is bigger than 64, the
- // content should be sent out for more times according to the FIFO empty interrupt.
- // uint8 *payload: point to the content.
- // Notes : In FIFO mode, send out one packet data.
- // 調(diào)用該函數(shù)可以把數(shù)據(jù)寫入模塊的FIFO中并把數(shù)據(jù)發(fā)送出去;數(shù)據(jù)長度不能大于64個(gè)字節(jié);
- void RFFIFOSendData(U8 length, U8 *payload)
- U8 i;
- RFSetIdleMode();
- //turn on the Tx LED to show the packet transmission
- //TxLEDOn();
- /*SET THE CONTENT OF THE PACKET*/
- //set the length of the payload.
- SpiWriteRegister(0x3E, length);
- //fill the payload into the transmit FIFO
- for(i = 0; i < length; i++)
- SpiWriteRegister(0x7F, payload[i]);
- //Disable all other interrupts and enable the packet sent interrupt only.
- //This will be used for indicating the successfull packet transmission for the MCU
- SpiWriteRegister(0x05, 0x04); //write 0x04 to the Interrupt Enable 1 register
- SpiWriteRegister(0x06, 0x00); //write 0x00 to the Interrupt Enable 2 register
- RFSetTxMode();
- /*wait for the packet sent interrupt*/
- //The MCU just needs to wait for the 'ipksent' interrupt.
- //等待發(fā)射完成中斷的到來,如果中斷采用非查詢方式,則本程序到這里可以結(jié)束,但必須在中斷服務(wù)程序中讀取狀態(tài)寄存器0x03和0x04,以便釋放中斷
- while(NIRQ == 1);
- UART_Send_Str("已發(fā)送..............\n");//調(diào)試信息時(shí)候用
- //read interrupt status registers to release the interrupt flags
- //turn off the Tx LED
- //TurnOffAllLEDs();
