查看: 13399|回復: 26
STM32學習--使用dsp庫的FFT函數
ID:81272 發表于 2015-5-27 18:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
完整程序源代碼工程文件下載地址: 使用dsp庫的FFT函數.rar (425.44 KB, 下載次數: 267)
stm32 dsp lib V2.0庫文件下載: stm32 dsp lib V2.0介紹.pdf (233.4 KB, 下載次數: 185)    stm32 dsp lib V2.0.zip (1.36 MB, 下載次數: 172)
  1. /**
  2.   ******************************************************************************
  3.   * @file FFT_Demo/src/main.c
  4.   * @author  MCD Application Team
  5.   * @version  V2.0.0
  6.   * @date  04/27/2017
  1. /**
  3.   * @file FFT_Demo/src/stm3210b_lcd.c
  6.   * @date  04/27/2009
  7.   * @brief  This file includes the LCD driver for AM-240320LTNQW00H
  8. *                      (LCD_HX8312), AM-240320L8TNQW00H (LCD_ILI9320),
  9. *                      AM-240320LDTNQW00H (LCD_SPFD5408B) Liquid Crystal Display
  10. *                      Module of STM3210B-EVAL board.
  11.   ******************************************************************************
  12.   * @copy
  13.   *
  14.   * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  15.   * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  16.   * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  17.   * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  18.   * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  19.   * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  20.   *
  21.   * <h2><center>© COPYRIGHT 2009 STMicroelectronics</center></h2>
  22.   */
  23. /* Includes ------------------------------------------------------------------*/
  24. #include "stm3210b_lcd.h"
  25. #include "fonts.h"
  26. /** @addtogroup FFT_Demo
  27.   * @{
  28.   */
  29. /* Private typedef -----------------------------------------------------------*/
  30. /* Private define ------------------------------------------------------------*/
  31. #define LCD_ILI9320     0x9320
  32. #define LCD_HX8312      0x8312
  33. #define LCD_SPFD5408    0x5408
  34. #define START_BYTE      0x70
  35. #define SET_INDEX       0x00
  36. #define READ_STATUS     0x01
  37. #define LCD_WRITE_REG   0x02
  38. #define LCD_READ_REG    0x03
  39. /* Private macro -------------------------------------------------------------*/
  40. /* Private variables ---------------------------------------------------------*/
  41.   /* Global variables to set the written text color */
  42. static __IO uint16_t TextColor = 0x0000, BackColor = 0xFFFF;
  43. static __IO uint32_t LCDType = LCD_ILI9320;
  44. /* Private function prototypes -----------------------------------------------*/
  45. static void LCD_WriteRegHX8312(uint8_t LCD_Reg, uint8_t LCD_RegValue);
  46. static void LCD_WriteRegILI9320(uint8_t LCD_Reg, uint16_t LCD_RegValue);
  47. /* Private functions ---------------------------------------------------------*/
  48. /**
  49.   * @brief  Setups the LCD.
  50.   * @param  None
  51.   * @retval : None
  52.   */
  53. void LCD_Setup(void)
  54. {
  55. /* Configure the LCD Control pins --------------------------------------------*/
  56.   LCD_CtrlLinesConfig();
  57.
  58. /* Configure the SPI2 interface ----------------------------------------------*/
  59.   LCD_SPIConfig();
  60.   if(LCDType == LCD_ILI9320)
  61.   {
  62.     Delay(5); /* Delay 50 ms */
  63.     /* Start Initial Sequence ------------------------------------------------*/
  64.     LCD_WriteReg(R229, 0x8000); /* Set the internal vcore voltage */
  65.     LCD_WriteReg(R0,  0x0001); /* Start internal OSC. */
  66.     LCD_WriteReg(R1,  0x0100); /* set SS and SM bit */
  67.     LCD_WriteReg(R2,  0x0700); /* set 1 line inversion */
  68.     LCD_WriteReg(R3,  0x1030); /* set GRAM write direction and BGR=1. */
  69.     LCD_WriteReg(R4,  0x0000); /* Resize register */
  70.     LCD_WriteReg(R8,  0x0202); /* set the back porch and front porch */
  71.     LCD_WriteReg(R9,  0x0000); /* set non-display area refresh cycle ISC[3:0] */
  72.     LCD_WriteReg(R10, 0x0000); /* FMARK function */
  73.     LCD_WriteReg(R12, 0x0000); /* RGB interface setting */
  74.     LCD_WriteReg(R13, 0x0000); /* Frame marker Position */
  75.     LCD_WriteReg(R15, 0x0000); /* RGB interface polarity */
  76.     /* Power On sequence -----------------------------------------------------*/
  77.     LCD_WriteReg(R16, 0x0000); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
  78.     LCD_WriteReg(R17, 0x0000); /* DC1[2:0], DC0[2:0], VC[2:0] */
  79.     LCD_WriteReg(R18, 0x0000); /* VREG1OUT voltage */
  80.     LCD_WriteReg(R19, 0x0000); /* VDV[4:0] for VCOM amplitude */
  81.     Delay(20);                 /* Dis-charge capacitor power voltage (200ms) */
  82.     LCD_WriteReg(R16, 0x17B0); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
  83.     LCD_WriteReg(R17, 0x0137); /* DC1[2:0], DC0[2:0], VC[2:0] */
  84.     Delay(5);                  /* Delay 50 ms */
  85.     LCD_WriteReg(R18, 0x0139); /* VREG1OUT voltage */
  86.     Delay(5);                  /* Delay 50 ms */
  87.     LCD_WriteReg(R19, 0x1d00); /* VDV[4:0] for VCOM amplitude */
  88.     LCD_WriteReg(R41, 0x0013); /* VCM[4:0] for VCOMH */
  89.     Delay(5);                  /* Delay 50 ms */
  90.     LCD_WriteReg(R32, 0x0000); /* GRAM horizontal Address */
  91.     LCD_WriteReg(R33, 0x0000); /* GRAM Vertical Address */
  92.     /* Adjust the Gamma Curve ------------------------------------------------*/
  93.     LCD_WriteReg(R48, 0x0006);
  94.     LCD_WriteReg(R49, 0x0101);
  95.     LCD_WriteReg(R50, 0x0003);
  96.     LCD_WriteReg(R53, 0x0106);
  97.     LCD_WriteReg(R54, 0x0b02);
  98.     LCD_WriteReg(R55, 0x0302);
  99.     LCD_WriteReg(R56, 0x0707);
  100.     LCD_WriteReg(R57, 0x0007);
  101.     LCD_WriteReg(R60, 0x0600);
  102.     LCD_WriteReg(R61, 0x020b);
  103.
  104.     /* Set GRAM area ---------------------------------------------------------*/
  105.     LCD_WriteReg(R80, 0x0000); /* Horizontal GRAM Start Address */
  106.     LCD_WriteReg(R81, 0x00EF); /* Horizontal GRAM End Address */
  107.     LCD_WriteReg(R82, 0x0000); /* Vertical GRAM Start Address */
  108.     LCD_WriteReg(R83, 0x013F); /* Vertical GRAM End Address */
  109.     LCD_WriteReg(R96,  0x2700); /* Gate Scan Line */
  110.     LCD_WriteReg(R97,  0x0001); /* NDL,VLE, REV */
  111.     LCD_WriteReg(R106, 0x0000); /* set scrolling line */
  112.     /* Partial Display Control -----------------------------------------------*/
  113.     LCD_WriteReg(R128, 0x0000);
  114.     LCD_WriteReg(R129, 0x0000);
  115.     LCD_WriteReg(R130, 0x0000);
  116.     LCD_WriteReg(R131, 0x0000);
  117.     LCD_WriteReg(R132, 0x0000);
  118.     LCD_WriteReg(R133, 0x0000);
  119.     /* Panel Control ---------------------------------------------------------*/
  120.     LCD_WriteReg(R144, 0x0010);
  121.     LCD_WriteReg(R146, 0x0000);
  122.     LCD_WriteReg(R147, 0x0003);
  123.     LCD_WriteReg(R149, 0x0110);
  124.     LCD_WriteReg(R151, 0x0000);
  125.     LCD_WriteReg(R152, 0x0000);
  126.     /* Set GRAM write direction and BGR = 1 */
  127.     /* I/D=01 (Horizontal : increment, Vertical : decrement) */
  128.     /* AM=1 (address is updated in vertical writing direction) */
  129.     LCD_WriteReg(R3, 0x1018);
  130.     LCD_WriteReg(R7, 0x0173); /* 262K color and display ON */
  131.   }
  132.   else if(LCDType == LCD_SPFD5408)
  133.   {
  134.     /* Start Initial Sequence --------------------------------------------------*/
  135.     LCD_WriteReg(R227, 0x3008); /* Set internal timing */
  136.     LCD_WriteReg(R231, 0x0012); /* Set internal timing */
  137.     LCD_WriteReg(R239, 0x1231); /* Set internal timing */
  138.     LCD_WriteReg(R1, 0x0100);   /* Set SS and SM bit */
  139.     LCD_WriteReg(R2, 0x0700);   /* Set 1 line inversion */
  140.     LCD_WriteReg(R3, 0x1030);   /* Set GRAM write direction and BGR=1. */
  141.     LCD_WriteReg(R4, 0x0000);   /* Resize register */
  142.     LCD_WriteReg(R8, 0x0202);   /* Set the back porch and front porch */
  143.     LCD_WriteReg(R9, 0x0000);   /* Set non-display area refresh cycle ISC[3:0] */
  144.     LCD_WriteReg(R10, 0x0000);  /* FMARK function */
  145.     LCD_WriteReg(R12, 0x0000);  /* RGB interface setting */
  146.     LCD_WriteReg(R13, 0x0000);  /* Frame marker Position */
  147.     LCD_WriteReg(R15, 0x0000);  /* RGB interface polarity */
  148.     /* Power On sequence -------------------------------------------------------*/
  149.     LCD_WriteReg(R16, 0x0000);  /* SAP, BT[3:0], AP, DSTB, SLP, STB */
  150.     LCD_WriteReg(R17, 0x0000);  /* DC1[2:0], DC0[2:0], VC[2:0] */
  151.     LCD_WriteReg(R18, 0x0000);  /* VREG1OUT voltage */
  152.     LCD_WriteReg(R19, 0x0000);  /* VDV[4:0] for VCOM amplitude */
  153.     Delay(20);                  /* Dis-charge capacitor power voltage (200ms) */
  154.     LCD_WriteReg(R17, 0x0007);        /* DC1[2:0], DC0[2:0], VC[2:0] */
  155.     Delay(5);                   /* Delay 50 ms */
  156.     LCD_WriteReg(R16, 0x12B0);        /* SAP, BT[3:0], AP, DSTB, SLP, STB */
  157.     Delay(5);                        /* Delay 50 ms */
  158.     LCD_WriteReg(R18, 0x01BD);  /* External reference voltage= Vci */
  159.     Delay(5);                   /* Delay 50 ms */
  160.     LCD_WriteReg(R19, 0x1400);  /* VDV[4:0] for VCOM amplitude */
  161.     LCD_WriteReg(R41, 0x000E);  /* VCM[4:0] for VCOMH */
  162.     Delay(5);                   /* Delay 50 ms */
  163.     LCD_WriteReg(R32, 0x0000);  /* GRAM horizontal Address */
  164.     LCD_WriteReg(R33, 0x013F);  /* GRAM Vertical Address */
  165.     /* Adjust the Gamma Curve --------------------------------------------------*/
  166.     LCD_WriteReg(R48, 0x0007);
  167.     LCD_WriteReg(R49, 0x0302);
  168.     LCD_WriteReg(R50, 0x0105);
  169.     LCD_WriteReg(R53, 0x0206);
  170.     LCD_WriteReg(R54, 0x0808);
  171.     LCD_WriteReg(R55, 0x0206);
  172.     LCD_WriteReg(R56, 0x0504);
  173.     LCD_WriteReg(R57, 0x0007);
  174.     LCD_WriteReg(R60, 0x0105);
  175.     LCD_WriteReg(R61, 0x0808);
  176.     /* Set GRAM area -----------------------------------------------------------*/
  177.     LCD_WriteReg(R80, 0x0000);  /* Horizontal GRAM Start Address */
  178.     LCD_WriteReg(R81, 0x00EF);  /* Horizontal GRAM End Address */
  179.     LCD_WriteReg(R82, 0x0000);  /* Vertical GRAM Start Address */
  180.     LCD_WriteReg(R83, 0x013F);  /* Vertical GRAM End Address */
  181.     LCD_WriteReg(R96,  0xA700); /* Gate Scan Line */
  182.     LCD_WriteReg(R97,  0x0001); /* NDL,VLE, REV */
  183.     LCD_WriteReg(R106, 0x0000); /* Set scrolling line */
  184.     /* Partial Display Control -------------------------------------------------*/
  185.     LCD_WriteReg(R128, 0x0000);
  186.     LCD_WriteReg(R129, 0x0000);
  187.     LCD_WriteReg(R130, 0x0000);
  188.     LCD_WriteReg(R131, 0x0000);
  189.     LCD_WriteReg(R132, 0x0000);
  190.     LCD_WriteReg(R133, 0x0000);
  191.     /* Panel Control -----------------------------------------------------------*/
  192.     LCD_WriteReg(R144, 0x0010);
  193.     LCD_WriteReg(R146, 0x0000);
  194.     LCD_WriteReg(R147, 0x0003);
  195.     LCD_WriteReg(R149, 0x0110);
  196.     LCD_WriteReg(R151, 0x0000);
  197.     LCD_WriteReg(R152, 0x0000);
  198.     /* Set GRAM write direction and BGR = 1
  199.        I/D=01 (Horizontal : increment, Vertical : decrement)
  200.        AM=1 (address is updated in vertical writing direction) */
  201.     LCD_WriteReg(R3, 0x1018);
  202.     LCD_WriteReg(R7, 0x0112);   /* 262K color and display ON */
  203.   }
  204.   else if(LCDType == LCD_HX8312)
  205.   {
  206.     /* Enable the LCD Oscillator ---------------------------------------------*/
  207.     LCD_WriteReg(R1, 0x10);
  208.     LCD_WriteReg(R0, 0xA0);
  209.     LCD_WriteReg(R3, 0x01);
  210.     Delay(1); /* Delay 10 ms */
  211.     LCD_WriteReg(R3, 0x00);
  212.     LCD_WriteReg(R43, 0x04);
  213.
  214.     LCD_WriteReg(R40, 0x18);
  215.     LCD_WriteReg(R26, 0x05);
  216.     LCD_WriteReg(R37, 0x05);
  217.     LCD_WriteReg(R25, 0x00);
  218.
  219.     /* LCD Power On ----------------------------------------------------------*/
  220.     LCD_WriteReg(R28, 0x73);
  221.     LCD_WriteReg(R36, 0x74);
  222.     LCD_WriteReg(R30, 0x01);
  223.     LCD_WriteReg(R24, 0xC1);
  224.     Delay(1); /* Delay 10 ms */
  225.     LCD_WriteReg(R24, 0xE1);
  226.     LCD_WriteReg(R24, 0xF1);
  227.     Delay(6); /* Delay 60 ms */
  228.     LCD_WriteReg(R24, 0xF5);
  229.     Delay(6); /* Delay 60 ms */
  230.     LCD_WriteReg(R27, 0x09);
  231.     Delay(1); /* Delay 10 ms */
  232.     LCD_WriteReg(R31, 0x11);
  233.     LCD_WriteReg(R32, 0x0E);
  234.     LCD_WriteReg(R30, 0x81);
  235.     Delay(1); /* Delay 10 ms */
  236.
  237.     /* Chip Set --------------------------------------------------------------*/
  238.     LCD_WriteReg(R157, 0x00);
  239.     LCD_WriteReg(R192, 0x00);
  240.
  241.     LCD_WriteReg(R14, 0x00);
  242.     LCD_WriteReg(R15, 0x00);
  243.     LCD_WriteReg(R16, 0x00);
  244.     LCD_WriteReg(R17, 0x00);
  245.     LCD_WriteReg(R18, 0x00);
  246.     LCD_WriteReg(R19, 0x00);
  247.     LCD_WriteReg(R20, 0x00);
  248.     LCD_WriteReg(R21, 0x00);
  249.     LCD_WriteReg(R22, 0x00);
  250.     LCD_WriteReg(R23, 0x00);
  251.
  252.     LCD_WriteReg(R52, 0x01);
  253.     LCD_WriteReg(R53, 0x00);
  254.     LCD_WriteReg(R75, 0x00);
  255.     LCD_WriteReg(R76, 0x00);
  256.     LCD_WriteReg(R78, 0x00);
  257.     LCD_WriteReg(R79, 0x00);
  258.     LCD_WriteReg(R80, 0x00);
  259.
  260.     LCD_WriteReg(R60, 0x00);
  261.     LCD_WriteReg(R61, 0x00);
  262.     LCD_WriteReg(R62, 0x01);
  263.     LCD_WriteReg(R63, 0x3F);
  264.     LCD_WriteReg(R64, 0x02);
  265.     LCD_WriteReg(R65, 0x02);
  266.     LCD_WriteReg(R66, 0x00);
  267.     LCD_WriteReg(R67, 0x00);
  268.     LCD_WriteReg(R68, 0x00);
  269.     LCD_WriteReg(R69, 0x00);
  270.     LCD_WriteReg(R70, 0xEF);
  271.     LCD_WriteReg(R71, 0x00);
  272.     LCD_WriteReg(R72, 0x00);
  273.     LCD_WriteReg(R73, 0x01);
  274.     LCD_WriteReg(R74, 0x3F);
  275.
  276.     LCD_WriteReg(R29, 0x08);  /* R29:Gate scan direction setting */
  277.
  278.     LCD_WriteReg(R134, 0x00);
  279.     LCD_WriteReg(R135, 0x30);
  280.     LCD_WriteReg(R136, 0x02);
  281.     LCD_WriteReg(R137, 0x05);
  282.
  283.     LCD_WriteReg(R141, 0x01);  /* R141:Register set-up mode for one line clock */
  284.     LCD_WriteReg(R139, 0x20);  /* R139:One line SYSCLK number in one-line */
  285.     LCD_WriteReg(R51, 0x01);  /* R51:N line inversion setting */
  286.     LCD_WriteReg(R55, 0x01);  /* R55:Scanning method setting */
  287.     LCD_WriteReg(R118, 0x00);
  288.
  289.     /* Gamma Set -------------------------------------------------------------*/
  290.     LCD_WriteReg(R143, 0x10);
  291.     LCD_WriteReg(R144, 0x67);
  292.     LCD_WriteReg(R145, 0x07);
  293.     LCD_WriteReg(R146, 0x65);
  294.     LCD_WriteReg(R147, 0x07);
  295.     LCD_WriteReg(R148, 0x01);
  296.     LCD_WriteReg(R149, 0x76);
  297.     LCD_WriteReg(R150, 0x56);
  298.     LCD_WriteReg(R151, 0x00);
  299.     LCD_WriteReg(R152, 0x06);
  300.     LCD_WriteReg(R153, 0x03);
  301.     LCD_WriteReg(R154, 0x00);
  302.
  303.     /* Display On ------------------------------------------------------------*/
  304.     LCD_WriteReg(R1, 0x50);
  305.     LCD_WriteReg(R5, 0x04);
  306.     LCD_WriteReg(R0, 0x80);
  307.     LCD_WriteReg(R59, 0x01);
  308.     Delay(4);  /* Delay 40 ms */
  309.     LCD_WriteReg(R0, 0x20);
  310.   }
  311. }
  312. /**
  313.   * @brief  Initializes the LCD.
  314.   * @param  None
  315.   * @retval : None
  316.   */
  317. void STM3210B_LCD_Init(void)
  318. {
  319.   /* Setups the LCD */
  320.   LCD_Setup();
  321.   /* Try to read new LCD controller ID 0x9320 */
  322.   if (LCD_ReadReg(R0) == LCD_ILI9320)
  323.   {
  324.     LCDType = LCD_ILI9320;
  325.   }
  326.   else
  327.   {
  328.     LCDType = LCD_SPFD5408;
  329.     /* Setups the LCD */
  330.     LCD_Setup();
  331.     /* Try to read new LCD controller ID 0x5408 */
  332.     if (LCD_ReadReg(R0) != LCD_SPFD5408)
  333.     {
  334.       LCDType = LCD_HX8312;
  335.       /* Setups the LCD */
  336.       LCD_Setup();
  337.     }
  338.   }
  339. }
  340. /**
  341.   * @brief  Sets the Text color.
  342.   * @param Color: specifies the Text color code RGB(5-6-5).
  343.   *   and LCD_DrawPicture functions.
  344.   * @retval : None
  345.   */
  346. void LCD_SetTextColor(__IO uint16_t Color)
  347. {
  348.   TextColor = Color;
  349. }
  350. /**
  351.   * @brief  Sets the Background color.
  352.   * @param Color: specifies the Background color code RGB(5-6-5).
  353.   *   LCD_DrawChar and LCD_DrawPicture functions.
  354.   * @retval : None
  355.   */
  356. void LCD_SetBackColor(__IO uint16_t Color)
  357. {
  358.   BackColor = Color;
  359. }
  360. /**
  361.   * @brief  Clears the selected line.
  362.   * @param Line: the Line to be cleared.
  363.   *   This parameter can be one of the following values:
  364.   * @arg Linex: where x can be 0..9
  365.   * @retval : None
  366.   */
  367. void LCD_ClearLine(uint8_t Line)
  368. {
  369.   LCD_DisplayStringLine(Line, "                    ");
  370. }
  371. /**
  372.   * @brief  Clears the hole LCD.
  373.   * @param lor: the color of the background.
  374.   * @retval : None
  375.   */
  376. void LCD_Clear(uint16_t Color)
  377. {
  378.   uint32_t index = 0;
  379.
  380.   LCD_SetCursor(0x00, 0x013F);
  381.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  382.   {
  383.     LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
  384.   }
  385.   for(index = 0; index < 76800; index++)
  386.   {
  387.     LCD_WriteRAM(Color);
  388.   }
  389.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  390.   {
  391.     LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
  392.   }
  393. }
  394. /**
  395.   * @brief  Sets the cursor position.
  396.   * @param Xpos: specifies the X position.
  397.   * @param Ypos: specifies the Y position.
  398.   * @retval : None
  399.   */
  400. void LCD_SetCursor(uint8_t Xpos, uint16_t Ypos)
  401. {
  402.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  403.   {
  404.     LCD_WriteReg(R32, Xpos);
  405.     LCD_WriteReg(R33, Ypos);
  406.   }
  407.   else if(LCDType == LCD_HX8312)
  408.   {
  409.     LCD_WriteReg(R66, Xpos);
  410.     LCD_WriteReg(R67, ((Ypos & 0x100)>> 8));
  411.     LCD_WriteReg(R68, (Ypos & 0xFF));
  412.   }
  413. }
  414. /**
  415.   * @brief  Draws a character on LCD.
  416.   * @param Xpos: the Line where to display the character shape.
  417.   *   This parameter can be one of the following values:
  418.   * @param Linex: where x can be 0..9
  419.   * @param Ypos: start column address.
  420.   * @param c: pointer to the character data.
  421.   * @retval : None
  422.   */
  423. void LCD_DrawChar(uint8_t Xpos, uint16_t Ypos, const uint16_t *c)
  424. {
  425.   uint32_t index = 0, i = 0;
  426.   uint8_t Xaddress = 0;
  427.
  428.   Xaddress = Xpos;
  429.
  430.   LCD_SetCursor(Xaddress, Ypos);
  431.
  432.   for(index = 0; index < 24; index++)
  433.   {
  434.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  435.     {
  436.       LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
  437.     }
  438.     for(i = 0; i < 16; i++)
  439.     {
  440.       if((c[index] & (1 << i)) == 0x00)
  441.       {
  442.         LCD_WriteRAM(BackColor);
  443.       }
  444.       else
  445.       {
  446.         LCD_WriteRAM(TextColor);
  447.       }
  448.     }
  449.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  450.     {
  451.       LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
  452.     }
  453.     Xaddress++;
  454.     LCD_SetCursor(Xaddress, Ypos);
  455.   }
  456. }
  457. /**
  458.   * @brief  Displays one character (16dots width, 24dots height).
  459.   * @param Line: the Line where to display the character shape .
  460.   *   This parameter can be one of the following values:
  461.   * @arg Linex: where x can be 0..9
  462.   * @param Column: start column address.
  463.   * @param Ascii: character ascii code, must be between 0x20 and 0x7E.
  464.   * @retval : None
  465.   */
  466. void LCD_DisplayChar(uint8_t Line, uint16_t Column, uint8_t Ascii)
  467. {
  468.   Ascii -= 32;
  469.   LCD_DrawChar(Line, Column, &ASCII_Table[Ascii * 24]);
  470. }
  471. /**
  472.   * @brief  Displays a maximum of 20 char on the LCD.
  473.   * @param Line: the Line where to display the character shape .
  474.   *   This parameter can be one of the following values:
  475.   * @arg Linex: where x can be 0..9
  476.   * @param *ptr: pointer to string to display on LCD.
  477.   * @retval : None
  478.   */
  479. void LCD_DisplayStringLine(uint8_t Line, uint8_t *ptr)
  480. {
  481.   uint32_t i = 0;
  482.   uint16_t refcolumn = 319;
  483.   /* Send the string character by character on lCD */
  484.   while ((*ptr != 0) & (i < 20))
  485.   {
  486.     /* Display one character on LCD */
  487.     LCD_DisplayChar(Line, refcolumn, *ptr);
  488.     /* Decrement the column position by 16 */
  489.     refcolumn -= 16;
  490.     /* Point on the next character */
  491.     ptr++;
  492.     /* Increment the character counter */
  493.     i++;
  494.   }
  495. }
  496. /**
  497.   * @brief  Sets a display window
  498.   * @param Xpos: specifies the X buttom left position.
  499.   * @param Ypos: specifies the Y buttom left position.
  500.   * @param Height: display window height.
  501.   * @param Width: display window width.
  502.   * @retval : None
  503.   */
  504. void LCD_SetDisplayWindow(uint8_t Xpos, uint16_t Ypos, uint8_t Height, uint16_t Width)
  505. {
  506.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  507.   {
  508.     /* Horizontal GRAM Start Address */
  509.     if(Xpos >= Height)
  510.     {
  511.       LCD_WriteReg(R80, (Xpos - Height + 1));
  512.     }
  513.     else
  514.     {
  515.       LCD_WriteReg(R80, 0);
  516.     }
  517.     /* Horizontal GRAM End Address */
  518.     LCD_WriteReg(R81, Xpos);
  519.     /* Vertical GRAM Start Address */
  520.     if(Ypos >= Width)
  521.     {
  522.       LCD_WriteReg(R82, (Ypos - Width + 1));
  523.     }
  524.     else
  525.     {
  526.       LCD_WriteReg(R82, 0);
  527.     }
  528.     /* Vertical GRAM End Address */
  529.     LCD_WriteReg(R83, Ypos);
  530.   }
  531.   else if(LCDType == LCD_HX8312)
  532.   {
  533.     LCD_WriteReg(R1, 0xD0);
  534.     LCD_WriteReg(R5, 0x14);
  535.
  536.     LCD_WriteReg(R69, (Xpos - Height + 1));
  537.     LCD_WriteReg(R70, Xpos);
  538.     LCD_WriteReg(R71, (((Ypos - Width + 1) & 0x100)>> 8));
  539.     LCD_WriteReg(R72, ((Ypos - Width + 1) & 0xFF));
  540.     LCD_WriteReg(R73, ((Ypos & 0x100)>> 8));
  541.     LCD_WriteReg(R74, (Ypos & 0xFF));
  542.   }
  543.   LCD_SetCursor(Xpos, Ypos);
  544. }
  545. /**
  546.   * @brief  Disables LCD Window mode.
  547.   * @param  None
  548.   * @retval : None
  549.   */
  550. void LCD_WindowModeDisable(void)
  551. {
  552.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  553.   {
  554.     LCD_SetDisplayWindow(239, 0x13F, 240, 320);
  555.     LCD_WriteReg(R3, 0x1018);
  556.   }
  557.   else if(LCDType == LCD_HX8312)
  558.   {
  559.     LCD_WriteReg(R1, 0x50);
  560.     LCD_WriteReg(R5, 0x04);
  561.   }
  562.
  563. }
  564. /**
  565.   * @brief  Displays a line.
  566.   * @param Xpos: specifies the X position.
  567.   * @param Ypos: specifies the Y position.
  568.   * @param Length: line length.
  569.   * @param Direction: line direction.
  570.   *   This parameter can be one of the following values: Vertical
  571.   *   or Horizontal.
  572.   * @retval : None
  573.   */
  574. void LCD_DrawLine(uint8_t Xpos, uint16_t Ypos, uint16_t Length, uint8_t Direction)
  575. {
  576.   uint32_t i = 0;
  577.
  578.   LCD_SetCursor(Xpos, Ypos);
  579.   if(Direction == Horizontal)
  580.   {
  581.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  582.     {
  583.       LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
  584.     }
  585.     for(i = 0; i < Length; i++)
  586.     {
  587.       LCD_WriteRAM(TextColor);
  588.     }
  589.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  590.     {
  591.       LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
  592.     }
  593.   }
  594.   else
  595.   {
  596.    for(i = 0; i < Length; i++)
  597.     {
  598.       if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  599.       {
  600.         LCD_WriteRAMWord(TextColor);
  601.       }
  602.       else  if(LCDType == LCD_HX8312)
  603.       {
  604.         LCD_WriteRAM(TextColor);
  605.       }
  606.       Xpos++;
  607.       LCD_SetCursor(Xpos, Ypos);
  608.     }
  609.   }
  610. }
  611. /**
  612.   * @brief  Displays a rectangle.
  613.   * @param Xpos: specifies the X position.
  614.   * @param Ypos: specifies the Y position.
  615.   * @param Height: display rectangle height.
  616.   * @param Width: display rectangle width.
  617.   * @retval : None
  618.   */
  619. void LCD_DrawRect(uint8_t Xpos, uint16_t Ypos, uint8_t Height, uint16_t Width)
  620. {
  621.   LCD_DrawLine(Xpos, Ypos, Width, Horizontal);
  622.   LCD_DrawLine((Xpos + Height), Ypos, Width, Horizontal);
  623.
  624.   LCD_DrawLine(Xpos, Ypos, Height, Vertical);
  625.   LCD_DrawLine(Xpos, (Ypos - Width + 1), Height, Vertical);
  626. }
  627. /**
  628.   * @brief  Displays a circle.
  629.   * @param Xpos: specifies the X position.
  630.   * @param Ypos: specifies the Y position.
  631.   * @param Height: display rectangle height.
  632.   * @param Width: display rectangle width.
  633.   * @retval : None
  634.   */
  635. void LCD_DrawCircle(uint8_t Xpos, uint16_t Ypos, uint16_t Radius)
  636. {
  637.   int32_t  D;/* Decision Variable */
  638.   uint32_t  CurX;/* Current X Value */
  639.   uint32_t  CurY;/* Current Y Value */
  640.
  641.   D = 3 - (Radius << 1);
  642.   CurX = 0;
  643.   CurY = Radius;
  644.
  645.   while (CurX <= CurY)
  646.   {
  647.     LCD_SetCursor(Xpos + CurX, Ypos + CurY);
  648.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  649.     {
  650.       LCD_WriteRAMWord(TextColor);
  651.     }
  652.     else if(LCDType == LCD_HX8312)
  653.     {
  654.       LCD_WriteRAM(TextColor);
  655.     }
  656.     LCD_SetCursor(Xpos + CurX, Ypos - CurY);
  657.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  658.     {
  659.       LCD_WriteRAMWord(TextColor);
  660.     }
  661.     else if(LCDType == LCD_HX8312)
  662.     {
  663.       LCD_WriteRAM(TextColor);
  664.     }
  665.     LCD_SetCursor(Xpos - CurX, Ypos + CurY);
  666.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  667.     {
  668.       LCD_WriteRAMWord(TextColor);
  669.     }
  670.     else if(LCDType == LCD_HX8312)
  671.     {
  672.       LCD_WriteRAM(TextColor);
  673.     }
  674.     LCD_SetCursor(Xpos - CurX, Ypos - CurY);
  675.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  676.     {
  677.       LCD_WriteRAMWord(TextColor);
  678.     }
  679.     else if(LCDType == LCD_HX8312)
  680.     {
  681.       LCD_WriteRAM(TextColor);
  682.     }
  683.     LCD_SetCursor(Xpos + CurY, Ypos + CurX);
  684.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  685.     {
  686.       LCD_WriteRAMWord(TextColor);
  687.     }
  688.     else if(LCDType == LCD_HX8312)
  689.     {
  690.       LCD_WriteRAM(TextColor);
  691.     }
  692.     LCD_SetCursor(Xpos + CurY, Ypos - CurX);
  693.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  694.     {
  695.       LCD_WriteRAMWord(TextColor);
  696.     }
  697.     else if(LCDType == LCD_HX8312)
  698.     {
  699.       LCD_WriteRAM(TextColor);
  700.     }
  701.     LCD_SetCursor(Xpos - CurY, Ypos + CurX);
  702.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  703.     {
  704.       LCD_WriteRAMWord(TextColor);
  705.     }
  706.     else if(LCDType == LCD_HX8312)
  707.     {
  708.       LCD_WriteRAM(TextColor);
  709.     }
  710.     LCD_SetCursor(Xpos - CurY, Ypos - CurX);
  711.     if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  712.     {
  713.       LCD_WriteRAMWord(TextColor);
  714.     }
  715.     else if(LCDType == LCD_HX8312)
  716.     {
  717.       LCD_WriteRAM(TextColor);
  718.     }
  719.     if (D < 0)
  720.     {
  721.       D += (CurX << 2) + 6;
  722.     }
  723.     else
  724.     {
  725.       D += ((CurX - CurY) << 2) + 10;
  726.       CurY--;
  727.     }
  728.     CurX++;
  729.   }
  730. }
  731. /**
  732.   * @brief  Displays a monocolor picture.
  733.   * @param Pict: pointer to the picture array.
  734.   * @retval : None
  735.   */
  736. void LCD_DrawMonoPict(const uint32_t *Pict)
  737. {
  738.   uint32_t index = 0, i = 0;
  739.   LCD_SetCursor(0, 319);
  740.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  741.   {
  742.     LCD_WriteRAM_Prepare(); /* Prepare to write GRAM */
  743.   }
  744.   for(index = 0; index < 2400; index++)
  745.   {
  746.     for(i = 0; i < 32; i++)
  747.     {
  748.       if((Pict[index] & (1 << i)) == 0x00)
  749.       {
  750.         LCD_WriteRAM(BackColor);
  751.       }
  752.       else
  753.       {
  754.         LCD_WriteRAM(TextColor);
  755.       }
  756.     }
  757.   }
  758.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  759.   {
  760.     LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
  761.   }
  762. }
  763. /**
  764.   * @brief  Reset LCD control line(/CS) and Send Start-Byte
  765.   * @param Start_Byte: the Start-Byte to be sent
  766.   * @retval : None
  767.   */
  768. void LCD_nCS_StartByte(uint8_t Start_Byte)
  769. {
  770.   LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_RESET);
  771.   SPI_I2S_SendData(SPI2, Start_Byte);
  772.   while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  773.   {
  774.   }
  775. }
  776. /**
  777.   * @brief  Writes index to select the LCD register.
  778.   * @param LCD_Reg: address of the selected register.
  779.   * @retval : None
  780.   */
  781. void LCD_WriteRegIndex(uint8_t LCD_Reg)
  782. {
  783.   /* Reset LCD control line(/CS) and Send Start-Byte */
  784.   LCD_nCS_StartByte(START_BYTE | SET_INDEX);
  785.   /* Write 16-bit Reg Index (High Byte is 0) */
  786.   SPI_I2S_SendData(SPI2, 0x00);
  787.   while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  788.   {
  789.   }
  790.   SPI_I2S_SendData(SPI2, LCD_Reg);
  791.   while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  792.   {
  793.   }
  794.   LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
  795. }
  796. /**
  797.   * @brief  Writes to the selected LCD ILI9320 register.
  798.   * @param LCD_Reg: address of the selected register.
  799.   * @arg LCD_RegValue: value to write to the selected register.
  800.   * @retval : None
  801.   */
  802. static void LCD_WriteRegILI9320(uint8_t LCD_Reg, uint16_t LCD_RegValue)
  803. {
  804.   /* Write 16-bit Index (then Write Reg) */
  805.   LCD_WriteRegIndex(LCD_Reg);
  806.   /* Write 16-bit Reg */
  807.   /* Reset LCD control line(/CS) and Send Start-Byte */
  808.   LCD_nCS_StartByte(START_BYTE | LCD_WRITE_REG);
  809.   SPI_I2S_SendData(SPI2, LCD_RegValue>>8);
  810.   while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  811.   {
  812.   }
  813.   SPI_I2S_SendData(SPI2, (LCD_RegValue & 0xFF));
  814.   while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  815.   {
  816.   }
  817.   LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
  818. }
  819. /**
  820.   * @brief  Reads the selected LCD Register.
  821.   * @param  None
  822.   * @retval : LCD Register Value.
  823.   */
  824. uint16_t LCD_ReadReg(uint8_t LCD_Reg)
  825. {
  826.   uint16_t tmp = 0;
  827.   uint8_t i = 0;
  828.
  829.   /* SPI2 prescaler: 4 */
  830.   SPI2->CR1 &= 0xFFC7;
  831.   SPI2->CR1 |= 0x0008;
  832.   /* Write 16-bit Index (then Read Reg) */
  833.   LCD_WriteRegIndex(LCD_Reg);
  834.   /* Read 16-bit Reg */
  835.   /* Reset LCD control line(/CS) and Send Start-Byte */
  836.   LCD_nCS_StartByte(START_BYTE | LCD_READ_REG);
  837.
  838.   for(i = 0; i < 5; i++)
  839.   {
  840.     SPI_I2S_SendData(SPI2, 0xFF);
  841.     while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  842.     {
  843.     }
  844.     /* One byte of invalid dummy data read after the start byte */
  845.     while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET)
  846.     {
  847.     }
  848.     SPI_I2S_ReceiveData(SPI2);
  849.   }
  850.   SPI_I2S_SendData(SPI2, 0xFF);
  851.   /* Read upper byte */
  852.   while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  853.   {
  854.   }
  855.   /* Read lower byte */
  856.   while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET)
  857.   {
  858.   }
  859.   tmp = SPI_I2S_ReceiveData(SPI2);
  860.
  861.
  862.   SPI_I2S_SendData(SPI2, 0xFF);
  863.   while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  864.   {
  865.   }
  866.   /* Read lower byte */
  867.   while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET)
  868.   {
  869.   }
  870.   tmp = ((tmp & 0xFF) << 8) | SPI_I2S_ReceiveData(SPI2);
  871.   LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
  872.   /* SPI2 prescaler: 2 */
  873.   SPI2->CR1 &= 0xFFC7;
  874.   return tmp;
  875. }
  876. /**
  877.   * @brief  Prepare to write to the LCD RAM.
  878.   * @param  None
  879.   * @retval : None
  880.   */
  881. void LCD_WriteRAM_Prepare(void)
  882. {
  883.   LCD_WriteRegIndex(R34); /* Select GRAM Reg */
  884.   /* Reset LCD control line(/CS) and Send Start-Byte */
  885.   LCD_nCS_StartByte(START_BYTE | LCD_WRITE_REG);
  886. }
  887. /**
  888.   * @brief  Writes 1 word to the LCD RAM.
  889.   * @param RGB_Code: the pixel color in RGB mode (5-6-5).
  890.   * @retval : None
  891.   */
  892. void LCD_WriteRAMWord(uint16_t RGB_Code)
  893. {
  894.   LCD_WriteRAM_Prepare();
  895.   LCD_WriteRAM(RGB_Code);
  896.   LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
  897. }
  898. /**
  899.   * @brief  Writes to the selected LCD HX8312 register.
  900.   * @param LCD_Reg: address of the selected register.
  901.   * @arg LCD_RegValue: value to write to the selected register.
  902.   * @retval : None
  903.   */
  904. static void LCD_WriteRegHX8312(uint8_t LCD_Reg, uint8_t LCD_RegValue)
  905. {
  906.   uint16_t tmp = 0;
  907.
  908.   LCD_CtrlLinesWrite(GPIOD, CtrlPin_NWR, Bit_RESET);
  909.   LCD_CtrlLinesWrite(GPIOD, CtrlPin_RS, Bit_RESET);
  910.   LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_RESET);
  911.
  912.   tmp = LCD_Reg << 8;
  913.   tmp |= LCD_RegValue;
  914.   SPI_I2S_SendData(SPI2, tmp);
  915.   while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  916.   {
  917.   }
  918.
  919.   LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
  920. }
  921. /**
  922.   * @brief  Writes to the selected LCD register.
  923.   * @param LCD_Reg: address of the selected register.
  924.   * @arg LCD_RegValue: value to write to the selected register.
  925.   * @retval : None
  926.   */
  927. void LCD_WriteReg(uint8_t LCD_Reg, uint16_t LCD_RegValue)
  928. {
  929.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  930.   {
  931.     LCD_WriteRegILI9320(LCD_Reg, LCD_RegValue);
  932.   }
  933.   else if(LCDType == LCD_HX8312)
  934.   {
  935.     LCD_WriteRegHX8312(LCD_Reg, ((uint8_t)LCD_RegValue));
  936.   }
  937. }
  938. /**
  939.   * @brief  Writes to the LCD RAM.
  940.   * @param RGB_Code: the pixel color in RGB mode (5-6-5).
  941.   * @retval : None
  942.   */
  943. void LCD_WriteRAM(uint16_t RGB_Code)
  944. {
  945.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  946.   {
  947.     SPI_I2S_SendData(SPI2, RGB_Code >> 8);
  948.     while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  949.     {
  950.     }
  951.     SPI_I2S_SendData(SPI2, RGB_Code & 0xFF);
  952.     while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  953.     {
  954.     }
  955.   }
  956.   if(LCDType == LCD_HX8312)
  957.   {
  958.     LCD_CtrlLinesWrite(GPIOD, CtrlPin_NWR, Bit_RESET);
  959.     LCD_CtrlLinesWrite(GPIOD, CtrlPin_RS, Bit_SET);
  960.     LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_RESET);
  961.     SPI_I2S_SendData(SPI2, RGB_Code);
  962.     while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_BSY) != RESET)
  963.     {
  964.     }
  965.
  966.     LCD_CtrlLinesWrite(GPIOB, CtrlPin_NCS, Bit_SET);
  967.   }
  968. }
  969. /**
  970.   * @brief  Power on the LCD.
  971.   * @param  None
  972.   * @retval : None
  973.   */
  974. void LCD_PowerOn(void)
  975. {
  976.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  977.   {
  978.     /* Power On sequence ---------------------------------------------------------*/
  979.     LCD_WriteReg(R16, 0x0000); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
  980.     LCD_WriteReg(R17, 0x0000); /* DC1[2:0], DC0[2:0], VC[2:0] */
  981.     LCD_WriteReg(R18, 0x0000); /* VREG1OUT voltage */
  982.     LCD_WriteReg(R19, 0x0000); /* VDV[4:0] for VCOM amplitude */
  983.     Delay(20);                 /* Dis-charge capacitor power voltage (200ms) */
  984.     LCD_WriteReg(R16, 0x17B0); /* SAP, BT[3:0], AP, DSTB, SLP, STB */
  985.     LCD_WriteReg(R17, 0x0137); /* DC1[2:0], DC0[2:0], VC[2:0] */
  986.     Delay(5);                  /* Delay 50 ms */
  987.     LCD_WriteReg(R18, 0x0139); /* VREG1OUT voltage */
  988.     Delay(5);                  /* delay 50 ms */
  989.     LCD_WriteReg(R19, 0x1d00); /* VDV[4:0] for VCOM amplitude */
  990.     LCD_WriteReg(R41, 0x0013); /* VCM[4:0] for VCOMH */
  991.     Delay(5);                  /* delay 50 ms */
  992.     LCD_WriteReg(R7, 0x0173);  /* 262K color and display ON */
  993.   }
  994.   else if(LCDType == LCD_HX8312)
  995.   {
  996.     /* Power On Set */
  997.     LCD_WriteReg(R28, 0x73);
  998.     LCD_WriteReg(R36, 0x74);
  999.     LCD_WriteReg(R30, 0x01);
  1000.     LCD_WriteReg(R24, 0xC1);
  1001.     Delay(1); /* Delay 10 ms */
  1002.     LCD_WriteReg(R24, 0xE1);
  1003.     LCD_WriteReg(R24, 0xF1);
  1004.     Delay(6); /* Delay 60 ms */
  1005.     LCD_WriteReg(R24, 0xF5);
  1006.     Delay(6); /* Delay 60 ms */
  1007.     LCD_WriteReg(R27, 0x09);
  1008.     Delay(1); /* Delay 10 ms */
  1009.     LCD_WriteReg(R31, 0x11);
  1010.     LCD_WriteReg(R32, 0x0E);
  1011.     LCD_WriteReg(R30, 0x81);
  1012.     Delay(1); /* Delay 10 ms */
  1013.   }
  1014. }
  1015. /**
  1016.   * @brief  Enables the Display.
  1017.   * @param  None
  1018.   * @retval : None
  1019.   */
  1020. void LCD_DisplayOn(void)
  1021. {
  1022.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  1023.   {
  1024.     /* Display On */
  1025.     LCD_WriteReg(R7, 0x0173); /* 262K color and display ON */
  1026.   }
  1027.   else if(LCDType == LCD_HX8312)
  1028.   {
  1029.     LCD_WriteReg(R1, 0x50);
  1030.     LCD_WriteReg(R5, 0x04);
  1031.     /* Display On */
  1032.     LCD_WriteReg(R0, 0x80);
  1033.     LCD_WriteReg(R59, 0x01);
  1034.     Delay(4);                 /* Delay 40 ms */
  1035.     LCD_WriteReg(R0, 0x20);
  1036.   }
  1037. }
  1038. /**
  1039.   * @brief  Disables the Display.
  1040.   * @param  None
  1041.   * @retval : None
  1042.   */
  1043. void LCD_DisplayOff(void)
  1044. {
  1045.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  1046.   {
  1047.     /* Display Off */
  1048.     LCD_WriteReg(R7, 0x0);
  1049.   }
  1050.   else if(LCDType == LCD_HX8312)
  1051.   {
  1052.     /* Display Off */
  1053.     LCD_WriteReg(R0, 0xA0);
  1054.     Delay(4);                 /* Delay 40 ms */
  1055.     LCD_WriteReg(R59, 0x00);
  1056.   }
  1057. }
  1058. /**
  1059.   * @brief  Configures LCD control lines in Output Push-Pull mode.
  1060.   * @param  None
  1061.   * @retval : None
  1062.   */
  1063. void LCD_CtrlLinesConfig(void)
  1064. {
  1065.   GPIO_InitTypeDef GPIO_InitStructure;
  1066.   /* Configure NCS (PB.02) in Output Push-Pull mode */
  1067.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  1068.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  1069.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  1070.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  1071.
  1072.   /* Configure NWR(RNW), RS (PD.15, PD.07) in Output Push-Pull mode */
  1073.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_15;
  1074.   GPIO_Init(GPIOD, &GPIO_InitStructure);
  1075.
  1076.   LCD_CtrlLinesWrite(GPIOD, CtrlPin_NWR, Bit_SET);
  1077.   LCD_CtrlLinesWrite(GPIOD, CtrlPin_RS, Bit_SET);
  1078. }
  1079. /**
  1080.   * @brief  Sets or reset LCD control lines.
  1081.   * @param GPIOx: where x can be B or D to select the GPIO peripheral.
  1082.   * @param CtrlPins: the Control line. This parameter can be:
  1083.   * @param CtrlPin_NCS: Chip Select pin (PB.02)
  1084.   * @param CtrlPin_NWR: Read/Write Selection pin (PD.15)
  1085.   * @param CtrlPin_RS: Register/RAM Selection pin (PD.07)
  1086.   * @param BitVal: specifies the value to be written to the selected bit.
  1087.   *   This parameter can be:
  1088.   * @param Bit_RESET: to clear the port pin
  1089.   * @param Bit_SET: to set the port pin
  1090.   * @retval : None
  1091.   */
  1092. void LCD_CtrlLinesWrite(GPIO_TypeDef* GPIOx, uint16_t CtrlPins, BitAction BitVal)
  1093. {
  1094.   /* Set or Reset the control line */
  1095.   GPIO_WriteBit(GPIOx, CtrlPins, BitVal);
  1096. }
  1097. /**
  1098.   * @brief  Configures the SPI2 interface.
  1099.   * @param  None
  1100.   * @retval : None
  1101.   */
  1102. void LCD_SPIConfig(void)
  1103. {
  1104.   SPI_InitTypeDef    SPI_InitStructure;
  1105.   GPIO_InitTypeDef   GPIO_InitStructure;
  1106.   /* Enable GPIOB clock */
  1107.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  1108.   /* Enable SPI2 clock  */
  1109.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  1110.   /* Configure SPI2 pins: NSS, SCK, MISO and MOSI */
  1111.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
  1112.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  1113.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  1114.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  1115.   SPI_I2S_DeInit(SPI2);
  1116.
  1117.   /* SPI2 Config */
  1118.   SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  1119.   SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  1120.   if((LCDType == LCD_ILI9320) || (LCDType == LCD_SPFD5408))
  1121.   {
  1122.     SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  1123.     SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  1124.     SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  1125.   }
  1126.   else if(LCDType == LCD_HX8312)
  1127.   {
  1128.     SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
  1129.     SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
  1130.     SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  1131.   }
  1132.   SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  1133.   SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
  1134.   SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  1135.   SPI_Init(SPI2, &SPI_InitStructure);
  1136.   /* SPI2 enable */
  1137.   SPI_Cmd(SPI2, ENABLE);
  1138. }
  1139. /**
  1140.   * @}
  1141.   */
  1142. /******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
收藏收藏3 分享淘帖 頂 踩
ID:95186 發表于 2015-11-21 08:13 | 只看該作者
可以把    來看看俺的餓
ID:96660 發表于 2015-11-22 04:44 | 只看該作者
南無觀世音菩薩,感謝樓主分享。
ID:109094 發表于 2016-3-15 21:48 | 只看該作者
正要學習呢,感謝樓主
ID:109094 發表于 2016-3-15 21:51 | 只看該作者
不錯,正在學習dsp,感謝樓主分享
ID:120174 發表于 2016-5-11 22:51 | 只看該作者
非常感謝
ID:147443 發表于 2016-11-14 15:39 | 只看該作者
看看,。幫頂
ID:85788 發表于 2017-1-10 17:49 | 只看該作者
好東西,謝謝分享
ID:193126 發表于 2017-4-24 17:53 | 只看該作者
樓主的東西真心不錯,感謝!
ID:169559 發表于 2017-4-25 08:23 | 只看該作者
謝謝分享!
ID:194323 發表于 2017-4-27 19:37 來自觸屏版 | 只看該作者
好東西,謝謝分享
ID:223897 發表于 2017-8-7 20:46 | 只看該作者
正好需要這個,謝謝樓主
ID:224179 發表于 2017-8-23 21:19 | 只看該作者
感謝分享
ID:233417 發表于 2017-9-15 23:56 | 只看該作者
好東西,可惜沒有積分下載不了
ID:233417 發表于 2017-9-16 00:05 | 只看該作者
正在做這方面的項目,可惜下載不了
ID:186131 發表于 2017-9-16 10:14 | 只看該作者
正在做這方面的項目,可惜下載不了
ID:233487 發表于 2017-9-16 17:21 | 只看該作者
牛人!學習一下!
ID:233588 發表于 2017-9-17 08:41 | 只看該作者
66666非常好
ID:238016 發表于 2017-10-9 15:17 | 只看該作者
好東西,謝謝分享。
ID:244198 發表于 2017-10-30 14:14 | 只看該作者
謝謝分享
ID:74229 發表于 2017-12-12 20:43 | 只看該作者
好東西,謝謝分享。
ID:204733 發表于 2018-5-1 20:27 | 只看該作者
感謝分享,學習了
ID:224401 發表于 2018-5-21 11:54 | 只看該作者
好東西,可惜沒有積分下載不了。
ID:374854 發表于 2018-7-19 14:50 | 只看該作者
好東西,謝謝分享。
ID:445737 發表于 2018-12-13 15:59 | 只看該作者
名字非常好的資料,單沒有積分。
ID:695637 發表于 2020-2-21 11:05 | 只看該作者
這是M3內核下的吧
ID:700459 發表于 2020-3-19 18:41 | 只看該作者
thank you very much
