完整程序源代碼工程文件下載地址:
唯一ID編碼 .RAR
(232.68 KB, 下載次數: 15)
2015-5-27 17:25 上傳
- STM32學習日志(19)----唯一ID編碼
- 編譯環境: EWARM V5.30
- 硬件環境: 南京萬利 EK-STM32F
- STM32 FW: V3.0.0
- 作者 : szlihongtao
- 時間 : 2017-07-28
- 說明 : 1.讀取stm32芯片的唯一id碼
- 2.讀取stm32芯片的閃存容量寄存器,單位為KB
- * @file Project/Template/main.c
- * @author MCD Application Team
- * @version V3.0.0
- * @date 04/06/2009
- * @brief Main program body
- * @copy
- * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
- * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
- * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
- * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
- * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- * <h2><center>© COPYRIGHT 2009 STMicroelectronics</center></h2>
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f10x.h"
- #include "stm32_m.h"
- /** @addtogroup Template_Project
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- * @brief Main program.
- * @param None
- * @retval : None
- // 延時50ms
- static void delay(void)
- INT32U i;
- static INT32U jjj=5240*50;
- for (i=0; i<jjj; i++);
- // 時鐘設置初始化
- static void RCC_Configuration(void)
- ErrorStatus HSEStartUpStatus;
- RCC_AdjustHSICalibrationValue 調整內部高速晶振(HSI)校準值
- RCC_ITConfig 使能或者失能指定的RCC中斷
- RCC_ClearFlag 清除RCC的復位標志位
- RCC_GetITStatus 檢查指定的RCC中斷發生與否
- RCC_ClearITPendingBit 清除RCC的中斷待處理位
- /* RCC system reset(for debug purpose) */
- // 時鐘系統復位
- RCC_DeInit();
- // 使能外部的8M晶振
- // 設置外部高速晶振(HSE)
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- // 使能或者失能內部高速晶振(HSI)
- RCC_HSICmd(DISABLE);
- // 等待HSE起振
- // 該函數將等待直到HSE就緒,或者在超時的情況下退出
- /* Wait till HSE is ready */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)
- /* HCLK = SYSCLK */
- // 設置AHB時鐘(HCLK)
- RCC_HCLKConfig(RCC_SYSCLK_Div1); // 72 MHz
- /* PCLK1 = HCLK/2 */
- // 設置低速AHB時鐘(PCLK1)
- RCC_PCLK1Config(RCC_HCLK_Div2); // 36 MHz
- /* PCLK2 = HCLK */
- // 設置高速AHB時鐘(PCLK2)
- RCC_PCLK2Config(RCC_HCLK_Div1); // 72 MHz
- /* ADCCLK = PCLK2/8 */
- // 設置ADC時鐘(ADCCLK)
- RCC_ADCCLKConfig(RCC_PCLK2_Div8);
- // 設置USB時鐘(USBCLK)
- // USB時鐘 = PLL時鐘除以1.5
- RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);
- // 設置外部低速晶振(LSE)
- RCC_LSEConfig(RCC_LSE_OFF);
- // 使能或者失能內部低速晶振(LSI)
- // LSE晶振OFF
- RCC_LSICmd(DISABLE);
- // 設置RTC時鐘(RTCCLK)
- // 選擇HSE時鐘頻率除以128作為RTC時鐘
- RCC_RTCCLKConfig(RCC_RTCCLKSource_HSE_Div128);
- // 使能或者失能RTC時鐘
- // RTC時鐘的新狀態
- RCC_RTCCLKCmd(DISABLE);
- /* Flash 2 wait state */
- FLASH_SetLatency(FLASH_Latency_2);
- /* Enable Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
- /* PLLCLK = 8MHz * 9 = 72 MHz */
- // 設置PLL時鐘源及倍頻系數
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
- /* Enable PLL */
- // 使能或者失能PLL
- RCC_PLLCmd(ENABLE);
- /* Wait till PLL is ready */
- // 檢查指定的RCC標志位設置與否
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
- /* Select PLL as system clock source */
- // 設置系統時鐘(SYSCLK)
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- /* Wait till PLL is used as system clock source */
- // 返回用作系統時鐘的時鐘源
- while(RCC_GetSYSCLKSource() != 0x08)
- // 使能或者失能AHB外設時鐘
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1
- |RCC_AHBPeriph_DMA2
- |RCC_AHBPeriph_SRAM
- |RCC_AHBPeriph_FLITF
- |RCC_AHBPeriph_CRC
- |RCC_AHBPeriph_FSMC
- |RCC_AHBPeriph_SDIO,DISABLE);
- // 使能或者失能APB1外設時鐘
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_ALL,DISABLE);
- // 強制或者釋放高速APB(APB2)外設復位
- RCC_APB2PeriphResetCmd(RCC_APB2Periph_ALL,ENABLE);
- // 退出復位狀態
- RCC_APB2PeriphResetCmd(RCC_APB2Periph_ALL,DISABLE);
- // 強制或者釋放低速APB(APB1)外設復位
- RCC_APB1PeriphResetCmd(RCC_APB1Periph_ALL,ENABLE);
- // 強制或者釋放后備域復位
- RCC_BackupResetCmd(ENABLE);
- // 使能或者失能時鐘安全系統
- RCC_ClockSecuritySystemCmd(DISABLE);
- // GPIO設置
- static void GPIO_Configuration(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- // 使能或者失能APB2外設時鐘
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- // LED5亮
- void Led_RW_ON(void)
- GPIO_SetBits(GPIOC,GPIO_Pin_4);
- // LED5滅
- void Led_RW_OFF(void)
- GPIO_ResetBits(GPIOC,GPIO_Pin_4);
- INT32U un; //閃存容量寄存器
- INT32U CpuID[3];
- INT32U Lock_Code;
- // 主程序
- int main(void)
- RCC_Configuration();
- GPIO_Configuration();
- Led_RW_ON();
- delay();
- Led_RW_OFF();
- un=(*( u16 *)0x1FFFF7E0); // 閃存容量寄存器,單位為KB
- // 仿真結果為128,與STM32F103VB的型號是一致的
- //獲取CPU唯一ID
- CpuID[0]=*(vu32*)(0x1ffff7e8); // 0XFFFFFF37
- CpuID[1]=*(vu32*)(0x1ffff7ec); // 0X31383836
- CpuID[2]=*(vu32*)(0x1ffff7f0); // 0X43163562
- //加密算法,很簡單的加密算法
- Lock_Code=(CpuID[0]>>1)+(CpuID[1]>>2)+(CpuID[2]>>3); // X94B0D454
- for (;;)
- delay();
- GPIOC->ODR ^= GPIO_Pin_4; // led5 toogle
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval : None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- /******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
- LED2---------PC7
- LED3---------PC6
- LED4---------PC5
- LED5---------PC4
- KEY2---------PD3
- KEY3---------PD4
