查看: 6025|回復: 12
密碼鎖
ID:77698 發(fā)表于 2015-5-25 22:34 | 顯示全部樓層 |閱讀模式
                    電子密碼鎖主函數(shù)
#include<reg51.h>
#include<12864.h>
#include<keypad.h>
#include<24C01.h>
sbit LED1=P1^5;
sbit LED2=P1^6;
sbit INIT=P2^2;
sbit SOUND=P1^7;
uchar idata key[6]={0,0,0,0,0,0};
uchar idata iic[6]={0,1,2,3,4,5};
void press(uchar *s)
           uchar dat;
       P3=0xf0;        //保存第一位密碼
           while(P3==0xf0);
       dat=key_scan();
           if((dat!=0x0a)&&(dat!=0x0b))
         {   *s=dat;
                         Left();
                         star_12864(star,0x05,16);
           s++;
           P3=0xf0;                                                          //保存第二位密碼
           while(P3==0xf0);
       dat=key_scan();
         {   *s=dat;
                         Left();
                         star_12864(star,0x05,24);
           s++;
           P3=0xf0;                                                          //保存第三位密碼
           while(P3==0xf0);
       dat=key_scan();
         {   *s=dat;
                         Left();
                         star_12864(star,0x05,32);
           s++;
           P3=0xf0;                                                          //保存第四位密碼
           while(P3==0xf0);
           dat=key_scan();
         {   *s=dat;
                         Left();
                         star_12864(star,0x05,40);
           s++;
           P3=0xf0;                                                          //保存第五位密碼
           while(P3==0xf0);
       dat=key_scan();
         {   *s=dat;
                         Left();
                         star_12864(star,0x05,48);
           s++;
           P3=0xf0;                                                          //保存第六位密碼
           while(P3==0xf0);
       dat=key_scan();
         {   *s=dat;
                         Left();
                         star_12864(star,0x05,56);
           do{P3=0xf0;                                                        //鍵入Enter鍵盤繼續(xù)執(zhí)行下面語句,否則等待
              while(P3==0xf0);
          dat=key_scan();
              }while(dat!=0x0b);
void Delay10ms(void)           //延時10ms
        uint i,j,k;
        for(i=5;i>0;i--)
        for(j=4;j>0;j--)
        for(k=248;k>0;k--);
      uchar dat;
      uchar i=0,j=0,k;
      uchar x;
          LED1=1;
          LED2=1;
          SOUND=0;
          INIT=1;
      if(INIT==0)                   //密碼初始化
             x=SendB(iic,0x50,6);
                 Delay10ms();
      }             //首先從IIC器件中讀出密碼以供下面輸入密碼進行比較
      x=ReadB(iic,0x50,6);
      Init_12864();
          for(i=0;i<150;i++){Delay10ms();}
//**********************************若密碼不正確,循環(huán)執(zhí)行do{}while()********************************************
do{
             LED1=1;
             System();                  //顯示:"請輸入密碼"字幕
             press(key);
                 if((key[0]==iic[0])&&(key[1]==iic[1])&&(key[2]==iic[2])&&(key[3]==iic[3])&&(key[4]==iic[4])&&(key[5]==iic[5])) //密碼比較,若密碼正確責進入系統(tǒng),若密碼不正確則顯示密碼錯誤,重新輸入密碼
                    true();
                    do
                       P3=0xf0;                                                        //鍵入1或2繼續(xù)執(zhí)行下面語句,否則等待
                   while(P3==0xf0);
               dat=key_scan();
                 }while(dat!=0x01&&dat!=0x02);
                    if(dat==1)                                                       //開鎖
                        LED1=0;
                                unlock();
                            for(i=0;i<100;i++){Delay10ms();}
                    continue;
                    if(dat==2)                                                        //修改密碼
                       do{
                              System();
                                  press(key);
                                  again();
                                  press(iic);
                                          succeed();                                //修改密碼成功
                                      Delay10ms();
                                      Delay10ms();
                          x=ReadB(iic,0x50,6);break;
                                      else                             //修改密碼不成功,重新修改
                                              repeat();
                                  }while(1);
                else        //密碼不正確,重新輸入密碼
                    j++;
                        if(j==3)
                           for(i=0;i<8;i++)
                              LED2=0;
                                  for(k=0;k<5;k++){Delay10ms();}
                                  LED2=1;
                                j=0;
                        error();
                        for(i=0;i<50;i++){Delay10ms();}
}while(1);
參與人數(shù) 1黑幣 +50 收起 理由
admin + 50 共享資料的積分獎勵!
ID:80284 發(fā)表于 2015-6-8 16:15 | 顯示全部樓層
密碼鎖挺不錯的 ,在這一方面可以學習
ID:82937 發(fā)表于 2015-6-17 12:19 | 顯示全部樓層
要用什么模塊啊
ID:113580 發(fā)表于 2016-4-11 20:56 | 顯示全部樓層
贊贊贊贊贊贊
ID:121746 發(fā)表于 2016-5-18 16:56 | 顯示全部樓層
不是c語言怎么做
ID:123712 發(fā)表于 2016-7-22 09:39 | 顯示全部樓層
謝謝樓主分享資料,學習中
ID:66032 發(fā)表于 2016-7-23 08:15 | 顯示全部樓層
現(xiàn)在的密碼鎖已不再是簡單的指紋識別和密碼設置, 要加彩色LCD, Zigbee, WIFI和手機連接,設置IP和網(wǎng)關, 當密碼丟失和忘記可以通過手機重新找回密碼和設置密碼。很簡單的例子, 你的房子租給別人住了一段時間, 別人不租了, 以前的辦法是更換鎖芯, 現(xiàn)在的辦法只需重置密碼。
ID:136393 發(fā)表于 2016-10-24 21:32 | 顯示全部樓層
有仿真嗎
ID:144301 發(fā)表于 2016-10-24 21:59 | 顯示全部樓層
不知道這個密碼怎么連續(xù)輸入
不知道這個密碼怎么連續(xù)輸入
ID:145054 發(fā)表于 2016-10-29 13:39 | 顯示全部樓層
用protus仿真仿真
ID:168327 發(fā)表于 2017-3-5 16:13 | 顯示全部樓層
啦啦啦啦啦啦啦啦啦啦啦啦
ID:171085 發(fā)表于 2017-3-16 21:23 | 顯示全部樓層
謝謝樓主
