查看: 3801|回復: 0
<<音神東祝八國>>音樂程序編程代碼
ID:76127 發表于 2015-4-17 21:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
; <<音神東祝八國>>音樂程序編程代碼清單姬學瑞
; 姬家寨電子科技實驗室制作,版權所有,侵權必究
   ORG 0000H
   LJMP START
   ORG 000BH             ;中斷入口
   INC 20H               ;中斷服務程序,中斷計數器加1
   MOV TH0,#0D8H
   MOV TL0,#0EFH         ;12M晶振,形成10毫秒中斷
   RETI
START:
   MOV SP,#50H
   MOV TH0,#0D8H
   MOV TL0,#0EFH
   MOV TMOD,#01H
   MOV IE,#82H
MUSIC0:
   NOP
   MOV DPTR,#DAT        ;表頭地址送DPTR
   MOV 20H,#00H         ;中斷計數器清0
   MOV B,#00H           ;表序號清0
MUSIC1:
   NOP
   CLR A
   MOVC A,@A+DPTR       ;查表取代碼
   JZ END0              ;是00H,則結束
   CJNE A,#0FFH,MUSIC5
   LJMP MUSIC3
MUSIC5:
   NOP
   MOV R6,A
   INC DPTR
   MOV A,B
   MOVC A,@A+DPTR       ;取節拍代碼送R7
   MOV R7,A
   SETB TR0             ;啟動計數
MUSIC2:
   NOP
   CPL P3.7
   MOV A,R6
   MOV R3,A
   CPL A
   MOV P1,A             ;顯示(修改者加入的顯示)
   CPL A
   LCALL DEL
   MOV A,R7
   CJNE A,20H,MUSIC2    ;中斷計數器(20H)=R7否?
                        ;不等,則繼續循環
   MOV 20H,#00H         ;等于,則取下一代碼
   INC DPTR
   LJMP MUSIC1
MUSIC3:
   NOP
   CLR TR0              ;休止100毫秒
   MOV R2,#0DH
MUSIC4:
   NOP
   MOV R3,#0FFH
   LCALL DEL
   DJNZ R2,MUSIC4
   INC DPTR
   LJMP MUSIC1
END0:
   NOP
   MOV R2,#64H          ;歌曲結束,延時1秒后繼續
MUSIC6:
   MOV R3,#00H
   LCALL DEL
   DJNZ R2,MUSIC6
   LJMP MUSIC0
DEL:
   NOP
DEL3:
   MOV R4,#05H
DEL4:
   NOP
   DJNZ R4,DEL4
   NOP
   DJNZ R3,DEL3
   RET
DAT:
DB 60H,10H,55H,10H,4CH,10H,48H,10H,40H,10H,39H,10H,33H,10H,0FFH  ;12345670;10 《壹音譜測試》
DB 30H,10H,2BH,10H,26H,10H,24H,10H,20H,10H,1CH,10H,19H,10H,0FFH  ;12345670
DB 18H,10H,15H,10H,13H,10H,12H,10H,10H,10H,0EH,10H,0DH,10H,0FFH  ;12345670
DB 60H,20H,55H,20H,4CH,20H,48H,20H,40H,20H,39H,20H,33H,20H,0FFH  ;12345670;20
DB 30H,20H,2BH,20H,26H,20H,24H,20H,20H,20H,1CH,20H,19H,20H,0FFH  ;12345670
DB 18H,20H,15H,20H,13H,20H,12H,20H,10H,20H,0EH,20H,0DH,20H,0FFH  ;12345670
DB 60H,30H,55H,30H,4CH,30H,48H,30H,40H,30H,39H,30H,33H,30H,0FFH  ;12345670;30
DB 30H,30H,2BH,30H,26H,30H,24H,30H,20H,30H,1CH,30H,19H,30H,0FFH  ;12345670
DB 18H,30H,15H,30H,13H,30H,12H,30H,10H,30H,0EH,30H,0DH,30H,0FFH  ;12345670
DB 60H,40H,55H,40H,4CH,40H,48H,40H,40H,40H,39H,40H,33H,40H,0FFH  ;12345670;40
DB 30H,40H,2BH,40H,26H,40H,24H,40H,20H,40H,1CH,40H,19H,40H,0FFH  ;12345670
DB 18H,40H,15H,40H,13H,40H,12H,40H,10H,40H,0EH,40H,0DH,40H,0FFH  ;12345670
DB 60H,50H,55H,50H,4CH,50H,48H,50H,40H,50H,39H,50H,33H,50H,0FFH  ;12345670;50
DB 30H,50H,2BH,50H,26H,50H,24H,50H,20H,50H,1CH,50H,19H,50H,0FFH  ;12345670
DB 18H,50H,15H,50H,13H,50H,12H,50H,10H,50H,0EH,50H,0DH,50H,0FFH  ;12345670
DB 60H,60H,55H,60H,4CH,60H,48H,60H,40H,60H,39H,60H,33H,60H,0FFH  ;12345670;60
DB 30H,60H,2BH,60H,26H,60H,24H,60H,20H,60H,1CH,60H,19H,60H,0FFH  ;12345670
DB 18H,60H,15H,60H,13H,60H,12H,60H,10H,60H,0EH,60H,0DH,60H,0FFH  ;12345670
DB 60H,70H,55H,70H,4CH,70H,48H,70H,40H,70H,39H,70H,33H,70H,0FFH  ;12345670;70
DB 30H,70H,2BH,70H,26H,70H,24H,70H,20H,70H,1CH,70H,19H,70H,0FFH  ;12345670
DB 18H,70H,15H,70H,13H,70H,12H,70H,10H,70H,0EH,70H,0DH,70H,0FFH  ;12345670
DB 60H,80H,55H,80H,4CH,80H,48H,80H,40H,80H,39H,80H,33H,80H,0FFH  ;12345670;80
DB 30H,80H,2BH,80H,26H,80H,24H,80H,20H,80H,1CH,80H,19H,80H,0FFH  ;12345670
DB 18H,80H,15H,80H,13H,80H,12H,80H,10H,80H,0EH,80H,0DH,80H,0FFH  ;12345670
DB 60H,90H,55H,90H,4CH,90H,48H,90H,40H,90H,39H,90H,33H,90H,0FFH  ;12345670;90
DB 30H,90H,2BH,90H,26H,90H,24H,90H,20H,90H,1CH,90H,19H,90H,0FFH  ;12345670
DB 18H,90H,15H,90H,13H,90H,12H,90H,10H,90H,0EH,90H,0DH,90H,0FFH  ;12345670
DB 60H,99H,55H,99H,4CH,99H,48H,99H,40H,99H,39H,99H,33H,99H,0FFH  ;12345670;99
DB 30H,99H,2BH,99H,26H,99H,24H,99H,20H,99H,1CH,99H,19H,99H,0FFH  ;12345670
DB 18H,99H,15H,99H,13H,99H,12H,99H,10H,99H,0EH,99H,0DH,99H,0FFH  ;12345670
DB 20H,20H,30H,20H,1CH,20H,18H,10H,1CH,10H,20H,40H,0FFH,   26H,10H ;51616503第一段《貳神的傳說》
DB 2BH,10H,30H,20H,1CH,40H,20H,20H,20H,80H,20H,20H,30H,20H,1CH,20H ;21655516
DB 18H,10H,1CH,10H,20H,40H,0FFH, 26H,10H,2BH,10H,30H,20H,2BH,40H   ;16503212
DB 26H,20H,2BH,80H,2BH,30H,30H,10H,39H,40H,30H,20H,30H,40H,0FFH    ;32216110
DB 30H,10H,2BH,10H,26H,20H,20H,40H,1CH,20H,26H,80H,2BH,30H,30H,10H ;12356321
DB 39H,20H,30H,20H,30H,40H,0FFH,   30H,10H,2BH,10H,26H,20H,18H,20H ;61101231
DB 19H,20H,1CH,10H,20H,10H,20H,80H,18H,20H,15H,40H,18H,40H,1CH,20H ;76551216
DB 18H,40H,1CH,20H,18H,40H,1CH,40H,20H,20H,1CH,40H,26H,20H,20H,40H ;16165635
DB 1CH,10H,2BH,40H,0FFH,   26H,40H,39H,20H,30H,40H,30H,20H,30H,10H ;62036111
DB 0FFH                                                ;0
DB 20H,20H,30H,20H,1CH,20H,18H,10H,1CH,10H,20H,40H,0FFH,   26H,10H ;15616503第二段
DB 39H,20H,30H,20H,30H,40H, 0FFH,  30H,10H,2BH,10H,26H,20H,18H,20H ;61101231
DB 0FFH,30H,90H                                              ;01
DB 20H,20H,15H,30H,18H,20H,15H,40H,13H,80H,18H,40H,15H,90H,15H,90H ;52123122第三段
DB 20H,80H,15H,60H,18H,20H,1CH,40H,18H,80H,20H,40H,1CH,90H,1CH,90H ;52161566
DB 1CH,30H,20H,20H,26H,40H,20H,40H,20H,90H,20H,30H,26H,20H,2BH,40H ;65355532
DB 26H,40H,26H,90H,0FFH,   26H,40H,20H,40H,1CH,40H,2BH,90H,26H,40H ;33035623
DB 30H,40H,2BH,40H,2BH,80H,26H,40H,2BH,20H,30H,20H,39H,40H,30H,40H ;12232161
DB 30H,90H,30H,90H                                              ;11
DB 20H,20H,15H,30H,18H,20H,15H,40H,13H,80H,18H,40H,15H,90H,15H,90H ;55123122
DB 30H,40H,2BH,40H,2BH,80H,26H,40H,15H,20H,18H,20H,1CH,40H,18H,40H ;12232161
DB 18H,90H,18H,90H,18H,90H,0FFH                                 ;111
DB 20H,40H,20H,20H,1CH,20H,2BH,80H,30H,40H,30H,20H,39H,20H,2BH,80H ;55621162 第一段《叁東方紅》
DB 20H,40H,20H,40H,1CH,20H,18H,20H,1CH,20H,20H,20H,30H,40H,30H,20H ;55616511
DB 39H,20H,2BH,80H,20H,40H,2BH,20H,30H,40H,33H,20H,39H,20H,40H,40H ;62521765
DB 20H,40H,2BH,40H,26H,20H,2BH,20H,30H,40H,30H,20H,39H,20H,2BH,20H ;52321162
DB 26H,20H,2BH,20H,30H,20H,2BH,20H,30H,20H,33H,20H,39H,20H,40H,80H ;32121765
DB 40H,80H,0FFH,20H,40H,2BH,20H,30H,40H,33H,20H,39H,20H,40H,40H     ;O521765
DB 40H,80H,0FFH                ;50
DB 20H,40H,20H,20H,1CH,20H,2BH,80H,30H,40H,30H,20H,39H,20H,2BH,80H ;55621162 第二段
DB 40H,80H,0FFH                ;50
DB 40H,80H,0FFH                ;50
DB 20H,40H,20H,20H,1CH,20H,2BH,80H,30H,40H,30H,20H,39H,20H,2BH,80H ;55621162 第三段
DB 40H,80H,0FFH,20H,40H,2BH,20H,30H,40H,33H,20H,39H,20H,40H,40H    ;5O521765
DB 40H, 80H,0FFH                          ;50
DB 26H,20H,20H,20H,20H,20H,26H,10H,20H,10H,20H,80H,26H,20H,30H,20H ;35535531《肆祝你平安》
DB 30H,20H,39H,10H,30H,10H,30H,80H,26H,20H,20H,20H,20H,20H,1CH,20H ;16113556
DB 20H,80H,2BH,20H,26H,20H,20H,20H,2BH,10H,26H,10H,2BH,80H,26H,20H ;52352323
DB 30H,20H,30H,20H,39H,10H,26H,10H,26H,60H,40H,10H,39H,10H,26H,20H ;11633563
DB 30H,20H,30H,20H,39H,10H,26H,10H,26H,80H,26H,20H,2BH,10H,2BH,10H ;11633322
DB 2BH,20H,30H,10H,39H,10H,26H,10H,2BH,10H,2BH,20H,2BH,40H,40H,20H ;21632225
DB 20H,10H,20H,10H,2BH,10H,26H,30H,30H,80H,18H,20H,18H,20H,26H,20H ;25231113
DB 20H,20H,20H,40H,26H,20H,2BH,20H,30H,20H,30H,20H,1CH,20H,20H,20H ;55321165
DB 20H,80H,1CH,20H,1CH,20H,1CH,20H,30H,20H,30H,60H,39H,10H,30H,10H ;56661161
DB 20H,20H,2BH,10H,26H,10H,2BH,10H,26H,10H,26H,10H,2BH,10H,2BH,80H ;52323322
DB 18H,20H,18H,20H,26H,20H,20H,20H,20H,60H,26H,10H,2BH,20H,30H,20H ;11355321
DB 30H,20H,1CH,20H,20H,20H,20H,80H,26H,20H,30H,10H,30H,10H,30H,20H ;16553111
DB 39H,20H,26H,10H,2BH,10H,2BH,20H,2BH,40H,40H,10H,40H,10H,20H,10H ;63222555
DB 20H,10H,2BH,10H,26H,30H,30H,80H,0FFH,0FFH        ;523100
DB 18H,30H,1CH,10H,20H,40H,1CH,10H,18H,10H,20H,10H,1CH,10H,18H,40H ;16561561《伍八月桂花香》
DB 1CH,20H,20H,20H,1CH,20H,18H,20H,20H,80H,0FFH,20H,30H,1CH,10H,18H;65615056
DB 20H,15H,20H,1CH,20H,20H,20H,26H,40H,20H,20H,2BH,20H,26H,20H,20H ;55555555
DB 20H,30H,80H,0FFH,20H,20H,1CH,10H,18H,10H,20H,20H,26H,20H,2BH,20H;50561532
DB 30H,20H,2BH,40H,20H,20H,1CH,10H,18H,10H,20H,20H,26H,20H,2BH,20H ;12561532
DB 30H,20H,2BH,40H,20H,30H,1CH,10H,18H,20H,15H,20H,1CH,20H,20H,20H ;12561265
DB 26H,40H,20H,20H,2BH,20H,26H,20H,20H,20H,30H,80H,20H,30H,1CH,10H ;35235156
DB 20H,10H,1CH,10H,20H,20H,26H,20H,2BH,20H,30H,20H,2BH,40H,20H,15H ;56532125
DB 1FH,05H,20H,10H,1CH,10H,20H,20H,26H,20H,2BH,20H,30H,20H,2BH,40H ;15653212
DB 20H,30H,1CH,10H,18H,20H,15H,20H,1CH,20H,20H,20H,26H,40H,20H,20H ;56126535
DB 2BH,20H,26H,20H,20H,20H,30H,30H,20H,30H,1CH,10H,18H,40H,1CH,20H ;23515616
DB 20H,20H,26H,40H,13H,60H,18H,20H,15H,40H,13H,40H,18H,80H,0FFH,0FFH;533123100
DB 40H,20H,30H,60H,30H,40H,30H,20H,30H,10H,40H,20H,39H,30H,33H,30H ;51111567《陸國歌》
DB 30H,40H,30H,40H,0FFH,   26H,20H,30H,20H,2BH,10H,26H,10H,20H,30H ;11031235
DB 20H,10H,20H,40H,26H,20H,26H,10H,30H,20H,26H,10H,20H,20H,26H,10H ;55331353
DB 2BH,40H,2BH,80H,1CH,40H,20H,40H,2BH,40H,26H,40H,20H,20H,26H,40H ;22652353
DB 20H,20H,26H,20H,2BH,10H,26H,10H,30H,20H,2BH,10H,26H,40H,0FFH    ;53231230
DB 20H,20H,39H,10H,30H,20H,30H,20H,26H,20H,26H,10H,2BH,20H,2BH,20H ;56113355
DB 2BH,20H,2BH,20H,2BH,20H,39H,30H,39H,10H,2BH,60H,40H,20H,30H,60H ;22266251
DB 30H,20H,26H,60H,26H,20H,20H,80H,20H,80H,30H,20H,26H,10H,20H,20H ;13355135
DB 20H,10H,1CH,40H,20H,40H,26H,20H,30H,10H,20H,20H,20H,20H,20H,20H ;56531555
DB 26H,20H,0FFH,30H,20H,0FFH,40H,40H,30H,40H,4CH,20H,30H,10H       ;30105131
DB 20H,20H,20H,20H,20H,20H,26H,20H,0FFH,30H,20H,0FFH,40H,40H       ;55530105
DB 30H,40H,40H,40H,30H,40H,40H,40H,30H,40H,30H,40H,0FFH,0FFH    ;15151100
DB 0FFH,0FFH                                                 ;00
DB 00H                  ;結束
   END
