查看: 6808|回復: 0
單片機流水燈的電路圖和演示程序
ID:75926 發表于 2015-4-10 19:11 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
[color=#ff0000,strength=3)"]單片機編程是硬件編程:
1.  編寫底層驅動
2.  根據電路原理圖來實現
&附電路原理圖:
&硬件實物圖:
[color=#ff0000,strength=3)"]實現的功能演示:
1.  8個LED小燈的正向與反向流水演示
C代碼源程序:
# include <reg51.h>
typedef unsigned char uint8;         //宏定義
typedef unsigned int uint16;
sbit ENLED = P1^4;                                //位聲明
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
main()
        uint8 j = 0;
        uint16 i;
        ENLED = 0;
    ADDR0 = 0; ADDR1 = 1; ADDR2 = 1; ADDR3 = 1;
        while (1)
                P0 = ~(1 << j++);//00000001 按位取反后為11111110
                //非精確延時
                for(i = 0; i < 20000; i++); //分號不能少
                while (8 == j)
                        j = 0;
匯編代碼源程序:
ORG 00H
MOV DPTR,#TABLE
MAIN:
        MOV P1,#11101110B  ;38譯碼器對三極管的開關控制,使LED燈能正常工作
        MOV R2,#0
START:
        MOV A,R2
        MOVC A,@A+DPTR ;MOVC A,@A+DPTR 寫成        MOVC A,@DPTR+A 是錯誤的
        MOV P0,A
        LCALL DELAY100MS
        INC R2
        CJNE R2,#13,START
        SJMP MAIN
TABLE:DB 0FEH, 0FDH, 0FBH, 0F7H, 0EFH, 0DFH, 0BFH, 7FH, 0BFH, 0DFH, 0EFH, 0F7H, 0FBH, 0FDH
DELAY100MS:                        ;@11.0592MHz
        PUSH 30H
        PUSH 31H
        MOV 30H,#180
        MOV 31H,#68
NEXT:
        DJNZ 31H,NEXT
        DJNZ 30H,NEXT
        POP 31H
        POP 30H
        RET
END
