查看: 5591|回復: 3
單片機解2262碼 315兆無線模塊源程序
ID:76127 發表于 2015-4-8 21:11 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
單片機解2262無線電遙控碼 成功后用串口輸出
作者  rewtewer
#include<reg52.h>
sbit p00=P0^0;
sbit p01=P0^1;
sbit p02=P0^2;
sbit p03=P0^3;
sbit p04=P0^4;
sbit p05=P0^5;
sbit p06=P0^6;
sbit p07=P0^7;
sbit p32=P3^2;
sbit p34=P3^4;
sbit p35=P3^5;
sbit p36=P3^6;
sbit p37=P3^7;
sbit p11=P1^1;//繼電器輸出;
sbit p12=P1^2;//蜂鳴器;
bit ts1;//秒時鐘;
bit tms100;//100毫秒時鐘;
bit uf=0;//正在解碼中標志位;
bit b;//數據碼接收正確并收完成標志;
bit bw1,bw2,bw3,bw4,bw10,bw11;
uchar a1;//接收位計數;
uchar  *p;
uint setdata;
uint  address1;//數據幀地址;
uint  dataint1;//數據幀數據;
uint  datatemp[4];
void delay(uint a)
while(a--);
void suma(uint a,uchar b)//數碼管顯示(動態掃描);
{ //a為要顯示的數,B為要顯示位的位數;
   static uchar b1,b2;
  uchar code sumadata[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  if(a>9)b2=1;
  else b2=0;
  if(a>99)b2=2;
  if(a>999)b2=3;
  if(b1>b2)b1=0;
   if(b1>=b)b1=0;
  P1|=0xf0;
  if(b1==0)P2=sumadata[a%10];
  if(b1==1)P2=sumadata[a%100/10];
  if(b1==2)P2=sumadata[a%1000/100];
  if(b1==3)P2=sumadata[a/1000];
  if(b)P1&=~(0X80>>b1);
b1++;
void int0init()//外部中斷初始化;
IT0=1;
EX0=1;
EA=1;
uf=0;
void timer0init()//定時器0初始化;
  TMOD=0X09;
  TR0=1;
void time1init()//定時器1初始化;
  TMOD&=0X0F;
  TMOD|=0X10;
  TH1=0X4B;
  TL1=0XFF;
  TR1=1;
  ET1=1;
  EA=1;
void int0() interrupt 0 //外部中斷處理;
uint j;
p05=!p05;
   j=TH0;
   j=j<<8;
   j|=TL0;
   TR0=0;
   TH0=0 ;
   TL0=0;
   TR0=1;
if(!uf)
   if(!TF0)
   if((j<14000)&&(j>10000))
   uf=1,a1=0,p01=!p01;
  datatemp[0]=0;
  datatemp[1]=0;
  datatemp[2]=0;
  datatemp[3]=0;
   else TF0=0,uf=0,a1=0;
   if(a1<64)
if((j>200)&&(j<850))//判斷窄脈沖;
p02=!p02;
    datatemp[a1/16]|=0x01<<(a1%16);
  a1++;
  if(j>900&&j<2250) //判斷寬脈沖;
  p03=!p03;
  a1++;
   p07=!p07;
   a1=0;
   uf=0;
  if(a1>=64)
if((datatemp[0]==~datatemp[1])&&(datatemp[2]==~datatemp[3]))
   address1=datatemp[0];
   dataint1=datatemp[2];
  b=1;
p00=!p00;
uf=0;
a1=0;
//EA=0;
void usartinit() //串行通信初始化;
/*RCAP2H=(65535-12000000/9600/16 )/256;
RCAP2L=(65535-12000000/9600/16 )&0xFF;
T2CON=0x34; */
RCAP2H=(65535-11059200/9600/16 )/256;
RCAP2L=(65535-11059200/9600/16 )&0xFF;
T2CON=0x34;
TR2=1;
SM0=0;
SM1=1;
REN=1;
SM2=1;
//ES=1;
// EA=1;
void time1() interrupt 3 //定時器1中斷函數,用于系統時鐘;
static uchar a;
  TH1=0X4B;
  TL1=0XFF;
  if(a>=20)a=0;
  if(a<10)ts1=1;
  else ts1=0;
  a++;
  tms100=!tms100;
  bw10=1;
void main(void)
bit x1,x2;
uchar f,fw1,fw2,fs=4;
IP=0X01;
IPH=0X01;//設定外部中斷0為最高優先級別;
usartinit();
timer0init();
int0init();
time1init();
if(b)
if(f<2)p=&address1;
  else p=&dataint1;
if(f==0)SBUF=p[0],f++;
  if(TI==1)
    TI=0;
if(f==1)SBUF=p[1];
  if(f==2)SBUF=p[0];
    if(f==3)SBUF=p[1];
if(f>=4)
   f=0,b=0;EA=1;
  f++;
if(!b)EA=1,f=0;
delay(100);
if(bw2)
if(ts1)fs=4;
else fs=0;
suma(setdata,fs);
else fs=4,suma(dataint1,fs);
if(!p35&&!bw1&&!bw2)
  delay(4000);
  if(!p35)bw1=1,bw2=1;
if(!p35&&!bw1&&bw2)
delay(4000);
if(!p35)bw2=0,bw1=1;
if(p35)bw1=0;
if(bw2)
   if(!p36&&!bw3)
    delay(2000);
if(!p36)
  if(setdata<9999)setdata++,bw3=1;
   if(p36)bw3=0,fw1=0;
   if(!p37&&!bw4)
    delay(2000);
if(!p37)
  if(setdata>0)setdata--,bw4=1;
  if(p37)bw4=0,fw2=0;
  if(bw3&&bw11)
    if(fw1<40)fw1++;
if(setdata<9999)setdata++;
  if(bw4&&bw11)
  if(fw2<40)fw2++;
if(setdata>0)setdata--;
bw11=0;
if(dataint1>=setdata&&!x1&&x2)x1=1;
if(dataint1<setdata)x1=0,x2=1;
if(!p34)
   delay(2000);
   if(!p34)x1=0,x2=0;
if(x1)
if(ts1)p11=0,p12=1;
else p11=1,p12=0;
else p11=1,p12=1;
if(bw10)bw11=1;bw10=0;
if(TF0)uf=0;
收藏收藏4 分享淘帖 頂1 踩
ID:77387 發表于 2015-5-10 11:47 | 只看該作者
不錯,收藏了
ID:79329 發表于 2015-5-10 17:40 | 只看該作者
樓主牛逼
ID:66287 發表于 2015-5-28 16:03 | 只看該作者
樓主牛
