說明:
1.原理圖中有點小問題液晶的RS端要接高電平(原圖懸空,極易花屏)
2.另外原來的程序1302的時序不對,這里傳一份改過的
- //頭文件
- #include <AT89X52.h>
- #include <string.h>
- //燈與蜂鳴器定義
- sbit beep = P3^3;
- //溫度傳感器定義
- sbit DQ = P3 ^ 4;//ds18B20
- //鍵盤引腳定義
- sbit KEY_1 = P1^4; //左上
- sbit KEY_2 = P1^5; //左下
- sbit KEY_3 = P1^6; //右上
- sbit KEY_4 = P1^7; //右下
- sbit KEY_5 = P1^3; //常0
- //引腳定義
- sbit SID = P2^1; //數據
- sbit SCLK = P2^2; //時鐘
- //定義DS1302時鐘接口
- sbit clock_clk = P1 ^ 0;//ds1302_clk(時鐘線)
- sbit clock_dat = P1 ^ 1;//ds1302_dat(數據線)
- sbit clock_Rst = P1 ^ 2;//ds1302_Rst(復位線)
- //定義累加器A中的各位
- sbit a0 = ACC ^ 0;
- sbit a1 = ACC ^ 1;
- sbit a2 = ACC ^ 2;
- sbit a3 = ACC ^ 3;
- sbit a4 = ACC ^ 4;
- sbit a5 = ACC ^ 5;
- sbit a6 = ACC ^ 6;
- sbit a7 = ACC ^ 7;
- //定義全局變量
- unsigned char yy,mo,dd,xq,hh,mm,ss;//定義時間映射全局變量(專用寄存器)
- bit w = 0; //調時標志位
- static unsigned char menu = 0;//定義靜態小時更新用數據變量
- static unsigned char keys = 0;//定義靜態小時更新用數據變量
- static unsigned char timecount = 0;//定義靜態軟件計數器變量
- //函數聲明
- void lcm_w_word(unsigned char *str) ; //寫字符 例:lcm_w_word("公司名稱)
- void lcm_w_test(bit start,unsigned char ddata); //(0,指令) (1,數據)
- void lcm_w_byte(unsigned char bbyte); //寫一個字節給lcm
- void delaynms(unsigned int di); //延時
- void lcm_init(void); //lcm初始化
- void lcm_clr(void); //清屏
- void days (void);
- void Init_DS18B20(void);
- void WriteOneChar(unsigned char dat);
- unsigned char ReadOneChar(void);
- void lcm_w_ss(void);void lcm_w_mm(void);
- void lcm_w_hh(void);void lcm_w_dd(void);
- void lcm_w_mo(void);void lcm_w_yy(void);void lcm_w_xq(void);
- void Init_1302(void);
- unsigned char read_clock(unsigned char ord);
- void read_clockS(void);
- void Set_time(unsigned char sel);
- void write_clock(unsigned char ord, unsigned char dd);
- void updata (void);
- void lcm_w_xq(void);
- //公歷節日數據庫
- void days (void)
- lcm_w_test(0,0x86);
- if ( yy == 0x08||yy == 0x20 ){lcm_w_word("鼠");}
- if ( yy == 0x09||yy == 0x21 ){lcm_w_word("牛");}
- if ( yy == 0x10||yy == 0x22 ){lcm_w_word("虎");}
- if ( yy == 0x11||yy == 0x23 ){lcm_w_word("兔");}
- if ( yy == 0x12||yy == 0x24 ){lcm_w_word("龍");}
- if ( yy == 0x13||yy == 0x25 ){lcm_w_word("蛇");}
- if ( yy == 0x14||yy == 0x26 ){lcm_w_word("馬");}
- if ( yy == 0x15||yy == 0x27 ){lcm_w_word("羊");}
- if ( yy == 0x16||yy == 0x28 ){lcm_w_word("猴");}
- if ( yy == 0x17||yy == 0x29 ){lcm_w_word("雞");}
- if ( yy == 0x18||yy == 0x30 ){lcm_w_word("狗");}
- if ( yy == 0x19||yy == 0x31 ){lcm_w_word("豬");}
- lcm_w_test(0,0x98);
- if ( mo == 0x01 && dd == 0x01 ){ lcm_w_word(" 元旦快樂 "); }//1月
- if ( mo == 0x01 && dd == 0x28 ){ lcm_w_word(" 世界麻風日 "); }
- if ( mo == 0x02 && dd == 0x02 ){ lcm_w_word(" 世界濕地日 "); }//2月
- if ( mo == 0x02 && dd == 0x13 ){ lcm_w_word(" 明天情人節了 "); }
- if ( mo == 0x02 && dd == 0x14 ){ lcm_w_word(" 今天是情人節 "); }
- if ( mo == 0x03 && dd == 0x01 ){ lcm_w_word(" 國際海豹日 "); }//3月
- if ( mo == 0x03 && dd == 0x03 ){ lcm_w_word(" 全國愛耳日 "); }
- if ( mo == 0x03 && dd == 0x08 ){ lcm_w_word(" 3.8婦女節 "); }
- if ( mo == 0x03 && dd == 0x12 ){ lcm_w_word(" 植樹節 "); }
- if ( mo == 0x03 && dd == 0x14 ){ lcm_w_word(" 國際警察日 "); }
- if ( mo == 0x03 && dd == 0x15 ){ lcm_w_word(" 消費者權益日 "); }
- if ( mo == 0x03 && dd == 0x17 ){ lcm_w_word(" 國際航海日 "); }
- if ( mo == 0x03 && dd == 0x21 ){ lcm_w_word(" 世界森林日 "); }
- if ( mo == 0x03 && dd == 0x22 ){ lcm_w_word(" 世界水日 "); }
- if ( mo == 0x03 && dd == 0x23 ){ lcm_w_word(" 世界氣象日 "); }
- if ( mo == 0x03 && dd == 0x24 ){ lcm_w_word("世界防治結核病日"); }
- if ( mo == 0x04 && dd == 0x01 ){ lcm_w_word("愚人節 小心上當"); }//4
- if ( mo == 0x04 && dd == 0x07 ){ lcm_w_word(" 世界衛生日 "); }
- if ( mo == 0x04 && dd == 0x08 ){ lcm_w_word(" 復活節 "); }
- if ( mo == 0x04 && dd == 0x13 ){ lcm_w_word(" 黑色星期五 "); }
- if ( mo == 0x05 && dd == 0x01 ){ lcm_w_word(" 勞動節 放假 "); }//5
- if ( mo == 0x05 && dd == 0x04 ){ lcm_w_word(" 青年節 "); }
- if ( mo == 0x05 && dd == 0x08 ){ lcm_w_word(" 世界紅十字日 "); }
- if ( mo == 0x05 && dd == 0x12 ){ lcm_w_word(" 國際護士節 "); }
- if ( mo == 0x05 && dd == 0x05 ){ lcm_w_word("近日注意母親節 "); }
- if ( mo == 0x05 && dd == 0x15 ){ lcm_w_word(" 國際家庭日 "); }
- if ( mo == 0x05 && dd == 0x31 ){ lcm_w_word(" 世界無煙日 "); }
- if ( mo == 0x06 && dd == 0x01 ){ lcm_w_word(" 國際兒童節 "); }//6
- if ( mo == 0x06 && dd == 0x05 ){ lcm_w_word(" 世界環境日 "); }
- if ( mo == 0x06 && dd == 0x26 ){ lcm_w_word(" 國際禁毒日 "); }
- if ( mo == 0x06 && dd == 0x06 ){ lcm_w_word(" 全國愛眼日 "); }
- if ( mo == 0x06 && dd == 0x13 ){ lcm_w_word("近日注意父親節 "); }
- if ( mo == 0x06 && dd == 0x15 ){ lcm_w_word("近日注意父親節 "); }
- if ( mo == 0x07 && dd == 0x01 ){ lcm_w_word("香港回歸記念日 "); }//7
- if ( mo == 0x07 && dd == 0x07 ){ lcm_w_word("抗日戰爭記念日 "); }
- if ( mo == 0x07 && dd == 0x11 ){ lcm_w_word(" 世界人口日 "); }
- if ( mo == 0x08 && dd == 0x01 ){ lcm_w_word(" 八一建軍節 "); }//8
- if ( mo == 0x08 && dd == 0x08 ){ lcm_w_word(" 中國男子節 "); }
- if ( mo == 0x08 && dd == 0x15 ){ lcm_w_word("抗戰勝利記念日 "); }
- if ( mo == 0x09 && dd == 0x10 ){ lcm_w_word(" 中國教師節 "); }//9
- if ( mo == 0x09 && dd == 0x18 ){ lcm_w_word("九·一八事變記念"); }
- if ( mo == 0x09 && dd == 0x20 ){ lcm_w_word(" 國際愛牙日 "); }
- if ( mo == 0x09 && dd == 0x27 ){ lcm_w_word(" 世界旅游日 "); }
- if ( mo == 0x10 && dd == 0x01 ){ lcm_w_word(" 中國國慶節 "); }//10
- if ( mo == 0x10 && dd == 0x04 ){ lcm_w_word(" 世界動物日 "); }
- if ( mo == 0x10 && dd == 0x24 ){ lcm_w_word(" 聯合國日 "); }
- if ( mo == 0x10 && dd == 0x12 ){ lcm_w_word("明天國際教師節 "); }
- if ( mo == 0x10 && dd == 0x13 ){ lcm_w_word(" 國際教師節 "); }
- if ( mo == 0x11 && dd == 0x10 ){ lcm_w_word(" 世界青年節 "); }//11
- if ( mo == 0x11 && dd == 0x17 ){ lcm_w_word(" 世界學生節 "); }
- if ( mo == 0x12 && dd == 0x01 ){ lcm_w_word(" 世界艾滋病日 "); }//12
- if ( mo == 0x12 && dd == 0x23 ){ lcm_w_word(" 明晚平安夜 "); }
- if ( mo == 0x12 && dd == 0x24 ){ lcm_w_word(" 今晚平安夜 "); }
- if ( mo == 0x12 && dd == 0x25 ){ lcm_w_word(" 圣誕快樂 "); }
- if ( mo == 0x12 && dd == 0x31 ){ lcm_w_word(" 明日新年 "); }
- else{
- if ( hh >= 0x04 && hh < 0x06 ){ lcm_w_word("★★__▲▲__凌晨"); }
- if ( hh >= 0x06 && hh < 0x08 ){ lcm_w_word("☆○__▲△__早晨"); }
- if ( hh >= 0x08 && hh < 0x12 ){ lcm_w_word("__●__▲▲__上午"); }
- if ( hh == 0x12) { lcm_w_word("____▲●▲__中午"); }
- if ( hh >= 0x13 && hh < 0x18 ){ lcm_w_word("__▲▲__●__下午"); }
- if ( hh >= 0x18 && hh < 0x22 ){ lcm_w_word("△▲__●☆__晚上"); }
- if ( hh >= 0x22 && hh <= 0x23 ){ lcm_w_word("△▲__★☆__夜里"); }
- if ( hh >= 0x00 && hh < 0x04 ){ lcm_w_word("__★▲▲★__深夜"); }
- void DelayM(unsigned int a){//延時函數 1MS/次
- unsigned char i;
- while( --a != 0){
- for(i = 0; i < 125; i++); //一個 ; 表示空語句,CPU空轉。
- } //i 從0加到125,CPU大概就耗時1毫秒
- //初始化LCM
- void lcm_init(void) {
- delaynms(100); //啟動等待,等LCM講入工作狀態
- lcm_w_test(0,0x30); //8 位介面,基本指令集
- lcm_w_test(0,0x0c); //顯示打開,光標關,反白關
- lcm_w_test(0,0x01); //清屏,將DDRAM的地址計數器歸零
- //寫指令或數據 (0,指令) (1,數據)
- void lcm_w_test(bit start, unsigned char ddata) {
- unsigned char start_data,Hdata,Ldata;
- if(start==0)
- start_data=0xf8; //0:寫指令
- else
- start_data=0xfa; //1:寫數據
- Hdata=ddata&0xf0; //取高四位
- Ldata=(ddata<<4)&0xf0; //取低四位
- lcm_w_byte(start_data); //發送起始信號
- delaynms(5); //延時是必須的
- lcm_w_byte(Hdata); //發送高四位
- lcm_w_byte(Ldata); //發送低四位
- //發送一個字節(底層函數)
- void lcm_w_byte(unsigned char bbyte) {
- unsigned char i;
- for(i=0;i<8;i++){
- SID=bbyte&0x80; //取出最高位
- SCLK=1;
- SCLK=0;
- bbyte<<=1; //左移
- //延時(LCM占用)
- void delaynms(unsigned int di) {
- unsigned int da,db;
- for(da=0;da<di;da++);
- for(db=0;db<10;db++);
- //清屏函數
- void lcm_clr(void){
- delaynms(40); //啟動等待,等LCM講入工作狀態
- //向LCM發送一個字符串,長度64字符之內。
- //應用:lcm_w_word("您好!");
- void lcm_w_word(unsigned char *str){
- while(*str != '\0'){
- lcm_w_test(1,*str++);
- *str = 0;
- void Delay(int num)//延時函數
- while(num--) ;
- void Init_DS18B20(void)//初始化ds1820
- unsigned char x=0;
- DQ = 1; //DQ復位
- Delay(8); //稍做延時
- DQ = 0; //單片機將DQ拉低
- Delay(80); //精確延時 大于 480us
- DQ = 1; //拉高總線
- Delay(14);
- x=DQ; //稍做延時后 如果x=0則初始化成功 x=1則初始化失敗
- Delay(20);
- unsigned char ReadOneChar(void)//讀一個字節
- unsigned char i=0;
- unsigned char dat = 0;
- for (i=8;i>0;i--)
- DQ = 0; // 給脈沖信號
- dat>>=1;
- DQ = 1; // 給脈沖信號
- if(DQ)
- dat|=0x80;
- Delay(4);
- return(dat);
- void WriteOneChar(unsigned char dat)//寫一個字節
- for (i=8; i>0; i--)
- DQ = 0;
- DQ = dat&0x01;
- Delay(5);
- DQ = 1;
- dat>>=1;
- unsigned int ReadTemperature(void)//讀取溫度
- unsigned char a=0;
- unsigned char b=0;
- unsigned int t=0;
- float tt=0;
- Init_DS18B20();
- WriteOneChar(0xCC); // 跳過讀序號列號的操作
- WriteOneChar(0x44); // 啟動溫度轉換
- Init_DS18B20();
- WriteOneChar(0xCC); //跳過讀序號列號的操作
- WriteOneChar(0xBE); //讀取溫度寄存器
- a=ReadOneChar(); //讀低8位
- b=ReadOneChar(); //讀高8位
- t=b;
- t<<=8;
- t=t|a;
- tt=t*0.0625;
- t= tt*10+0.5; //放大10倍輸出并四舍五入
- return(t);
- //聲明
- //常用時鐘數據讀取
- void read_clockS(void){
- ss = read_clock(0x81);//讀取秒數據
- mm = read_clock(0x83);//讀取分鐘數據
- hh = read_clock(0x85);//小時
- dd = read_clock(0x87);//日
- mo = read_clock(0x89);//月
- xq = read_clock(0x8b);//星期
- yy = read_clock(0x8d);//年
- //調時用加1程序
- void Set_time(unsigned char sel){ //根據選擇調整的相應項目加1并寫入DS1302
- signed char address,item;
- signed char max,mini;
- lcm_w_test(0,0x9a);
- lcm_w_word("調整");
- //if(sel==6) {lcm_w_word("秒鐘");address=0x80; max=0;mini=0;} //秒7
- if(sel==5) {lcm_w_word("分鐘");address=0x82; max=59;mini=0;} //分鐘6
- if(sel==4) {lcm_w_word("小時");address=0x84; max=23;mini=0;} //小時5
- if(sel==3) {lcm_w_word("星期");address=0x8a; max=7;mini=1;} //星期4
- if(sel==2) {lcm_w_word("日期");address=0x86; max=31;mini=1;} //日3
- if(sel==1) {lcm_w_word("月份");address=0x88; max=12;mini=1;} //月2
- if(sel==0) {lcm_w_word("年份");address=0x8c; max=99; mini=0;} //年1
- //讀取1302某地址上的數值轉換成10進制賦給item
- item=((read_clock(address+1))/16)*10 + (read_clock(address+1))%16;
- if(KEY_2 == 0){
- item++;//數加 1
- if(KEY_4 == 0){
- item--;//數減 1
- if(item>max) item=mini;//查看數值有效范圍
- if(item<mini) item=max;
- write_clock(0x8e,0x00);//允許寫操作
- write_clock(address,(item/10)*16+item%10);//轉換成16進制寫入1302
- write_clock(0x8e,0x80);//寫保護,禁止寫操作
- updata (); //刷新數據
- lcm_w_mm();//刷新 分
- //設置1302的初始時間
- void Init_1302(void){//(2008年1月1日00時00分00秒星期一)
- write_clock(0x8c,0x08);//年
- write_clock(0x8a,0x02);//星期
- write_clock(0x88,0x01);//月
- write_clock(0x86,0x01);//日
- write_clock(0x84,0x12);//小時
- write_clock(0x82,0x00);//分鐘
- write_clock(0x80,0x00);//秒
- write_clock(0x90,0xa5);//充電
- write_clock(0x8e,0x80);//禁止寫操作
- //DS1302寫數據(底層協議)
- void write_clock(unsigned char Writeaddr,unsigned char Writedata)
- unsigned char i;
- clock_clk=0;
- Delay(1);
- clock_Rst=1;
- Delay(1);
- for(i=8;i>0;i--)
- clock_clk=0;
- clock_dat=Writeaddr&0x01;
- Delay(1);
- clock_clk=1;
- Writeaddr=Writeaddr>>1;
- for(i=8;i>0;i--)
- clock_clk=0;
- clock_dat=Writedata&0x01;
- Delay(1);
- clock_clk=1;
- Writedata=Writedata>>1;
- clock_Rst=0;
- Delay(1);
- clock_clk=0;
- Delay(1);
- //DS1302讀數據(底層協議)
- unsigned char read_clock(unsigned char Readaddr)
- unsigned char i;
- unsigned char value=0;
- clock_clk=0;
- Delay(1);
- clock_Rst=1;
- Delay(1);
- for(i=8;i>0;i--)
- clock_clk=0;
- clock_dat=Readaddr&0x01;
- Delay(1);
- clock_clk=1;
- Readaddr=Readaddr>>1;
- for(i=8;i>0;i--)
- value=value>>1;
- clock_clk=1;
- Delay(1);
- clock_clk=0;
- if(clock_dat==1)
- value=value|0x80;
- Delay(1);
- clock_Rst=0;
- Delay(1);
- clock_clk=0;
- Delay(1);
- return value;
- //向LCM中填寫 年 數據
- void lcm_w_yy(void){
- //if(read_clock(0x8d) != yy){
- lcm_w_test(0,0x81);
- lcm_w_word("20");
- lcm_w_test(0,0x83);
- lcm_w_word("年");
- lcm_w_test(0,0x82);
- lcm_w_test(1,(yy/16)+0x30);
- lcm_w_test(1,yy%16+0x30);
- //向LCM中填寫 月 數據
- void lcm_w_mo(void){
- //if(read_clock(0x89) != mo){
- lcm_w_test(0,0x90);
- if(mo/16 != 0){lcm_w_test(1,(mo/16)+0x30);} //十位消隱
- else{lcm_w_test(1,0x20);}//同上
- lcm_w_test(1,mo%16+0x30);
- lcm_w_test(0,0x91);
- lcm_w_word("月");
- //星期處理并送入LCM的指定區域
- void lcm_w_xq(void){
- unsigned char sel;
- //if(read_clock(0x8b) != xq){
- sel = (read_clock(0x8b))%16; //字節低4位的BCD碼放入sel
- lcm_w_test(0,0x97);//寫入指定區域(97H 第二行第8個字)
- if(sel==7) {lcm_w_word("日");} //
- if(sel==6) {lcm_w_word("六");} //
- if(sel==5) {lcm_w_word("五");} //
- if(sel==4) {lcm_w_word("四");} //
- if(sel==3) {lcm_w_test(1,0xc8);lcm_w_test(1,0xfd);} //此指令等于lcm_w_word("三"); 因為“三”的內碼失效。
- if(sel==2) {lcm_w_word("二");} //
- if(sel==1) {lcm_w_word("一");} //星期一
- lcm_w_test(0,0x95);
- lcm_w_word("星期");
- //向LCM中填寫 日 數據
- void lcm_w_dd(void){
- // if(read_clock(0x87) != dd){
- lcm_w_test(0,0x92);
- if(dd/16 != 0){lcm_w_test(1,(dd/16)+0x30);} //十位消隱
- lcm_w_test(1,dd%16+0x30);
- lcm_w_test(0,0x93);
- lcm_w_word("日 ");
- //向LCM中填寫 小時 數據
- void lcm_w_hh(void){
- if(read_clock(0x85) != hh){
- if (hh > 0x07 && hh < 0x22 && w == 0){
- beep = 0;
- DelayM(100);
- beep = 1;
- lcm_w_test(0,0x88);
- lcm_w_test(1,(hh/16)+0x30);
- lcm_w_test(1,hh%16+0x30);
- //向LCM中填寫 分鐘 數據
- void lcm_w_mm(void){
- if(read_clock(0x83) != mm){
- if( w == 0){
- days(); //節日顯示
- updata (); //刷新數據
- lcm_w_test(0,0x89);
- lcm_w_test(1,0x3a); //":"
- lcm_w_test(1,(mm/16)+0x30);
- lcm_w_test(1,mm%16+0x30);
- lcm_w_test(1,0x3a); //"."
- //刷新數據
- void updata (void){
- lcm_w_hh();//刷新 小時
- lcm_w_dd();//刷新 日
- lcm_w_xq();//更新星期值
- lcm_w_mo();//刷新 月
- lcm_w_yy();//刷新 年
- //向LCM中填寫 秒 數據
- void lcm_w_ss(void){
- unsigned int i=0;
- unsigned char a=0,b=0,c=0;
- if(read_clock(0x81) != ss)
- { //判斷是否需要更新
- ss = read_clock(0x81); //更新數據
- lcm_w_test(0,0x8b); //秒值在LCM上的寫入位置
- lcm_w_test(1,(ss/16)+0x30); //寫十位
- lcm_w_test(1,ss%16+0x30); //寫個位
- //led_b = ~led_b; //背光閃爍
- lcm_w_mm();//刷新 分
- lcm_w_test(0,0x8d); //溫度在LCM上的寫入位置
- i=ReadTemperature();//讀溫度并送顯
- a=i/100;
- lcm_w_test(1,a+0x30); //顯示溫度十位
- b=i/10-a*10;
- lcm_w_test(1,b+0x30); //個位
- lcm_w_test(1,0x2e); //"."
- c=i-a*100-b*10;
- lcm_w_test(1,c+0x30); //小位1位
- lcm_w_word("℃"); //度C
- days(); //節日顯示
- //---主程序---//
- main()
- unsigned char e=0;
- yy=0xff;mo=0xff;dd=0xff;xq=0xff;hh=0xff;mm=0xff;ss=0xff; //各數據刷新
- P0=0xff;P1=0xff;P2=0xff;P3=0xff; //清I/O端口
- beep = 0;
- DelayM(900);
- beep = 1;
- lcm_init();//初始化液晶顯示器
- lcm_clr();//清屏
- //lcm_w_word("")可以自己隨意加字
- //lcm_w_test(0,0x91);
- //lcm_w_word("");
- //lcm_w_test(0,0x8a);
- //lcm_w_word("?);
- DelayM(5000); //顯示等留5秒
- lcm_clr();//清屏
- while(1)
- if (w == 0)
- { //正常走時
- lcm_w_ss();//刷新 秒
- if (KEY_3 == 0) // 設置時間
- DelayM(20); //去抖
- if(KEY_3 == 0 && w == 1) //當是調時狀態 本鍵用于調整下一項
- e++;
- if (e >= 6 ){e = 0;}
- Set_time(e);//調整
- if(KEY_3 == 0 && w == 0) //當是正常狀態時就進入調時狀態
- lcm_clr(); //清屏
- w=1; //進入調時
- //lcm_w_test(0,0x9e);
- //lcm_w_word(" [-]");
- //lcm_w_test(0,0x80);
- //lcm_w_word("[Esc]");
- //lcm_w_test(0,0x85);
- //lcm_w_word("[Next]");
- //lcm_w_test(0,0x98);
- //lcm_w_word("[+]");
- Set_time(e); //調整
- while(KEY_3 == 0); //等待鍵松開
- if (KEY_1 == 0) // 當在調時狀態時就退出調時
- DelayM(20);
- if(KEY_1 == 0 && w == 1){
- w = 0; //退出調時
- e = 0; //“下一項”計數器清0
- if(KEY_1 == 0 && w == 0){
- lcm_clr();//清屏
- DelayM(3000);
- //----------|-------1-------|-------3-------|-------2-------|-------4-------|-----//標尺
- while(KEY_1 == 0);//等待鍵松開
- lcm_clr();//清屏
- days(); //節日顯示
- updata (); //刷新數據
- lcm_w_mm();//刷新 分
- if (KEY_2 == 0 && w == 1){ // 加減調整{
- DelayM(20);
- if(KEY_2 == 0 && w == 1){
- Set_time(e);//調整
- while(KEY_2 == 0);//等待鍵松開
- if (KEY_4 == 0 && w == 1){ // 加減調整
- DelayM(20);
- if(KEY_4 == 0 && w == 1){
- Set_time(e);//調整
- while(KEY_4 == 0);//等待鍵松開
- if(KEY_1 == 1 && KEY_2 == 0 && KEY_3 == 1 && KEY_4 == 0){ //時鐘初始化{
- if(KEY_1 == 0 && KEY_2 == 0&& KEY_3 == 1&& KEY_4 == 0){
- Init_1302();
- DelayM(3000);
- lcm_w_test(0,0x80);
- lcm_clr();//清屏
- lcm_w_word("初始化成功! 2008-1-1 00:00.0");
- while(1);
