查看: 12975|回復: 30
立體旋轉LED制作
ID:76190 發表于 2015-4-5 16:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
相信這東西沒什么新鮮了,很多人都做過,我也來分享一下制作的心得!
   由我的平面旋轉LED改造的,改造很容易,就把平面的LED改成的立體的不就是了。因為用的是無線供電方式,旋轉起來很安靜,很平穩,電機的速度也夠快的,旋轉時不怎么閃爍。但是相機拍來視頻來還是會有點閃,眼睛看不怎么覺得會閃。‍‍‍‍
       電源輸入是6V1A的,經過無線供電模塊后變成交流電用兩個線圈感應電壓來供旋轉部分的電,PCB板上有簡單的整流濾波電路。時鐘的效果在這里就沒演示了。板上的1302和后背電池在這里沒用到,板子剛好平衡,旋轉起來沒什么太大的晃動。限流電阻改小點亮度估計會好很多!
小小玩意,忘論壇里的高手們多多指教!
視頻效果:
程序比較簡單:
  1. /*************************************************************
  2.                       旋轉LED字體程序
  3. 單片機 STC89C52
  4. 字模軟件用的PC2002
  5. 逐列取模方式
  6. ***************************************************************/
  7. #include <AT89X52.h>
  8. #define uchar unsigned char
  9. #define uint unsigned int    //宏定義
  10. sbit KEY=P3^2;
  11. sbit led1=P1^1;
  12. unsigned char code love[] = {
  13. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
  14. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",1*/
  15. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",2*/
  16. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",3*/
  17. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  18. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  19. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",6*/
  20. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",7*/
  21. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",8*/
  22. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",9*/
  23. 0xF7,0xDF,0xF7,0xE7,0x06,0xD8,0xB1,0xBF,0xB7,0xDF,0x37,0x60,0xEF,0x9F,0x57,0xE0,
  24. 0xD8,0xEF,0xDB,0xDF,0x1B,0xC0,0xDB,0xBD,0xDB,0xBD,0x9B,0xBD,0xDB,0xBF,0xFF,0xFF,/*"旋",0*/
  25. 0x37,0xF7,0x57,0xF7,0x63,0xFB,0x14,0x00,0x77,0xFB,0x77,0xFB,0x77,0xFF,0xBF,0xFD,
  26. 0xB7,0xF4,0x07,0xED,0xB0,0xDD,0xB7,0x2D,0xB7,0xF1,0xB7,0xFD,0xBF,0xFF,0xFF,0xFF,/*"轉",1*/
  27. 0xF7,0xDF,0x07,0xC0,0xF7,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xCF,0xFF,0xFF,/*"L",2*/
  28. 0xF7,0xDF,0x07,0xC0,0x77,0xDF,0x77,0xDF,0x17,0xDC,0xF7,0xDF,0xEF,0xE7,0xFF,0xFF,/*"E",3*/
  29. 0xF7,0xDF,0x07,0xC0,0xF7,0xDF,0xF7,0xDF,0xF7,0xDF,0xEF,0xEF,0x1F,0xF0,0xFF,0xFF,/*"D",4*/
  30. 0xF7,0xFB,0xCE,0x03,0x79,0xFC,0x9F,0xFF,0xFF,0x7F,0x01,0xB8,0xFD,0xCF,0x0D,0xF0,
  31. 0xFD,0xEF,0x01,0x98,0xFF,0xFF,0x07,0xF8,0xFF,0xBF,0xFF,0x7F,0x00,0x80,0xFF,0xFF,/*"測",5*/
  32. 0xBF,0xFF,0xBD,0xFF,0x23,0x80,0xF7,0xDF,0xFF,0xEF,0x6F,0xDF,0x6F,0xDF,0x6F,0xE0,
  33. 0x6F,0xEF,0x6F,0xEF,0x00,0xFE,0xEF,0xF9,0xED,0xE7,0xE3,0xDF,0xEF,0x87,0xFF,0xFF,/*"試",6*/
  34. 0xF7,0xFD,0xF7,0xFE,0x76,0xFF,0x31,0x00,0x57,0xFF,0xE7,0x7C,0xFF,0xBF,0x01,0xCF,
  35. 0x7D,0xF0,0x7D,0xFF,0x7D,0xFF,0x7D,0x80,0x01,0x7F,0xFF,0x7F,0xFF,0x0F,0xFF,0xFF,/*"祝",7*/
  36. 0xDF,0xFF,0xDF,0x7F,0xDF,0xBF,0xDF,0xDF,0xDF,0xEF,0xDF,0xF3,0x5F,0xFC,0x80,0xFF,
  37. 0x5F,0xFE,0xDF,0xF9,0xDF,0xF7,0xDF,0xCF,0xDF,0x9F,0xDF,0x3F,0xDF,0xBF,0xFF,0xFF,/*"大",8*/
  38. 0xFF,0xFF,0xE7,0xD6,0xFB,0xD6,0xEB,0xEA,0x6B,0xEB,0x6B,0xB5,0x2A,0x76,0x49,0xBB,
  39. 0xEB,0xC0,0xEB,0xF9,0x6B,0xF6,0xFB,0xF6,0xEB,0xEF,0xF3,0xCF,0xFB,0xEF,0xFF,0xFF,/*"家",9*/
  40. 0xBF,0xFF,0xCF,0xFD,0xEF,0xFD,0xED,0xFD,0xA3,0xFD,0xAB,0xFD,0xAF,0xBD,0xAE,0x7D,
  41. 0xA1,0x80,0x2B,0xFD,0xAF,0xFD,0xE7,0xFD,0xA8,0xFD,0xCD,0xFD,0xEF,0xFD,0xFF,0xFF,/*"學",10*/
  42. 0xFF,0xFF,0xFF,0xFF,0xFD,0xFB,0xFD,0xF3,0xF5,0xFB,0xED,0xFD,0xDD,0xFD,0x9D,0xFE,
  43. 0xFD,0xFE,0x7D,0xFF,0x7D,0xDF,0xBD,0xBF,0xFD,0x7F,0x01,0x80,0xFF,0xFF,0xFF,0xFF,/*"習",11*/
  44. 0x7F,0xFF,0x7D,0xBF,0x63,0xDF,0x77,0xE0,0xFF,0xDF,0x77,0xAF,0x77,0xB3,0x00,0xBC,
  45. 0x77,0xBF,0x77,0xBF,0x77,0xBF,0x00,0xA0,0x77,0xBF,0x77,0xBF,0x7F,0xBF,0xFF,0xFF,/*"進",12*/
  46. 0xFF,0xFF,0xDF,0xBB,0xDF,0xBB,0xDF,0xBD,0x43,0xBE,0xDF,0xDF,0xDF,0xDF,0xDF,0xDF,
  47. 0x00,0xE8,0xDB,0xEF,0xDB,0xF7,0xDB,0xFB,0xDB,0xFC,0xDF,0xFD,0xDF,0xFF,0xFF,0xFF,/*"步",13*/
  48. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xA0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  49. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"!",14*/
  50. 0xFF,0xFF,0x1F,0xF0,0xEF,0xEF,0xF7,0xDF,0xF7,0xDF,0xEF,0xEF,0x1F,0xF0,0xFF,0xFF,/*"0",15*/
  51. 0xFF,0xFF,0xC7,0xFF,0xF7,0xFF,0xF7,0xC0,0x37,0xFF,0xC7,0xFF,0xF7,0xFF,0xFF,0xFF,/*"7",16*/
  52. 0xFF,0xFF,0xFF,0xFF,0x07,0xF0,0xB7,0xFB,0xB7,0xFB,0xB7,0xFB,0xB7,0xFB,0x00,0xC0,
  53. 0xB7,0xBB,0xB7,0xBB,0xB7,0xBB,0xB7,0xBB,0x07,0xB0,0xFF,0xBF,0xFF,0x8F,0xFF,0xFF,/*"電",17*/
  54. 0xFF,0xFF,0xDF,0xFF,0xEF,0xFF,0x73,0xFF,0x58,0xFF,0x5B,0xFF,0x5B,0xFF,0x5B,0xFF,
  55. 0x5B,0xFF,0x5B,0xFF,0x5B,0xFF,0x5B,0xF0,0xDB,0xCF,0xFB,0xBF,0xFB,0x0F,0xFF,0xFF,/*"氣",18*/
  56. 0xFF,0xDF,0xFF,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0x01,0xC0,
  57. 0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFD,0xDF,0xFF,0xDF,0xFF,0xFF,/*"工",19*/
  58. 0xEF,0xFB,0xED,0xFC,0x2D,0xFF,0x01,0x00,0x6E,0xFF,0xEE,0xBE,0x7F,0xBB,0x40,0xBB,
  59. 0x5E,0xBB,0x5E,0x80,0x5E,0xBB,0x5E,0xBB,0x40,0xBB,0x7F,0xBB,0xFF,0xBF,0xFF,0xFF,/*"程",20*/
  60. 0xFF,0xFF,0xAF,0xFF,0xB0,0xC0,0xB5,0xFE,0xB7,0xFE,0x00,0x00,0xB7,0xDE,0xB7,0x9E,
  61. 0xB7,0xC0,0xFF,0xFF,0x03,0xF0,0xFF,0xBF,0xFF,0x7F,0x00,0x80,0xFF,0xFF,0xFF,0xFF,/*"制",21*/
  62. 0x7F,0xFF,0xBF,0xFF,0xDF,0xFF,0x07,0x00,0xF8,0xFF,0xDD,0xFF,0xE7,0xFF,0xF3,0xFF,
  63. 0x04,0x00,0xB7,0xFB,0xB7,0xFB,0xB7,0xFB,0x97,0xFB,0xB7,0xF9,0xF7,0xFB,0xFF,0xFF,/*"作",22*/
  64. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xA0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  65. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"!",23*/
  66. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",0*/
  67. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",1*/
  68. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",2*/
  69. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",3*/
  70. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  71. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  72. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  73. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  74. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  75. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  76. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  77. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  78. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  79. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",4*/
  80. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*" ",5*/
  81. };
  82. /*****n(us)延時子程序*****/
  83. void DelayUs(uint N)
  84. {
  85.     uint x ;
  86.     for(x=0;x<=N;x++);
  87. }
  88. /*****主函數*****/
  89. void main(void)
  90. {
  91.     uint i=0,j=0 ;
  92.     led1=0 ;
  93.     //主程序中只檢測按鍵
  94.     while(1)
  95.     {
  96.         if(KEY==0)
  97.         {
  98.             j++;
  99.             if(j>580)
  100.             {
  101.                 j=0 ;
  102.             }
  103.             for(i=j;i<128+j;i++)
  104.             {
  105.                 P0=love[i*2];
  106.                 P2=love[i*2+1];
  107.                 DelayUs(60);
  108.                 P0=0XFF;
  109.                 P2=0XFF;
  110.
  111.             }
  112.         }
  113.     }
  114. }
  115. /*****END*****/
收藏收藏10 分享淘帖 頂1 踩
ID:76209 發表于 2015-4-5 23:36 | 只看該作者
棒棒的
ID:76671 發表于 2015-4-25 12:37 來自觸屏版 | 只看該作者
厲害,求資料
ID:76671 發表于 2015-4-25 13:03 來自觸屏版 | 只看該作者
求高清原理圖,812175465@qq.com
ID:78880 發表于 2015-5-4 22:01 | 只看該作者
樓主您好,有高清原理圖嗎,736092685@qq.com
ID:76671 發表于 2015-5-7 18:33 來自觸屏版 | 只看該作者
nlztc77 發表于 2015-5-4 22:01
樓主您好,有高清原理圖嗎,
我找到高清原理圖了!可是不知道怎么下載程序!交流交流下唄!
ID:77383 發表于 2015-6-7 11:36 | 只看該作者
厲害,求資料
ID:82852 發表于 2015-6-12 22:49 | 只看該作者
6666大神啊
ID:97369 發表于 2015-11-27 16:38 | 只看該作者
求高清原理圖605613364@qq.com
ID:97673 發表于 2015-11-30 13:06 | 只看該作者
太厲害壓
魚魚yy語音
ID:98638 發表于 2015-12-8 18:14 | 只看該作者
底下電源是怎么做的?
ID:44267 發表于 2015-12-26 07:58 | 只看該作者
幫樓主頂起
ID:104450 發表于 2016-2-17 21:34 | 只看該作者
感覺比其他的簡單多了!有資料的話就好了
ID:104763 發表于 2016-2-18 09:46 | 只看該作者
樓主厲害
ID:100985 發表于 2016-3-8 18:18 | 只看該作者
好厲害!學習了、
ID:108140 發表于 2016-3-10 00:09 來自觸屏版 | 只看該作者
樓主有高清圖嗎?更新一下吧
這東西太好了
ID:100985 發表于 2016-3-12 18:04 來自觸屏版 | 只看該作者
求效果圖啊!
ID:111164 發表于 2016-3-28 17:34 | 只看該作者
求資料!
ID:39025 發表于 2016-4-3 11:51 | 只看該作者
幫樓主頂起
ID:103831 發表于 2016-4-4 11:58 | 只看該作者
無線供電部分 有什么特殊要求嗎?比如222的電容 瓷片電容可以嗎,線圈L的繞制  是采用多少線徑的漆包線呢,我弄得 無線供電 不能實現,不起振 是咋回事
ID:99130 發表于 2016-6-26 17:27 | 只看該作者
原理圖有高清的嗎
ID:128560 發表于 2016-7-1 13:42 | 只看該作者
非常棒,求資料
ID:145294 發表于 2016-10-31 11:04 | 只看該作者
求資料
ID:145320 發表于 2016-10-31 13:06 | 只看該作者
厲害!!!!!!!!!!!!!
ID:65581 發表于 2016-10-31 14:12 | 只看該作者
贊!!!最好有效果圖看一下。
ID:233756 發表于 2017-11-29 09:00 | 只看該作者
6666大神啊
ID:187478 發表于 2017-11-29 10:50 | 只看該作者
我有問題 ,板子自己做嗎???因為我自己做的板子太重了
ID:313953 發表于 2018-6-7 01:46 來自觸屏版 | 只看該作者
樓主你好,請問你用的是哪種取模軟件
