查看: 3208|回復: 0
RF1100SE單片機C8051F310
ID:75926 發表于 2015-4-4 02:47 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <c8051f310.h>
#include <stdio.h>
#include <math.h>
#include <Intrins.h>
#include <absacc.h>
#define BUSY SPI0CFG&0x80//SPI接口檢測
code uchar PaTabel[]={0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60};//配置功率
uchar send_buf[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
//要發送的有效數據,其中第一個為數據的長度
uchar rx_buf[8]={0}; //接收的數據緩存
//引腳定義*********************************************************************************
#define CSN_HIGH CSN=1
#define CSN_LOW CSN=0
sbit GDO0 =P0^6;
sbit CSN =P0^3;
sbit MISO =P0^1; //為了檢測是否穩定
sbit c=P0^7;
#define WRITE_BURST      0x40 //連續寫入多個字節,即為突發訪問
#define READ_SINGLE      0x80 //讀一個字節
#define READ_BURST       0xC0 //連續讀多個字節
#define BYTES_IN_RXFIFO     0x7F   //接收緩沖區的有效字節數
#define CRC_OK              0x80  //CRC校驗通過位標志
//RF1100SE寄存器地址
#define IOCFG2   0x00
#define IOCFG1   0x01
#define IOCFG0   0x02
#define FIFOTHR  0x03
#define SYNC1    0x04
#define SYNC0    0x05
#define PKTLEN   0x06
#define PKTCTRL1 0x07
#define PKTCTRL0 0x08
#define ADDR     0x09
#define CHANNR   0x0a
#define FSCTRL1  0x0b
#define FSCTRL0  0x0c
#define FREQ2    0x0d
#define FREQ1    0x0e
#define FREQ0    0x0f
//配置寄存器
#define MDMCFG4  0x10
#define MDMCFG3  0x11
#define MDMCFG2  0x12
#define MDMCFG1  0x13
#define MDMCFG0  0x14
#define DEVIATN  0x15
#define MCSM2    0x16
#define MCSM1    0x17
#define MCSM0    0x18
#define FOCCFG   0x19
#define BSCFG    0x1a
#define AGCTRL2  0x1b
#define AGCTRL1  0x1c
#define AGCTRL0  0x1d
#define WOREVT1  0x1e
#define WOREVT0  0x1f
#define WORCTRL  0x20
#define FREND1   0x21
#define FREND0   0x22
#define FSCAL3   0x23
#define FSCAL2   0x24
#define FSCAL1   0x25
#define FSCAL0   0x26
#define RCCTRL1  0x27
#define RCCTRL0  0x28
#define FSTEST   0x29
#define PTEST    0x2a
#define AGCTEST  0x2b
#define TEST2    0x2c
#define TEST1    0x2d
#define TEST0    0x2e
//狀態寄存器
#define PARTNUM  0x30
#define VERSION  0x31
#define FREQEST  0x32
#define LQI      0x33
#define RSSI     0x34
#define MARCSTATE 0x35
#define WORTIME1  0x36
#define WORTIME0  0x37
#define PKTSTATUS 0x38
#define VCOVCDAC  0x39
#define TXBYTES   0x3a
#define RXBYTES   0x3b
#define PATABLE   0x3e
#define TX_FIFO   0x3f
#define RX_FIFO   0x3f
//控制命令寄存器
#define SRES     0x30//重啟芯片
#define SFSTXON  0x31//開啟和校準頻率合成器
#define SXOFF    0x32//關閉晶體振蕩器
#define SCAL     0x33//校準頻率合成器并關斷
#define SRX      0x34//啟用RX
#define STX      0x35//空閑狀態時啟用TX
#define SIDLE    0x36//離開RX/TX關斷頻率合成器并離開電磁波激活模式
#define SAFC     0x37//運行頻率合成器的AFC調節
#define SWOR     0x38//運行自動RX選舉序列
#define SPWD     0x39//當CSn為高時進入功率降低模式
#define SFRX     0x3a//沖洗RX_FIFO緩沖
#define SFTX     0x3b//沖洗TX_FIFO緩沖
#define SWORRST  0x3c//重新設置真實時間時鐘
#define SNOP     0x3d//附加:軟件擴充為兩個字節
//函數聲明*********************************************************************************
void sysclk(void);
void pio(void);
void SPI(void);
void Interrupt_int(void);
void delay(uint i);
void dat_int(void);
uchar SPI_RW(uchar byte);        //用SPI讀寫一字節的數據
void SPI_WR_Strobe(uchar strobe);    //寫入濾波命令
void POWER_UP_RESET_CC1100(void);    //上電復位
uchar SPI_RW_Reg(uchar reg,uchar value);  //向寄存器寫一字節的數據,同時返回狀態字
uchar SPI_Read_Reg(uchar reg);     //從寄存器讀一字節的數據
uchar SPI_Read_Buf(uchar reg,uchar *pBuf,uchar bytes); //從reg連續讀出bytes字節的數據
uchar SPI_RW_Buf(uchar reg,uchar *pBuf,uchar bytes); //向reg連續寫入bytes字節的數據
uchar RF1100CE_RxPacket(uchar *rx_buf,uchar *length); //接收函數
void  RF1100CE_TxPacket(uchar *tx_buf,uchar size);  //發送函數
void RF1100CE_Config(void);        //RF1100CE的配置函數
void main(void)   //主程序
{uchar sta=0;
PCA0MD &= ~0x40;// 關閉看門狗
pio();
sysclk();
dat_int();
SPI();   //SPI0DAT是SPI的數據寄存器
Interrupt_int();
EA=0;
POWER_UP_RESET_CC1100();
    RF1100CE_Config();     //RF1100CE的配置函數
SPI_RW_Buf(PATABLE,PaTabel,8); //對設備進行功率配置
delay(6000);
  RF1100CE_TxPacket(send_buf,8);  //發送函數
c=1;
delay(100);
  if(sta&0xff)
  CSN_LOW;
   SPI_RW(SFTX); //清除發送寄存器的值
    CSN_HIGH;
void dat_int(void)
CSN_LOW;
_nop_();
CSN_HIGH;
c=0;
void sysclk(void)    //內部晶振
   OSCICL=0xb3; // 0xb3
   OSCICN=0xc2; //二分頻
   CLKSEL=0x00;
//延時子函數10us
void delay(uint i)
  while(i--);
uchar SPI_RW(uchar byte)   //用SPI讀寫一字節的數據
  uchar rbyte;
  SPI0DAT=byte;
while(!SPIF);
  rbyte=SPI0DAT;
  SPIF=0;
  return rbyte;
void SPI_WR_Strobe(uchar strobe) //寫入濾波命令
    CSN_LOW;
    while (MISO);
    SPI_RW(strobe);
while(MISO);
    CSN_HIGH;
void POWER_UP_RESET_CC1100(void) //上電復位
CSN = 1;
delay(10);
CSN = 0;
delay(10);
CSN = 1;
delay(500);
SPI_WR_Strobe(SRES);     //復位CC1100
uchar SPI_RW_Reg(uchar reg,uchar value) //向寄存器寫一字節的數據,同時返回狀態字
  uchar status;
  CSN_LOW;
  while(MISO);
  SPI0DAT=reg;
  while(!SPIF);
  status=SPI0DAT;
  SPIF=0;
  SPI0DAT=value;
  while(!SPIF);
  SPIF=0;
  CSN_HIGH;
  return(status);
uchar SPI_Read_Reg(uchar reg)  //從寄存器讀出一字節的數據
  uchar byte;
  CSN_LOW;
   while (MISO);
    SPI0DAT=reg|READ_SINGLE ;
   while(!SPIF);
  SPIF=0;
  SPI0DAT=0x00;
   while(!SPIF);
  byte=SPI0DAT;
  SPIF=0;
  CSN_HIGH;
  return byte;
uchar SPI_Read_Buf(uchar reg,uchar *pBuf,uchar bytes) //從reg讀出bytes字節的數據
  uchar status,byte_ctr;
  CSN_LOW;
while (MISO);
   status=SPI_RW(reg|READ_BURST);
   for(byte_ctr=0;byte_ctr<bytes;byte_ctr++)
     pBuf[byte_ctr]=SPI_RW(0);
  CSN_HIGH;
  return status;
uchar SPI_RW_Buf(uchar reg,uchar *pBuf,uchar bytes)  //向reg寫入bytes字節的數據
  CSN_LOW;
while (MISO);
status=SPI_RW(reg|WRITE_BURST);
     SPI_RW(pBuf[byte_ctr]);
  CSN_HIGH;
  return status;
//接收函數,接收返回1表示有數據收到
  uchar status[2];
  uchar packetLength;
  uchar i=(*length)*4;  // 具體多少要根據datarate和length來決定
SPI_WR_Strobe(SRX);  //進入接收模式指令
delay(10);
while (GDO0)
  delay(10);
  --i;
  if(i<1)
    return 0;
if(SPI_Read_Reg(RXBYTES+READ_BURST) & BYTES_IN_RXFIFO) //如果接的字節數不為0
        packetLength = SPI_Read_Reg(RX_FIFO);//讀出第一個字節,此字節為該幀數據長度
        if (packetLength <= *length)   //如果所要的有效數據長度小于等于接收到的數據包的長度
            SPI_Read_Buf(RX_FIFO, rx_buf, packetLength); //讀出所有接收到的數據
            *length = packetLength;    //把接收數據長度的修改為當前數據的長度
            SPI_Read_Buf(RX_FIFO, status, 2);  //讀出CRC校驗位
   SPI_WR_Strobe(SFRX);    //清洗接收緩沖區
            return (status[1] & CRC_OK);  //如果校驗成功返回接收成功
            return 0;
  return 0;
//發送函數
    SPI_RW_Reg(TX_FIFO, size);
    SPI_RW_Buf(TX_FIFO, tx_buf, size); //寫入要發送的數據
    SPI_WR_Strobe(STX);  //進入發送模式發送數據
    while (!GDO0);
    while (GDO0);
SPI_WR_Strobe(SFTX); //清除發送緩沖寄存器
SPI_WR_Strobe(SIDLE);//進入休眠模式
void RF1100CE_Config(void)   //RF1100CE的配置函數
   CSN_HIGH;//SPI復位
    SPI_RW_Reg(FSCTRL1, 0x08);//頻率合成器控制
    SPI_RW_Reg(FSCTRL0, 0x00);
    SPI_RW_Reg(FREQ2,   0x10);//頻率控制詞匯
    SPI_RW_Reg(FREQ1,   0xa7);
    SPI_RW_Reg(FREQ0,   0x62);
    SPI_RW_Reg(MDMCFG4, 0x5b);//調制器配置
    SPI_RW_Reg(MDMCFG3, 0xf8);
    SPI_RW_Reg(MDMCFG2, 0x03);
    SPI_RW_Reg(MDMCFG1, 0x22);
    SPI_RW_Reg(MDMCFG0, 0xf8);
    SPI_RW_Reg(CHANNR,  0x00);//信道數
SPI_RW_Reg(DEVIATN, 0x47);
SPI_RW_Reg(FREND1,  0xb6);
SPI_RW_Reg(FREND0,  0x10);
SPI_RW_Reg(MCSM0,   0x18);
SPI_RW_Reg(FOCCFG,  0x1d);
SPI_RW_Reg(BSCFG,   0x1c);
SPI_RW_Reg(AGCTRL2, 0xc7);
SPI_RW_Reg(AGCTRL1, 0x00);
SPI_RW_Reg(AGCTRL0, 0xb2);
SPI_RW_Reg(FSCAL3,   0xea);//頻率合成器校準
SPI_RW_Reg(FSCAL2,   0x2a);
SPI_RW_Reg(FSCAL1,   0x00);
    SPI_RW_Reg(FSCAL0,   0x11);
    SPI_RW_Reg(FSTEST,   0x59);//產品測試
    SPI_RW_Reg(TEST2,    0x81);//不同的測試設置
    SPI_RW_Reg(TEST1,    0x35);
    SPI_RW_Reg(TEST0,    0x09);
    SPI_RW_Reg(IOCFG2,   0x0b);
    SPI_RW_Reg(IOCFG0,   0x06);//GDO輸出腳配置
    SPI_RW_Reg(PKTCTRL1, 0x04);//數據包自動控制,無地址檢測,包含兩個狀態字節
    SPI_RW_Reg(PKTCTRL0, 0x05);//開啟CC2400支持,采用可變長度數據包
    SPI_RW_Reg(ADDR,     0x00);//設置地址
    SPI_RW_Reg(PKTLEN,   0x10);//有效允許最大數據包長度16個字節
void SPI(void)  //SPI初始化
SPI0CFG=0x40; //時鐘極性為低,即剛開始時鐘要為低電平
SPI0CN=0x01; //0000 0001最后一位是SPI使能位 SPI工作在三線主方式
SPI0CKR=0x2f; //SPI 時鐘頻率設置為150kHz 0x6f 0x2f
void Interrupt_int(void)   //中斷設定
   IE=0x40;  //允許SPI中斷請求
   IP=0x00;  //SPI為低優先級
void pio(void)   // 端口配置
P0MDIN=0xff;  //禁止模擬輸入,0為模擬,1為數字
P0MDOUT=0xff; //0為開漏,1為推挽(ff)
P0SKIP=0x00;
P1MDIN=0xff;
P1MDOUT=0xff; //低四位用于138
P2MDIN=0xff;  //禁止模擬輸入,0為模擬,1為數字
P2MDOUT=0xff; //0為開漏,1為推挽(ff)
P3MDIN=0xff;
P3MDOUT=0xff; //低四位用于138
XBR0=0x02;
XBR1=0x40;
