只需一步,快速開(kāi)始
查看: 4219|回復(fù): 1
單片機(jī)一字節(jié)帶符號(hào)乘法運(yùn)算-匯編語(yǔ)言程序
ID:75926 發(fā)表于 2015-4-4 02:33 | 顯示全部樓層 |閱讀模式
ZF            bit             00horg           0000h
AJmp       Main
Main:       Clr             Zf
                Mov          A,#-74
                Mov          B,#69
                Jnb           Acc.7,Af
                Mov          R3,A
                Cpl           ZF
                clr             C
                Clr             A
                Subb         A,R3
AF:           Mov          R5,A
                Jnb            B.7,BF
                Mov           R3,B
                Cpl            ZF
                clr              C
                Clr             A
                Subb         A,R3
                Mov           B,A
BF:           Mov           A,R5
                Mul            AB
                 Jnb            ZF,Result
                 Clr             c
                 Mov           R5,A
                 Clr               A
                 Subb           A,R5
                 Mov            R5,A
                 Clr               A
                 Subb           A,B
                 Mov            B,A
                 Mov            A,R5
Result:
MainLoop:
                AJmp         MainLoop
                End
ID:148126 發(fā)表于 2018-11-6 14:39 | 顯示全部樓層
C語(yǔ)言系列有沒(méi)有
