目錄
1、 輸入偏置電流和輸入失調(diào)電流 ........................................................................................... 2
2、 如何測(cè)量輸入偏置電流Ib,失調(diào)電流Ios ......................................................................... 6
3、 輸入失調(diào)電壓Vos 及溫漂 ................................................................................................. 10
4、 運(yùn)放噪聲快速計(jì)算 ............................................................................................................. 14
5、 電源抑制比DC-PSRR .......................................................................................................... 18
6、 電源抑制比AC-PSRR .......................................................................................................... 19
7、 共模抑制比CMRR .............................................................................................................. 22
8、 共模抑制比CMRR 的影響 ................................................................................................. 25
9、 放大電路直流誤差(DC error) ....................................................................................... 28
10、 放大電路直流誤差(DC error)的影響因素 ............................................................... 29
11、 輸入阻抗和輸入電容 ..................................................................................................... 31
12、 輸入電容Cin 的測(cè)量 ...................................................................................................... 33
13、 軌至軌輸入(rail to rail input) .................................................................................... 35
14、 軌至軌輸入_TI 的領(lǐng)先技術(shù) ........................................................................................... 38
15、 開(kāi)環(huán)增益Aol .................................................................................................................. 40
16、 增益帶寬積(GBW)..................................................................................................... 43
17、 從開(kāi)環(huán)增益曲線談到運(yùn)放穩(wěn)定性 ................................................................................. 44
18、 壓擺率(SR) ...................................................................................................................... 47
19、 全功率帶寬(FPBW) ......................................................................................................... 50
20、 建立時(shí)間(Settling Time) ................................................................................................. 52
21、 總諧波失真(THD) ........................................................................................................... 53
22、 軌至軌(rail to rail)輸出 ................................................................................................... 55
23、 輸出短路電流 ................................................................................................................. 57
24、 輸出阻抗Ro 和Rout ...................................................................................................... 58
25、 運(yùn)放的熱阻 ..................................................................................................................... 62
運(yùn)放參數(shù)的詳細(xì)解釋和分析
運(yùn)算放大器電路中固有噪聲的分析與測(cè)量
下載地址:
運(yùn)算放大器電路中固有噪聲的分析與測(cè)量.pdf
(4 MB, 下載次數(shù): 140)
2015-3-20 19:14 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
運(yùn)算放大器設(shè)計(jì)與應(yīng)用.pdf
(1.14 MB, 下載次數(shù): 131)
2015-3-20 19:14 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
