查看: 9315|回復(fù): 4
LCD12864顯示奇怪符號(hào),如何破?
ID:74595 發(fā)表于 2015-3-20 11:41 | 顯示全部樓層 |閱讀模式
后面四個(gè)笑臉如何讓它顯示數(shù)字。。。
LCD12864顯示
LCD12864顯示
相關(guān)帖子
ID:1 發(fā)表于 2015-3-20 16:25 | 顯示全部樓層
你的程序呢?貼上來看看 能不能改
ID:67796 發(fā)表于 2015-3-20 18:05 | 顯示全部樓層
12使用半角字符試試。
ID:74897 發(fā)表于 2015-3-20 18:22 | 顯示全部樓層
看看數(shù)據(jù)格式
ID:74595 發(fā)表于 2015-3-21 10:50 | 顯示全部樓層
本帖最后由 糖果 于 2015-3-21 11:00 編輯
#include <reg51.h>
#include <intrins.h>
#include<absacc.h>
typedef unsigned char uchar;
typedef unsigned char uint;
//數(shù)碼管IO
#define DIG    P0
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
sbit DSPORT=P3^7;
//****************************************NRF24L01端口定義***************************************
sbit     MISO    =P2^0;
sbit     MOSI    =P2^2;
sbit    SCK        =P3^6;
sbit    CE        =P1^0;
sbit    CSN        =P3^7;
sbit    IRQ        =P3^3;
//*************************************PH傳感器端口定義**********************************
#define GPIO_DIG P0
sbit DOUT = P3^7;      //輸出
sbit CLK  = P3^6;      //時(shí)鐘
sbit DIN  = P3^4;      //輸入
sbit CS   = P3^5;      //片選
//sbit DSPORT=P3^7;
//************************************按鍵***************************************************
//sbit    KEY1=P3^4;
//************************************蜂明器***************************************************
sbit     LED=P2^5;
//***********************************發(fā)送緩沖區(qū)*********************************************
   uchar codess[10]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
   uchar TxBuf[32];
   unsigned char code DIG_CODE[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
   unsigned char Num=0;
   unsigned int disp[8]={0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f};
//*********************************************NRF24L01*************************************
#define TX_ADR_WIDTH    5       // 5 uints TX address width
#define RX_ADR_WIDTH    5       // 5 uints RX address width
#define TX_PLOAD_WIDTH  32      // 20 uints TX payload
#define RX_PLOAD_WIDTH  32      // 20 uints TX payload
uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};    //本地地址
uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01};    //接收地址
//***************************************NRF24L01寄存器指令*******************************************************
#define READ_REG        0x00      // 讀寄存器指令
#define WRITE_REG       0x20     // 寫寄存器指令
#define RD_RX_PLOAD     0x61      // 讀取接收數(shù)據(jù)指令
#define WR_TX_PLOAD     0xA0      // 寫待發(fā)數(shù)據(jù)指令
#define FLUSH_TX        0xE1     // 沖洗發(fā)送 FIFO指令
#define FLUSH_RX        0xE2      // 沖洗接收 FIFO指令
#define REUSE_TX_PL     0xE3      // 定義重復(fù)裝載數(shù)據(jù)指令
#define NOP             0xFF      // 保留
//*************************************SPI(nRF24L01)寄存器地址****************************************************
#define CONFIG          0x00  // 配置收發(fā)狀態(tài),CRC校驗(yàn)?zāi)J揭约笆瞻l(fā)狀態(tài)響應(yīng)方式
#define EN_AA           0x01  // 自動(dòng)應(yīng)答功能設(shè)置
#define EN_RXADDR       0x02  // 可用信道設(shè)置
#define SETUP_AW        0x03  // 收發(fā)地址寬度設(shè)置
#define SETUP_RETR      0x04  // 自動(dòng)重發(fā)功能設(shè)置
#define RF_CH           0x05  // 工作頻率設(shè)置
#define RF_SETUP        0x06  // 發(fā)射速率、功耗功能設(shè)置
#define STATUS          0x07  // 狀態(tài)寄存器
#define OBSERVE_TX      0x08  // 發(fā)送監(jiān)測(cè)功能
#define CD              0x09  // 地址檢測(cè)
#define RX_ADDR_P0      0x0A  // 頻道0接收數(shù)據(jù)地址
#define RX_ADDR_P1      0x0B  // 頻道1接收數(shù)據(jù)地址
#define RX_ADDR_P2      0x0C  // 頻道2接收數(shù)據(jù)地址
#define RX_ADDR_P3      0x0D  // 頻道3接收數(shù)據(jù)地址
#define RX_ADDR_P4      0x0E  // 頻道4接收數(shù)據(jù)地址
#define RX_ADDR_P5      0x0F  // 頻道5接收數(shù)據(jù)地址
#define TX_ADDR         0x10  // 發(fā)送地址寄存器
#define RX_PW_P0        0x11  // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define RX_PW_P1        0x12  // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define RX_PW_P2        0x13  // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define RX_PW_P3        0x14  // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define RX_PW_P4        0x15  // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define RX_PW_P5        0x16  // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define FIFO_STATUS     0x17  // FIFO棧入棧出狀態(tài)寄存器設(shè)置
void Delay(unsigned int s);
void inerDelay_us(unsigned char n);
void init_NRF24L01(void);
uint SPI_RW(uint uchar1);
uchar SPI_Read(uchar reg);
void SetRX_Mode(void);
uint SPI_RW_Reg(uchar reg, uchar value);
uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars);
uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars);
unsigned char nRF24L01_RxPacket(unsigned char* rx_buf);
void nRF24L01_TxPacket(unsigned char * tx_buf);
//***********************傳感器相關(guān)函數(shù)**************************************8
uint Read_AD_Data(uchar cmd);
uint SPI_Read_AD(void);
void SPI_Write(uchar dat);
//*****************************************長(zhǎng)延時(shí)*****************************************
    unsigned int i;
    for(i=0; i<s; i++);
    for(i=0; i<s; i++);
uchar Display(uchar temp)      //顯示
      unsigned char datas[] = {0, 0, 0, 0, 0}; //定義數(shù)組
    float tp;
    if(temp< 0)                //當(dāng)溫度值為負(fù)數(shù)
        disp[2] = 0x40;
        //因?yàn)樽x取的溫度是實(shí)際溫度的補(bǔ)碼,所以減1,再取反求出原碼
        temp=temp-1;
        temp=~temp;
        tp=temp;
        temp=tp*0.0625*100+0.5;
        //留兩個(gè)小數(shù)點(diǎn)就*100,+0.5是四舍五入,因?yàn)镃語言浮點(diǎn)數(shù)轉(zhuǎn)換為整型的時(shí)候把小數(shù)點(diǎn)
        //后面的數(shù)自動(dòng)去掉,不管是否大于0.5,而+0.5之后大于0.5的就是進(jìn)1了,小于0.5的就
        //算由?.5,還是在小數(shù)點(diǎn)后面。
        disp[2] = 0;
        tp=temp;//因?yàn)閿?shù)據(jù)處理有小數(shù)點(diǎn)所以將溫度賦給一個(gè)浮點(diǎn)型變量
        //如果溫度是正的那么,那么正數(shù)的原碼就是補(bǔ)碼它本身
        //算加上0.5,還是在小數(shù)點(diǎn)后面。
    disp[0] = 0;
    disp[1] = 0;
    disp[3] = DIG_CODE[temp / 10000];
    disp[4] = DIG_CODE[temp % 10000 / 1000];
    disp[5] = DIG_CODE[temp % 1000 / 100] | 0x80;
    disp[6] = DIG_CODE[temp % 100 / 10];
    disp[7] = DIG_CODE[temp % 10];
    return temp;
* 函數(shù)名         : Timer0Configuration()
* 函數(shù)功能           : 設(shè)置計(jì)時(shí)器
* 輸入           : 無
* 輸出              : 無
void Delay1ms(unsigned int y)
    unsigned int x;
    for(y;y>0;y--)
        for(x=110;x>0;x--);
void Timer0Configuration()
    TMOD=0X02;//選擇為定時(shí)器模式,工作方式2,僅用TRX打開啟動(dòng)。
    TH0=0X9C;    //給定時(shí)器賦初值,定時(shí)100us
    TL0=0X9C;
    ET0=1;//打開定時(shí)器0中斷允許
    EA=1;//打開總中斷
    TR0=1;//打開定時(shí)器
* 函數(shù)名         : DigDisplay() interrupt 1
* 函數(shù)功能           : 中斷數(shù)碼管顯示
* 輸入           : 無
* 輸出              : 無
void DigDisplay() interrupt 1
//定時(shí)器在工作方式二會(huì)自動(dòng)重裝初,所以不用在賦值。
//    TH0=0X9c;//給定時(shí)器賦初值,定時(shí)1ms
//    TL0=0X00;
    DIG=0; //消隱
    switch(Num)     //位選,選擇點(diǎn)亮的數(shù)碼管,
        case(7):
            LSA=0;LSB=0;LSC=0; break;
        case(6):
            LSA=1;LSB=0;LSC=0; break;
        case(5):
            LSA=0;LSB=1;LSC=0; break;
        case(4):
            LSA=1;LSB=1;LSC=0; break;
        case(3):
            LSA=0;LSB=0;LSC=1; break;
        case(2):
            LSA=1;LSB=0;LSC=1; break;
        case(1):
            LSA=0;LSB=1;LSC=1; break;
        case(0):
            LSA=1;LSB=1;LSC=1; break;
    DIG=disp[Num]; //段選,選擇顯示的數(shù)字。
    Num++;
    if(Num>7)
        Num=0;
  unsigned char Ds18b20Init()
    unsigned int i;
    EA = 0;
    DSPORT=0;             //將總線拉低480us~960us
    i=70;
    while(i--);            //延時(shí)642us
    DSPORT=1;            //然后拉高總線,如果DS18B20做出反應(yīng)會(huì)將在15us~60us后總線拉低
    i=0;
    EA = 1;
    while(DSPORT)    //等待DS18B20拉低總線
        i++;
        if(i>5000)//等待>5MS
            return 0;//初始化失敗
    return 1;//初始化成功
* 函數(shù)名         : Ds18b20WriteByte
* 函數(shù)功能           : 向18B20寫入一個(gè)字節(jié)
* 輸入           : com
* 輸出              : 無
void Ds18b20WriteByte(unsigned char dat)
    unsigned int i,j;
    EA = 0;
    for(j=0;j<8;j++)
        DSPORT=0;            //每寫入一位數(shù)據(jù)之前先把總線拉低1us
        i++;
        DSPORT=dat&0x01; //然后寫入一個(gè)數(shù)據(jù),從最低位開始
        i=6;
        while(i--); //延時(shí)68us,持續(xù)時(shí)間最少60us
        DSPORT=1;    //然后釋放總線,至少1us給總線恢復(fù)時(shí)間才能接著寫入第二個(gè)數(shù)值
        dat>>=1;
    EA = 1;
* 函數(shù)名         : Ds18b20ReadByte
* 函數(shù)功能           : 讀取一個(gè)字節(jié)
* 輸入           : com
* 輸出              : 無
unsigned char Ds18b20ReadByte()
    unsigned char byte,bi;
    unsigned int i,j;
    EA = 0;
    for(j=8;j>0;j--)
        DSPORT=0;//先將總線拉低1us
        i++;
        DSPORT=1;//然后釋放總線
        i++;
        i++;//延時(shí)6us等待數(shù)據(jù)穩(wěn)定
        bi=DSPORT;     //讀取數(shù)據(jù),從最低位開始讀取
        /*將byte左移一位,然后與上右移7位后的bi,注意移動(dòng)之后移掉那位補(bǔ)0。*/
        byte=(byte>>1)|(bi<<7);
        i=4;        //讀取完之后等待48us再接著讀取下一個(gè)數(shù)
        while(i--);
    EA = 1;
    return byte;
* 函數(shù)名         : Ds18b20ChangTemp
* 函數(shù)功能           : 讓18b20開始轉(zhuǎn)換溫度
* 輸入           : com
* 輸出              : 無
void  Ds18b20ChangTemp()
    Ds18b20Init();
    Delay1ms(1);
    Ds18b20WriteByte(0xcc);        //跳過ROM操作命令
    Ds18b20WriteByte(0x44);        //溫度轉(zhuǎn)換命令
//    Delay1ms(100);    //等待轉(zhuǎn)換成功,而如果你是一直刷著的話,就不用這個(gè)延時(shí)了
* 函數(shù)名         : Ds18b20ReadTempCom
* 函數(shù)功能           : 發(fā)送讀取溫度命令
* 輸入           : com
* 輸出              : 無
void  Ds18b20ReadTempCom()
    Ds18b20Init();
    Delay1ms(1);
    Ds18b20WriteByte(0xbe);     //發(fā)送讀取溫度命令
* 函數(shù)功能           : 讀取溫度
* 輸入           : com
* 輸出              : 無
int Ds18b20ReadTemp()
    int temp=0;
    unsigned char tmh,tml;
    Ds18b20ChangTemp();                 //先寫入轉(zhuǎn)換命令
    Ds18b20ReadTempCom();            //然后等待轉(zhuǎn)換完后發(fā)送讀取溫度命令
    tml=Ds18b20ReadByte();        //讀取溫度值共16位,先讀低字節(jié)
    tmh=Ds18b20ReadByte();        //再讀高字節(jié)
    temp=tmh;
    temp<<=8;
    temp|=tml;
    return temp;
* 函數(shù)名         : main
* 函數(shù)功能           : 主函數(shù)
* 輸入           : 無
* 輸出              : 無
uint     bdata sta;   //狀態(tài)標(biāo)志
sbit    RX_DR    =sta^6;
sbit    TX_DS    =sta^5;
sbit    MAX_RT    =sta^4;
/*延時(shí)函數(shù)
    for(;n>0;n--)
        _nop_();
/*NRF24L01初始化
    inerDelay_us(100);
     CE=0;    // chip enable
     CSN=1;   // Spi disable
     SCK=0;   // Spi clock line init high
    SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH);    // 寫本地地址
    SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 寫接收端地址
    SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);      //  頻道0自動(dòng)    ACK應(yīng)答允許
    SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01);  //  允許接收地址只有頻道0,如果需要多頻道可以參考Page21
    SPI_RW_Reg(WRITE_REG + RF_CH, 0);        //   設(shè)置信道工作為2.4GHZ,收發(fā)必須一致
    SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //設(shè)置接收數(shù)據(jù)長(zhǎng)度,本次設(shè)置為32字節(jié)
    SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);          //設(shè)置發(fā)射速率為1MHZ,發(fā)射功率為最大值0dB
    SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);           // IRQ收發(fā)完成中斷響應(yīng),16位CRC,主發(fā)送
/*函數(shù):uint SPI_RW(uint uchar)
/*功能:NRF24L01的SPI寫時(shí)序
    uint bit_ctr;
       for(bit_ctr=0;bit_ctr<8;bit_ctr++) // output 8-bit
        MOSI = (uchar1 & 0x80);         // output 'uchar', MSB to MOSI
        uchar1 = (uchar1 << 1);           // shift next bit into MSB..
        SCK = 1;                      // Set SCK high..
        uchar1 |= MISO;                // capture current MISO bit
        SCK = 0;                     // ..then set SCK low again
    return(uchar1);                     // return read uchar
/*函數(shù):uchar SPI_Read(uchar reg)
/*功能:NRF24L01的SPI時(shí)序
    uchar reg_val;
    CSN = 0;                // CSN low, initialize SPI communication...
    SPI_RW(reg);            // Select register to read from..
    reg_val = SPI_RW(0);    // ..then read registervalue
    CSN = 1;                // CSN high, terminate SPI communication
    return(reg_val);        // return register value
/*功能:NRF24L01讀寫寄存器函數(shù)
    uint status;
    CSN = 0;                   // CSN low, init SPI transaction
    status = SPI_RW(reg);      // select register
    SPI_RW(value);             // ..and write value to it..
    CSN = 1;                   // CSN high again
    return(status);            // return nRF24L01 status uchar
/*函數(shù):uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars)
/*功能: 用于讀數(shù)據(jù),reg:為寄存器地址,pBuf:為待讀出數(shù)據(jù)地址,uchars:讀出數(shù)據(jù)的個(gè)數(shù)
    uint status,uchar_ctr;
    CSN = 0;                           // Set CSN low, init SPI tranaction
    status = SPI_RW(reg);              // Select register to write to and read status uchar
    for(uchar_ctr=0;uchar_ctr<uchars;uchar_ctr++)
        pBuf[uchar_ctr] = SPI_RW(0);    //
    CSN = 1;
/*函數(shù):uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars)
/*功能: 用于寫數(shù)據(jù):為寄存器地址,pBuf:為待寫入數(shù)據(jù)地址,uchars:寫入數(shù)據(jù)的個(gè)數(shù)
    CSN = 0;            //SPI使能
    for(uchar_ctr=0; uchar_ctr<uchars; uchar_ctr++) //
        SPI_RW(*pBuf++);
    CSN = 1;           //關(guān)閉SPI
    return(status);    //
/*函數(shù):void SetRX_Mode(void)
/*功能:數(shù)據(jù)接收配置
    CE=0;
    SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f);          // IRQ收發(fā)完成中斷響應(yīng),16位CRC    ,主接收
    CE = 1;
    inerDelay_us(130);    //延時(shí)不能太短
/*函數(shù):unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
/*功能:數(shù)據(jù)讀取后放如rx_buf接收緩沖區(qū)中
    unsigned char revale=0;
    sta=SPI_Read(STATUS);    // 讀取狀態(tài)寄存其來判斷數(shù)據(jù)接收狀況
    if(RX_DR)                // 判斷是否接收到數(shù)據(jù)
        CE = 0;            //SPI使能
        SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);// read receive payload from RX_FIFO buffer
        revale =1;            //讀取數(shù)據(jù)完成標(biāo)志
    SPI_RW_Reg(WRITE_REG+STATUS,sta);   //接收到數(shù)據(jù)后RX_DR,TX_DS,MAX_PT都置高為1,通過寫1來清楚中斷標(biāo)志
    return revale;
/*函數(shù):void nRF24L01_TxPacket(unsigned char * tx_buf)
/*功能:發(fā)送 tx_buf中數(shù)據(jù)
    CE=0;            //StandBy I模式
    SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 裝載接收端地址
    SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH);             // 裝載數(shù)據(jù)
//    SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e);            // IRQ收發(fā)完成中斷響應(yīng),16位CRC,主發(fā)送
    CE=1;         //置高CE,激發(fā)數(shù)據(jù)發(fā)送
    inerDelay_us(10);
//*************************************PH傳感器函數(shù)*******************************************
*函數(shù)名:TSPI_Start
*輸  入:無
*輸  出:無
*功  能:初始化觸摸SPI
void SPI_Start(void)
    CLK = 0;
    CS  = 1;
    DIN = 1;
    CLK = 1;
    CS  = 0;
*函數(shù)名:SPI_Write
*輸  入:dat:寫入數(shù)據(jù)
*輸  出:無
*功  能:使用SPI寫入數(shù)據(jù)
    uchar i;
    CLK = 0;
    for(i=0; i<8; i++)
        DIN = dat >> 7;     //放置最高位
        dat <<= 1;
        CLK = 0;            //上升沿放置數(shù)據(jù)
        CLK = 1;
*函數(shù)名:SPI_Read
*輸  入:無
*輸  出:dat:讀取 到的數(shù)據(jù)
*功  能:使用SPI讀取數(shù)據(jù)
    uint i, dat=0;
    CLK = 0;
    for(i=0; i<12; i++)        //接收12位數(shù)據(jù)
        dat <<= 1;
        CLK = 1;
        CLK = 0;
        dat |= DOUT;
    return dat;
*函數(shù)名:Read_AD_Data
*輸  入:cmd:讀取的X或者Y
*輸  出:endValue:最終信號(hào)處理后返回的值
*功  能:讀取觸摸數(shù)據(jù)
    uchar i;
    uint AD_Value;
    CLK = 0;
    CS  = 0;
    SPI_Write(cmd);
    for(i=6; i>0; i--);    //延時(shí)等待轉(zhuǎn)換結(jié)果
    CLK = 1;      //發(fā)送一個(gè)時(shí)鐘周期,清除BUSY
    _nop_();
    _nop_();
    CLK = 0;
    _nop_();
    _nop_();
    AD_Value=SPI_Read_AD();
    CS = 1;
    return AD_Value;
//************************************主函數(shù)************************************************************
void main(void)
        uint temp,count=0,phh,phl;
         uchar wendu =0;
    init_NRF24L01();
    Timer0Configuration();
//    nRF24L01_TxPacket(TxBuf);    // Transmit Tx buffer data
    Delay(6000);
//    P0=0xBF;
         if(count==50)
         wendu=Display(Ds18b20ReadTemp());
    count=0;
        temp = Read_AD_Data(0xE4);            //   AIN3 外部輸入
        temp=(float)temp*(-0.0000519)+21;
        phh=temp/10;
        phl=temp%10;
        init_NRF24L01() ;
        Delay(6000);
       count++;
           TxBuf[6] = codess[wendu / 10000];
        TxBuf[5] = codess[wendu % 10000 / 1000];
        TxBuf[4] = codess[wendu % 1000 / 100];
        TxBuf[3] =codess[wendu % 100 / 10];
        TxBuf[2] = codess[wendu % 10];
        TxBuf[0]=codess[phl];
        TxBuf[1]=codess[phh];
       //下面是無線發(fā)射程序
        LED=0;
        Delay(100);      //可變
        SPI_RW_Reg(WRITE_REG+STATUS,0XFF);
         LED=1;
        Delay(80);
修改后效果為
可是數(shù)據(jù)不對(duì),怎么解決啊。。。
效果顯示
效果顯示
