查看: 5250|回復(fù): 0
LPC11xx讀寫AT24C04主模式400KHz程序
ID:73735 發(fā)表于 2015-2-18 23:06 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
IIC.c文件:
*   i2c.c:  I2C C file for NXP LPC11xx Family Microprocessors
*   Copyright(C) 2008, NXP Semiconductor
*   All rights reserved.
*   History
*   2008.07.19  ver 1.00    Preliminary version, first Release
#include "LPC11xx.h"                        /* LPC11xx Peripheral Registers */
#include "type.h"
#include "i2c.h"
#include "Delay.h"
volatile uint32_t I2CMasterState = I2C_IDLE;
volatile uint32_t I2CSlaveState = I2C_IDLE;
volatile uint32_t I2CMode;
volatile uint8_t  I2CMasterBuffer[I2C_BUFSIZE]={0};
volatile uint8_t  I2CSlaveBuffer[I2C_BUFSIZE] ={0};
volatile uint32_t I2CReadLength;
volatile uint32_t I2CWriteLength;
volatile uint32_t RdIndex = 0;
volatile uint32_t WrIndex = 0;
From device to device, the I2C communication protocol may vary,
in the example below, the protocol uses repeated start to read data from or
write to the device:
For master read: the sequence is: STA,Addr(W),offset,RE-STA,Addr(r),data...STO
for master write: the sequence is: STA,Addr(W),offset,RE-STA,Addr(w),data...STO
Thus, in state 8, the address is always WRITE. in state 10, the address could
be READ or WRITE depending on the I2C command.
** Function name:                I2C_IRQHandler
** Descriptions:                I2C interrupt handler, deal with master mode only.
** parameters:                        None
** Returned value:                None
void I2C_IRQHandler(void)
  uint8_t StatValue;
  /* this handler deals with master read and master write only */
  StatValue = LPC_I2C->STAT;
  switch ( StatValue )
/**************** Master write **********************************/
          case 0x08:                        /* A Start condition is issued. */
          WrIndex = 0;
          LPC_I2C->DAT = I2CMasterBuffer[WrIndex++];
          LPC_I2C->CONCLR = (I2CONCLR_SIC | I2CONCLR_STAC);
          I2CMasterState = I2C_STARTED;
          break;
          case 0x10:                        /* A repeated started is issued */
          WrIndex = 0;
          /* Send SLA with R bit set, */
          I2CMasterState = I2C_RESTARTED;
          break;
          case 0x18:                        /* Regardless, it's a ACK */
          if ( I2CMasterState == I2C_STARTED )
            I2CMasterState = DATA_ACK;
          LPC_I2C->CONCLR = I2CONCLR_SIC;
          break;
          case 0x28:        /* Data byte has been transmitted, regardless ACK or NACK */
          case 0x30:
          if ( WrIndex < I2CWriteLength )
            LPC_I2C->DAT = I2CMasterBuffer[WrIndex++]; /* this should be the last one */
            if ( I2CReadLength != 0 )
                    LPC_I2C->CONSET = I2CONSET_STA;                 /* Set Repeated-start flag */
                    I2CMasterState = I2C_REPEATED_START;
                    I2CMasterState = DATA_NACK;
                    LPC_I2C->CONSET = I2CONSET_STO;          /* Set Stop flag */
          break;
/**************** Master read *********************************/
          case 0x40:        /* Master Receive, SLA_R has been sent */
          LPC_I2C->CONSET = I2CONSET_AA;        /* assert ACK after data is received */
          break;
          case 0x50:        /* Data byte has been received, regardless following ACK or NACK */
          I2CSlaveBuffer[RdIndex++] = LPC_I2C->DAT;
          if ( RdIndex < I2CReadLength )
          break;
          case 0x58:
          LPC_I2C->CONCLR = I2CONCLR_SIC;        /* Clear SI flag */
          break;
          case 0x20:                /* regardless, it's a NACK */
          case 0x48:
          break;
          case 0x38:                /* Arbitration lost, in this example, we don't
                                        deal with multiple master situation */
          default:
          break;
  return;
** Function name:                I2CStart
** Descriptions:                Create I2C start condition, a timeout
**                                value is set if the I2C never gets started,
**                                and timed out. It's a fatal error.
** parameters:                        None
** Returned value:                true or false, return false if timed out
uint32_t I2CStart( void )
  uint32_t timeout = 0;
  uint32_t retVal = FALSE;
  /*--- Issue a start condition ---*/
  LPC_I2C->CONSET = I2CONSET_STA;        /* Set Start flag */
  /*--- Wait until START transmitted ---*/
  while( 1 )
            retVal = TRUE;
            break;
          if ( timeout >= MAX_TIMEOUT )
            retVal = FALSE;
            break;
          timeout++;
  return( retVal );
** Function name:                I2CStop
** Descriptions:                Set the I2C stop condition, if the routine
**                                never exit, it's a fatal bus error.
** parameters:                        None
** Returned value:                true or never return
uint32_t I2CStop( void )
  /*--- Wait for STOP detected ---*/
  while( LPC_I2C->CONSET & I2CONSET_STO );
  return TRUE;
** Function name:                I2CInit
** Descriptions:                Initialize I2C controller
** parameters:                        I2c mode is either MASTER or SLAVE
** Returned value:                true or false, return false if the I2C
**                                interrupt handler was not installed correctly
uint32_t I2CInit( uint32_t I2cMode )
  /* It seems to be bit0 is for I2C, different from
  UM. To be retested along with SSP reset. SSP and I2C
  reset are overlapped, a known bug, for now, both SSP
  and I2C use bit 0 for reset enable. Once the problem
  is fixed, change to "#if 1". */
#if 1
  LPC_SYSCON->PRESETCTRL |= (0x1<<1);
#else
  LPC_SYSCON->PRESETCTRL |= (0x1<<0);
#endif
  //LPC_SYSCON->SYSAHBCLKCTRL |= (1<<5);
  LPC_IOCON->PIO0_4 &= ~0x3F;                   /*  I2C I/O config */
  LPC_IOCON->PIO0_4 |= 0x01;                         /* I2C SCL */
  LPC_IOCON->PIO0_5 &= ~0x3F;                   /*  I2C I/O config */
  LPC_IOCON->PIO0_5 |= 0x01;                         /* I2C SDA */
  /*--- Clear flags ---*/
  LPC_I2C->CONCLR = I2CONCLR_AAC | I2CONCLR_SIC | I2CONCLR_STAC | I2CONCLR_I2ENC;
  /*--- Reset registers ---*/
#if FAST_MODE_PLUS
  LPC_IOCON->PIO0_4 |= (0x1<<9);
  LPC_IOCON->PIO0_5 |= (0x1<<9);
  LPC_I2C->SCLL   = I2SCLL_HS_SCLL;
  LPC_I2C->SCLH   = I2SCLH_HS_SCLH;
#else
  LPC_I2C->SCLL   = I2SCLL_SCLL;
  LPC_I2C->SCLH   = I2SCLH_SCLH;
#endif
  if ( I2cMode == I2CSLAVE )
          LPC_I2C->ADR0 = AT24C_ADDR;
  NVIC_EnableIRQ(I2C_IRQn);             /* Enable the I2C Interrupt */
  LPC_I2C->CONSET = I2CONSET_I2EN;      /* Enable I2C */
  return( TRUE );
**I2C_SendOneByte()啟動(dòng)I2C發(fā)送一個(gè)數(shù)據(jù),Addr為從機(jī)地址,Data為將要發(fā)送的數(shù)據(jù)****
uint32_t I2C_SendOneByte(uint8_t Addr, uint8_t Data)
        /* Write SLA(W), address and one data byte */
  I2CWriteLength = 2;
  I2CReadLength  = 0;
  I2CMasterBuffer[0] = Addr;              /* Address Data and Write Bit */
  I2CMasterBuffer[1] = Data;              /* Data 0 */
        do                                      /*發(fā)送起始條件,直到起始條件成功發(fā)送,順利接管總線*/
        while(I2CStart() == FALSE);
        while (1)
          if ( I2CMasterState == DATA_NACK )
            I2CStop();
            break;
  return ( TRUE );
**I2C_SendOneByte()啟動(dòng)I2C發(fā)送多個(gè)數(shù)據(jù),Addr為從機(jī)地址,Num為要發(fā)送的數(shù)據(jù)個(gè)數(shù),pdata為數(shù)據(jù)首字節(jié)地址指針**
uint32_t I2C_SendNumByte(uint8_t Addr, uint8_t Num, uint8_t *pdata)
        uint8_t x=0;
  I2CWriteLength = Num+1;
  I2CReadLength  = 0;
  I2CMasterBuffer[0] = Addr;                        /* Address Data and Write Bit*/
        for(x=0;x<Num;x++)
                I2CMasterBuffer[x+1] = pdata[x];                /* Data */
        while (1)
            I2CStop();
            break;
  return ( TRUE );
****I2C_ReadByte()啟動(dòng)I2C讀取多個(gè)數(shù)據(jù),Addr為從機(jī)地址,Num為要發(fā)送的數(shù)據(jù)個(gè)數(shù)
uint32_t I2C_ReadByte(uint32_t Num)
        I2CWriteLength = 1;
  I2CReadLength  = Num;
        I2CMasterBuffer[0] = AT24C_ADDR|READ_BIT;     /*Address Data and Write Bit*/
        do                                            /*發(fā)送起始條件,直到起始條件成功發(fā)送,接管總線*/
        while ( 1 )
            I2CStop();
            break;
  return ( TRUE );
** 以下為AT24C04驅(qū)動(dòng)程序**
uint32_t AT24C04_ByteWrite(uint8_t Page,uint8_t WordAddr,uint8_t Data)
        /* Write SLA(W), DeviceAddress+Page and one data byte */
  I2CWriteLength = 3;
  I2CReadLength  = 0;
  I2CMasterBuffer[0] = AT24C_ADDR|Page|WRITE_BIT;       /* DeviceAddress Data+Page and Write Bit*/
  I2CMasterBuffer[1] = WordAddr;                        /* Word Address*/
        I2CMasterBuffer[2] = Data;                            /* Data */
        while (1)
            I2CStop();
            break;
  return ( TRUE );
/* the microcontroller can transmit up to seven(1K/2K) or fifteen (4K, 8K, 16K) more data words.*/
uint32_t AT24C04_PageWrite(uint8_t Page,uint8_t WordAddr,uint32_t Num,uint8_t *pdata)
        uint8_t x=0;
        if(Num>16)
                Num=16;
  I2CWriteLength = Num+2;
  I2CReadLength  = 0;
        for(x=0;x<=Num;x++)
                I2CMasterBuffer[x+2] = pdata[x];          /* Data */
        while (1)
            I2CStop();
            break;
  return ( TRUE );
**AT24C04_CurrAdrRead(),參數(shù)Page為0或者1,以選擇所讀取的頁面*******************
**Word Address保持上次讀寫操作所用的Word Address地址,并自增1*****************
uint32_t AT24C04_CurrAdrRead(uint8_t Page)
        I2CWriteLength = 1;
  I2CReadLength  = 1;
        I2CMasterBuffer[0] = AT24C_ADDR|Page|READ_BIT;     /*DeviceAddress Data and Write Bit*/
        while ( 1 )
            I2CStop();
            break;
  return ( TRUE );
**AT24C04_RandomRead(),參數(shù)Page為0或者1,以選擇所讀取的頁面,WordAddr為所選取頁面的字節(jié)地址**
uint32_t AT24C04_RandomRead(uint8_t Page,uint8_t WordAddr)
        /* Write SLA(W), address+Page and one data byte */
  I2CWriteLength = 2;
  I2CReadLength  = 1;
        while(I2CStart() == FALSE);                       /* 接管總線后,發(fā)送DeviceAddress和WoraAddress */
        while (1)
          if ( I2CMasterState == I2C_REPEATED_START )
                        I2CWriteLength = 1;
      I2CMasterBuffer[0] = AT24C_ADDR|Page|READ_BIT;     /* DeviceAddress Data+Page and Write Bit*/
                        while ( 1 )
                I2CStop();
                break;
      return ( TRUE );
**AT24C04_SequRead(),參數(shù)Page為0或者1,以選擇所讀取的頁面,Num為讀出的字節(jié)個(gè)數(shù)***************
uint32_t AT24C04_SequRead(uint8_t Page,uint32_t Num)
        I2CWriteLength = 1;
        while ( 1 )
            I2CStop();
            break;
  return ( TRUE );
**                            End Of File
IIC.h文件:
*   i2c.h:  Header file for NXP LPC Family Microprocessors
*   Copyright(C) 2006, NXP Semiconductor
*   History
*   2006.07.19  ver 1.00    Preliminary version, first Release
#ifndef __I2C_H
#define __I2C_H
/* If I2C SEEPROM is tested, make sure FAST_MODE_PLUS is 0.
For board to board test, this flag can be turned on. */
#define FAST_MODE_PLUS               1
#define I2C_BUFSIZE                               6
#define MAX_TIMEOUT                         0x00FFFFFF
#define I2CMASTER                           0x01
#define I2CSLAVE                           0x02
#define I2C_ADDR                     0x80
#define AT24C_ADDR                   0xA0
#define AT24C_Page0                   0x00
#define AT24C_Page1                   0x02
#define WRITE_BIT                           0x00
#define READ_BIT                                 0x01
#define I2C_IDLE                                 0
#define I2C_STARTED                               1
#define I2C_RESTARTED                       2
#define I2C_REPEATED_START           3
#define DATA_ACK                                 4
#define DATA_NACK                                 5
#define I2CONSET_I2EN                       0x00000040  /* I2C Control Set Register */
#define I2CONSET_AA                               0x00000004
#define I2CONSET_SI                               0x00000008
#define I2CONSET_STO                       0x00000010
#define I2CONSET_STA                       0x00000020
#define I2CONCLR_AAC                       0x00000004  /* I2C Control clear Register */
#define I2CONCLR_SIC                       0x00000008
#define I2CONCLR_STAC                       0x00000020
#define I2CONCLR_I2ENC               0x00000040
#define I2DAT_I2C                                 0x00000000  /* I2C Data Reg */
#define I2ADR_I2C                                 0x00000000  /* I2C Slave Address Reg */
#define I2SCLH_SCLH                               0x00000060  /* I2C SCL Duty Cycle High Reg */
#define I2SCLL_SCLL                               0x00000060  /* I2C SCL Duty Cycle Low Reg */
#define I2SCLH_HS_SCLH                      0x00000015  /* Fast Plus I2C SCL Duty Cycle High Reg */
#define I2SCLL_HS_SCLL                      0x00000015  /* Fast Plus I2C SCL Duty Cycle Low Reg */
void I2C_IRQHandler(void);
uint32_t I2CStart( void );
uint32_t I2CStop( void );
uint32_t I2CInit( uint32_t I2cMode );
uint32_t I2CEngine( void );
uint32_t I2C_SendNumByte(uint8_t Addr, uint8_t Num, uint8_t *pdata);
uint32_t I2C_ReadByte(uint32_t Num);
uint32_t AT24C04_ByteWrite(uint8_t Page,uint8_t WordAddr,uint8_t Data);
uint32_t AT24C04_PageWrite(uint8_t Page,uint8_t WordAddr,uint32_t Num,uint8_t *pdata);
uint32_t AT24C04_CurrAdrRead(uint8_t Page);
uint32_t AT24C04_RandomRead(uint8_t Page,uint8_t WordAddr);
uint32_t AT24C04_SequRead(uint8_t Page,uint32_t Num);
#endif /* end __I2C_H */
**                            End Of File
