是用51hei單片機開發板 電路圖詳見:http://m.raoushi.com/f/51hei-5.pdf 的數碼管部分, 用2個74hc573 鎖存,p0口作為數據口 ,p3.6和p3.7分別是段和位的鎖存端口.P2口上面是按鍵
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- sbit D=P3^6;
- sbit V=P3^7;
- uchar ACT[5]={0xfe,0xfd,0xfb,0xf7,0xef};
- uint data shuzu[10];
- uchar status;
- uchar temp;
- int max,f;
- void delay_1ms(void)
- uint k;
- for(k=0;k<121;k++);
- void dis_max(void)
- D=1;P0=SEG7[max%10];D=0;P0=0xff;V=1;P0=ACT[4];V=0;delay_1ms();
- D=1;P0=SEG7[(max/10)%10];D=0;P0=0xff;V=1;P0=ACT[3];V=0;delay_1ms();
- D=1;P0=SEG7[max/100];D=0;P0=0xff;V=1;P0=ACT[2];V=0;delay_1ms();
- void dis_input(void)
- D=1;P0=SEG7[f%10];D=0;P0=0xff;V=1;P0=ACT[4];V=0;delay_1ms();
- D=1;P0=SEG7[(f/10)%10];D=0;P0=0xff;V=1;P0=ACT[3];V=0;delay_1ms();
- D=1;P0=SEG7[f/100];D=0;P0=0xff;V=1;P0=ACT[2];V=0;delay_1ms();
- D=1;P0=SEG7[status];D=0;P0=0xff;V=1;P0=ACT[0];V=0;delay_1ms();
- void key_s1(void)
- P2=0xff;
- if(P2==0xef)
- {if(temp>30)temp=0;
- if(temp==0)f++;
- if(f>999)f=999;
- temp++;
- delay_1ms();
- void key_s2(void)
- P2=0xff;
- if(P2==0xdf)
- if(temp==0)f--;
- if(f<0)f=0;
- temp++;
- delay_1ms();
- void key_s3(void)
- P2=0xff;
- if(P2==0xbf)
- switch(status)
- case 0:shuzu[0]=f;break;
- case 1:shuzu[1]=f;break;
- case 2:shuzu[2]=f;break;
- case 3:shuzu[3]=f;break;
- case 4:shuzu[4]=f;break;
- case 5:shuzu[5]=f;break;
- case 6:shuzu[6]=f;break;
- case 7:shuzu[7]=f;break;
- case 8:shuzu[8]=f;break;
- case 9:shuzu[9]=f;break;
- default:break;
- void key_s4(void)
- P2=0xff;
- if(P2==0x7f)
- {if(temp>100)temp=0;
- if(temp==0)status++;
- if(status>10)status=0;
- temp++;
- delay_1ms();
- void conv(void)
- uchar i;
- max=shuzu[0];
- for(i=1;i<10;i++)
- if(shuzu[i]>max)max=shuzu[i];
- void main(void)
- while(1)
- key_s1();
- key_s2();
- key_s3();
- key_s4();
- conv();
- if(status==10)dis_max();
- else dis_input();
