查看: 4077|回復: 0
單片機輸入年份和月份該程序計算該月有多少天
ID:72519 發表于 2015-1-21 23:00 | 顯示全部樓層 |閱讀模式
是用51hei單片機開發板 電路圖詳見:http://m.raoushi.com/f/51hei-5.pdf  的數碼管部分, 用2個74hc573 鎖存,p0口作為數據口 ,p3.6和p3.7分別是段和位的鎖存端口.
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  5. uchar ACT[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  6. sbit D=P3^6;
  7. sbit V=P3^7;
  8. sbit P2_4=P2^4;
  9. sbit P2_6=P2^6;
  10. sbit P2_7=P2^7;
  11. //============
  12. uchar status_flag;
  13. uint year;
  14. uchar month;
  15. uchar day;
  16. uchar temp_year_1,temp_month;
  17. uchar temp_year_h;
  18. //==============
  19. void key_S1(void);
  20. void key_S2(void);
  21. void key_S4(void);
  22. void delay(uint k);
  23. uchar conv(uint year,uchar month);
  24. //============
  25. void main(void)
  26. { uchar i;
  27. uint temp1,temp2;
  28. while(1)
  29. { key_S4();
  30. switch(status_flag)
  31. {
  32. case 0:key_S1();temp1=temp_year_1;
  33.     key_S2();temp2=temp_year_h;break;
  34. case 1:key_S1();month=temp_month;break;
  35. default :break;
  36. }
  37. year=temp1+(temp2*100);
  38. //=============
  39. day=conv(year,month);
  40. //===============
  41. for(i=0;i<40;i++)
  42. {
  43. switch(status_flag)
  44. {
  45. case 0:D=1;P0=SEG7[year%10];D=0;P0=0xff;V=1;P0=ACT[7];V=0;delay(5);
  46.     D=1;P0=SEG7[(year%100)/10];D=0;P0=0xff;V=1;P0=ACT[6];V=0;delay(5);
  47.     D=1;P0=SEG7[(year/100)%10];D=0;P0=0xff;V=1;P0=ACT[5];V=0;delay(5);
  48.     D=1;P0=SEG7[year/1000];D=0;P0=0xff;V=1;P0=ACT[4];V=0;delay(5);break;
  49. case 1:D=1;P0=SEG7[month%10];D=0;P0=0xff;V=1;P0=ACT[3];V=0;delay(3);
  50.     D=1;P0=SEG7[month/10];D=0;P0=0xff;V=1;P0=ACT[2];V=0;delay(3);break;
  51. case 2:if(day){D=1;P0=SEG7[day%10];D=0;P0=0xff;V=1;P0=ACT[1];V=0;delay(3);
  52.       D=1;P0=SEG7[day/10];D=0;P0=0xff;V=1;P0=ACT[0];V=0;delay(3);}
  53.    else{D=1;P0=0x00;D=0;P0=0xff;V=1;P0=0xff;V=0;delay(3);
  54.         D=1;P0=0x00;D=0;P0=0xff;V=1;P0=0xff;V=0;delay(3);}break;
  55.    default :break;
  56.    }
  57.    }
  58.    }
  59. }
  60. //==============
  61. void delay(uint k)
  62. {
  63. uint i,j;
  64. for(i=0;i<k;i++){
  65. for(j=0;j<121;j++)
  66. {;}}
  67. }
  68. //==============
  69. void key_S1(void)
  70. {
  71. P2=0xff;
  72. if(!P2_4)
  73. {
  74. switch(status_flag)
  75. {
  76. case 0:temp_year_1++;
  77. if(temp_year_1>99)temp_year_1=0;break;
  78. case 1:temp_month++;
  79. if(temp_month>12)temp_month=1;break;
  80. default :break;
  81.    }
  82. }
  83. }
  84. //===========
  85. void key_S2(void)
  86. {
  87. P2=0xff;
  88. if(!P2_7)
  89. {
  90. switch(status_flag)
  91. {
  92. case 0:temp_year_h++;
  93.   if(temp_year_h>99)temp_year_h=0;break;
  94.   default :break;
  95.     }
  96.   }
  97. }
  98. //===============
  99. void key_S4(void)
  100. {
  101.   P2=0xff;
  102.   if(!P2_6)status_flag++;
  103.   if(status_flag>2)status_flag=0;
  104.   }
  105.   //=====================
  106. uchar conv(uint year,uchar month)
  107. {uchar len;
  108. switch(month)
  109. {
  110. case 1:len=31;break;
  111. case 3:len=31;break;
  112. case 5:len=31;break;
  113. case 7:len=31;break;
  114. case 8:len=31;break;
  115. case 10:len=31;break;
  116. case 12:len=31;break;
  117. case 4:len=30;break;
  118. case 6:len=30;break;
  119. case 9:len=30;break;
  120. case 11:len=30;break;
  121. case 2:if(year%4==0&&year%100!=0||year%400==0)len=29;
  122. else len=28;break;
  123.   default:return 0;break;
  124.   }
  125.   return len;
  126. }
