查看: 4400|回復(fù): 0
單片機輸入數(shù)的大小比較及判斷實驗
ID:72519 發(fā)表于 2015-1-21 22:50 | 顯示全部樓層 |閱讀模式
是用51hei單片機開發(fā)板 電路圖詳見:http://m.raoushi.com/f/51hei-5.pdf   用2個74hc573 鎖存,p0口作為數(shù)據(jù)口 ,p3.6和p3.7分別是段和位的鎖存端口.
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  5. sbit D=P3^6;
  6. sbit V=P3^7;
  7. //===================
  8. uchar a=0,b=0,c;
  9. //===================
  10. uchar key_S1(void);
  11. uchar key_S2(void);
  12. void delay(uint k);
  13. //=====================
  14. void main(void)
  15. {  uchar i;
  16. while(1)
  17. {
  18. b=key_S1();
  19. a=key_S2();
  20. if(a>b)c=0x76;
  21. if(a<b)c=0x38;
  22. if(a==b)c=0x09;
  23. for(i=0;i<50;i++)
  24. {
  25. D=1;
  26. P0=SEG7[a];
  27. D=0;
  28. P0=0xff;
  29. V=1;
  30. P0=0xfe;
  31. V=0;
  32. delay(2);
  33. D=1;
  34. P0=SEG7[b];
  35. D=0;
  36. P0=0xff;
  37. V=1;
  38. P0=0xfd;
  39. V=0;
  40. delay(2);
  41. D=1;
  42. P0=c;
  43. D=0;
  44. P0=0xff;
  45. V=1;
  46. P0=0xfb;
  47. V=0;
  48. delay(2);
  49.       }
  50. }
  51. }
  52. //==============
  53. void delay(uint k)
  54. {
  55. uint i,j;
  56. for(i=0;i<k;i++){
  57. for(j=0;j<121;j++)
  58. {;}}
  59. }
  60. //===================
  61. uchar key_S1(void)
  62. {static uchar x;
  63. P2=0xff;
  64. if(P2!=0xff)
  65. {delay(10);
  66. if(P2==0xdf)
  67. {
  68. x=x+1;
  69.   }
  70.   }
  71. if(x>9)x=0;
  72. return x;
  73. }
  74. //=======================
  75. uchar key_S2(void)
  76. {static uchar y;
  77. P2=0xff;
  78. if(P2!=0xff)
  79. {delay(10);
  80. if(P2==0xbf)
  81. {
  82. y=y+1;
  83.   }
  84.   }
  85. if(y>9)y=0;
  86. return y;
  87. }
