http://m.raoushi.com/ziliao/51hei-5/精準控制步進電機.rar
/*******************51hei************************ 硬件結構框架: 1,MCU STC89C52 2,步進電機驅動芯片ULN2003 顯示效果: 1,電機的方向可改變 ************************************************/ #include"AT89x52.h" #define uint unsigned int #define uchar unsigned char
uchar plus[]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x09,0x00}; //電機正轉 uchar minu[]={0x08,0x0c,0x04,0x06,0x02,0x03,0x01,0x09,0x00}; //電機反轉
sbit key1=P3^1; bit flag; uchar idata *x;
void control(bit cf,uchar n) //電機控制函數,返回變量為方向和步數 { uchar i; if(cf==0)x=plus; //改變電機方向 else x=minu; for(i=0;i<n;i++) //記錄電機的步數 { while(flag==0); flag=0; } }
void init() //初始化,開定時器0 { TMOD=0x01; TCON=0x10; TH0=(65536-5000)/256; TL0=(65536-5000)%256; IE=0x82; }
void timer0() interrupt 1 { static uchar i; if(i++>1) //改變電機的速度 { i=0; flag=1; //設置中斷標志 P1=*x++; //數組地址加1 if(*x==0)x=x-8; //判斷8個控制字后恢復初值 } TH0=(65536-5000)/256; TL0=(65536-5000)%256; }
void main() { init(); while(1) { control(0,200); //電機正轉 control(1,200); //電機反轉 } } |
