只需一步,快速開(kāi)始
查看: 7164|回復(fù): 1
nfs掛載實(shí)驗(yàn)疑問(wèn)記錄
ID:3721 發(fā)表于 2015-1-5 15:21 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
gedit /etc/exports
/home/camel/Mini2440-NFS *(rw,sync,no_root_squash)
/camel/Mini2440-NFS:要共享的目錄
* :允許所有的網(wǎng)段訪問(wèn)
rw :讀寫權(quán)限
sync:資料同步寫入內(nèi)在和硬盤
no_root_squash:nfs客戶端共享目錄使用者權(quán)限
/camel/Mini2440-NFS是我的NFS共享目錄
#sudo /etc/init.d/portmap restart
  顯示錯(cuò)誤:
root@camel-dynabook-SS-1700MY-106S-2:~# sudo /etc/init.d/portmap restart
sudo:/etc/init.d/portmap: command not found
這個(gè)錯(cuò)誤我一直未解,因?yàn)槲乙呀?jīng)執(zhí)行過(guò)portmap的安裝,應(yīng)該不影響下面的工作,就繼續(xù)了。
#sudo /etc/init.d/nfs-kernel-server restart
下面的
* Stopping NFS kernel daemon                                            [ OK ]
* Unexporting directories for NFS kernel daemon...                      [ OK ]
* Exporting directories for NFS kernel daemon...                               exportfs: /etc/exports [1]: Neither 'subtree_check' or 'no_subtree_check' specified for export "*:/home/camel/Mini2440-NFS".
  Assuming default behaviour ('no_subtree_check').
  NOTE: this default has changed since nfs-utils version 1.0.x
        [ OK ]
* Starting NFS kernel daemon                                            [ OK ]
root@camel-dynabook-SS-1700MY-106S-2:~# showmount -e
Export list for camel-dynabook-SS-1700MY-106S-2:
root@camel-dynabook-SS-1700MY-106S-2:~# ifconfig
eth0      Link encap:以太網(wǎng)  硬件地址 00:1c:7e:91:c7:aa
          inet6 地址: fe80::21c:7eff:fe91:c7aa/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  躍點(diǎn)數(shù):1
          接收數(shù)據(jù)包:0 錯(cuò)誤:0 丟棄:0 過(guò)載:0 幀數(shù):0
          發(fā)送數(shù)據(jù)包:224 錯(cuò)誤:0 丟棄:0 過(guò)載:0 載波:0
          碰撞:0 發(fā)送隊(duì)列長(zhǎng)度:1000
          接收字節(jié):0 (0.0 B)  發(fā)送字節(jié):44906 (44.9 KB)
lo        Link encap:本地環(huán)回
          inet 地址:127.0.0.1  掩碼:255.0.0.0
          inet6 地址: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  躍點(diǎn)數(shù):1
          接收數(shù)據(jù)包:2054 錯(cuò)誤:0 丟棄:0 過(guò)載:0 幀數(shù):0
          發(fā)送數(shù)據(jù)包:2054 錯(cuò)誤:0 丟棄:0 過(guò)載:0 載波:0
          碰撞:0 發(fā)送隊(duì)列長(zhǎng)度:0
          接收字節(jié):293895 (293.8 KB)  發(fā)送字節(jié):293895 (293.8 KB)
wlan0     Link encap:以太網(wǎng)  硬件地址 00:1b:9e:fb:6b:a7
          inet 地址:192.168.1.116  廣播:192.168.1.255  掩碼:255.255.255.0
          inet6 地址: fe80::21b:9eff:fefb:6ba7/64 Scope:Link
          接收數(shù)據(jù)包:740936 錯(cuò)誤:0 丟棄:0 過(guò)載:0 幀數(shù):0
          發(fā)送數(shù)據(jù)包:442245 錯(cuò)誤:0 丟棄:0 過(guò)載:0 載波:0
          接收字節(jié):1094026905 (1.0 GB)  發(fā)送字節(jié):36368663 (36.3 MB)
據(jù)上我的本機(jī)ip地址是
192.168.1.116
root@camel-dynabook-SS-1700MY-106S-2:~# mount -t nfs -o nolock 192.168.1.116:/home/camel/Mini2440-NFS /mnt
綜上我的本機(jī)ip地址填寫有誤,陪對(duì)象聊天,今天到此,收獲頗豐。成功在window下連接手機(jī)進(jìn)行了安卓程序的調(diào)試,linux下沒(méi)有成功,還在研究。NFS發(fā)現(xiàn)錯(cuò)誤,如果正確操作后還是沒(méi)有成功,將會(huì)發(fā)表論壇求助。
mini2440寫入?yún)?shù)修正
console=ttySAC0
root=/dev/nfs
nfsroot=192.168.1.116:/home/camel/Mini2440-NFS
ip=192.168.1.70:192.168.1.111:192.168.1.111:255.255.255.0:sbc2440.arm9.net:eth0:off
其各參數(shù)的含義如下:
nfsroot 是自己開(kāi)發(fā)主機(jī)的 IP 地址。
“ip=”后面:
第一項(xiàng)(192.168.1.70)是目標(biāo)板的臨時(shí) IP(注意不要和局域網(wǎng)內(nèi)其他 IP 沖突);
第二項(xiàng)(192.168.1.111)是開(kāi)發(fā)主機(jī)的 IP;
第三項(xiàng)(192.168.1.111)是目標(biāo)板上網(wǎng)關(guān)(GW)的設(shè)置;
第四項(xiàng)(255.255.255.0)是子網(wǎng)掩碼;
第五項(xiàng)是開(kāi)發(fā)主機(jī)的名字(一般無(wú)關(guān)緊要,可隨便填寫)
eth0 是網(wǎng)卡設(shè)備的名稱。
ID:3721 發(fā)表于 2015-1-5 15:23 | 只看該作者
1,portmap配置失敗原因答案
Ubuntu上默認(rèn)是沒(méi)有安裝NFS服務(wù)器的,首先要安裝NFS服務(wù)程序:
$ sudo apt-get installnfs-kernel-server
(安裝nfs-kernel-server時(shí),apt會(huì)自動(dòng)安裝nfs-common rpcbind(注意,選取這里是 rpcbind 而非portmap))這樣,宿主機(jī)就相當(dāng)于NFSServer
(1)配置/etc/hosts.deny(禁止任何host(主機(jī))能和你的NFS服務(wù)器進(jìn)行NFS連接),加入:
### NFS DAEMONS
rpcbind:ALL
lockd:ALL
mountd:ALL
rquotad:ALL
statd:ALL
(2)配 置/etc/hosts.allow
允許那些你想要的主機(jī)和你的NFS服務(wù)器建立連接。下列步驟將允許任何IP地址以192.168.0開(kāi)頭的主機(jī)(連接到NFS服務(wù)器上),也可以指定特定的IP地址。加入:
### NFS DAEMON
S
rpcbind: 192.168.0.
lockd: 192.168.0.
rquotad: 192.168.0.
mountd: 192.168.0.
statd: 192.168.0.
(3) 配置/etc/exports
NFS掛載目錄及權(quán)限由/etc/exports文件定義
比如我要將將我的usr目錄中的/usr/local目錄讓192.168.0.*IP共享,則在該文件末尾添加下列語(yǔ)句:
/usr/local192.168.0.*(rw,sync,no_root_squash)
或者: /usr/local192.168.197.0/24(rw,sync,no_root_squash)
192.168.0.*
網(wǎng)段內(nèi)的NFS客戶端能夠共享NFS服務(wù)器/usr/local目錄內(nèi)容.且有讀,寫權(quán)限,并且該用戶進(jìn)入/usr/local目錄后的身份為root,最好加上sync, 否則 $ sudo exportfs-r 時(shí)會(huì)給出警告,syncNFS的默認(rèn)選項(xiàng).
運(yùn)行$ showmount-e 查看NFSserverexportlist.
若更改了/etc/exports, 運(yùn)行 $ sudo exportfs-r 更新
運(yùn)行 $ sudo/etc/init.d/nfs-kernel-server restart 重啟nfs服務(wù))
后續(xù)實(shí)驗(yàn)記錄:
root@camel-dynabook-SS-1700MY-106S-2:~# cd /mnt
root@camel-dynabook-SS-1700MY-106S-2:/mnt# ls
bin  etc   lib      mnt  proc  sbin   sys  usr  www
dev  home  linuxrc  opt  root  share  tmp  var
mini2440寫入?yún)?shù):
console=ttySAC0
root=/dev/nfs
nand啟動(dòng)mini2440串口輸出:
IP-Config: Complete:
     device=eth0, addr=192.168.1.70, mask=255.255.255.0, gw=192.168.1.111,
     host=sbc2440, domain=, nis-domain=arm9.net,
     bootserver=192.168.1.111, rootserver=192.168.1.116, rootpath=
Looking up port of RPC 100003/2 on 192.168.1.116
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
rpcbind: server 192.168.1.116 not responding, timed out
Root-NFS: Unable to get nfsd port number from server, using default
Looking up port of RPC 100005/1 on 192.168.1.116
Root-NFS: Unable to get mountd port number from server, using default
Root-NFS: Server returned error -5 while mounting /home/camel/Mini2440-NFS
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "nfs" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00             256 mtdblock0one_wire_status: 4
(driver?)
1f01             128 mtdblock1 (driver?)
1f02            5120 mtdblock2 (driver?)
1f03          256640 mtdblock3 (driver?)
1f04          262144 mtdblock4 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
one_wire_status: 4
Backtrace:
[<c00341cc>] (dump_backtrace+0x0/0x10c) from [<c0329f3c>] (dump_stack+0x18/0x1c)
r7:c03dba08 r6:00008000 r5:c3923000 r4:c0481c90
[<c0329f24>] (dump_stack+0x0/0x1c) from [<c0329f8c>] (panic+0x4c/0x114)
one_wire_status: 4
[<c0329f40>] (panic+0x0/0x114) from [<c0008dbc>] (mount_block_root+0x174/0x228)
r3:c38583ec r2:00000000 r1:c3823f60 r0:c03db9a0
[<c0008c48>] (mount_block_root+0x0/0x228) from [<c0008f34>] (mount_root+0xc4/0xfc)
[<c0008e70>] (mount_root+0x0/0xfc) from [<c0009094>] (prepare_namespace+0x128/0x180)
r5:c002081d r4:c0481660
[<c0008f6c>] (prepare_namespace+0x0/0x180) from [<c00084b0>] (kernel_init+0xe0/0x114)
r5:c001f2e4 r4:c0481420
[<c00083d0>] (kernel_init+0x0/0x114) from [<c004bbbc>] (do_exit+0x0/0x620)
r5:00000000 r4:00000000
one_wire_status: 4
還有錯(cuò)誤,革命尚未成功,同志仍需努力。
