查看: 4131|回復: 1
基于Atmega16L的簡單音樂制作
ID:71259 發(fā)表于 2014-12-29 01:40 | 顯示全部樓層 |閱讀模式
很久沒有寫過東西了,人懶了。
一直想要搞下AVR,因為是電氣而不是電子專業(yè)的,整天對著電機啊,交流調(diào)速啊,復雜的計算公式,所以學習電子類的東西比較麻煩,最近才有大塊的時間來學習AVR,馬潮的《AVR單片機嵌入式系統(tǒng)原理與應用實踐》不錯。
想想也算搞過一些程序了,空間里也沒有貼過AVR的程序,就算來個突破下
做了一小段的《卡農(nóng)》高潮部分。聽著感覺不錯,呵呵,以前用51的匯編寫過《歡樂女神》,聽上去不跑調(diào),但是用C51來做,誤差實在是太大了,根本沒辦法聽,這次用mega16,外掛8M的晶振,做的是一小段的《卡農(nóng)》,因為高音的頻率太高,蜂鳴器完全受不了,直接破音(哎,什么叫能力有限),所以都降低了7度,即高音變成中音,中音變成低音。聽上去還可以,但是難免有些音會走不準。
不廢話貼下程序(注解為英文,希望不會寫錯
// by Witnessiz
// chip : Atmega16L
// frequency : 8,000,000Hz
// function : play music
// output : OC1A(PB5) connect buzzer
#include<avr/io.h>
#include<avr/interrupt.h>
const uint note[] = {0,1908,1700,1516,1433,1276,1136,1012,956,865,759,716,638,568,506,470};
const uint beat[] = {0,419,470,528,558,627,704,790,837,925,1054,1117,1254,1408,1581,1702};
//const uchar score[] = {4,8,10,4,9,12,10,8,11,4,6,4,8,12,5,4,6,4,7,8,9,4,5,12,8,12}; //《好久不見》一小段
const uchar score[]={12,4,10,2,11,2,12,4,10,2,11,2,10,2,5,2,6,2,7,2,8,2,9,2,10,2,11,2,10,4,8,2,
      9,2,10,4,3,2,4,2,5,2,6,2,5,2,4,2,5,2,8,2,7,2,8,2,6,4,8,2,7,2,6,4,5,2,4,
      2,5,2,4,2,3,2,4,2,5,2,6,2,7,2,8,2,6,4,8,2,7,2,8,4,7,2,6,2,7,2,8,2,9,2,
      8,2,7,2,8,2,6,2,7,2}; //《canon》
volatile uint note_num,beat_num;
int main()
// DDRD |= (1 << PD5);
DDRD = 0x20;
PORTD = 0x20;
TCCR1A |= (1 << COM1A0); // toggle OC1A on compare match [0x40]
TCCR1B |= (1 << WGM12);  //Clear Timer on Compare match (CTC) mode [0x80]
TIMSK |= (1 << OCIE1A);  //Output Compare match Intrrupt Enable [0x10]
beat_num = 1;
TCCR1B = 0x09;
sei();
SIGNAL(SIG_OUTPUT_COMPARE1A)
if(-- beat_num == 0)
  TCCR1B = 0x08; //TCCR1B |= (1 << WGM12); no clock sourse,stop CTC [0x08]
  if(note_num < 112)
   OCR1A = note[score[note_num]];
   beat_num = beat[score[note_num]];
   note_num ++;
   beat_num = beat_num * score[note_num];
   note_num ++;
   TCCR1B = 0x09; //TCCR1B |= (1 << WGM12) | (1 << CS10); clkio/1(no prescale),start CTC [0x09]
   note_num = 0;
   beat_num = 1;
   TCCR1B = 0x08;
后記:果然懶,才寫了10分鐘。
ID:72577 發(fā)表于 2015-4-26 15:24 | 顯示全部樓層
樓主的歌曲怎么弄的
