查看: 4198|回復: 0
單片機定時器0方式3編程實驗程序
ID:70976 發表于 2014-12-24 16:40 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#define uint  unsigned int
sbit SPK=P1^5;
unsigned char frq;
void DelayUs2x(unsigned char t);
void DelayMs(unsigned char t);
sbit led1=P1^0;
sbit led2=P1^1;
uint num1,num2;
unsigned int i;
TMOD=0x03;
TH0=6;
TL0=6;
EA=1;
ET0=1;
ET1=1;
TR0=1;
TR1=1;
if(num1>=3686)
num1=0;
led1=~led1;
if(num2>=1843)
num2=0;
led2=~led2;
for(i=0;i<200;i++)
      DelayUs2x(120);
   SPK=!SPK;
   SPK=0;
   for(i=0;i<120;i++)
      DelayMs(1);
void TL0_time()interrupt 1
  TL0=6;
  num1++;
void THO_time()interrupt 3
TH0=6;
num2++;
while(--t);
while(t--)
     DelayUs2x(245);
  DelayUs2x(245);
相關帖子
