查看: 22373|回復: 0
VHDL之加法器系列(四位 八位 半加器 全加器)
ID:51269 發表于 2014-11-10 15:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
一、半加器
Library ieee;
Use ieee.std_logic_1164.all;
Entity halfadd is
Port(a,b:in std_logic;
     S,c:out std_logic);
end halfadd;
Architecture add of halfadd is
begin
S<=a xor b;
c<=a and b;
end;
二、全加器
Library ieee;
Entity fulladd is
Port(a,b,cin:in std_logic;
     S,c:out std_logic);
end fulladd;
Architecture add of fulladd is
signal m,n,k:std_logic;
component halfadd is
     S,c:out std_logic);
end component;
begin
U0:halfadd port map(a,b,m,n);
U1:halfadd port map(m,cin,S,k);
c<=n or k;
end;
三、四位加法器
一)元件化全加器實現
Library ieee;
Entity adder4 is
Port(a,b:in std_logic_vector(3 downto 0);
      cin:in std_logic;
      S:out std_logic_vector(3 downto 0);
      co:out std_logic);
end adder4;
Architecture add of adder4 is
signal c:std_logic_vector(3 downto 0);
component fulladd is
     S,c:out std_logic);
end component;
begin
U0:fulladd port map(a(0),b(0),cin,S(0),c(0));
U1:fulladd port map(a(1),b(1),c(0),S(1),c(1));
U2:fulladd port map(a(2),b(2),c(1),S(2),c(2));
U3:fulladd port map(a(3),b(3),c(2),S(3),co);
end;
二)循環語句實現
Library ieee;
Entity adder4 is
      cin:in std_logic;
      co:out std_logic);
end adder4;
begin
Process(a,b,cin)
variable c:std_logic_vector(4 downto 0);
begin
c(0):=cin;
for i in 0 to 3 loop
  s(i)<=a(i) xor b(i) xor c(i);
  c(i+1):=((a(i) xor b(i))and c(i))or (a(i) and b(i));
end loop;
co<=c(4);
end process;
end;
三)子程序實現
Library ieee;
Entity adder4 is
      cin:in std_logic;
      co:out std_logic);
end adder4;
Procedure sam(ai,bi,ci:in std_logic;
               so,co: out std_logic) is
   begin
   so:=ai xor bi xor ci;
   co:=((ai xor bi)and ci)or(ai and bi);
   end sam;
begin
Process(a,b,cin)
variable sum:std_logic_vector(3 downto 0);
begin
c(0):=cin;
  sam(a(i),b(i),c(i),Sum(i),c(i+1));
end loop;
co<=c(4);
S<=sum;
end process;
end;
-------n-1位加法器,修改n的值,可以改變運算位數--------
Library ieee;
entity adder_n is
generic(n:integer:=4);----改變w的值可以改變運算寬度
port(a,b:in std_logic_vector(n-1 downto 0);
     cin:in std_logic;
     Sum:out std_logic_vector(n-1 downto 0);
     co:out std_logic);
end;
Architecture add of adder_n is
  ---------------以下子程序---------------------
procedure fulladder(ai,bi,ci:in std_logic;
                     s,cc:out std_logic)is
       begin
        s:=ai xor bi xor ci;
        cc:=((ai xor bi)and ci)or(ai and bi);
  end fulladder;
begin
  process(a,b,cin)
   ---loop循環語句必須在process中使用,切子程序要求使用變量,所以在此不使用信號------
   variable ss:std_logic_vector(n-1 downto 0);
   variable c:std_logic_vector(n downto 0);
   begin
  c(0):=cin;
  for i in 0 to n-1 loop
    fulladder(a(i),b(i),c(i),ss(i),c(i+1));
    end loop;
    co<=c(n);
    sum<=ss;
   end process;
  end;
四、八位二進制數相加
一)元件化實現
Library ieee;
Entity adder8 is
Port(a,b:in std_logic_vector(7 downto 0);
      cin:in std_logic;
      S:out std_logic_vector(7 downto 0);
      co:out std_logic);
end adder8;
Architecture add of adder8 is
signal a1,a2,b1,b2,s1,s2:std_logic_vector(3 downto 0);
signal cc:std_logic;
component adder4 is
     cin:in std_logic;
     co:out std_logic);
end component;
begin
a1<=a(3 downto 0);a2<=a(7 downto 4);
b1<=b(3 downto 0);b2<=b(7 downto 4);
U0:adder4 port map(a1,b1,cin,S1,cc);
U1:adder4 port map(a2,b2,cc,S2,co);
S(7 downto 4)<=S2;S(3 downto 0)<=S1;
end;
二)循環語句實現
Library ieee;
Entity adder4 is
      cin:in std_logic;
      co:out std_logic);
end adder4;
variable c:std_logic_vector(8 downto 0);
begin
Process(a,b,cin)
begin
c(0)<=cin;
for i in 0 to 7 loop
  c(i+1)<=((a(i) xor b(i))and c(i))or (a(i) and b(i));
end loop;
co<=c(8);
end process;
end;
三)子程序實現
Library ieee;
Entity adder8 is
      cin:in std_logic;
      co:out std_logic);
end adder8;
   begin
   end sam;
begin
Process(a,b,cin)
variable sum:std_logic_vector(7 downto 0);
begin
c(0):=cin;
end loop;
co<=c(8);
S<=sum;
end process;
end;
減法器接下篇:http://m.raoushi.com/bbs/dpj-28501-1.html
