查看: 3826|回復: 0
數碼管的驅動
ID:65608 發表于 2014-9-1 23:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<pic.h>               //包含單片機內部資源預定義
#include "DelayMs.h"
__CONFIG(0x3B31);
//定義常數0-9的數據表格
const unsigned char TABLE[] = {0x3f,0x6,0x5b,0x4f,0x66,0x6d,0x7c,0x7,0x7f,0x6f};
void Display(unsigned char num,unsigned char data)
PORTD = TABLE[data]; //取出數據,送D口顯示
PORTC = 0x01;
switch(num)
  case 0:
   PORTA = 0x01;
   break;
  case 1:
   PORTA = 0x02;
   break;
  case 2:
   PORTA = 0x04;
   break;
  case 3:
   PORTA = 0x06;
   break;
  case 4:
   PORTA = 0x08;
   break;
  case 5:
   PORTA = 0x0A;
   break;
  case 6:
   PORTA = 0x0C;
   break;
  case 7:
   PORTA = 0x0E;
   break;
  default:
   PORTA = 0x00;
DelayMs(1);
/*void main()
unsigned char i;
TRISD = 0;     //portd 輸出
   TRISA = 0;     //porta 輸出
TRISC = 0;     //porta 輸出
PORTC = 0x01;     //74HC138控制端口
while (1)         //死循環,讓數碼管持續點亮
  for(i=0;i<8;i++)
   Display(i,i+1);
   DelayMs(3);
