查看: 13310|回復: 0
DSP仿真器驅(qū)動安裝錯誤導致的報錯及處理
ID:51088 發(fā)表于 2014-8-20 03:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
使用的合眾達510仿真器,安裝完仿真器驅(qū)動后可以用驅(qū)動安裝包帶的usb20emurst.exe來復位仿真器,但是進行CCS3.3后connect開發(fā)板會報下面的錯誤。
Error connecting to the target:
Error 0x80000240/-172
Fatal Error during: Initialization, OCS,
This error was generated by TI's USCIF driver.
SC_ERR_REG_DETECT_SPRT <-172>
The wrong support-logic address value has been used.
A controller cannot be detected even though the
selected port does match the hardware configuration.
The standard 560 ports are 0x0, 0x1, 0x2 and 0x3.
The standard EVM ports are 0x0, 0x1, 0x2 and 0x3.
The standard DSK ports are 0x378, 0x278 and 0x3BC.
The standard 510 ports are 0x240, 0x280, 0x320 and 0x340.
I/O Port = 240
Board Name: C64xx SEEDXDS510USB  Emulator
Cpu Name: TMS320C6400_0
Abort:            Close Code Composer Studio.
Retry:             Try to connect to the target again.
Cancel:           Remain disconnected from the target
Diagnostic:     Run diagnostic utility.
選擇“retry”出下面報錯信息
Error 0x80002240/-121
Fatal Error during: Initialization, OCS, Control,
SC_ERR_CMD_HANDLE <-121>
A bad controller handle has been given to a function,
either before attempting to open the controller, or after
having opened the controller and ignored its error status.
Valid controller handles are generated when attempts
to open the controller return a clean error status.
I/O Port = 240
出現(xiàn)這種情況一般是仿真器驅(qū)動沒有裝好,可以查看“..CCStudio_v3.3\cc\bin”路徑下的“xdsfast3.dll”文件,如果這個文件是160K大小那么驅(qū)動就是沒有裝好的。如果出現(xiàn)這樣的問題,即使重裝驅(qū)動往往也不能成功。需要刪除該“xdsfast3.dll”文件,然后斷開PC和仿真器,重新裝仿真器驅(qū)動。安裝后查看“xdsfast3.dll”文件大小為352K即表示驅(qū)動安裝成功。
