查看: 5968|回復: 0
ALTERA DDR2內核編譯遇到的問題
ID:51088 發表于 2014-8-20 02:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
        最近做一個FPGA的小項目,用到NIOS2軟核和DDR2內核。昨天編譯DDR2內核的時候遇到一個錯誤:
  Error: The DDIO_OUT WYSIWYG primitive "nios_osd_v20:inst|altmemddr:the_altmemddr|altmemddr_controller_phy:altmemddr_controller_phy_inst|altmemddr_phy:altmemddr_phy_inst|altmemddr_phy_alt_mem_phy:altmemddr_phy_alt_mem_phy_inst|altmemddr_phy_alt_mem_phy_clk_reset:clk|altddio_bidir:DDR_CLK_OUT[0].ddr_clk_out_p|ddio_bidir_e4h:auto_generated|ddio_outa[0]" feeding the pin "DDR_CK[0]" has multiple fan-outs
  昨晚找了一晚,一直查不出原因。剛剛在國外的一個網站上終于找到了答案:)有幾個人跟我遇到同樣的問題,最后原因很簡單。
  “The error was not a bug in Quartus II 7.2 beta, but an error in my own design.... I had not noticed that the sdram_clk and the sdram_clk_n are both bidirectional. When this error is fixed the design compiles. I have not tested the design on my board yet, but hopefully everything works....
Regards
Tom”
  開始大家都懷疑是版本的問題,后來一位兄弟找到了原因。DDR2內核的mem_clk和mem_clk_n都是雙向的,而我在配置的時候把它們都設成輸出了。在這里把它共享出來,希望以后遇到這個問題的朋友可以看到。
