只需一步,快速開(kāi)始
查看: 8583|回復(fù): 1
msp430單片機(jī)adc+12864液晶顯示菜單程序
ID:60266 發(fā)表于 2014-8-18 21:35 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
#include "msp430g2553.h"
typedef unsigned char u8;                              //數(shù)據(jù)類型定義
typedef unsigned int  u16;
typedef unsigned long u32;
float   T_diff1 = 0 ;                                  //定義積分環(huán)節(jié)參數(shù)
float   T_diff2[10] ;                                  //定義微分環(huán)節(jié)參數(shù)
float   T_diff3 = 0;
#define SID_1 P1OUT  |=BIT0                            //串行數(shù)據(jù)傳輸P1.0
#define SID_0 P1OUT  &=~BIT0
#define SID_IN_1 P1IN
#define CLK_1 P1OUT  |=BIT3                            //串行時(shí)鐘P1.2
#define CLK_0 P1OUT  &=~BIT3
#define KM_S         (P2IN&BIT4)                       //主菜單鍵   P2.4
#define KM_SSDOWN    (P2IN&BIT5)                       //功能下選鍵 P2.5
#define KM_SSUP      (P2IN&BIT3)                       //功能上選鍵 P2.3
#define KM_SURE      (P2IN&BIT2)                       //確認(rèn)鍵     P2.2
#define KM_RETURN    (P2IN&BIT0)                       //返回鍵     P2.0
#define SCLK_UP    P2OUT |= BIT0
#define SCLK_DOWN  P2OUT &= ~BIT0
#define SYNC_UP    P1OUT |= BIT4
#define SYNC_DOWN  P1OUT &= ~BIT4
#define SDIN_UP    P1OUT |= BIT5
#define SDIN_DOWN  P1OUT &= ~BIT5
u8   M_S   ;                                           //全局變量M_S功能選擇函數(shù)入口
u8   MM_S   ;                                          //功能選定結(jié)果
u16  ADC_Result;                                       //AD轉(zhuǎn)換的結(jié)果
u8   Number[10] ={"0123456789"};
u32  time1 = 0,time2 = 0;                              //計(jì)時(shí)變量
float  T_real = 0;                                     //當(dāng)前值
float  T_target = 0;                                   //目標(biāo)值
float  T_diff = 0;                                     //誤差
float f;
float T ;
float c;
float last = 0;
u8 DA_ON[4]={0,0,0,1};
u8 time11 = 0;
u8 flag =0;
u8 CHANGE = 0;                          //子菜單功能切換變量
u8   M_S1;                              //全局變量子菜單入口
u8   MM_S1;                             //子菜單功能選擇結(jié)果
u8   MM_S2;                              //子菜單2功能選擇結(jié)果
u16  ADC_RESULT1;                       //ADC轉(zhuǎn)換結(jié)果
u8   GO = 0;
u8   GO1 = 0;
u8   FANHUI;                            //記錄上級(jí)菜單最后選定結(jié)果
u8   FANHUI1;                           //記錄二級(jí)菜單中最后選定結(jié)果
u8   FANHUI2;                           //溫度二級(jí)菜單中的最后選定結(jié)果
float  TEMPE ;                          //溫度變量
u16 _ADC;
signed int  TARGET;                     //目標(biāo)溫度
float TEMPE1;                           //溫度轉(zhuǎn)換變量
u8 HOW_A;                               //程控增益基礎(chǔ)篇增益選擇變量
u8 HOW_A1;                              //程控增益提高篇增益選擇變量
void delay(u16 t);                      //延時(shí)函數(shù)
void Send_Byte(u8 data);                //串行發(fā)送8位數(shù)據(jù)
void Write_CMD(u8 CMD);                 //寫(xiě)命令函數(shù)
void Write_DATA(u8 DATA);               //寫(xiě)數(shù)據(jù)函數(shù)
void LCD12864_Init(void);               //LCD初始化函數(shù)
void print_string(u8 *s);               //顯示字符串函數(shù)
void Init_port(void) ;                  //msp430管腳初始化函數(shù)
void LCD_write_char(u8 X,u8 Y,u8 data); //在屏幕任意位置寫(xiě)字符函數(shù)
void Menu_LCDshow(u8 HOW);              //LCD12864顯示菜單函數(shù)
void Menu_Init(void);                   //菜單初始化函數(shù)
void ADC_Init(void);                    //ADC初始化函數(shù)
void ADC_Run(void);                     //ADC運(yùn)行函數(shù)
void LCD_set_xy( u8 x, u8 y );          //設(shè)置LCD12864上顯示的位置
void Time_Init(void);                   //LCD12864上顯示時(shí)鐘函數(shù)
void RES_show(void);
void Time_change(void);
void Miaobiao(void);
void Daojishi(void);
void Time_choose(u8 HOW);
u16  ADC_LVBO(void);
void game_play(void);
void delay_(u32 time);
u16  PID_Run(float Target);              //PID運(yùn)算函數(shù)
void Temper_run(void);                  //溫度操控
void Tempe_show(u8 HOW);                //顯示溫度
void Tempe_relook(void);                //查看當(dāng)前溫度
void Tempe_change(void);                //溫度調(diào)整函數(shù)
void Tempe_PID(void);                   //溫度PID
void write_da7811(u16 data);              //模擬SPI串行發(fā)送數(shù)據(jù)
*函數(shù)名稱:void write_da7811(u16 da)
*函數(shù)功能:實(shí)現(xiàn)普通I/O模擬SPI通信
*輸入?yún)?shù):void
*返回值:u16 data
      char i;
      SYNC_DOWN;
      for(i=0;i<4;i++)
            SCLK_UP;
            if(DA_ON[i])
               SDIN_UP;
               SDIN_DOWN;
             SCLK_DOWN;
      for (i=0;i<12;i++)
        SCLK_UP;
        if(data&0x800)
           SDIN_UP;
           SDIN_DOWN;
        SCLK_DOWN;
         data<<=1;
      SDIN_UP;
      SYNC_UP;
      SCLK_DOWN;
*函數(shù)名稱:void Zeng_yi(void)
*函數(shù)功能:輸出相應(yīng)的增益
*輸入?yún)?shù):void
*返回值:  void
void Zeng_yi(void)
          signed long i,j,i_1,j_1,b = 0,c=0;
          u16 Control_Val[3] = {0} ;                            //存儲(chǔ)數(shù)據(jù)的地址
          u16  a = 0;
          u16 SHUZI=0 ,SHUZI_1=0 ;
          ADC10CTL1|= CONSEQ_3 + INCH_2 + INCH_0 + INCH_1;     //序列通道多次轉(zhuǎn)換+最大通道為A2
          ADC10CTL0|= ADC10SHT_2 + MSC + ADC10ON + SREF_0 ;
          ADC10DTC1|= 0x08;                                    //一共采樣8次
          ADC10AE0 |= BIT1 + BIT2;                             //打開(kāi)A1和A2的模擬輸入通道
          Write_CMD(0x01);                                     //清屏
          P1DIR |= BIT4 + BIT5;                                //讓P1.4和P1.5工作在輸出狀態(tài)
          Write_CMD(0x80);                                     //第一行顯示
          print_string("當(dāng)前增益:");                          //選擇倒計(jì)時(shí)功能
          i = HOW_A/10;
          LCD_write_char(5,0,Number[i]);
          LCD_write_char(6,0,'.');
          i = HOW_A%10;
          LCD_write_char(7,0,Number[i]);
          Write_CMD(0x90);                //第一行顯示
          print_string("Vin:");       //選擇倒計(jì)時(shí)功能
          Write_CMD(0x88);                //第一行顯示
          print_string("Vout:");       //選擇倒計(jì)時(shí)功能
          Write_CMD(0x98);                //第一行顯示
          print_string("返回");           //選擇倒計(jì)時(shí)功能
          Write_CMD(0x9c);                //第一行顯示
          print_string("單位:V");         //選擇倒計(jì)時(shí)功能
    while(M_S ==12)
         do{
                SHUZI=0 ;
                SHUZI_1=0 ;
                ADC10CTL0 &= ~ENC;                      //關(guān)閉采樣使能
                while(ADC10CTL1 & BUSY);
                ADC10CTL0 |= ENC + ADC10SC;             //Enable conversion,Start conversion
                ADC10SA = (unsigned int)Control_Val;
                SHUZI   =  Control_Val[2] ;
                SHUZI_1 =  Control_Val[1] ;
                b = b + SHUZI;
                c = c + SHUZI_1;
              if(a==400)
                  b = b/400;
                  i = (b*35)/10*2-50 ;
                  j = i/1000;
                  LCD_write_char(3,1,Number[j]);
                  LCD_write_char(4,1,'.');
                  j = i/100%10;
                  LCD_write_char(5,1,Number[j]);
                  j = i/10%10;
                  LCD_write_char(6,1,Number[j]);
                    if(i*50<=21000)
                       HOW_A = 50;
                    else if(i*20<=21000)
                       HOW_A = 20;
                   else if(i*5<=21000)
                      HOW_A = 5;
                   else if(i*2<=21000)
                        HOW_A = 2;
                 c = c/400;
                 if((HOW_A==50)||(HOW_A==20))
                    i_1 = (c*35)/10 ;
                 else if(HOW_A==5)
                    i_1 = ((c*35)/10)*100/88 -280;
                 else if(HOW_A==2)
                    i_1 = ((c*35)/10)*100/85-210;
                 if(i_1>2000)
                    i_1=2000;
                 j_1 = i_1/1000;
                 LCD_write_char(3,2,Number[j_1]);
                 LCD_write_char(4,2,'.');
                 j_1 = i_1/100%10;
                 LCD_write_char(5,2,Number[j_1]);
                 j_1 = i_1/10%10;
                 LCD_write_char(6,2,Number[j_1]);
                  a=0;
                  b=0;
                  a++;
                 i = HOW_A/10;
                 i = HOW_A%10;
               switch(HOW_A)
                   case 2:
                           P1OUT &= ~BIT4 ;
                           P1OUT &= ~BIT5;
                           break;
                   case 5:
                           P1OUT &= ~BIT4 ;
                           P1OUT |=  BIT5;
                           break;
                   case 20:
                           P1OUT |=  BIT4 ;
                           P1OUT &= ~BIT5;
                           break;
                   case 50:
                           P1OUT |=  BIT4 ;
                           P1OUT |=  BIT5;
                           break;
            }while(KM_RETURN&&KM_S);
            if(!KM_RETURN)
                     while(!KM_RETURN);
                     P1DIR &= ~BIT5  ;          //讓P1.4和P1.5工作在輸出狀態(tài)
                     P1DIR &= ~BIT4  ;          //讓P1.4和P1.5工作在輸出狀態(tài)
                     M_S = 5;
                else if(!KM_S)
                     while(!KM_S);
                     M_S = 0;
*函數(shù)名稱:void PID_PWM(void)
*函數(shù)功能:進(jìn)行PID運(yùn)行
*輸入?yún)?shù):void
*返回值:void
  u8 a = 1,b,c,d   ;
  u16 e;
  Write_CMD(0x01);                     //第一行顯示
  while(M_S == 11)
    do{
           if(a==1)
                P2SEL  |=  BIT1 ;
                TA1CCTL1 = OUTMOD_7;
                TA1CCR0 =10000;
                 Write_CMD(0x80);
                 b = (u8)(TARGET*10/100);
                 c = (u8)(TARGET*10/10%10);
                 d = (u8)(TARGET*10%10);
                 print_string("當(dāng)前溫度:");        //當(dāng)前溫度顯示
                 Write_CMD(0x88);
                 print_string("目標(biāo)溫度:");        //目標(biāo)溫度顯示
                 LCD_write_char(2,3,Number[b]);
                 LCD_write_char(3,3,Number[c]);
                 LCD_write_char(4,3,'.');
                 LCD_write_char(5,3,Number[d]);
                 Write_CMD(0x9e);
                 print_string("°C");               //目標(biāo)溫度設(shè)置
                 Write_CMD(0x96);                  //第二行
                 a = 2;
         TA1CCR1 = PID_Run(TARGET);
         TEMPE = TEMPE*10;
         e = (u16)TEMPE;
         b = (u8)(e/100);
         c = (u8)(e/10%10);
         d = (u8)(e%10);
         LCD_write_char(2,1,Number[b]);
         LCD_write_char(3,1,Number[c]);
         LCD_write_char(5,1,Number[d]);
         delay_(3);
         }while(KM_S&&KM_RETURN );
      if(!KM_S)
        M_S = 0;
        TA1CCTL1 = OUTMOD_0;
        T_diff = 0;                           //誤差
      else if(!KM_RETURN)
          M_S = 10;
          T_diff = 0;                           //誤差
          T_diff3 = 0;
          T_diff1 = 0 ;
*函數(shù)名稱:void Tempe_show(u8 HOW)
*函數(shù)功能:顯示溫度
*輸入?yún)?shù):void
*輸出參數(shù):void
  switch(HOW)
     case 0:
            print_string("1.當(dāng)前溫度");        //顯示當(dāng)前溫度值
            Write_CMD(0x90);                   //第二行顯示
            print_string("2.目標(biāo)溫度");        //目標(biāo)溫度設(shè)置
            break;
     case 1:
            Write_CMD(0x96);                   //第二行顯示
            Write_DATA(0x20);                  //清除其他功能
            Write_CMD(0x86);                   //第一行顯示
            Write_DATA(0x03);                  //選定電壓測(cè)量
            break;
     case 2:
            Write_CMD(0x86);                   //第二行顯示
            Write_DATA(0x20);                  //選定電壓測(cè)量
            Write_DATA(0x03);                  //清除其他功能
            break;
*函數(shù)名稱:void Tempe_change(void)
*函數(shù)功能:選擇目標(biāo)溫度
*輸入?yún)?shù):void
*返回值:void
    u8 a = 1,b,c;
    signed int Target = 30;
    while(M_S == 10 )
       while(!KM_SURE)
       do{
              b = Target/10%10;
              c = Target%10;
             if(a)
                 print_string("目標(biāo)溫度:");        //目標(biāo)溫度設(shè)置
                 Write_CMD(0x95);                  //第四行
                 Write_CMD(0x98);                  //第四行
                 print_string("返回");        //目標(biāo)溫度設(shè)置
                 Write_CMD(0x9e);
                 print_string("確定");        //目標(biāo)溫度設(shè)置
                 a = 0;
               LCD_write_char(3,1,Number[b]);
               LCD_write_char(4,1,Number[c]);
              if(!KM_SSUP)
                 while(!KM_SSUP);
                   Target++;
                    if(Target>80)
                      Target=80;
              else if(!KM_SSDOWN)
                  while(!KM_SSDOWN);
                   Target--;
                   if(Target<30)
                     Target=30;
               }while(KM_S&&KM_RETURN&&KM_SURE);
         if(!KM_S)
            M_S = 0;
           FANHUI=1;
         else if(!KM_RETURN)
             M_S = 3;
         else if(!KM_SURE)
            M_S = 11;
            TARGET = Target;                       //將目標(biāo)溫度值傳遞給pid1結(jié)構(gòu)體
*函數(shù)名稱:void Tempe_relook(void)
*函數(shù)功能:查看當(dāng)前溫度值
*輸入?yún)?shù):void
*返回值:void
    u8 i;
    while(M_S == 9 )
         do{
              _ADC = ADC_LVBO();                          //經(jīng)過(guò)濾波算法后取值
              TEMPE = ((float)(_ADC-24)/30)  ;            //計(jì)算當(dāng)前溫度值
              i=((u8)TEMPE)/100;
              Write_CMD(0x80);
              print_string("當(dāng)前溫度值:");
              if(i!=0)
                LCD_write_char(2,1,Number[i]);
                  LCD_write_char(2,1,0x20);
              i=((u8)TEMPE)/10%10;
              LCD_write_char(3,1,Number[i]);
              i=((u8)TEMPE)%10;
              LCD_write_char(4,1,Number[i]);
              Write_CMD(0x95);
              print_string("°C");
            }while(KM_S&&KM_RETURN);
         if(!KM_S)
           M_S = 0;
           FANHUI=1;
         else if(!KM_RETURN)
           M_S = 3;
*函數(shù)名稱:void Temper_run(void)
*函數(shù)功能:溫度操作
*輸入?yún)?shù):void
*輸出參數(shù):void
   MM_S2 = 0;
   Tempe_show(MM_S2);                       //調(diào)用溫度顯示函數(shù)
   while(M_S==3)
      while((!KM_SURE)||(!KM_RETURN))
       MM_S2 =FANHUI2;
       do{
             _ADC = ADC_LVBO();
             TEMPE = (((float)(_ADC-24))/30)  ;           //計(jì)算當(dāng)前溫度值
             if(!KM_SSDOWN)                           //下選鍵按下
                     while(!KM_SSDOWN )               //按鍵消抖操作
                          Tempe_show(MM_S2);          //顯示當(dāng)前MM_S(即所選功能)
                       MM_S2++;
                       if(MM_S2 == 3)
                             MM_S2 = 1;                     //當(dāng)MM_S加到3就恢復(fù)到1
                   else  if(!KM_SSUP)
                           while(!KM_SSUP )               //按鍵消抖操作
                                  Menu_LCDshow(MM_S2);      //顯示當(dāng)前MM_S(即所選功能)
                              MM_S2--;                        //選擇下一功能
                              if(MM_S2 == 0)
                                 MM_S2 = 2;                 //當(dāng)MM_S減到0就恢復(fù)到2
            if(!KM_S)
              M_S = 0;
              FANHUI=1;
             else if(!KM_RETURN)
              while(!KM_RETURN);
              M_S = 0;
           else if(!KM_SURE)
              M_S = MM_S2 + 8;
*函數(shù)名稱:u16 PID_Run(signed Target)
*函數(shù)功能:進(jìn)行PID計(jì)算
*輸入?yún)?shù):PID_INT *pid
*輸出參數(shù):void
          signed long  PWM = 0 ;
          float  Kp;                               //比例系數(shù)
          float  Ki;                               //積分系數(shù)
          float  Kd;                               //微分系數(shù)
          float  P_OUT;                             //比例
          float  D_OUT;                             //微分
          float  I_OUT;                             //積分
          Kp = 250;                         //PID參數(shù)
          Ki = 1.0;
          Kd =  0;
          TEMPE  =   (((float)(ADC_LVBO()-24))/30) ;            //讀取當(dāng)前溫度
          T_real =   (((float)(ADC_LVBO()-24))/30) ;            //讀取當(dāng)前溫度
          T_target = Target;                                   //設(shè)置目標(biāo)溫度
          T_diff = (float)((T_target - T_real)*10);               //計(jì)算誤差
          if(T_diff<=30&&T_diff>0)
              P_OUT = Kp* T_diff ;                              //計(jì)算比例環(huán)節(jié)
              I_OUT = Ki* T_diff1 ;                             //計(jì)算積分環(huán)節(jié)
              D_OUT = Kd* T_real;
              PWM = (signed int)(P_OUT  + I_OUT + D_OUT ) ;
             return 10000;
          if(PWM<0)
             return 0;
         else if(PWM >=10000)
            return 10000;
            return (u16) PWM;
*函數(shù)名稱:void delay_(u32)
*函數(shù)功能:可被打斷延時(shí)
*輸入?yún)?shù):u32
*返回值:void
   u32 b = 0,a;
  do{
      for(a=0;a<990;a++)
         _NOP();
      b++;
     }while((b<time)&&KM_S&&KM_RETURN);
*函數(shù)名稱:void LCD_write_char(u8 X,u8 Y,u8 data)
*函數(shù)功能:在屏幕上隨意顯示字符
*輸入?yún)?shù):u8 x,u8 y,u8 data
*返回值:void
   LCD_set_xy( X, Y ); //寫(xiě)地址
   Write_DATA( data);
*函數(shù)名稱:void LCD_set_xy( u8 x, u8 y )
*函數(shù)功能:設(shè)置LCD12864上要顯示的位置(字母或是符號(hào))
*返回值:void
  u8 address;
  switch(y)
       case 0:
              address=x+0x80;
              break;
       case 1:
              address=x+0x90;
              break;
       case 2:
              address=x+0x88;
              break;
       case 3:
              address=x+0x98;
              break;
     Write_CMD( address);
*函數(shù)名稱:void int_port(void)
*函數(shù)功能:初始化LCD的管腳
*輸入?yún)?shù):void
*輸出參數(shù):void
void Init_port(void)                    //管腳初始化
    P1DIR |=  BIT3;
    P1OUT &= ~BIT3;
  //P1DIR |=  BIT0;
  //P1OUT &= ~BIT0;
    P2DIR &= ~BIT4 ;                //P2.4(KM_S菜單)設(shè)置為輸入
    P2DIR &= ~BIT5 ;                //P2.5(KM_SS功能向下選擇)設(shè)置為輸入
    P2DIR &= ~BIT3;                 //P2.3(KM_SS功能向上選擇)設(shè)置為輸入
    P2DIR &= ~BIT2;                 //P2.2(KM_SURE確定鍵)設(shè)置為輸入
    P2DIR &= ~BIT0;                 //P2.1(KM_RETURN返回鍵)設(shè)置為輸入
*函數(shù)名稱:void delay(u8 t)
*函數(shù)功能:實(shí)現(xiàn)簡(jiǎn)單的軟件延時(shí)
*輸入?yún)?shù):u8 t
*輸出參數(shù):void
void delay(u16 t)
     u16 i,j;
       for(i=0; i<t;  i++)
       for(j=0; j<10; j++);
*函數(shù)名稱:void Send_Byte(u8 data)
*函數(shù)功能:串行發(fā)送8位數(shù)據(jù)
*輸入?yún)?shù):u8 data
*輸出參數(shù):void
   P1DIR |=  BIT0;
   P1OUT &= ~BIT0;
   u8 a;
   for(a=0;a<8;a++)
      if(data&(0x80>>a))
        SID_1;
        SID_0;
          CLK_0;
          delay(2);
          CLK_1;
*函數(shù)名稱:void Send_CMD(u8)
*函數(shù)功能:向LCD發(fā)送指令
*輸入?yún)?shù):u8  CMD
*返回值:void
   Send_Byte(0xf8);            //5個(gè)1,RS(0),RW(0),0
   Send_Byte(0xf0&CMD);         //高四位
   Send_Byte(0xf0&(CMD<<4));    //低四位
   delay(2);
*函數(shù)名稱:void Send_DATA(u8 DATA)
*函數(shù)功能:向LCD發(fā)送數(shù)據(jù)
*返回值:void
   Send_Byte(0xfa);            //5個(gè)1,RS(0),RW(0),0
   Send_Byte(0xf0&DATA);         //高四位
   Send_Byte(0xf0&(DATA<<4));    //低四位
   delay(2);
*函數(shù)名稱:void LCD12864_Init(void)
*函數(shù)功能:LCD初始化函數(shù)
*輸入?yún)?shù):void
*返回值:void
   delay(200);                  //復(fù)位等待(內(nèi)部自帶上電復(fù)位電路),時(shí)間較長(zhǎng)
   Write_CMD(0x30);
   delay(50);                     //延時(shí)等待
   Write_CMD(0x0c);               //整體顯示,關(guān)游標(biāo)
   delay(50);
*函數(shù)名稱:void print_string(u8  *s)
*函數(shù)功能:顯示一個(gè)字符串
*輸入?yún)?shù):u8 *s
*返回值:void
    while(*s>0)                  //C語(yǔ)言里字符串末尾自動(dòng)加“\0”(ASCII碼值為0)
       Write_DATA(*s);        //發(fā)送字符對(duì)應(yīng)的ASCII碼,12864指針可設(shè)置自動(dòng)指向下一個(gè)顯示地址
       s++;
       delay(50);
*函數(shù)名稱:void Menu_LCDshow(U8 HOW)
*函數(shù)功能:顯示菜單
*輸入?yún)?shù):void
*返回值:void
    switch(HOW)
         case 0 :
                 print_string("1.測(cè)量電壓");    //選擇電壓顯示功能
                 print_string("2.功能合集");        //選擇時(shí)鐘功能
                 Write_CMD(0x88);                //第三行顯示
                 print_string("3.溫度PID");        //選擇游戲功能
                 Write_CMD(0x98);                //第三行顯示
                 print_string("4.串口調(diào)試");        //選擇游戲功能
                 break;
         case 1:
                 Write_CMD(0x9E);                //第四行顯示
                 Write_CMD(0x8E);                //第三行顯示
                 break;
         case 2:
                 break;
        case 3:
                 break;
         case 4:
                 break;
*函數(shù)名稱:void menu(void)
*函數(shù)功能:進(jìn)入菜單
*輸入?yún)?shù):void
*返回值:  void
    MM_S = 0;
    Menu_LCDshow(MM_S);
    while(M_S==0)
         MM_S = FANHUI;
              do{
                  Menu_LCDshow(MM_S);                  //MM_S為菜單中功能選擇變量
                           Menu_LCDshow(MM_S);      //顯示當(dāng)前MM_S(即所選功能)
                       MM_S++;                        //選擇下一功能
                       if(MM_S == 5)
                             MM_S = 1;                 //當(dāng)MM_S加到3就恢復(fù)到1
                   else  if(!KM_SSUP)
                              MM_S--;                        //選擇下一功能
                              if(MM_S == 0)
                                 MM_S = 4;                 //當(dāng)MM_S減到0就恢復(fù)到2
                  }while(KM_SURE&&KM_S);                    //當(dāng)菜單鍵再次按下的時(shí)候即可退出循環(huán)
         if(!KM_SURE)
                     if(MM_S==4)
                        MM_S = 13;
                     M_S = MM_S;
                     FANHUI = M_S;                       //把M_S的值賦給FANHUI
                  else if(!KM_S)
                    M_S = 0;
                    FANHUI =1;
*函數(shù)名稱:void ADC_Run(void)
*函數(shù)功能:運(yùn)行ADC檢測(cè)電壓(管腳P1.1)
*輸入?yún)?shù):void
*輸出參數(shù):void
void ADC_Run(void)
      ADC10CTL1 |= INCH_1;                         // input A1模擬信號(hào)輸入選擇通道A1即p1.1
      ADC10AE0 |= 0x02;                           // PA.1 ADC option select使p1.1允許AD模擬輸入信號(hào)
      u8 i;
      Write_CMD(0x01);
      while(M_S)
         while(!KM_S )
          do
              ADC_RESULT1 = ADC_LVBO() ;
              Write_CMD(0x90);
              print_string("U");
              LCD_write_char(1,1,':');
              i = ADC_RESULT1/1000;
              LCD_write_char(3,1,'.');
              i = (ADC_RESULT1/100)%10;
              i = (ADC_RESULT1/10)%10;
              LCD_write_char(5,1,Number[i]);
              i = ADC_RESULT1%10;
              LCD_write_char(6,1,Number[i]);
              LCD_write_char(7,1,'V');
         if(!KM_S)
            while(!KM_S);
            M_S = 0;
        else if(!KM_RETURN)
            while(!KM_RETURN);
            M_S = 0;
            ADC10CTL0 &= ~ADC10ON  ; // ADC10ON, interrupt enabled
*函數(shù)名稱:u16 ADC_LVBO(void)
*函數(shù)功能:濾波算法(中位值)
*輸入?yún)?shù):void
*返回值:u32
u16 ADC_LVBO(void)
   u8 a,b,c ;
   u16 SHUZI[9] ,SHUZHI,d;
for(a=0;a<9;a++)
      ADC10CTL0 |= ENC + ADC10SC;               //開(kāi)始轉(zhuǎn)換
      while(ADC10CTL1&ADC10BUSY);
      ADC_Result = ADC10MEM;                    //采集轉(zhuǎn)換結(jié)果
      SHUZHI  = ADC_Result*35/10;               //轉(zhuǎn)換結(jié)果運(yùn)算
      SHUZI[a] =  SHUZHI;                       //取轉(zhuǎn)換結(jié)果接下來(lái)進(jìn)行濾波計(jì)算
  for(c=0;c<9;c++)
     for(b=c;b<9;b++)
       if(b+1<9)
         if(SHUZI[c]<SHUZI[b+1])
            d = SHUZI[c];
            SHUZI[c] = SHUZI[b+1];
            SHUZI[b+1] = d;
  return   SHUZI[4];
*函數(shù)名稱:void ADC_Init(void)
*函數(shù)功能:初始化ADC
*輸入?yún)?shù):void
*返回值:void
void ADC_Init(void)
    ADC10CTL0 |= ADC10SHT_2 + ADC10ON  ;         // ADC10ON, interrupt enabled
*函數(shù)名稱:void Time_choose(u8 HOW)
*函數(shù)功能:時(shí)鐘第二功能設(shè)置
*輸入?yún)?shù):u8 HOW
*返回值:void
  switch(HOW)
       case 0:
                 print_string("1.測(cè)電阻(H)");     //選擇電壓顯示功能
                 print_string("2.程控放大");        //選擇時(shí)鐘功能
                 print_string("3.測(cè)電容");         //選擇秒表功能
                 Write_CMD(0x98);                //第四行顯示
                 print_string("4.程控提高");       //選擇倒計(jì)時(shí)功能
                 break;
       case 1:
                 break;
       case 2:
                 break;
        case 3:
                 break;
         case 4:
                 break;
         case 5:
                 if(GO==0)
                    GO = 1;
                 print_string("5.呼吸燈");       //選擇PWM呼吸燈功能
                 Write_DATA(0x03);               //選定呼吸燈
                 break;
*函數(shù)名稱:void Time_Init(void)
*函數(shù)功能:進(jìn)入時(shí)鐘選擇
*輸入?yún)?shù):void
*返回值:void
  if(FANHUI1!=5)
    MM_S1 = 0;
    Time_choose(MM_S1);
   MM_S1 = FANHUI1;
   Time_choose(MM_S1);                  //MM_S為菜單中功能選擇變量
  if(MM_S1==5)
     GO=0;
  while(M_S==2)
       while(!KM_SURE)
          Time_choose(MM_S1);
      do{
                           Time_choose(MM_S1);      //顯示當(dāng)前MM_S(即所選功能)
                       if(MM_S1==5)
                             Write_CMD(0x01);//清屏
                             print_string("3.側(cè)電容");         //選擇秒表功能
                       MM_S1++;                        //選擇下一功能
                       if(MM_S1==5)
                              GO=0;
                       if(MM_S1 == 6)
                            MM_S1 = 1;                 //當(dāng)MM_S加到5就恢復(fù)到1
           else  if(!KM_SSUP)
                   if(MM_S1==5)
                      MM_S1--;                        //選擇下一功能
                    if(MM_S1==5)
                            GO=0;
                      if(MM_S1 == 0)
                         MM_S1 = 5;                 //當(dāng)MM_S減到0就恢復(fù)到5
                         GO=0;
         }while(KM_SURE&&KM_S&&KM_RETURN);
         if(!KM_SURE)
            M_S = MM_S1 + 3;                             //把選定結(jié)果賦給M_S
            FANHUI1 = MM_S1;                              //將選定結(jié)果賦給FANHUI
         else if(!KM_S)
            M_S = 0;
            FANHUI = 1;
         else if(!KM_RETURN)
            M_S = 0;
            FANHUI1 = 1;
*函數(shù)名稱:void Time_Look(void)
*函數(shù)功能:測(cè)量電阻
*輸入?yún)?shù):void
*返回值:void
void RES_show(void)
   CHANGE = 1;                                   //功能切換變量為1(選擇測(cè)電阻)
   TACTL = TASSEL_2 + MC_2 + ID_3 ;                    //SMCLK,up?mode
   TACCTL1 |= CM_1 + CCIS_0 + CAP + CCIE;       //cap設(shè)置
   P1SEL |= BIT2  ;                             //select P1.1,P1.2 function
   P1DIR &= ~BIT2;
   P1DIR |= BIT4;
   P1OUT |=BIT2;
   TAR = 0;
   _BIS_SR( GIE);
   P2SEL  &=  ~BIT1 ;
   while(M_S==4)
       do{
       if(!KM_S)
         M_S = 0;
                   _DINT();
                   TACCTL1 &= (~CM_1) + (~CCIS_0) + (~CAP) + (~CCIE);       //cap設(shè)置
                   TACTL  &= (~TASSEL_1) + (~MC_2) ;
                   TAR = 0;
                   time11 = 0;
                   CHANGE = 0;
       else if(!KM_RETURN)
           while(!KM_RETURN);
           M_S = 2;
                   _DINT();
                   P1OUT &= ~BIT4;
                   TAR = 0;
                   time11=0;
                   CHANGE = 0;
*函數(shù)名稱:void Time_change(void)
*函數(shù)功能:程控增益基礎(chǔ)篇一級(jí)菜單
*輸入?yún)?shù):void
*返回值:void
  signed char a = 0,b = 0  ;
  u8 i[4]={ 2,5,20,50};
   while(M_S==5)
       while(!KM_RETURN);
       while(!KM_SURE)
            b = i[a]/10;
            Write_CMD(0x80);
            print_string("選擇增益:");     //選擇電壓顯示功能
            b = i[a]%10;
            LCD_write_char(5,1,Number[b]);
       do{
              b = i[a]/10;
              Write_CMD(0x80);
              b = i[a]%10;
              Write_CMD(0x98);
              print_string("返回");     //選擇電壓顯示功能
              Write_CMD(0x9e);
              print_string("確定");     //選擇電壓顯示功能
            if(!KM_SSDOWN)
              while(!KM_SSDOWN);
              a--;
              if(a<0)
                a = 3;
            else if(!KM_SSUP)
               while(!KM_SSUP);
               a++;
               if(a>3)
                 a = 0;
        if(!KM_S)
            while(!KM_S);       //延時(shí)
            M_S = 0;
          else if(!KM_RETURN)
             while(!KM_RETURN); //延時(shí)
             M_S = 2;
        else if(!KM_SURE)
           while(!KM_SURE);     //延時(shí)
           HOW_A = i[a];
           M_S = 12;
*函數(shù)名稱:void Miaobiao(void)
*函數(shù)功能:測(cè)量電容
*輸入?yún)?shù):void
*返回值:void
void Miaobiao(void)
   Write_CMD(0x01);
   CHANGE = 2;                                   //功能切換變量為1(選擇測(cè)電容)
   P1DIR &= ~BIT2;
   P1DIR |= BIT4;
   P1OUT |=BIT2;
   TAR = 0;
   _BIS_SR( GIE);
   while(M_S==6)
         do{
             if(!KM_S)
                   M_S = 0;
                           _DINT();
                           TAR = 0;
                           time11 = 0;
                           CHANGE = 0;
    else if(!KM_RETURN)
          while(!KM_RETURN);
          M_S = 2;
                    _DINT();
                    P1OUT &= ~BIT4;
                    TAR = 0;
                    time11=0;
                    CHANGE = 0;
*函數(shù)名稱:void Daojishi(void)
*函數(shù)功能:實(shí)現(xiàn)程控增益提高篇
*輸入?yún)?shù):void
*返回值:void
void Daojishi(void)
          u16  a = 0;
          P1DIR |= BIT1;                                       //設(shè)置為輸入狀態(tài)
          P1DIR |= BIT2;
          i = HOW_A/10;
          i = HOW_A%10;
    while(M_S==7)
       do{
                SHUZI=0 ;
                SHUZI_1=0 ;
                b = b + SHUZI;
                c = c + SHUZI_1;
               if(!KM_S)
                  M_S = 0;
                else if(!KM_RETURN)
                while(!KM_RETURN);
                 M_S = 2;
void Pwm_run(void)
  u16 a = 20000;
  u16 b;
  P2SEL  |=  BIT1 ;
  TA1CCR0 =20000;
  TA1CCR1 = a;
  while(M_S == 8)
       do{
             print_string("呼吸燈");       //選擇倒計(jì)時(shí)功能
             if(a==20000)
               do{
                  delay(1);
                  b++;
                 }while((b<10000)&&KM_S&&KM_RETURN);
                 b=0;
               do{
                  a--;
                  TA1CCR1 = a;
                  delay(3);
                }while((a>0)&&KM_S&&KM_RETURN);
               if(a==0)
                  do{
                    delay(1);
                     b++;
                  b=0;
                 do{
                 a++;
                 TA1CCR1 = a;
                 delay(3);
                 }while((a<20000)&&KM_S&&KM_RETURN);
      if(!KM_S)
           M_S = 0;
       else if(!KM_RETURN)
            while(!KM_RETURN);
            M_S = 2;
void main(void)
      WDTCTL = WDTPW + WDTHOLD;                     //關(guān)閉看門狗
      P2DIR  |=  BIT1 ;
      P2OUT &= ~BIT1;
      BCSCTL1 = CALBC1_8MHZ;  //MCLK=8MHz
      DCOCTL  = CALDCO_8MHZ;
      TA1CTL = MC_1 + TASSEL_2;
      Init_port();                                  //管腳初始化
      LCD12864_Init();                              //LCD12864初始化
      ADC_Init();                                   //AD轉(zhuǎn)換初始化
    //  Write_CMD(0x01);
      M_S = 0;                                      //直接進(jìn)入主菜單
      MM_S = 0;
      FANHUI = 1;                                   //將上級(jí)菜單最后結(jié)果設(shè)置為1
      FANHUI1 = 1;                                  //將二級(jí)菜單中最后結(jié)果設(shè)置為1
      FANHUI2 = 1;                                  //將溫度二級(jí)菜單中最后結(jié)果設(shè)置為1
      MM_S1 = 1;
      MM_S2 = 0;
        switch(M_S)
     case 0:
      Menu_Init();                 //菜單顯示
      break;
              case 1:
                       ADC_Run();                   //ADC運(yùn)行
                       break;
              case 2:
                       Time_Init();
                       break;
              case 3:
                       Temper_run();                //溫度
                       break;
              case 4:
                       RES_show ();                 //檢測(cè)電阻
                       break;
              case 5:
                       Time_change();               //選擇放大器增益
                       break;
              case 6:
                       Miaobiao();
                       break;
              case 7:
                       Daojishi();
                       break;
              case 8:
                       Pwm_run();
                       break;
              case 9:
                       Tempe_relook();
                       break;
              case 10:
                       Tempe_change();
                       break;
              case 11:
                       Tempe_PID();
                       break;
              case 12:
                       Zeng_yi();
                       break;
#pragma vector = TIMER0_A1_VECTOR
__interrupt void Timer_A(void)
  long a = 0 ;
      if(TACCTL1&CCIFG)
          TACCTL1 &= ~CCIFG;
            time11++;
            if(time11==1)
               TA0CTL |= TACLR;
            if(time11==2)
                 T  = TACCR1;
                 f  = 1000000/T;
              switch (CHANGE)
                  case 2:
                           f = 1000000000000/(709632*f);
                           print_string("電容值");     //選擇電壓顯示功能
                           print_string("單位,pF");     //選擇電壓顯示功能
                           a = (u16)(((long)f)/1000%10);
                           LCD_write_char(3,1,Number[a]);
                           a = (u16)(((long)f)/100%10);
                           LCD_write_char(4,1,Number[a]);
                           a = (u16)(((long)f)/10%10);
                           LCD_write_char(5,1,Number[a]);
                           a = (u16)(((long)f)%10);
                           LCD_write_char(6,1,Number[a]);
                           P1OUT ^= BIT4;
                           break;
                    case 1:
                                LCD_write_char(0,1,0x20);
                                 LCD_write_char(1,1,0x20);
                                   LCD_write_char(3,1,0x20);
                                    LCD_write_char(4,1,0x20);
                                     LCD_write_char(5,1,0x20);
                                      LCD_write_char(6,1,0x20);
                                       LCD_write_char(7,1,0x20);
                           f = (3333333/f-165);
                           print_string("電阻值");     //選擇電壓顯示功能
                           print_string("單位,R");     //選擇電壓顯示功能
                        if((f>=1)&&(f<10))
                           f = f-f*0.04;
                           a = (u16)f;
                           LCD_write_char(7,1,Number[a]);
                           last  = f;
                        else if((f>=10)&&(f<100))
                              f = f-f*0.04;
                             a = ((u16)f)/10;
                             a = ((u16)f)%10;
                        else if((f>=100)&&(f<1000))
                             f = f-f*0.04;
                             a = ((u16)f)/100;
                             a = ((u16)f)/10%10;
                             a = ((u16)f)%10;
                        else if((f>=1000)&&(f<10000))
                             f = f-f*0.04;
                             a = ((u16)f)/1000;
                             a = ((u16)f)/100%10;
                             a = ((u16)f)/10%10;
                             a = ((u16)f)%10;
                      else if((f>=10000)&&(f<100000))
                             f = f-f*0.04;
                             a = ((u16)f)/10000;
                             a = ((u16)f)/1000%10;
                             a = ((u16)f)/10%10;
                              a = ((u16)f)%10;
                       else if((f>=100000)&&(f<1000000))
                             f = f-f*0.04;
                             a = ((long)f)/100000;
                             LCD_write_char(2,1,Number[a]);
                             a = ((long)f)/10000%10;
                             a = ((long)f)/1000%10;
                             a = ((long)f)/100%10;
                              a = ((long)f)/10%10;
                             a = ((long)f)%10;
                         P1OUT ^= BIT4;
                         break;
ID:65585 發(fā)表于 2014-9-5 15:42 | 只看該作者
很強(qiáng)大,樓主把效果圖貼一下就好了!
