查看: 4643|回復(fù): 2
別克系列CAN跑表器制作--完全公開
ID:50962 發(fā)表于 2014-8-13 18:54 | 顯示全部樓層 |閱讀模式
準(zhǔn)備工作
1、購買一個OBD外殼(10元)
2、采集CAN信號
3、畫好PCB圖
原件清單:STC15F104E*1
                  120歐0805電阻*1
                  82C250*1
                  47UF電容*1
                   IN4007*1
                  LM7805  *1
源程序代碼:直接寫入即可ORG 00H
    AJMP  MAIN
    MAINI:mov p3,#0ffh
         MOV R2,#00H
    MA:  MOV R0,#0112D;14組
    DIAO:MOV A,R2
         MOV DPTR,#TAB7
         MOVC A,@A+DPTR
         NOP
         NOP
         NOP
         NOP
         NOP
         NOP
         MOV  P3,A
         INC R2
         DJNZ R0,DIAO
         MOV  P3,#0FFH
         LCALL YANCHANG
         MOV R2,#00H
    MA0:  MOV R0,#0112D;14組
    DIAO0:MOV A,R2
         MOV DPTR,#TAB8
         MOVC A,@A+DPTR
         NOP
         NOP
         NOP
         NOP
         NOP
         NOP
         MOV  P3,A
         INC R2
         DJNZ R0,DIAO0
         MOV  P3,#0FFH
         LCALL YANCHANG
         AJMP MAIN
    MOV R2,#00H
    MA1:  MOV R0,#0112D;14組
    DIAO1:MOV A,R2
         MOV DPTR,#TAB9
         MOVC A,@A+DPTR
         NOP
         NOP
         NOP
         NOP
         NOP
         NOP
         MOV  P3,A
         INC R2
         DJNZ R0,DIAO1
         MOV  P3,#0FFH
         LCALL YANCHANG
    MOV R2,#00H
    MA2:  MOV R0,#0112D;14組
    DIAO2:MOV A,R2
         MOV DPTR,#TAB10
         MOVC A,@A+DPTR
         NOP
         NOP
         NOP
         NOP
         NOP
         NOP
         MOV  P3,A
         INC R2
         DJNZ R0,DIAO2
         MOV  P3,#0FFH
         LCALL YANCHANG
    MOV R2,#00H
    MA3:  MOV R0,#0112D;14組
    DIAO3:MOV A,R2
         MOV DPTR,#TAB11
         MOVC A,@A+DPTR
         NOP
         NOP
         NOP
         NOP
         NOP
         NOP
         MOV  P3,A
         INC R2
         DJNZ R0,DIAO3
         MOV  P3,#0FFH
         LCALL YANCHANG
    MOV R2,#00H
    MA4:  MOV R0,#0112D;14組
    DIAO4:MOV A,R2
         MOV DPTR,#TAB12
         MOVC A,@A+DPTR
         NOP
         NOP
         NOP
         NOP
         NOP
         NOP
         MOV  P3,A
         INC R2
         DJNZ R0,DIAO4
         MOV  P3,#0FFH
         LCALL YANCHANG
    MOV R2,#00H
    MA5:  MOV R0,#0112D;14組
    DIAO5:MOV A,R2
         MOV DPTR,#TAB13
         MOVC A,@A+DPTR
         NOP
         NOP
         NOP
         NOP
         NOP
         NOP
         MOV  P3,A
         INC R2
         DJNZ R0,DIAO5
         MOV  P3,#0FFH
         LCALL YANCHANG
    MOV R2,#00H
    MA6:  MOV R0,#0112D;14組
    DIAO6:MOV A,R2
         MOV DPTR,#TAB14
         MOVC A,@A+DPTR
         NOP
         NOP
         NOP
         NOP
         NOP
         NOP
         MOV  P3,A
         INC R2
         DJNZ R0,DIAO6
         MOV  P3,#0FFH
         LCALL YANCHANG
          RET
    TAB:  DB 0H,0H,1H,1H,1H,1H,1H,0H,0H,1H,0H,0H,1H,0H,0H,0H,1H,0H,0H,0H,0H,0H,1H,0B,0H,0H,1H,0H,1H,1H,0H,1B,1H,1H,0H,1H,0H,0H,0H,0B,0H,1H,0H,0H,1H,1H,1H,1B,1H,0H
          DB 1H,1H,1H,0H,1H,0B,0H,0H,0H,0H,1H,1H,0H,1B,1H,1H,1H,1H,0H,0H,1H,0B,1H,0H,0H,0H,0H,0H,1H,1H,0H,0H,0H,0H,0H,1H,1H,0B,1H,1H,0H,0H,0H,1H,1H,0B,1H,0H,0H,1H,0H,1H,1H,0B,1H,1H,1H,1H,1H,1H,1H,1B
    TAB0: DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,0B,1B,1B,0B,1B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,0B,1B,1B
          DB 0B,1B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B,1B,1B,1B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,1B,0B,1B,0B,0B,0B,1B,1B,0B,1B,0B,1B,1B,1B,1B,1B,0B,1B,1B,0B,0B,0B,0B,1B,1B,1B,1B,1B,1B,1B
    TAB1: DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,0B,1B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,0B,1B,1B
          DB 0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B,1B,1B,1B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B,0B,0B,1B,0B,0B,1B,0B,1B,1B,1B,1B,0B,1B,1B,0B,1B,1B,0B,0B,0B,1B,1B,0B,1B,1B,1B,1B,1B,1B,1B,1B,1B,1B
    TAB2: DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,1B,0B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B,0B,0B,0B,1B,0B,1B,1B,0B,0B,0B,0B,0B,1B,0B,0B,1B,0B
          DB 1B,1B,1B,1B,0B,0B,1B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,1B,0B,0B,1B,0B,1B,1B,1B,1B,0B,1B,1B,0B,1B,1B,0B,0B,0B,1B,1B,0B,1B,1B,1B,1B,1B,1B,1B,1B,1B,1B
    TAB3: DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,0B,1B,1B,0B,1B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,0B,1B,1B,0B,1B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B
          DB 1B,1B,1B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,1B,0B,1B,0B,0B,0B,1B,1B,0B,1B,0B,1B,1B,1B,1B,1B,0B,1B,1B,0B,0B,0B,0B,1B,1B,1B,1B,1B,1B,1B
    TAB4: DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,0B,1B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,0B,1B,1B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B
          DB 1B,1B,1B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B,0B,0B,1B,0B,0B,1B,0B,1B,1B,1B,1B,0B,1B,1B,0B,1B,1B,0B,0B,0B,1B,1B,0B,1B,1B,1B,1B,1B,1B,1B,1B,1B,1B
    TAB5: DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,1B,0B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B,0B,0B,0B,1B,0B,1B,1B,0B,0B,0B,0B,0B,1B,0B,0B,1B,0B
          DB 1B,1B,1B,1B,0B,0B,1B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,1B,0B,0B,0B,1B,1B,0B,0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,1B,1B,0B,1B,1B,1B,1B,1B,1B,1B,1B
    TAB6: DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,0B,1B,1B,1B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,1B,1B,1B,1B,1B,0B,1B,1B,1B,0B,1B,0B,0B,0B,0B,0B,1B,1B
          DB 0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B,1B,1B,0B,0B,0B,1B,1B,0B,1B,0B,0B,1B,0B,1B,1B,0B,1B,1B,1B,1B,1B,1B,1B,1B
    TAB7: DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,1B,0B,0B,0B,1B,1B,0B,0B,0B,0B,0B,1B,0B,0B,1B,1B,1B,1B,1B,0B,1B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B
          DB 0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,1B,1B,0B,1B,1B,1B,1B,1B
    TAB8: DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,0B,1B,1B,1B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,1B,1B,1B,1B,1B,0B,1B,1B,1B,0B,1B,0B,0B,0B,0B,0B,1B,1B
    TAB9: DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,0B,1B,1B,0B,1B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,0B,1B,1B,0B,1B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B
    TAB10:DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,0B,1B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,0B,1B,1B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B
    TAB11:DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,1B,0B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B,0B,0B,0B,1B,0B,1B,1B,0B,0B,0B,0B,0B,1B,0B,0B,1B,0B
    TAB12:DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,1B,0B,0B,1B,1B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B,0B,0B,0B,1B,0B,0B,1B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B
          DB 1B,1B,1B,1B,1B,0B,0B,0B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,1B,0B,0B,1B,0B,1B,1B,1B,1B,0B,1B,0B,0B,1B,1B,1B,1B,1B,1B,1B
    TAB13:DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,0B,1B,1B,1B,1B,0B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B
          DB 1B,1B,1B,1B,1B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,1B,1B,1B,1B,0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,1B,0B,1B,0B,0B,0B,0B,0B,1B,1B,1B,1B,1B,1B,1B
    TAB14:DB 0B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,0B,0B,1B,0B,0B,0B,0B,0B,1B,0B,0B,0B,1B,0B,1B,1B,0B,1B,1B,0B,1B,1B,0B,0B,0B,0B,0B,1B,0B,1B,0B,0B,0B,0B,0B,1B,1B,1B,1B,0B,1B,0B,0B,0B,0B,0B,1B,1B
          DB 0B,1B,1B,1B,1B,1B,0B,1B,0B,1B,1B,0B,0B,0B,0B,0B,1B,1B,0B,0B,0B,0B,1B,1B,0B,1B,1B,0B,1B,1B,1B,1B,1B,0B,0B,1B,0B,0B,1B,0B,1B,0B,0B,0B,1B,1B,1B,1B,1B,1B
    END;DB 0H,0,1H,1H,1H,1H,1H,0B ,01001000B ,10000010B, 00101101B, 11010000B ,01001111B ,10111010B ,00001101B, 11110010B, 10000011B, 00000110B ,11000110B ,10010110B
    ;DB 00111110B, 01001000B ,10000010B, 00101101B, 10111000B ,00110000B ,11011100B ,00011011B, 11000001B, 00000110B, 00101000B ,11010111B ,11011000B ,01111111B
       ; DB 00111110B, 01001000B ,10000010B, 00101101B, 10001000B ,00110000B ,11001000B ,00101011B, 11000100B, 00010100B, 01001011B ,11011011B ,00011011B ,11111111B
       ; DB 00111110B, 01001000B ,10000010B, 00101110B, 00010000B ,01010000B ,10110000B ,01001011B, 11001110B, 00001100B, 01001011B ,11011011B ,00011011B ,11111111B
        ;DB 00111110B ,01001000B ,10000010B, 00101101B, 10111000B ,00110000B ,11011100B ,00011011B, 11000001B, 00000110B, 00101000B ,11010111B ,11011000B ,01111111B
       ; DB 00111110B, 01001000B ,10000010B, 00101110B, 00010000B ,01010000B ,10110000B ,01001011B, 11001110B, 00001100B, 01000110B ,00111110B ,01001110B ,11111111B
        ;DB 00111110B, 01001000B ,10000010B, 00101101B, 11010000B ,01001111B ,10111010B ,00001101B, 11110010B, 10000011B, 00000110B ,11000110B ,10010110B ,11111111B
        ;DB 00111110B ,01001000B ,10000010B, 00101110B, 00110000B ,01001111B ,10110000B ,01000101B, 11110010B, 10000011B, 00000110B ,00100100B ,10000010B ,11011111B
       ; DB 00111110B, 01001000B ,10000010B, 00101101B, 11010000B ,01001111B ,10111010B ,00001101B, 11110010B, 10000011B, 00000110B ,11000110B ,10010110B ,11111111B
       ; DB 00111110B ,01001000B ,10000010B, 00101101B, 10001000B ,00110000B ,11001000B ,00101011B, 11000100B, 00010100B, 01001011B ,11011011B, 00011011B ,11111111B
       ; DB 00111110B ,01001000B ,10000010B, 00101110B, 00010000B ,01010000B ,10110000B ,01001011B, 11001110B, 00001100B, 01000110B ,00111110B ,01001110B ,11111111B
       ; DB 00111110B, 01001000B ,10000010B, 00101110B, 01110000B ,01010000B ,10011100B ,00011011B, 11100011B, 00000110B, 00100000B ,11001001B ,01111010B ,01111111B
       ; DB 00111110B ,01001000B ,10000010B, 00101011B, 11010000B ,01010000B ,10001000B ,00101011B, 11101000B, 00100010B, 00011110B ,01111100B ,11010000B ,01111111B
       ; DB 00111110B ,01001000B ,10000010B, 00101101B, 10110000B ,01010000B ,01111010B ,00001101B, 11110101B, 10000011B, 00001101B ,10111110B ,01001010B ,00111111B
ID:83029 發(fā)表于 2015-6-15 09:24 | 顯示全部樓層
歷害,看不懂,有C程序嗎
