查看: 13676|回復: 9
STM32F103C8T6控制1602液晶顯示
ID:51024 發表于 2014-7-29 21:06 | 顯示全部樓層 |閱讀模式
#include"stm32f10x_lib.h"
//定義LCD的RS,RW,EN=0時分別是 Set_RS,Set_RW,Set_EN
#define Set_RS (GPIO_SetBits(GPIOB,GPIO_Pin_0))
#define Set_RW (GPIO_SetBits(GPIOB,GPIO_Pin_1))
#define Set_EN (GPIO_SetBits(GPIOB,GPIO_Pin_2))
//定義RS,RW,EN=1時分別是CLR_RS,CLR_RW,CLR_EN
#define CLR_RS (GPIO_ResetBits(GPIOB,GPIO_Pin_0))
#define CLR_RW (GPIO_ResetBits(GPIOB,GPIO_Pin_1))
#define CLR_EN (GPIO_ResetBits(GPIOB,GPIO_Pin_2))
ErrorStatus HSEStartUpStatus;
void Delay(u32 count)
{  //定義無符號長整型變量count
   for(;count!=0;count--);
unsigned char table[]="liushuai";
unsigned char table1[]="2009.12.21";
//寫指令
void Send_Com(unsigned char Send_Com)
   u16 Temp;//定義短整型變量Temp,由于STM32F103C8的GPIOA恰好有16個IO口。
   Delay(0xAFFFF);
   CLR_RS;
   Temp=GPIO_ReadOutputData(GPIOA);//讀回GPIOA發送寄存器的數據。
   Temp&=0xff00;//將GPIOA的高8位保留,低8位清0.
   Temp|=(u16)Send_Com;//將char型變量Send_Com強制轉換成short(短整型),其中高8位由0代替,低8位是Send_Com的值
   GPIO_Write(GPIOA,Temp);
   Delay(100);
   Set_EN;
   Delay(100);
   CLR_EN;
//寫數據
void Send_Dat(unsigned char Send_Dat)
   Set_RS;
Temp=GPIO_ReadOutputData(GPIOA);//讀回發送寄存器內的數據
Temp&=0xff00;
Temp|=(u16)Send_Dat;
Delay(100);
    Set_EN;
Delay(500);
    CLR_EN;
void init()
  CLR_EN;
  //Delay(0xAFFF);
  Send_Com(0x38);    //置初值//
  Send_Com(0x0c);
  Send_Com(0x06);
  Send_Com(0x80);
void GPIO_Configuration(void)
   GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;
   GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
   GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
   GPIO_Init(GPIOB,&GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
   GPIO_Init(GPIOA,&GPIO_InitStructure);
void RCC_Configuration(void)
  RCC_DeInit();
     RCC_HSEConfig(RCC_HSE_ON);
     HSEStartUpStatus= RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus==SUCCESS)
   RCC_HCLKConfig(RCC_SYSCLK_Div1);
   RCC_PCLK2Config(RCC_HCLK_Div1);
      RCC_PCLK1Config(RCC_HCLK_Div2);
    FLASH_SetLatency(FLASH_Latency_2);
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);
    RCC_PLLCmd(ENABLE);
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET)
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    while(RCC_GetSYSCLKSource()!=0x08)
       RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                              RCC_APB2Periph_GPIOC , ENABLE);
int main(void)
  #ifdef DEBUG
  debug();
  #endif
  unsigned char num;
  RCC_Configuration();
  GPIO_Configuration();
  init();
  for(;;)
    for(num=0;num<8;num++)
   Send_Dat(table[num]);
   Delay(2000000);
   //while(1);
    //Send_Com(0x01);
  Delay(20000);
  Send_Com(0x80+0x40);
  for(num=0;num<10;num++)
   Send_Dat(table1[num]);
   Delay(2000000);
    while(1);
參與人數 1黑幣 +4 收起 理由
Erin1012 + 4 絕世好帖!
ID:78787 發表于 2015-5-4 01:37 | 顯示全部樓層
thanks!!!
ID:75635 發表于 2015-5-15 19:51 | 顯示全部樓層
謝啦
ID:186936 發表于 2017-10-10 22:09 | 顯示全部樓層
你好,可不可以借鑒一下你的工程文件,方便的話QQ郵箱1306501801@qq.com
ID:208751 發表于 2017-12-24 17:23 | 顯示全部樓層
可以發布源碼嗎?我將代碼放進新建的工程中不能運行,拜托了。
ID:265966 發表于 2017-12-25 11:41 | 顯示全部樓層
能否提供工程文件?
ID:547108 發表于 2019-5-27 09:28 | 顯示全部樓層
您好,關于STM32F103C8+LCD1602原理圖接法您還記得嗎?能麻煩您一下嗎?
ID:548694 發表于 2019-5-27 19:28 | 顯示全部樓層
好東西
ID:556948 發表于 2019-6-7 02:57 | 顯示全部樓層
good up up study!
ID:516571 發表于 2019-6-8 09:11 | 顯示全部樓層
你好,可以發布下你的源碼嗎,非常感謝
