查看: 3788|回復: 0
LCD12864--頭文件
ID:51024 發表于 2014-7-12 01:51 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
LCD12864.h
#define LCD12864_RS PORTA.0
#define LCD12864_RW PORTA.1
#define LCD12864_EN PORTA.2
#define LCD12864_PortOut DDRA|=0x07  //P3口的低三位設置為輸出
#define LCD12864_Data DDRB
#define LCD12864_Read  PINB
#define LCD12864_Write  PORTB
void lcd12864_init(void);
void lcd12864_cleardd(void);
void lcd12864_cursoron(void);
void lcd12864_cursoroff(void);
void lcd12864_gotoxy(unsigned char x,unsigned char y);
void lcd12864_putchar(unsigned char temp);
void lcd12864_puts(unsigned char *str);
void lcd12864_cleargd(void);
void lcd12864_picture(flash unsigned char *ptr);
lcd12864.c
#include "lcd12864.h"
#include
#include
static void Write_Cmd(unsigned char cmd)
    unsignedchar temp,i;
   LCD12864_RS=0;
   LCD12864_RW=1;
   LCD12864_Data=0x00;
   do
       LCD12864_EN=1;
       for(i=0;i<24;i++);
       temp=LCD12864_Read;
       LCD12864_EN=0;
    while(temp& 0x80);
   LCD12864_Data=0xff;
   LCD12864_RW=0;
   LCD12864_Write = cmd;
   LCD12864_EN=1;
   for(i=0;i<24;i++);//延時
   LCD12864_EN=0;
static void  Write_Data(unsigned chardat)
   LCD12864_RS=0;
   LCD12864_RW=1;
   LCD12864_Data=0x00;
   do
       LCD12864_EN=1;
       temp=LCD12864_Read;
       LCD12864_EN=0;
    while(temp& 0x80);
   LCD12864_Data=0xff;
   LCD12864_RS=1;
   LCD12864_RW=0;
   LCD12864_Write = dat;
   LCD12864_EN=1;
   LCD12864_EN=0;
   LCD12864_PortOut;   //液晶控制端口設置為輸出
   Write_Cmd(0x30);   //基本指令集
   delay_ms(1);
   Write_Cmd(0x02);   // 地址歸位
   delay_ms(1);
   Write_Cmd(0x0c);  //整體顯示打開,游標關閉
   delay_ms(1);
   Write_Cmd(0x01);   //清除顯示
   delay_ms(1);
   Write_Cmd(0x06);   //游標右移
   delay_ms(1);
   Write_Cmd(0x80);  //設定顯示的起始地址
   delay_ms(1);
   Write_Cmd(0x01);
   delay_ms(5);
   lcd12864_gotoxy(0,0);
   Write_Cmd(0x0f);           //整體顯示開,游標開,游標位置開
   Write_Cmd(0x0c);           //整體顯示開,游標關,游標位置關
   switch(y)
    case0:Write_Cmd(0x080+x);break;
    case1:Write_Cmd(0x090+x);break;
    case2:Write_Cmd(0x088+x);break;
    case3:Write_Cmd(0x098+x);break;
    default:break;
   Write_Data(temp);
    for(;*str !='\0';lcd12864_putchar(*(str++)));
    unsignedchar i,j,k;
   Write_Cmd(0x34);       //打開擴展指令集
    i =0x80;
    for(j = 0;j< 32;j++)
       Write_Cmd(i++);
       Write_Cmd(0x80);
          for(k = 0;k < 16;k++)
         Write_Data(0x00);
    i =0x80;
    for(j = 0;j < 32;j++)
    Write_Cmd(i++);
       Write_Cmd(0x88);
          Write_Data(0x00);
   Write_Cmd(0x30);       //回到基本指令集
       unsigned char i,j,k;
    i =0x80;
       Write_Cmd(i++);
       Write_Cmd(0x80);
             Write_Data(*ptr++);
    i =0x80;
        Write_Cmd(i++);
       Write_Cmd(0x88);
              Write_Data(*ptr++);
       Write_Cmd(0x36);       //打開繪圖顯示
