...............................PCF8563測試程序主函數............................
#include
#include "pcf8563.h"
#include "IIC.h"
__CONFIG(FOSC_INTOSC&WDTE_OFF&MCLRE_OFF); //PIC配置位設置
void init_fosc() //PIC內部晶振設置
OSCCON=0x61;
...................在PCF8563.h頭文件里定義的結構體.....................
struct Time
uchar second;
uchar minute;
uchar hour;
uchar day;
uchar week;
uchar month;
uchar year;
struct Time time;
init_fosc();
time.second=55;
time.minute=51;
time.hour=11;
time.day=2;
time.week=6;
time.month=4;
time.year=14;
P8563_Set_Time(); //PCF8563設置時間子函數
nop();nop();
P8563_Read_Time();//讀取PCF8563子程序
TRISB=0b00000000;
PORTB=~time.second;
uint n;
for(n=0;n<600;n++)
nop();
while(1);
...............................IIC通訊子程序.................................
#include
#include "IIC.h"
void start() //IIC起始程序
TRISC5=0; //SCL輸出
TRISC4=0; //SDA輸出
SDA_OUT=1;
SCL_OUT=1;
nop();
SDA_OUT=0;
nop(); //大于4us
SCL_OUT=0;
void stop() //IIC停止子程序
TRISC5=0;
TRISC4=0;
SDA_OUT=0;
SCL_OUT=1;
nop(); //大于4us
SDA_OUT=1;
TRISC4 = 1; // 結束后釋放總線,sda輸入
uchar IIC_Get_Ack(void) //檢測應答信號
TRISC4=1; //應答信號由從機發出,所以SDA設為輸入
SCL_OUT=0;
SCL_OUT=1;
nop();
if(SDA_IN==1) //讀取SDA狀態時,SCL保持高電平
ACK=1;
ACK=0;
SCL_OUT=0;
return (ACK);
void IIC_Ack() //主機向從機應答,發送繼續信號
TRISC4=0;
TRISC5=0;
SDA_OUT=0;
SCL_OUT=0;
SCL_OUT=1;
nop(); //大于4us
SCL_OUT=0;
SDA_OUT=1;
void IIC_NOAck() //主機向從機非應答,停止繼續讀取
TRISC4=0;
TRISC5=0;
SDA_OUT=1;
SCL_OUT=0;
SCL_OUT=1;
nop();
SCL_OUT=0;
SDA_OUT=0;
void IIC_Write_Byte(uchar dat) //發送一個字節
uchar bitcount=8;
do
TRISC4=0;
TRISC5=0;
if((dat&0x80)==0x80) //dat最高位為1,SDA拉高;dat最高位為0,SDA拉低
SDA_OUT=1;
SDA_OUT=0;
SCL_OUT=0;
SCL_OUT=1;
nop();
SCL_OUT=0; //SCL為低電平時,允許SDA電平變化
dat=dat<<1;
bitcount--;
}while(bitcount);
TRISC4=1;
nop();nop();
uchar IIC_Read_Byte() //接受一個字節
uchar temp1=0;
uchar bitcount1=8;
TRISC4=1; //SDA設置為輸入
TRISC5=0;
do
SCL_OUT=0;
SCL_OUT=1;
nop();
if(SDA_IN)
temp1=temp1|0x01; //如果SDA為1,則置高temp1最低位
temp1=temp1&0xfe; //如果SDA為0,則置低temp1最低位
SCL_OUT=0;
if(bitcount1-1)
temp1=temp1<<1;
bitcount1--;
}while(bitcount1);
return (temp1);
................................PCF8563子程序.......................................
#include
#include "PCF8563.h"
#include "IIC.h"
struct DownCounter dcounter;
struct Time time;
uchar Val2BCD(uchar x) //十進制轉BCD碼子程序
return ((x/10)<<4)+((x)&0x0F);
uchar PCF8563_Write_Bytes(uchar addr,uchar length,uchar *pbuf) //寫入子程序
uchar send_da;
uchar i=0;
start();
IIC_Write_Byte(0xA2); //器件地址
do
}while(IIC_Get_Ack());
IIC_Write_Byte(0x02); //器件讀取起始位
do
for(i=0;i
send_da=*(pbuf++);
IIC_Write_Byte(send_da);
do
stop();
nop();nop();
uchar PCF8563_Read_Bytes(uchar addr,uchar length,uchar *pbuf) //PCF8563讀取子程序
uint receive_da;
uchar i=0;
start();
IIC_Write_Byte(0xa2); //器件地址
do
IIC_Write_Byte(0x02); //最小地址
do
start();
IIC_Write_Byte(0xa3); //器件讀取地址
do
TRISC4=0;
while(length--)
receive_da=IIC_Read_Byte();
*(pbuf++)=receive_da;
IIC_Ack();
IIC_NOAck();
stop();
nop();nop();nop();nop();nop();nop();
return pbuf[i];
uchar P8563_Read_Time() //PCF8563讀取時間子程序
uchar temp[7];
PCF8563_Read_Bytes(0x02,0x07,temp);
time.second=BCD2Val(temp[0]&0x7f);
time.minute=BCD2Val(temp[1]&0x7f);
time.hour=BCD2Val(temp[2]&0x1f);
time.day=BCD2Val(temp[3]&0x3f);
time.week=BCD2Val(temp[4]&0x07);
time.month=BCD2Val(temp[5]&0x1f);
time.year=BCD2Val(temp[6]);
return 0;
uchar BCD2Val(uchar x) //BCD轉十進制
return ((x>>4)&0x0f)*10+(x&0x0f);
uchar P8563_Set_Time() //PCF8563設置時間子程序
uchar temp[7];
uchar i;
for(i=0;i<7;i++)
temp[i]=Val2BCD(((uchar *)(&time))[i]);
return PCF8563_Write_Bytes(0x02,7,temp);
uchar P8563_Set_DownCounter()
return PCF8563_Write_Bytes(0x0e,2,(uchar *)&dcounter);
uchar P8563_Read_DownCounter()
return PCF8563_Read_Bytes(0x0e,2,(uchar *)&dcounter);
