查看: 6854|回復: 12
光立方代碼
ID:60736 發表于 2014-4-16 09:35 | 顯示全部樓層 |閱讀模式
#include<STC12C5A60S2.h>
sbit keyamenu=P4^4;//按鍵
sbit keyout=P4^5;
sbit keymenu=P4^6;
uint code tab_water[]={
0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0080,0x0140,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,
0x0000,0x0000,0x0000,0x0000,0x0000,0x0080,0x0140,0x0220,0x0140,0x0080,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,
0x0000,0x0000,0x0000,0x0000,0x01c0,0x0220,0x0410,0x0410,0x0410,0x0220,0x01c0,0x0000,0x0000,0x0000,0x0000,0x0000,
0x0000,0x0000,0x0000,0x03e0,0x0410,0x0808,0x0808,0x0808,0x0808,0x0808,0x0410,0x03e0,0x0000,0x0000,0x0000,0x0000,
0x0000,0x0000,0x07f0,0x0808,0x1004,0x1004,0x1004,0x1004,0x1004,0x1004,0x1004,0x0808,0x07f0,0x0000,0x0000,0x0000,
0x0000,0x0ff8,0x1004,0x2002,0x2002,0x2002,0x2002,0x2002,0x2002,0x2002,0x2002,0x2002,0x1004,0x0ff8,0x0000,0x0000,
0x1ffc,0x2002,0x4001,0x4001,0x4001,0x4001,0x4001,0x4001,0x4001,0x4001,0x4001,0x4001,0x4001,0x2002,0x1ffc,0x0000
char code tab00[]={7,7,7,7,7,7,7,7,6,5,4,3,2,1,0,0,0,0,0,0,0,0,1,2,3,4,5,6,//28
         8+6,8+6,8+6,8+6,8+6,8+6,8+5,8+4,8+3,8+2,8+1,8+1,8+1,8+1,8+1,8+1,8+2,8+3,8+4,8+5,//20
         16+5,16+5,16+5,16+5,16+4,16+3,16+2,16+2,16+2,16+2,16+3,16+4,//12
       24+4,24+4,24+3,24+3,//24+4
       32+4,32+4,32+3,32+3,
         40+5,40+5,40+5,40+5,40+4,40+3,40+2,40+2,40+2,40+2,40+3,40+4,//12
         48+6,48+6,48+6,48+6,48+6,48+6,48+5,48+4,48+3,48+2,48+1,48+1,48+1,48+1,48+1,48+1,48+2,48+3,48+4,48+5,//20
       56+7,56+7,56+7,56+7,56+7,56+7,56+7,56+7,56+6,56+5,56+4,56+3,56+2,56+1,56+0,56+0,56+0,56+0,56+0,56+0,56+0,56+0,56+1,56+2,56+3,56+4,56+5,56+6//28
char code tab10[]={56+7,56+7,56+7,56+7,56+7,56+7,56+7,56+7,56+6,56+5,56+4,56+3,56+2,56+1,56+0,56+0,56+0,56+0,56+0,56+0,56+0,56+0,56+1,56+2,56+3,56+4,56+5,56+6,//56+28
       7,7,7,7,7,7,7,7,6,5,4,3,2,1,0,0,0,0,0,0,0,0,1,2,3,4,5,6//28
char code tab01[]={7,6,5,4,3,2,1,0,0,0,0,0,0,0,0,1,2,3,4,5,6,7,7,7,7,7,7,7,//28
       6,5,4,3,2,1,1,1,1,1,1,2,3,4,5,6,6,6,6,6,//20
       5,4,3,2,2,2,2,3,4,5,5,5,//12
       4,3,3,4,//
      4,3,3,4,
uchar code tab_print[]={//打印函數使用
0X00,0X00,0X81,0XFF,0XFF,0X81,0X00,0X00,//I
0X1C,0X3E,0X7E,0XFC,0XFC,0X7E,0X3E,0X1C,//心
0X3F,0X7F,0X80,0X80,0X80,0X80,0X7F,0X3F,//U
0X3C,0X42,0X14,0XA1,0XA1,0X14,0X42,0X3C,//笑臉
0X00,0X73,0XE9,0X89,0X89,0X8F,0X4F,0X00,//5
0X00,0XC6,0X86,0X89,0X99,0XB1,0XE7,0XC6,//2
0X3C,0X7E,0X81,0X81,0X81,0X7E,0X3C,0X00,//0
0X00,0X00,0X3C,0X3C,0X3C,0X3C,0X00,0X00,//正方形
0X20,0X30,0X38,0X3C,0X3C,0X38,0X30,0X20,//三角形
0X08,0X14,0X22,0X77,0X14,0X14,0X14,0X1C,//箭頭
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,//全亮
0X00,0X00,0X80,0XFF,0XFF,0X82,0X00,0X00,//1
0X00,0X76,0XFF,0X89,0X89,0X81,0XC2,0X00,//3
0X20,0XA0,0XFF,0XFF,0XA3,0X22,0X3C,0X30//4
char code tab_mian[]={4,3,7,2,0,6,1,5};
char code tab_xian[]={5,0,3,6,1,7,4,2};
char code tab_dian[]={
0,1,3,4,7,2,6,5,
1,7,5,0,4,2,3,6,
1,6,4,0,7,5,2,3,
5,7,4,2,0,1,6,3,
1,6,3,4,5,2,0,7,
6,7,1,5,4,2,0,3,
2,0,3,1,5,7,6,4,
5,2,1,0,3,6,7,4,
0,7,4,3,2,6,5,1,
4,7,2,6,5,3,1,0,
0,1,4,3,2,5,6,7,
3,6,7,2,1,4,0,5,
5,2,1,0,7,6,4,3,
1,4,0,2,3,5,7,6,
4,2,1,5,6,0,7,3,
0,4,7,3,1,5,2,6,
1,0,6,7,4,5,3,2,
6,0,4,2,7,5,1,3,
3,1,2,6,7,5,0,4,
2,4,1,0,6,5,3,7,
6,2,1,5,7,4,3,0,
1,0,5,3,2,6,7,4,
7,1,0,4,2,5,6,3,
6,4,1,0,2,5,7,3,
2,6,7,0,3,5,1,4,
6,3,7,2,1,4,5,0,
7,0,5,6,1,3,4,2,
5,2,3,4,0,7,1,6,
2,3,0,7,6,4,1,5,
1,3,0,4,5,2,7,6,
3,4,2,5,6,0,1,7,
4,2,0,6,3,7,5,1,
4,1,6,0,7,3,2,5,
7,6,0,5,1,4,2,3,
6,1,3,2,7,0,5,4,
2,7,3,6,0,5,1,4,
6,5,2,1,0,3,7,4,
7,1,0,5,4,6,3,2,
1,7,3,2,6,0,5,4,
0,2,6,7,4,3,5,1,
0,5,4,1,6,3,2,7,
0,1,5,4,7,2,3,6,
1,4,2,3,5,7,6,0,
2,7,0,5,6,1,3,4,
2,1,6,0,4,5,3,7,
6,1,5,4,2,7,3,0,
4,0,5,2,1,6,7,3,
1,2,0,6,3,7,4,5,
5,0,1,2,4,3,7,6,
4,2,0,6,7,5,1,3,
2,3,7,4,6,1,0,5,
1,5,7,0,3,4,2,6,
2,7,6,3,5,1,0,4,
4,5,7,0,2,3,1,6,
0,5,7,3,2,1,6,4,
6,4,5,7,1,0,3,2,
1,6,5,7,0,2,3,4,
2,1,5,3,6,4,0,7,
0,6,5,4,3,7,0,2,
6,4,2,0,3,1,5,7,
4,5,7,6,0,3,1,2,
0,3,7,2,1,5,6,4,
5,2,4,0,1,3,7,2,
4,5,3,1,7,0,2,6
uchar code tab_shandian[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//1
0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//2
0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//3
0x0f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//4
0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x1f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//5
0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,
0x3f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//6
0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,
0x7f,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//7
0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//8
0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,
0xff,0x80,0x00,0x00,0x00,0x00,0x00,0x00,//9
0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,
0xff,0x80,0x80,0x00,0x00,0x00,0x00,0x00,//10
0x00,0x00,0x01,0x01,0x01,0x01,0x00,0x00,
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//11
0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,
0x01,0x00,0x00,0x80,0x00,0x00,0x00,0x00,
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//12
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//13
0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x00,
0x01,0x00,0x00,0x80,0x80,0x00,0x00,0x00,
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//14
0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,
0x01,0x00,0x00,0x80,0x80,0x80,0x00,0x00,
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//15
0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x03,
0x01,0x01,0x01,0x00,0x00,0x80,0x00,0x00,
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//16
0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x07,
0x00,0x00,0x01,0x00,0x00,0x80,0x00,0x00,
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//17
0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x0f,
0x00,0x00,0x01,0x00,0x00,0x80,0x80,0x00,
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//18
0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x1f,
0x00,0x00,0x01,0x01,0x01,0x01,0x80,0x00,
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//19
0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x3f,
0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x00,
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//20
0x00,0x00,0x00,0x00,0x00,0x01,0x81,0x7f,
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//21
0x00,0x00,0x00,0x00,0x00,0x01,0x81,0xff,
0xff,0x80,0x80,0x80,0x00,0x00,0x00,0x00,//22
uchar code yc_table[]={//2幀,yinchu函數使用
0x00,0x00,0x00,0x3c,0x3c,0x00,0x00,0x00,//1I
0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,
0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,//2心臟
0x00,0x00,0x18,0x7e,0x7e,0x18,0x00,0x00,
0x00,0x00,0x3c,0x7e,0x7e,0x3c,0x00,0x00,
0x00,0x18,0x7e,0xff,0xff,0x7e,0x18,0x00,
0x00,0x00,0x7e,0xff,0xff,0x7e,0x00,0x00,
0x00,0x00,0x00,0x66,0x66,0x00,0x00,0x00,
0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,//3U
0x00,0x00,0x00,0x24,0x24,0x00,0x00,0x00,//4蘋果
0x00,0x00,0x00,0x7e,0x7e,0x00,0x00,0x00,
0x00,0x00,0x3c,0xff,0x7e,0x3c,0x00,0x00,
0x00,0x00,0x3c,0xfe,0xfe,0x3c,0x00,0x00,
0x00,0x00,0x00,0x6e,0x66,0x00,0x00,0x00,
0x00,0x00,0x00,0x18,0x10,0x00,0x00,0x00,
0x00,0x00,0x00,0x0c,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//5五角星
0x00,0x00,0x00,0x22,0x22,0x00,0x00,0x00,
0x00,0x00,0x00,0x36,0x36,0x00,0x00,0x00,
0x00,0x00,0x00,0x1c,0x1c,0x00,0x00,0x00,
0x00,0x00,0x00,0x3e,0x3e,0x00,0x00,0x00,
0x00,0x00,0x00,0x7f,0x7f,0x00,0x00,0x00,
0x00,0x00,0x00,0x08,0x08,0x00,0x00,0x00
uchar code tab_xuanzhuantiao[]=//旋轉條
0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,
0x00,0x01,0x06,0x08,0x10,0x60,0x80,0x00,
0x00,0x00,0x01,0x0e,0x70,0x80,0x00,0x00,
0x00,0x00,0x00,0x0f,0xf0,0x00,0x00,0x00,
0x00,0x00,0x00,0xf0,0x0f,0x00,0x00,0x00,
0x00,0x00,0x80,0x70,0x0e,0x01,0x00,0x00,
0x00,0x80,0x60,0x10,0x08,0x06,0x01,0x00,//
0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01,//1
0x40,0x20,0x20,0x10,0x08,0x04,0x04,0x02,
0x20,0x10,0x10,0x10,0x08,0x08,0x08,0x04,
0x10,0x10,0x10,0x10,0x08,0x08,0x08,0x08,
0x08,0x08,0x08,0x08,0x10,0x10,0x10,0x10,
0x04,0x08,0x08,0x08,0x10,0x10,0x10,0x20,
0x02,0x04,0x04,0x08,0x10,0x20,0x20,0x40//7
uchar code flash0__tab[]=
0X03,0X07,0X06,0X08,0X10,0X20,0X40,0X80,
0X07,0X07,0X0F,0X1C,0X18,0X20,0X40,0X80,
0X0F,0X0F,0X1F,0X3F,0X3C,0X78,0X60,0X80,
0X1F,0X1F,0X3F,0X3F,0X7F,0X7C,0X70,0X80,
0X3F,0X3F,0X3F,0X7F,0X7F,0X7F,0XF8,0XC0,
0X7F,0X7F,0X7F,0X7F,0XFF,0XFF,0XFF,0XF0,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF//7
uchar code tab_xuanzhuantiao2[]=//旋轉條
0X01,0X02,0X04,0X08,0X10,0X20,0X40,0X80,//1
0X02,0X04,0X08,0X00,0X10,0X20,0X40,0X80,//
0X04,0X08,0X00,0X10,0X20,0X20,0X40,0X80,//
0X08,0X10,0X10,0X20,0X20,0X40,0X40,0X80,//
0X10,0X10,0X20,0X20,0X20,0X40,0X40,0X80,//
0X20,0X20,0X40,0X40,0X40,0X80,0X80,0X80,//
0X40,0X40,0X40,0X40,0X80,0X80,0X80,0X80,//
0X80,0X80,0X80,0X80,0X80,0X80,0X80,0X80,//8
0X80,0X80,0X80,0X80,0X40,0X40,0X40,0X40,//
0X80,0X80,0X00,0X40,0X40,0X40,0X20,0X20,//10
0X80,0X80,0X40,0X40,0X20,0X20,0X10,0X10,//
0X80,0X40,0X40,0X20,0X20,0X10,0X10,0X08,//
0X80,0X40,0X20,0X20,0X10,0X10,0X08,0X04,//
0X80,0X40,0X20,0X10,0X08,0X08,0X04,0X02,//
0X80,0X40,0X20,0X10,0X08,0X04,0X02,0X01,//15
0X80,0X40,0X20,0X10,0X0C,0X02,0X01,0X00,//16
0X80,0X40,0X30,0X0C,0X02,0X01,0X00,0X00,//
0X80,0X60,0X18,0X06,0X01,0X00,0X00,0X00,//18
0XC0,0X30,0X0E,0X01,0X00,0X00,0X00,0X00,//
0XE0,0X1C,0X03,0X00,0X00,0X00,0X00,0X00,//20
0XF0,0X0F,0X00,0X00,0X00,0X00,0X00,0X00,//
0XFF,0X00,0X00,0X00,0X00,0X00,0X00,0X00,//22
0X0F,0XF0,0X00,0X00,0X00,0X00,0X00,0X00,//23
0X07,0X38,0XC0,0X00,0X00,0X00,0X00,0X00,
0X03,0X0C,0X20,0XC0,0X00,0X00,0X00,0X00,
0X01,0X02,0X0C,0X30,0XC0,0X00,0X00,0X00,
0X01,0X02,0X04,0X08,0X30,0XC0,0X00,0X00,
0X01,0X02,0X04,0X08,0X10,0X60,0X80,0X00,
0X01,0X02,0X04,0X08,0X10,0X20,0X20,0X40,
0X01,0X02,0X04,0X08,0X08,0X10,0X20,0X20,
0X01,0X02,0X04,0X04,0X08,0X08,0X10,0X10,
0X01,0X01,0X02,0X02,0X04,0X04,0X08,0X08,
0X01,0X01,0X01,0X02,0X02,0X02,0X04,0X04,
0X01,0X01,0X01,0X01,0X02,0X02,0X02,0X02,
0X01,0X01,0X01,0X01,0X01,0X01,0X01,0X01,//36
0X02,0X02,0X02,0X02,0X01,0X01,0X01,0X01,//37
0X04,0X04,0X02,0X02,0X02,0X01,0X01,0X01,
0X08,0X08,0X04,0X04,0X02,0X02,0X01,0X01,
0X10,0X10,0X08,0X08,0X04,0X04,0X02,0X01,
0X20,0X10,0X00,0X08,0X08,0X04,0X02,0X01,
0X40,0X20,0X10,0X08,0X08,0X04,0X02,0X01,
0X00,0X80,0X40,0X20,0X18,0X04,0X02,0X01,
0X00,0X00,0X80,0X40,0X38,0X04,0X02,0X01,
0X00,0X00,0X00,0X80,0X60,0X1C,0X02,0X01,
0X00,0X00,0X00,0X00,0X80,0X70,0X0E,0X01,
0X00,0X00,0X00,0X00,0X00,0XC0,0X3C,0X03,
0X00,0X00,0X00,0X00,0X00,0X00,0XF0,0X0F,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0XFF,//50
0X00,0X00,0X00,0X00,0X00,0X00,0X0F,0XF0,//51
0X00,0X00,0X00,0X00,0X00,0X03,0X1C,0XE0,
0X00,0X00,0X00,0X00,0X03,0X0C,0X30,0XC0,
0X00,0X00,0X00,0X01,0X06,0X18,0X20,0XC0,
0X00,0X00,0X01,0X02,0X0C,0X30,0X40,0X80,
0X00,0X01,0X02,0X04,0X18,0X20,0X40,0X80,
//0X01,0X02,0X04,0X08,0X10,0X20,0X40,0X80//57
uchar code bianxing_table[]={//變形
0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,//1
0x00,0x01,0x06,0x08,0x10,0x60,0x80,0x00,//2
0x00,0x00,0x01,0x0e,0x70,0x80,0x00,0x00,//3
0X00,0X00,0X00,0X0F,0XF0,0X00,0X00,0X00,
0X00,0X00,0X00,0X0F,0XF0,0X00,0X00,0X00,//4變形開始
0X00,0X00,0X00,0X0F,0X00,0XF0,0X00,0X00,
0X00,0X00,0X0F,0X00,0XF0,0X00,0X00,0X00,
0X00,0X00,0X0F,0X00,0XF0,0X00,0X00,0X00,//5
0X00,0X00,0X0f,0X0F,0Xf0,0XF0,0X00,0X00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//6
0X00,0X00,0X0F,0X0f,0XF0,0Xf0,0X00,0X00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//7
0x00,0x00,0x1e,0x1e,0x78,0x78,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//8
0x00,0x00,0x3c,0x3c,0x3c,0x3c,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//9,方體成型
0x00,0x66,0x66,0x00,0x00,0x66,0x66,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//10
0xc3,0xc3,0x00,0x00,0x00,0x00,0xc3,0xc3,
0xc3,0xc3,0x00,0x00,0x00,0x00,0xc3,0xc3,//11
uchar code y_table[]={//6幀四方塊外軸心旋轉
0x06,0x06,0x00,0x00,0x00,0x00,0x06,0x06,
0xc6,0xc6,0x00,0x00,0x00,0x00,0xc6,0xc6,
0xc0,0xc0,0x00,0x00,0x00,0x00,0xc0,0xc0,
0x03,0x03,0x00,0x00,0x00,0x00,0x03,0x03,
0x63,0x63,0x00,0x00,0x00,0x00,0x63,0x63,
0x60,0x60,0x00,0x00,0x00,0x00,0x60,0x60,//2
0x0c,0x0c,0x00,0x00,0x00,0x00,0x0c,0x0c,
0x0c,0x0c,0x00,0x00,0x00,0x00,0x03,0x03,
0x30,0x30,0x00,0x00,0x00,0x00,0x30,0x30,
0x30,0x30,0x00,0x00,0x00,0x00,0x30,0x30,//3
0x18,0x18,0x00,0x00,0x00,0x00,0x18,0x18,
0x18,0x18,0x00,0x00,0x00,0x00,0x18,0x18,//4
0x0c,0x0c,0x00,0x00,0x00,0x00,0x0c,0x0c,//5
0x06,0x06,0x00,0x00,0x00,0x00,0x06,0x06//6
uchar code z_table[]=
0x60,0x63,0x03,0x00,0x00,0xc0,0xc6,0x06,
0x60,0x63,0x03,0x00,0x00,0xc0,0xc6,0x06,//2
0x30,0x30,0x03,0x03,0xc0,0xc0,0x0c,0x0c,
0x30,0x30,0x03,0x03,0xc0,0xc0,0x0c,0x0c,//3
0x18,0x18,0x00,0xc3,0xc3,0x00,0x18,0x18,
0x18,0x18,0x00,0xc3,0xc3,0x00,0x18,0x18,//4
0x0c,0x0c,0xc0,0xc0,0x03,0x03,0x30,0x30,
0x0c,0x0c,0xc0,0xc0,0x03,0x03,0x30,0x30,//5
0x06,0xc6,0xc0,0x00,0x00,0x03,0x63,0x60,
0x06,0xc6,0xc0,0x00,0x00,0x03,0x63,0x60,//6
uchar code xz_table[]=
0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0xc3,
0xc3,0xc3,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xc3,0xc3,0x00,0x00,0x00,0xc3,0xc3,
0x00,0xc3,0xc3,0x00,0x00,0x00,0x00,0x00,//1
0x00,0x00,0xc3,0xc3,0x00,0x00,0x00,0x00,
0x00,0x00,0xc3,0xc3,0x00,0x00,0x00,0x00,//2
0x00,0x00,0x00,0xc3,0xc3,0x00,0x00,0x00,
0x00,0x00,0x00,0xc3,0xc3,0x00,0x00,0x00,//3
0x00,0x00,0x00,0x00,0xc3,0xc3,0x00,0x00,
0x00,0x00,0x00,0x00,0xc3,0xc3,0x00,0x00,//4
0xc3,0xc3,0x00,0x00,0x00,0xc3,0xc3,0x00,
0x00,0x00,0x00,0x00,0x00,0xc3,0xc3,0x00,//5
0xc3,0xc3,0x00,0x00,0x00,0x00,0xc3,0xc3,//6
0x00,0xc3,0xc3,0x00,0x00,0x00,0x00,0x00,//7
0x00,0x00,0xc3,0xc3,0x00,0x00,0x00,0x00,//8
0x00,0x00,0x00,0xc3,0xc3,0x00,0x00,0x00,//9
0x00,0x00,0x00,0x00,0xc3,0xc3,0x00,0x00,//10
0x00,0x00,0x00,0x00,0x00,0xc3,0xc3,0x00,//11
0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0xc3,//12
0x00,0x00,0x00,0x00,0x00,0x00,0xff,0xff,
0x00,0x00,0x00,0x00,0x00,0x00,0xff,0xff,//13
0x00,0x00,0x00,0x00,0x00,0x00,0xff,0xff,//14
0x00,0x00,0x00,0x00,0x00,0xc0,0xff,0x3f,
0x00,0x00,0x00,0x00,0x00,0xc0,0xff,0x3f,//15
0x00,0x00,0x00,0x00,0xc0,0xc0,0x3f,0x3f,
0x00,0x00,0x00,0x00,0xc0,0xc0,0x3f,0x3f,//16
0x00,0x00,0x00,0xc0,0xc0,0x00,0x3f,0x3f,
0x00,0x00,0x00,0xc0,0xc0,0x00,0x3f,0x3f,//17
0x00,0x00,0xc0,0xc0,0x00,0x00,0x3f,0x3f,
0x00,0x00,0xc0,0xc0,0x00,0x00,0x3f,0x3f,//18
0x00,0xc0,0xc0,0x00,0x00,0x00,0x6f,0x6f,
0x00,0xc0,0xc0,0x00,0x00,0x00,0x6f,0x6f,//19
0xc0,0xc0,0x00,0x00,0x00,0x00,0xcf,0xcf,
0xc0,0xc0,0x00,0x00,0x00,0x00,0xcf,0xcf,//20
0x60,0x60,0x00,0x00,0x00,0xc0,0xcf,0x0f,
0x60,0x60,0x00,0x00,0x00,0xc0,0xcf,0x0f,//21
0x18,0x18,0x00,0x00,0xc0,0xc0,0x0f,0x0f,
0x18,0x18,0x00,0x00,0xc0,0xc0,0x0f,0x0f,//22
0x18,0x18,0x00,0xc0,0xc0,0x00,0x0f,0x0f,
0x18,0x18,0x00,0xc0,0xc0,0x00,0x0f,0x0f,//23
0x0c,0x0c,0xc0,0xc0,0x00,0x00,0x1b,0x1b,
0x0c,0x0c,0xc0,0xc0,0x00,0x00,0x1b,0x1b,//24
0x06,0xc6,0xc0,0x00,0x00,0x00,0x33,0x33,
0x06,0xc6,0xc0,0x00,0x00,0x00,0x33,0x33,//25
0x03,0xc3,0xc0,0x00,0x00,0x00,0x63,0x63,
0x03,0xc3,0xc0,0x00,0x00,0x00,0x63,0x63,//26
uchar code yx_table[]={//Y軸心切換至X軸心變形
0xcc,0xcc,0x00,0x00,0x00,0x00,0xcc,0xcc,
0xd8,0xd8,0x00,0x00,0x00,0x00,0xd8,0xd8,
0xf0,0xf0,0x00,0x00,0x00,0x00,0xf0,0xf0,
0xf3,0xf3,0x00,0x00,0x00,0x00,0xf3,0xf3,
0x06,0x06,0x00,0x00,0x00,0x00,0x06,0x06,//6
0x03,0x03,0x00,0x00,0x00,0x00,0x03,0x03,//7
0xf6,0xf6,0x00,0x00,0x00,0x00,0xf6,0xf6,
0xfc,0xfc,0x00,0x00,0x00,0x00,0xfc,0xfc,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//11
0xff,0xff,0x00,0x00,0x00,0x00,0xff,0xff,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//12
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//13
0xff,0xff,0xc3,0xc3,0xc3,0xc3,0xff,0xff,//完成
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//14
0xc3,0xc3,0xc3,0xc3,0xc3,0xc3,0xc3,0xc3,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//15
0x00,0x00,0xc3,0xc3,0xc3,0xc3,0xc3,0xc3,
0xff,0xff,0xc3,0xc3,0xc3,0xc3,0xc3,0xc3,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//16
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//17
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//18
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//19
0x00,0xc3,0xc3,0x00,0xc3,0xc3,0xc3,0xc3,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//20
0xc3,0xc3,0x00,0x00,0xc3,0xc3,0xc3,0xc3,
0xc3,0xc3,0x00,0x00,0x00,0x00,0x00,0x00,//21
0x00,0x00,0x00,0x00,0xc3,0xc3,0xc3,0xc3,
0x00,0xc3,0xc3,0x00,0x00,0x00,0x00,0x00,//22
0x00,0x00,0xc3,0xc3,0x00,0x00,0x00,0x00,//23
0x00,0x00,0x00,0xc3,0xc3,0x00,0xc3,0xc3,
0x00,0x00,0x00,0xc3,0xc3,0x00,0x00,0x00,//24
0x00,0x00,0xc3,0xc3,0x00,0x00,0xc3,0xc3,
0x00,0x00,0x00,0x00,0xc3,0xc3,0x00,0x00,//25
0x00,0x00,0x00,0x00,0x00,0xc3,0xc3,0x00,//26
uchar code x_table[]={//四方塊X軸心旋轉
0x00,0x00,0xc3,0xc3,0x00,0x00,0x00,0x00,//3
0x00,0x00,0x00,0xc3,0xc3,0x00,0x00,0x00,//4
0x00,0x00,0x00,0x00,0xc3,0xc3,0x00,0x00,//5
0x00,0x00,0x00,0x00,0x00,0xc3,0xc3,0x00,//6
uchar code tab_rain[]={//rain
0X00,0X84,0X01,0X00,0X00,0X01,0X02,0X44,
0X84,0X00,0X24,0X08,0X04,0X20,0X80,0X00,
0X00,0X20,0X00,0X00,0X20,0X00,0X40,0X00,
0X00,0X04,0X00,0X40,0X00,0X00,0X08,0X00,
0X40,0X00,0X10,0X00,0X00,0X04,0X04,0X11,
0X00,0X41,0X00,0X00,0X80,0X00,0X40,0X00,
0X00,0X00,0X00,0X24,0X01,0X18,0X00,0X00,
0X22,0X10,0X02,0X00,0X40,0X00,0X02,0X00
uchar code sin_cube_table[]={//14幀
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xff,
0x00,0x00,0x00,0x00,0x00,0x00,0xff,0x00,
0xff,0x00,0x00,0x00,0x00,0xff,0x00,0x00,
0x00,0xff,0x00,0x00,0xff,0x00,0x00,0x00,
0x00,0x00,0xff,0xff,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xff,0x00,0x00,
0x00,0x00,0x00,0x00,0xff,0x00,0x00,0x00,
0xff,0x00,0x00,0xff,0x00,0x00,0x00,0x00,
0x00,0xff,0xff,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xff,0x00,0x00,0x00,0x00,
0x00,0x00,0xff,0x00,0x00,0x00,0x00,0x00,
0xff,0xff,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xff,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xff,0xff,0x00,
0x00,0x00,0x00,0x00,0xff,0x00,0x00,0xff,
0x00,0x00,0x00,0x00,0xff,0xff,0x00,0x00,
0x00,0x00,0x00,0xff,0x00,0x00,0xff,0x00,
0x00,0x00,0xff,0x00,0x00,0x00,0x00,0xff,
0x00,0x00,0x00,0xff,0xff,0x00,0x00,0x00,
0x00,0x00,0xff,0x00,0x00,0xff,0x00,0x00,
0x00,0xff,0x00,0x00,0x00,0x00,0xff,0x00,
0xff,0x00,0x00,0x00,0x00,0x00,0x00,0xff,
uchar code hart_table[]={//2幀心跳
0x00,0x00,0x18,0x00,0x00,0x00,0x00,0x00,
0x00,0x18,0x3c,0x18,0x00,0x00,0x00,0x00,
0x00,0x3c,0x7e,0x3c,0x18,0x00,0x00,0x00,
0x00,0x18,0x7e,0x18,0x00,0x00,0x00,0x00,
0x00,0x00,0x24,0x00,0x00,0x00,0x00,0x00,
uchar code szfc_table[]={//數字浮出
0X38,0X64,0X06,0X3E,0X66,0X66,0X24,0X18,//9
0X3C,0X66,0X66,0X3C,0X66,0X66,0X24,0X18,//8
0X30,0X30,0X30,0X18,0X0C,0X04,0X46,0X7E,//7
0X18,0X26,0X66,0X78,0X60,0X66,0X24,0X18,//6
0X18,0X64,0X46,0X06,0X1C,0X60,0X62,0X7E,//5
0X0C,0X0C,0X7E,0X68,0X6C,0X2C,0X3C,0X1C,//4
0x78,0x46,0x06,0x06,0x1c,0x06,0x46,0x3c,//3
0xfc,0xc0,0x60,0x30,0x18,0xc6,0xc6,0x78,//2
0x3c,0x18,0x18,0x18,0x18,0x18,0x38,0x18,//1
0X18,0X24,0X66,0X66,0X66,0X66,0X24,0X18,//0
/*音柱編碼*/
uchar code tuku1[]={0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff,0xff};
uchar code table1[]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff/*0X1C,0X3E,0X7E,0XFC,0XFC,0X7E,0X3E,0X1C*/};
uchar code table2[]={
0Xe0,0Xe0,0Xe0,0xe0,0Xe0,0Xe0,0Xe0,0Xe0,
0X07,0X07,0X07,0X07,0X07,0X07,0X07,0X07
/*uchar code table2[]={
0X80,0Xc0,0Xe0,0xf0,0Xf0,0Xe0,0Xc0,0X80,
0X01,0X03,0X07,0X0f,0X0f,0X07,0X03,0X01
uchar code table3[]={
0Xf0,0Xe0,0Xc0,0x80,0X00,0X00,0X00,0X00,
0X03,0X07,0X0e,0x1c,0X38,0X70,0Xe0,0Xc0,
0X00,0X00,0X00,0X00,0X01,0X03,0X07,0X0f
uchar code table4[]={
0Xc0,0Xc0,0X00,0x00,0X00,0X00,0X00,0X00,
0X00,0X00,0X30,0x30,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X0c,0X0c,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X03,0X03
uchar code table5[]={
0X18,0X18,0X00,0x00,0X00,0X00,0X00,0X00,
0X03,0X03,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X03,0X03,0X00,0X00,0X00,
uchar code table6[]={
0x0f,0x0f,0x0f,0x0f,0x00,0x00,0x00,0x00,
0X00,0X00,0X00,0xc0,0Xc0,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0xc0,0Xc0,
0X00,0X00,0X00,0X00,0X00,0X00,0X18,0X18,
uchar code number[]={//數字,滾動字幕使用,從上至下
0x00,0x40,0x40,0x40,0x40,0x40,0x7E,0x00,/*"L",0*/
0x00,0x7E,0x40,0x7E,0x40,0x40,0x7E,0x00,/*"E",1*/
0x00,0x7C,0x46,0x42,0x42,0x46,0x7C,0x00,/*"D",2*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",3*/
0x00,0x3C,0x62,0x40,0x40,0x61,0x3E,0x00,/*"C",4*/
0x00,0x42,0x42,0x42,0x42,0x42,0x3C,0x00,/*"U",5*/
0x00,0x7C,0x42,0x7C,0x42,0x41,0x7E,0x00,/*"B",6*/
0x00,0x7E,0x40,0x7E,0x40,0x40,0x7E,0x00,/*"E",7*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",8*/
0x00,0x42,0x42,0x7E,0x42,0x42,0x42,0x00,/*"H",9*/
0x00,0x42,0x42,0x42,0x42,0x42,0x3C,0x00,/*"U",10*/
0x00,0xC2,0x64,0x38,0x10,0x10,0x10,0x00,/*"Y",11*/
0x00,0x18,0x18,0x24,0x7E,0x42,0x81,0x00,/*"A",12*/
0x00,0x62,0x62,0x52,0x4A,0x46,0x46,0x00,/*"N",13*/
0x00,0x3C,0x62,0x40,0x4E,0x62,0x3E,0x00,/*"G",14*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",15*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",16*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",17*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"Y",18*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",19*/
0x00,0x44,0x44,0x7C,0x44,0x44,0x44,0x00,/*"H",20*/
0x00,0x44,0x44,0x44,0x44,0x44,0x38,0x00,/*"U",21*/
0x00,0x82,0x44,0x28,0x10,0x10,0x10,0x00,/*"Y",22*/
0x00,0x10,0x28,0x28,0x7C,0x44,0x82,0x00,/*"A",23*/
0x00,0x64,0x64,0x54,0x54,0x4C,0x44,0x00,/*"N",24*/
0x00,0x78,0xC4,0x80,0x9C,0xC4,0x7C,0x00,/*"G",25*/
0x00,0x10,0x10,0x10,0x10,0x00,0x10,0x00,/*"!",26*/
0X38,0X64,0X06,0X3E,0X66,0X66,0X24,0X18,//"9"27
0X3C,0X66,0X66,0X3C,0X66,0X66,0X24,0X18,//"8"28
0X30,0X30,0X30,0X18,0X0C,0X04,0X46,0X7E,//"7"29
0X18,0X26,0X66,0X78,0X60,0X66,0X24,0X18,//"6"30
0X18,0X64,0X46,0X06,0X1C,0X60,0X62,0X7E,//"5"31
0X0C,0X0C,0X7E,0X68,0X6C,0X2C,0X3C,0X1C,//"4"32
0x78,0x46,0x06,0x06,0x1c,0x06,0x46,0x3c,//"3"33
0xfc,0xc0,0x60,0x30,0x18,0xc6,0xc6,0x78,//"2"34
0x3c,0x18,0x18,0x18,0x18,0x18,0x38,0x18,//"1"35
0X18,0X24,0X66,0X66,0X66,0X66,0X24,0X18,//"0"36
//0XCC,0XCC,0X44,0X44,0X22,0X22,0X1f,0X00,
   0X66,0X66,0X66,0X7E,0X66,0X66,0X3C,0X18,/*"A",37*/
//0X00,0X99,0X99,0X99,0X99,0X99,0X66,0X00,
0XC3,0XC7,0XCF,0XDF,0XFB,0XF3,0XE3,0XC3,/*"N",38*/
//0X03,0X05,0XF9,0X81,0X81,0XF9,0X05,0X03,
  0X7E,0X62,0X62,0X60,0X60,0X60,0X60,0X60/*"L",39*/
/*音柱編碼*/
uchar code tuku[]={0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};
uchar code BRTable[64] ={ 0,32,16,48,8,40,24,56,4,36,20,52,12,44,28,60,2,34,18,50,10,42,26,58,6,38,22,54,14,46,30,62,1,33,17,49,9,41,25,57,5,37,21,53,13,45,29,61,3,35,19,51,11,43,27,59,7,39,23,55,15,47,31,63};
char code sin_tabb[64] = { 0 ,12 ,25 ,37 ,49 ,60 ,71 ,81 ,90 ,98 ,106 ,112 ,117 ,122 ,125 ,126 ,127 ,126 ,125 ,122 ,117 ,112 ,106 ,98 ,90 ,81 ,71 ,60 ,49 ,37 ,25 ,12 ,0 ,-12 ,-25 ,-37 ,-49 ,-60 ,-71 ,-81 ,-90 ,-98 ,-106 ,-112 ,-117 ,-122 ,-125 ,-126 ,-127 ,-126 ,-125 ,-122 ,-117 ,-112 ,-106 ,-98 ,-90 ,-81 ,-71 ,-60 ,-49 ,-37 ,-25 ,-12  };
char code cos_tabb[64] = {127 ,126 ,125 ,122 ,117 ,112 ,106 ,98 ,90 ,81 ,71 ,60 ,49 ,37 ,25 ,12 ,0 ,-12 ,-25 ,-37 ,-49 ,-60 ,-71 ,-81 ,-90 ,-98 ,-106 ,-112 ,-117 ,-122 ,-125 ,-126 ,-127 ,-126 ,-125 ,-122 ,-117 ,-112 ,-106 ,-98 ,-90 ,-81 ,-71 ,-60 ,-49 ,-37 ,-25 ,-12 ,0 ,12 ,25 ,37 ,49 ,60 ,71 ,81 ,90 ,98 ,106 ,112 ,117 ,122 ,125 ,126 };
char num;
char c[6];//用于存儲5個不同頻率的幅值
char b[6];//用于使音譜柱形顯示的平滑
char amenu,menu,out;
int xdata Real[64];//實部
int xdata Image[64];//虛部
void delay(int t)
int i;
while(t--)
  for(i=0;i<700;i++);
void delay1(int t)
char i;
while(t--)
  for(i=0;i<20;i++);
void clc()//全局清屏
P3=0;
P2=0xff;
P0=0;
P2=0;
uchar daoxu(uchar x)//一字節倒序
uchar k=0;
char i;
for(i=0;i<8;i++)
  if((x>>(7-i))&0x01)
   k|=0x01<<i;
return k;
void key_menu_scan()
if(!keymenu)
  delay(30);//按鍵驅抖
  if(!keymenu)
   P3=0;
   menu++;
   if(menu==4)
    menu=1;
  while(!keymenu);//釋放判斷
void key_amenu_scan()
if(!keyamenu)
  delay(30);//按鍵驅抖
  if(!keyamenu)
   P3=0;
   amenu++;
   if(amenu==7)
    amenu=1;
  while(!keyamenu);//釋放判斷
void key_out_scan()
if(!keyout)
  delay(30);//按鍵驅抖
  if(!keyout)
   P3=0;
   if(!out)
    out=1;
    out=0;
  while(!keyout);//釋放判斷
void fun(uchar *a)//層填充函數
uchar i,p;
p=1;
for(i=0;i<8;i++)
  P2=p;
  P0=a[i];
  P2=0;
  p<<=1;
uchar i,p;
p=0x80;
for(i=0;i<8;i++)
  P2=p;
  P0=a[i];
  P2=0;
  p>>=1;
void fun1(uchar *a,uchar d,uchar b,uchar c,uchar e)//滾動字幕數據處理
char i;
for(i=0;i<8;i++)
  a[i]=e&0x01;
  e>>=1;
a[7]|=(c<<1);
a[6]|=(c&0x80);
for(i=0;i<6;i++)
  a[5-i]|=((b<<(7-i))&0x80);
d=daoxu(d);
a[0]|=((d>>1)&0x7e);
void zhen(uchar *a,uchar v)//一幀,a是一幀編碼起始地址
uchar p;
char i;
while(v--)
  p=1;
  for(i=0;i<8;i++)
   key_out_scan();
   key_amenu_scan();
   key_menu_scan();
   if(amenu)
    break;
   P3=0;
   fun(a+i*8);
   P3=p;
   delay(2);
   p<<=1;
void turn_on(uchar v)
uchar a[64]={0};
char i,j;
a[7]=0x80;
zhen(a,v);
for(i=1;i<8;i++)
  a[i*8+7]=0x80;
  zhen(a,v);
for(i=6;i>=0;i--)
  for(j=0;j<8;j++)
   a[j*8+i]=0x80;
  zhen(a,v);
for(i=0;i<64;i++)
  a[i]=0;
void H_scan(uchar v)
uchar b[64]={0};
char i,j;
for(i=0;i<64;i++)
  b[i]=0x80;
for(i=0;i<7;i++)
  for(j=0;j<64;j++)
   b[j]>>=1;
  zhen(b,v);
void V_scan(uchar v)
uchar a[64]={0};
char i,j;
for(i=0;i<8;i++)
  a[i]=0xff;
zhen(a,v);
for(i=1;i<8;i++)
  for(j=0;j<8;j++)
   a[i*8+j]=0xff;
   a[(i-1)*8+j]=0;
  zhen(a,v);
void jb0(char num,char v)///////////////////////////////
char i,k;
uchar c[64]={0};
for(i=0;i<64;i++)
  c[i]=0x80;
zhen(c,v);
while(num--)
  for(i=0;i<28;i++)
   if(i<7)
    for(k=0;k<8;k++)
     c[k*8]|=(0x80>>(i+1));
     c[k*8+7-i]=0;
   else if(i<14)
    for(k=0;k<8;k++)
     c[k*8+i-6]=0x01;
     c[k*8]>>=0x01;
   else if(i<21)
    for(k=0;k<8;k++)
     c[k*8+i-14]=0;
     c[k*8+7]|=(0x01<<(i-13));
   else if(i<28)
    for(k=0;k<8;k++)
     c[k*8+27-i]=0x80;
     c[k*8+7]<<=1;
   zhen(c,v);
clc();
void link_pingmian1(char v)
uchar a[64]={0};
char i,j;
for(i=0;i<8;i++)
  for(j=0;j<8;j++)
   a[7*8+j]|=(0x01<<i);
   zhen(a,v);
void pingmian1(char num,char v)
char i,k;
uchar a[64]={0};
for(i=0;i<8;i++)
  a[7*8+i]=0xff;
zhen(a,v);
while(num--)
  for(i=0;i<28;i++)
   if(i<7)
    for(k=0;k<8;k++)
     a[(6-i)*8+k]=0x01;
     a[7*8+k]>>=1;
   else if(i<14)
    for(k=0;k<8;k++)
     a[k]|=0x01<<(i-6);
     a[(14-i)*8+k]=0;
   else if(i<21)
    for(k=0;k<8;k++)
     a[(i-13)*8+k]=0x80;
     a[k]<<=1;
    for(k=0;k<8;k++)
     a[7*8+k]|=0x80>>(i-20);
     a[(i-21)*8+k]=0;
   zhen(a,v);
clc();
void move(uchar *a,char kind,char direction,char length)//length不能為8
//kind=0 x軸,1 x軸,2 z軸;direction=0,負向,1正向
char i,j;
if(kind==0)
  if(direction==1)
   for(i=0;i<64;i++)
    a[i]<<=length;
   for(i=0;i<64;i++)
    a[i]>>=length;
else if(kind==1)
  if(direction==1)
   for(j=0;j<8;j++)
    for(i=7;i>=length;i--)
     a[i+j*8]=a[i-length+j*8];
    for(i=0;i<length;i++)
     a[i+j*8]=0;
   for(j=0;j<8;j++)
     a[i+j*8]=a[i+length+j*8];
    for(i=(8-length);i<8;i++)
     a[i+j*8]=0;
  if(direction==1)
   for(j=0;j<8;j++)
     a[j+i*8]=a[j+(i-length)*8];
     a[j+i*8]=0;
   for(j=0;j<8;j++)
    for(i=0;i<(8-length);i++)
     a[j+i*8]=a[j+(i+length)*8];
     a[j+i*8]=0;
void produce_cube(uchar *a,char n)//0<=n<=8
char i,j;
for(i=0;i<8;i++)
  for(j=0;j<8;j++)
   if(j<n&&i<n)
    a[j+i*8]=0xff>>(8-n);
    a[j+i*8]=0;
void produce_empty(uchar *a,char n)//0<n<=8,注意n不能為0
char j;
uchar p;
for(j=0;j<64;j++)
  a[j]=0;
p=0xff>>(8-n);
/************X4列*************/
a[(n-1)*8+n-1]=p;
a[(n-1)*8]=p;
a[0]=p;
a[n-1]=p;
for(j=0;j<n;j++)
  p=(0x01|(0x01<<(n-1)));
/************豎直4列*************/
  a[j*8]|=p;
  a[j*8+n-1]|=p;
/************Y4列*************/
  a[j]|=p;
  a[(n-1)*8+j]|=p;
void cube(char empty,char kind,char v)
uchar a[64]={0};
char i;
for(i=1;i<=8;i++)//生成
  if(empty==0)
   produce_cube(a,i);
   produce_empty(a,i);
  if(kind==0)
  else if(kind==1)
   move(a,1,1,8-i);
  else if(kind==2)
   move(a,1,1,8-i);
   move(a,0,1,8-i);
   move(a,0,1,8-i);
  zhen(a,v);
for(i=7;i>0;i--)//退出
  if(empty==0)
   produce_cube(a,i);
   produce_empty(a,i);
  if(kind==0)
   move(a,1,1,8-i);
   move(a,0,1,8-i);
  else if(kind==1)
   move(a,0,1,8-i);
  else if(kind==2)
   move(a,1,1,8-i);
  zhen(a,v);
void yinchu(uchar *table,char n,char v)
n為幀數
char i,j,k;
uchar a[64]={0},p;
for(k=0;k<n;k++)
  for(i=0;i<8;i++)
   p=0xff;
   for(j=0;j<64;j++)
    a[j]=(table[j+k*64]|(0x80>>i))&(p<<(7-i));
   zhen(a,v);
  zhen(table+k*64,50);
void rain(char menu,char num,char v)
{//menu=0,up;menu=1,down
uchar a[64]={0};
char i,j;
if(menu==0)
  for(i=0;i<8;i++)
   a[i]=tab_rain[i];
  zhen(a,v);
  for(i=1;i<8;i++)
   move(a,2,1,1);
   for(j=0;j<8;j++)
    a[j]=tab_rain[i*8+j];
   zhen(a,v);
  while(num--)
   for(i=0;i<8;i++)
    move(a,2,1,1);
    for(j=0;j<8;j++)
    zhen(a,v);
  for(i=0;i<8;i++)
   a[7*8+i]=tab_rain[i];
  zhen(a,v);
  for(i=1;i<8;i++)
   move(a,2,0,1);
   for(j=0;j<8;j++)
    a[7*8+j]=tab_rain[i*8+j];
   zhen(a,v);
  while(num--)
   for(i=0;i<8;i++)
    move(a,2,0,1);
    for(j=0;j<8;j++)
     a[j+7*8]=tab_rain[i*8+j];
    zhen(a,v);
void LED()
char i;
uchar p=0x01;
for(i=0;i<8;i++)
  P2=p;
  delay1(1);
  P0=0xff;
  delay1(1);
  p<<=1;
P2=0;
while(!out)
  key_out_scan();
  key_amenu_scan();
  P3=0xff;
  delay1(amenu*30);
  P3=0;
  delay1((6-amenu)*30);
P3=0;
void pc1(char num,char v)
uchar a[64]={0};
char i,j;
while(num--)
  for(i=1;i<8;i++)
   a[i]=0xff;
  zhen(a,v);
  for(i=1;i<8;i++)
   move(a,2,1,1);
   for(j=0;j<8;j++)
    a[j]=0xff;
   zhen(a,v);
  for(i=0;i<8;i++)
   if(num==0&&i==7)
    continue;
   move(a,2,1,1);
   zhen(a,v);
for(i=0;i<7;i++)
  move(a,2,0,1);
  zhen(a,v+5);
void link(char v)
旋轉銜接
char i,j,k;
uchar a[64]={0};
for(i=0;i<64;i++)
  a[i]=0x80;
zhen(a,3);
for(i=0;i<8;i++)
  for(j=0;j<8;j++)
   if(i<7)
    a[j*8+7-i]&=0x7f;
   a[j*8+i]|=(0x80>>i);
  zhen(a,v);
for(i=0;i<6;i++)
  for(j=0;j<8;j++)
   for(k=0;k<8;k++)
    a[j*8+k]=tab_xuanzhuantiao[(i+8)*8+k];
  zhen(a,3);
void leitu(uchar *b,char num,char v)//V>1
uchar a[64]={0},p;
char i,j,k,m;
for(m=0;m<num;m++)
  for(i=0;i<8;i++)
   for(k=0;k<8;k++)
    for(j=0;j<8;j++)
     p=b[m*64+i*8+k]&(0x01<<j);
     if(p)
      a[i*8+k]|=p;
      zhen(a,v);
  zhen(a,60);
  for(j=0;j<64;j++)
   if(!a[j])
    continue;
   a[j]=0;
   zhen(a,v-1);
  delay(30);
void fn(char v)
uchar a[64]={0};
int i;
for(i=0;i<128;i++)//點
  a[tab00[i]]=(0x01<<tab01[i]);
  zhen(a,v);
  a[tab00[i]]=0;
for(i=0;i<128;i++)//8點
  a[tab10[i]]|=(0x01<<tab01[i]);
  if(i>=8)
   a[tab10[i-8]]^=(0x01<<tab01[i-8]);
  zhen(a,v);
a[tab00[0]]|=(0x01<<tab01[0]);
a[0]=0x80;
zhen(a,v);
for(i=1;i<128;i++)//線
  if(i<8)
   a[i-1]=0;
  a[tab00[i]]|=(0x01<<tab01[i]);
  zhen(a,v);
zhen(a,120);
for(i=0;i<128;i++)//線
  a[tab10[i]]^=(0x01<<tab01[i]);
  zhen(a,v);
void xuanzhuantiao(char kind,char num,char v)//空心旋轉,kind=1實心,否則空心
uchar a[64]={0};
char i,j,k;
while(num--)
  for(i=0;i<14;i++)
   for(j=0;j<8;j++)
    for(k=0;k<8;k++)
     if(k>1&&k<6&&j>1&&j<6&&kind!=1)
      a[k+j*8]=tab_xuanzhuantiao[i*8+k]&0xc3;
      a[k+j*8]=tab_xuanzhuantiao[i*8+k];
   zhen(a,v);
void qumianxuanzhuan(char kind,char num,char v)//曲面旋轉
uchar a[64]={0};
char i,j,k;
for(j=0;j<8;j++)
  for(i=0;i<8;i++)
   a[i+j*8]=tab_xuanzhuantiao[i];
zhen(a,v);
if(kind==1)
  for(j=1;j<8;j++)//順時針初形變換
   for(i=0;i<j;i++)
    for(k=0;k<8;k++)
     a[k+i*8]=tab_xuanzhuantiao[(j-i)*8+k];
   zhen(a,v);
  for(i=8;i<14;i++)
   move(a,2,1,1);
   for(j=0;j<8;j++)
    a[j]=tab_xuanzhuantiao[i*8+j];
   zhen(a,v);
  for(j=1;j<8;j++)//逆時針初形變換
   for(i=0;i<j;i++)
    for(k=0;k<8;k++)
     a[k+i*8]=tab_xuanzhuantiao[(14-j+i)*8+k];
   zhen(a,v);
  for(i=7;i>=0;i--)
   move(a,2,1,1);
   for(j=0;j<8;j++)
   zhen(a,v);
while(num--)//主循環
  if(kind==1)
   for(i=0;i<14;i++)
    move(a,2,1,1);
    for(j=0;j<8;j++)
    zhen(a,v);
   for(i=13;i>=0;i--)
    move(a,2,1,1);
    for(j=0;j<8;j++)
    zhen(a,v);
if(kind==1)
  for(j=0;j<7;j++)
   for(i=7;i>=j;i--)
    if(i>j)
     for(k=0;k<8;k++)
      a[k+i*8]=tab_xuanzhuantiao[(14-i+j)*8+k];
     for(k=0;k<8;k++)
      a[k+i*8]=tab_xuanzhuantiao[k];
   zhen(a,v);
  for(j=1;j<7;j++)
   for(i=7;i>=j;i--)
    if(i>j)
     for(k=0;k<8;k++)
      a[k+i*8]=tab_xuanzhuantiao[(i-j)*8+k];
     for(k=0;k<8;k++)
   zhen(a,v);
void qumianxuanzhuan2(char num,char v)//曲面旋轉
uchar a[64]={0};
char i,j,k;
for(j=0;j<8;j++)
  for(i=0;i<8;i++)
zhen(a,v);
for(j=1;j<8;j++)
  for(i=0;i<j;i++)
   for(k=0;k<8;k++)
  zhen(a,v);
while(num--)
  for(j=1;j<8;j++)
   move(a,2,1,1);
   for(i=0;i<j;i++)
    for(k=0;k<8;k++)
     if(j!=7|i!=0)
      a[i*8+k]=tab_xuanzhuantiao[k+(j+7-i)*8];
      a[k]=tab_xuanzhuantiao[k];
   zhen(a,v);
  for(j=1;j<8;j++)
   move(a,2,1,1);
   for(i=0;i<j;i++)
    for(k=0;k<8;k++)
     a[i*8+k]=tab_xuanzhuantiao[k+(14-j+i)*8];
   zhen(a,v);
void W_scan(uchar v)
uchar a[64]={0};
char i,j;
for(i=0;i<8;i++)
  a[i*8+7]=0xff;
zhen(a,v);
for(i=6;i>=0;i--)
  for(j=0;j<8;j++)
   a[j*8+i]=0xff;
   a[j*8+i+1]=0;
  zhen(a,v);
clc();
void zimu(uchar *x,char n,char v,int num)//滾動字幕,num表示循環次數,v表示滾動速度,n字符個數
char i,j,k;
uchar xdata a[64]={0},temp0[8],temp1[8],temp2[8],temp3[8],temp[8];
for(i=0;i<8;i++)
  temp0[i]=0;
  temp1[i]=0;
  temp2[i]=0;
  temp3[i]=0;
while(num--)
  for(j=0;j<n;j++)//滾動
   for(k=7;k>=0;k--)//讀取數據
    temp[7-k]=x[j*8+k];
   for(k=0;k<8;k++)//移動8位
    for(i=0;i<8;i++)
     temp0[i]=(temp0[i]<<1)|(temp1[i]>>7);
     temp1[i]=(temp1[i]<<1)|(temp2[i]>>7);
     temp2[i]=(temp2[i]<<1)|(temp3[i]>>7);
     temp3[i]=(temp3[i]<<1)|(temp[i]>>7);
     temp[i]<<=1;
     fun1(a+i*8,temp0[i],temp1[i],temp2[i],temp3[i]);
    zhen(a,v);
void hy(uchar *tab,char v)
uchar a[64]={0};
char i,j;
for(i=0;i<8;i++)
  a[i*8]=tab[i];
zhen(a,v);
for(i=1;i<8;i++)
     for(j=0;j<8;j++)
      a[i+j*8]=a[i-1+j*8];
     zhen(a,v);
        for(i=0;i<7;i++)
     for(j=0;j<8;j++)
      a[i+j*8]=0;
     zhen(a,v);
        zhen(a,23);
void W_side(uchar *tab,char num,char v)
uchar a[64]={0};
int i,j;
for(j=0;j<num;j++)
  if(amenu)
   break;
  for(i=0;i<8;i++)
   a[i*8+7]=tab[j*8+i];
  zhen(a,v);
void print(uchar *a,char m)//m=0中空顯示,m=1實心顯示
uchar p;
char i,j,k;
uchar b[64]={0};
for(i=0;i<8;i++)
  b[7*8+i]=0xff;
for(i=0;i<8;i++)//行切換
  for(j=0;j<8;j++)//點移動
   p=a[i]&(0x01<<j);
   if(p)
    for(k=6;k>0;k--)
     if(m==1&&k==6)
      b[(k+1)*8+7-i]&=(~p);
     b[k*8+7-i]|=(0x01<<j);
     zhen(b,1);
    b[1*8+7-i]=0;
    b[7-i]|=p;
    zhen(b,1);
   b[7-i]|=p;
zhen(b,40);
b[0]=0;
for(j=7;j>0;j--)
  for(i=7;i>0;i--)
   b[i]=b[i-1];
   zhen(b,5);
clc();
void water1(char x,char y,char v)
uchar a[64]={0};
char i,r;
a[7*8+y]=0x01<<x;
zhen(a,v);
for(i=6;i>=0;i--)
  a[i*8+y]=a[(i+1)*8+y];
  a[(i+1)*8+y]=0;
  zhen(a,v);
}//下落
for(r=0;r<7;r++)
  for(i=0;i<8;i++)
   a[i]=tab_water[r*16+7-y+i]>>(7-x);
  zhen(a,v+1);
}//擴散
void water2(char x1,char y1,char x2,char y2,char v)
uchar a[64]={0};
char i,r;
a[7*8+y1]=0x01<<x1;
zhen(a,v);
for(i=6;i>=0;i--)
  move(a,2,0,1);
  if(i==5)
   a[7*8+y2]=0x01<<x2;
  zhen(a,v);
for(r=0;r<9;r++)
  if(r<2)
   move(a,2,0,1);
   for(i=0;i<8;i++)
    a[i]=tab_water[(r-2)*16+7-y2+i]>>(7-x2);
  if(r<7)
   for(i=0;i<8;i++)
    a[i]|=(tab_water[r*16+7-y1+i]>>(7-x1));
  if(r==1)
   a[y2]|=0x01<<x2;
  zhen(a,v);
void water3(char x1,char y1,char x2,char y2,char x3,char y3,char v)
{//3水滴
uchar a[64]={0};
char i,r;
a[7*8+y1]=0x01<<x1;
zhen(a,v);
for(i=6;i>=0;i--)
  move(a,2,0,1);
  if(i==5)//第二點
   a[7*8+y2]=0x01<<x2;
  if(i==3)
   a[7*8+y3]=0x01<<x3; //第三點
  zhen(a,v);
for(r=0;r<11;r++)
  if(r<4)
   move(a,2,0,1);
  if(r<11&&r>=4)
   for(i=0;i<8;i++)
    a[i]=tab_water[(r-4)*16+7-y3+i]>>(7-x3);
  if(r<9&&r>=2)
   for(i=0;i<8;i++)
    a[i]|=tab_water[(r-2)*16+7-y2+i]>>(7-x2);
  if(r<7)
   for(i=0;i<8;i++)
  if(r==1)
   a[y2]|=0x01<<x2;
  if(r==3)
   a[y3]|=0x01<<x3;
  zhen(a,v);
void xuanzhuantiao2(char num,char v)//空心旋轉,kind=1實心,否則空心
uchar a[64]={0};
char i,j,k;
while(num--)
  for(i=0;i<56;i++)
   for(j=0;j<8;j++)
    for(k=0;k<8;k++)
     a[j*8+k]=tab_xuanzhuantiao2[i*8+k];
   zhen(a,v);
void flash0(char v)//條狀升降
  char i,j,k;
  uchar a[64]={0};
  for(i=7;i>=0;i--)
   a[i]=0x01<<i;
   zhen(a,v+5);
  for(i=0;i<7;i++)
   for(j=0;j<8;j++)
    a[j]=flash0__tab[i*8+j];
   zhen(a,v+5);
  for(i=0;i<7;i++)
   move(a,2,1,1);
   zhen(a,v+5);
/*  for(i=0;i<64;i++)
   if(i>55)
    a[i]=0xff;
    a[i]=0;
  zhen(a,20);
  for(i=7;i>=0;i--)//1
   for(j=6;j>=0;j--)
    a[i+j*8]=0xff;
    a[i+(j+1)*8]=0;
    zhen(a,v);
  zhen(a,27);
  for(i=7;i>=0;i--)//2
   for(j=1;j<8;j++)
    a[i+j*8]=0xff;
    a[i+(j-1)*8]=0;
    zhen(a,v);
  zhen(a,27);
  for(i=7;i>=0;i--)//3
   for(k=6;k>=0;k--)
    for(j=0;j<8;j++)
     if(k==0)
      a[j+k*8]|=(0x80>>(7-i));
      a[j+k*8]=(0x80>>(7-i));
     a[j+(k+1)*8]^=(0x80>>(7-i));
    zhen(a,v);
  zhen(a,27);
  for(i=7;i>=0;i--)//4
   for(k=1;k<8;k++)
    for(j=0;j<8;j++)
     if(k==7)
     a[j+(k-1)*8]^=(0x80>>(7-i));
    zhen(a,v);
  zhen(a,27);
void donghua(uchar *tab,uchar num,uchar n,char v)
char i;
while(n--)
  for(i=0;i<num;i++)//清空
   zhen(tab+i*64,v);
void denghuo(char v)
uchar a[64];
char i,j,k;
for(k=0;k<8;k++)
  for(i=0;i<8;i++)
   for(j=0;j<8;j++)
    a[tab_mian[i]*8+tab_xian[j]]|=(0x01<<tab_dian[(i+j)*8+k]);
    zhen(a,v);
  zhen(a,90);
for(k=0;k<8;k++)
  for(i=0;i<8;i++)
   for(j=0;j<8;j++)
    a[tab_mian[i]*8+tab_xian[j]]^=(0x01<<tab_dian[(i+j)*8+k]);
    zhen(a,v);
void xzcube()
  char i;
  donghua(y_table,6,8,8);
  for(i=0;i<26;i++)
   if(i==12||i==13||i==14)
    zhen(yx_table+i*64,30);
    zhen(yx_table+i*64,14);
  donghua(x_table,6,8,8);
  for(i=0;i<26;i++)
    zhen(xz_table+i*64,30);
    zhen(xz_table+i*64,14);
  donghua(z_table,6,8,8);
void szfc0(char v)//數字上浮
char i,j;
uchar a[64];
for(i=0;i<64;i++)
  a[i]=0;
for(j=124;j>=0;j--)
  for(i=7;i>=0;i--)
   a[i*8+3]=szfc_table[j+i];
   a[i*8+4]=szfc_table[j+i];
  zhen(a,v);
void shandian(char v)
  char i,j;
  uchar a[64];
  for(i=0;i<64;i++)
   a[i]=tab_shandian[64*21+i];
  for(i=0;i<22;i++)
   zhen(tab_shandian+64*i,v);
  for(i=0;i<22;i++)
   for(j=0;j<64;j++)
    a[j]=a[j]&(~tab_shandian[64*i+j]);
   zhen(a,v);
void cut()
uchar a[64]={0};
char i;
for(i=0;i<4;i++)
  a[i*8+7]=0xff;
  a[(7-i)*8+7]=0xff;
  zhen(a,8);
zhen(a,30);
for(i=3;i>=0;i--)
  a[i*8+7]=0;
  a[(7-i)*8+7]=0;
  zhen(a,8);
void shensuo(uchar v)
char i,j;
uchar a[64]={0};
for(i=0;i<64;i++)
  a[i]=0xff;
for(i=0;i<7;i++)
  move(a,0,0,1);
  zhen(a,v);
for(i=0;i<7;i++)
  move(a,0,1,1);
  for(j=0;j<64;j++)
   a[j]|=0x01;
  zhen(a,v);
for(i=0;i<7;i++)
  move(a,2,0,1);
  zhen(a,v);
for(i=0;i<7;i++)
  move(a,2,1,1);
  for(j=0;j<8;j++)
   a[j]|=0xff;
  zhen(a,v);
for(i=7;i>0;i--)
  for(j=0;j<8;j++)
   a[j*8+i]=0;
  zhen(a,v);
for(i=1;i<8;i++)
  for(j=0;j<8;j++)
   a[j*8+i]|=0xff;
  zhen(a,v);
void linkpc1(char v)
uchar i,a[64]={0};
for(i=0;i<7;i++)
  a[7*8+i]=0xff;
for(i=0;i<8;i++)
  move(a,2,0,1);
  zhen(a,v);
void link00()
uchar a[64]={0};
char i;
for(i=10;i>7;i--)
  zhen(bianxing_table+i*64,70);
produce_cube(a,6);
move(a,1,1,1);
move(a,0,1,1);
zhen(a,110);
produce_cube(a,8);
zhen(a,110);
void link_jb0(char v)
uchar a[64]={0};
char i;
for(i=0;i<64;i++)
  a[i]=0x80;
  zhen(a,v);
int STC_ADC()
  uchar i;
    ADC_RES=0;
    ADC_RESL=0;
  ADC_CONTR=0x88;
  i=3;
    while(i--);
       if(ADC_CONTR&0x10)
    break;
    ADC_CONTR=0x80;
  return(ADC_RESL+ADC_RES<<2);
short sqrt_16( unsigned long M)
    unsigned int N,i;
    unsigned long tmp,ttp;
    if(M==0)
        return 0;
    N=0;
    tmp=(M>>30);
    M<<=2;
    if(tmp>1)
        N++;
        tmp-=N;
    for(i=15;i>0;i--)
        N<<=1;
        tmp<<=2;
        tmp+=(M>>30);
        ttp=N;
        ttp=(ttp<<1)+1;
        M<<=2;
        if(tmp>=ttp)
            tmp-=ttp;
            N++;
    return N;
void FFT()
int xdata i,bb,j,k,p;
int max,a[6];
int xdata TR,TI,temp;
   for(i=0; i<64;i++)
      Real[BRTable[i]]=STC_ADC();
      Image[i]=0;
   for(i=1;i<=6;i++)
      bb=1;
      bb<<=(i-1);
      for(j=0;j<=bb-1;j++)
         p=1;
         p<<=(6-i);
         p=p*j;
         for(k=j;k<64;k=k+2*bb)
      key_amenu_scan();
    key_out_scan();
            TR = Real[k];
    TI = Image[k];
    temp=Real[k+bb];
            Real[k]=Real[k]+((Real[k+bb]*cos_tabb[p])>>7)+((Image[k+bb]*sin_tabb[p])>>7);
            Image[k]=Image[k]-((Real[k+bb]*sin_tabb[p])>>7)+((Image[k+bb]*cos_tabb[p])>>7);
            Real[k+bb]=TR-((Real[k+bb]*cos_tabb[p])>>7)-((Image[k+bb]*sin_tabb[p])>>7);
            Image[k+bb]=TI+((temp*sin_tabb[p])>>7)-((Image[k+bb]*cos_tabb[p])>>7);
            Real[k]>>=1;
            Image[k]>>=1;
            Real[k+bb]>>=1;
            Image[k+bb]>>=1;
max=0;
for(i=0;i<6;i++)
    a[i]=sqrt_16((Real[i+1]*Real[i+1]+Image[i+1]*Image[i+1])>>1);
    if(a[i]<2 )
       a[i]=0;
       a[i]-=2;
  if(max<a[i])
   max=a[i];
if(max>7)
  max/=7;
  for(i=0;i<6;i++)
   a[i]/=max;
for(i=0;i<6;i++)
  c[i]=a[i];
void disp() interrupt 1
TR0=0;
TH0=(65536-2500)/256;
TL0=(65536-2500)%256;
if(num>=(amenu-1))
  num=0;
  num++;
if(b[num]<c[num])
  b[num]++;
if(b[num]>c[num])
  b[num]--;
if(b[num]>8)
  b[num]=8;
if(amenu==1)
  fun(table1+num*8);
else if(amenu==2)
  fun(table2+num*8);
else if(amenu==3)
  fun(table3+num*8);
else if(amenu==4)
  fun(table4+num*8);
else if(amenu==5)
  fun(table5+num*8);
  fun(table6+num*8);
P3=tuku1[b[num]];
TR0=1;
/**********初始化函數*****************/
void init()
/***********I/O口初始化*************/
P1M1=1;  //p1.0口高阻輸入
P1ASF=1;
P3M0=0xff;  //P3口推挽輸出
P2M0=0xff;
P0M0=0xff;
P4SW = 0x31;
TMOD=0x01;
TH0=(65536-4000)/256;
TL0=(65536-4000)%256;
EA=1;
ET0=1;
TR0=0;
   menu=0;
out=0;
amenu=0;
num=0;
/*************主函數******************/
int i,j;
char go;
delay(800);
init(); //初始化函數
////////////////////////呼吸燈
P2=0xff;
P0=0;
P2=0x80;
P3=1;
while(!menu)
  for(i=0;i<400;i++)
   key_menu_scan();
   if(menu)
    break;
   P0=0x80;
   delay1(i);
   P0=0;
   delay1(400-i);
   if(i<200)
    j=2;
    while(j--)
     P0=0x80;
     delay1(i);
     P0=0;
     delay1(400-i);
  for(i=0;i<401;i++)
   if(menu)
    break;
   key_menu_scan();
   P0=0x80;
   delay1(400-i);
   P0=0;
   delay1(i);
   if(i>200)
    j=2;
    while(j--)
     P0=0x80;
     delay1(400-i);
     P0=0;
     delay1(i);
P3M0=0x00;
///////////////////////////開機掃描
turn_on(10);
H_scan(20);
V_scan(20);
W_scan(20);
/////////////////主菜單選項
  hy(number+37*8,2);
  while(!amenu)
   W_side(number+(36+menu)*8,1,45);
  switch(menu){
  case 1://音譜顯示
   delay(400);
   while(!out)
    TR0=1;
    FFT();
   TR0=0;
   break;
  case 2://動畫顯示
   delay(400);
   amenu=0;//menu=1;
   go=1;
   cut();
   while(go)
    for(i=0;i<10;i++)
     hy(number+27*8+i*8,3);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    zimu(number,19,12,1);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    fn(4);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    out=0;
    flash0(2);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    linkpc1(10);
    pc1(4,3);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    leitu(yc_table,5,2);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    denghuo(3);
    if(out==1)
     go=1;
     go=0;
   go=1;
   while(go)
    water1(1,2,10);water1(2,4,10);
    water1(4,3,10);water1(7,1,10);
    water1(5,6,10);
    water2(0,2,7,1,9);
    water2(2,4,7,7,9);
    water2(4,7,7,1,9);
    water2(3,6,7,7,9);
    water2(4,1,6,6,9);
    water2(7,3,1,2,9);
    water3(0,4,7,4,5,1,9);
    water3(7,7,0,0,0,7,9);
    water3(0,6,6,6,5,1,9);
    water3(6,7,0,0,2,2,9);
    water3(3,3,6,6,2,2,9);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    clc();
    link_pingmian1(1);
    pingmian1(8,3);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    for(i=0;i<7;i++)
     print(tab_print+i*8,1);
    for(i=7;i<11;i++)
     print(tab_print+i*8,0);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    clc();
    link_jb0(1);
    jb0(10,3);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    yinchu(yc_table,5,9);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    clc();
    link_jb0(1);
    jb0(10,3);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    link(9);
    xuanzhuantiao(1,8,4);
    xuanzhuantiao(0,8,4);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    xuanzhuantiao2(3,3);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    qumianxuanzhuan(1,10,4);
    qumianxuanzhuan(0,10,4);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    qumianxuanzhuan2(13,4);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    xuanzhuantiao(1,4,4);
    xuanzhuantiao(1,3,5);
    xuanzhuantiao(1,2,6);
    xuanzhuantiao(1,1,7);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    donghua(bianxing_table,11,1,24);
    xzcube();
    donghua(y_table,6,5,5);
    donghua(x_table,6,5,5);
    donghua(z_table,6,5,5);
    link00();
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    shensuo(5);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    donghua(sin_cube_table,14,22,5);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    for(i=0;i<3;i++)
     for(j=0;j<3;j++)
      cube(0,j,6);
    for(i=0;i<3;i++)
     for(j=0;j<3;j++)
      cube(1,j,6);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    donghua(hart_table,2,10,32);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    for(i=2;i>0;i--)
      shandian(i);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    szfc0(10);
    if(out)
     go=1;
     go=0;
   go=1;
   while(go)
    rain(1,10,9);
    rain(0,10,9);
    if(out)
     go=1;
     go=0;
   break;
  case 3://夜燈模式
   delay(200);
   LED();break;
  out=0;
  amenu=0;
  menu=1;
參與人數 1黑幣 +5 收起 理由
渡客維2 + 5 共享資料的黑幣獎勵!
ID:76244 發表于 2015-4-7 00:23 | 顯示全部樓層
樓主 有電路圖嗎?
ID:70316 發表于 2015-4-29 16:11 | 顯示全部樓層
謝謝,樓主的共享
ID:78588 發表于 2015-5-7 17:57 | 顯示全部樓層
感謝樓主分享
ID:86932 發表于 2015-8-7 16:33 | 顯示全部樓層
我想說你太牛了!
ID:64125 發表于 2015-8-21 14:11 | 顯示全部樓層
研究研究
ID:90592 發表于 2015-10-7 15:54 | 顯示全部樓層
謝謝樓主的分享,,還幫我們省下了黑幣
ID:91274 發表于 2015-10-8 14:35 | 顯示全部樓層
謝謝樓主的分享,,還幫我們省下了黑幣,還可以賺到黑幣
ID:65226 發表于 2015-10-31 06:57 來自觸屏版 | 顯示全部樓層
謝謝分享,要是有電路圖就更好了
ID:94340 發表于 2015-11-1 19:28 | 顯示全部樓層
要是有電路圖就好了
ID:108173 發表于 2016-3-10 11:17 | 顯示全部樓層
謝謝分享
ID:138781 發表于 2016-9-7 23:26 | 顯示全部樓層
非常厲害
ID:165651 發表于 2017-2-21 00:29 | 顯示全部樓層
感謝樓主,正在做
